Hello. At night I updated the system, turned it off and went to bed. Browsers (opera, chrome) and other applications (atril, vs code, gvim (nvim works), onlyoffice, even manjaro hello) have stopped running today. I didn’t check everything. Some are working, some are not.
Ker: 5.15.38-1
Plasma 5.24.5
Manjaro 21.2.6
You probably need to reinstall them because they are from the AUR.
Reinstalling did not help and they are not all from AUR. pamac also does not start.
does running this: sudo pacman -Syyu gives you any errors
so can you post first formatted output from logs:
journalctl --boot=0 --priority=3 --no-pager
also, many programs through the launch in the terminal indicate an error related to the libicuuc.so.70 library
мая 19 14:52:29 manjaro kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.SAT0.SPT4._GTF.DSSP], AE_NOT_FOUND (20210730/psargs-330)
мая 19 14:52:29 manjaro kernel: ACPI Error: Aborting method \_SB.PCI0.SAT0.SPT4._GTF due to previous error (AE_NOT_FOUND) (20210730/psparse-529)
мая 19 14:52:33 manjaro pulseaudio[1010]: GetManagedObjects() failed: org.freedesktop.DBus.Error.NoReply: Did not receive a reply. Possible causes include: the remote application did not send a reply, the message bus security policy blocked the reply, the reply timeout expired, or the network connection was broken.
мая 19 14:52:49 manjaro systemd-coredump[1193]: Process 1168 (opera) of user 1000 dumped core.
Module linux-vdso.so.1 with build-id d3d3a1ec103a73e5e70f3a001cc6ee89a7e7deb9
Module libgpg-error.so.0 with build-id f9aaa96d5ddf6f6872051ed7abcdfe6bdaff9b1c
Module libgmp.so.10 with build-id e58d34ab389d1b649c24195c2d145e3ff2e58290
Module libhogweed.so.6 with build-id 2d70cff7b1841b4d9ca4e8e7726cd4b944c07fdc
Module libnettle.so.8 with build-id 9a878e513c02007598fcf1e2e286c2203f13536e
Module libtasn1.so.6 with build-id ee3429ca5e94718aea4fe5249fc859e0cd88e4e9
Module libbrotlienc.so.1 with build-id 74adbc62e4fbb5da9d37b5aa458471f4130862ff
Module libp11-kit.so.0 with build-id cc372ea3c28c4d3dfc633b4d2e933c8584d2af16
Module libgcrypt.so.20 with build-id 8bf3cb884124273640de797a3e77d86c98434ea4
Module libcap.so.2 with build-id 21b00ab76bb16fde56fd741f07233c78069f0579
Module liblz4.so.1 with build-id e63600ab23b2f6997f42fac2fa56e1f02ce159a1
Module liblzma.so.5 with build-id 28b40c7af8098a66af6ee093b6986b91cad7694d
Module libbz2.so.1.0 with build-id 919597c477c9b2cb9cdbb7745ed6494ac0e6da60
Module libgraphite2.so.3 with build-id 47761dc11e553f519cde97ed9ee985be12ccdae2
Module libdatrie.so.1 with build-id 6fe3b6ece2c8e7d11869fa051375128d8f808f58
Module libblkid.so.1 with build-id 140694a62d8d4d07c6c320a501f948dd1b389d73
Module libbrotlicommon.so.1 with build-id acfd597a977c8087bb6184383daae2e828a9ce42
Module libresolv.so.2 with build-id 46ffdf3d477a170314060c26927470d7399bc900
Module libkeyutils.so.1 with build-id ac405ddd17be10ce538da3211415ee50c8f8df79
Module libkrb5support.so.0 with build-id 36db7c21bc57a9b934ad2d3463782db9fef4af07
Module libcom_err.so.2 with build-id 358b783c9b3d12ba8248519ea2e7f3da4c4e0297
Module libk5crypto.so.3 with build-id f1c113fea46023cdf62c7e51cb643c45831abdd5
Module libkrb5.so.3 with build-id 9350783c946d77aec8ee8fd9c6bc12f4f7b72be9
Module libunistring.so.2 with build-id 617dbf3d3d6f85d6556a7a036e23845e95490158
Module libXi.so.6 with build-id 16603be937a02a7e61b0b0395d064be7efd86f49
Module libwayland-server.so.0 with build-id 5526cec43774a83c7ab8c7ff820eea8b28880d51
Module libgnutls.so.30 with build-id 5b2955e99a56f895cb70144748d096b5c4f7bf83
Module libavahi-client.so.3 with build-id 1858551543958190c653b565cf0eb64609ad908a
Module libavahi-common.so.3 with build-id 80fda945459a3476ccd1050783dfd5f5c17c479a
Module libsystemd.so.0 with build-id cdfc45d8f96e3af51b3d041c32f7899a93b86706
Module libpixman-1.so.0 with build-id 341f793dcada3a48a306a793d265a517e3f2e7d6
Module libxcb-shm.so.0 with build-id 828fec4d856e2710e732ea8d92c3f250c807b1c2
Module libxcb-render.so.0 with build-id b1ca498d665807ab0ccdafbe8070853efd058173
Module libXrender.so.1 with build-id 97e0b9ab6ba96ebc86527cc2b3c3078aad8616b3
Module libfreetype.so.6 with build-id f89dd5502e75aca28fb5c3ccd0dbd26fe822bfef
Module libfontconfig.so.1 with build-id 36be6951b8c1e42a7dd05684a37400fc8ef9147c
Module libpng16.so.16 with build-id 2dc0bce07f199bf983c07a05fb95a6f4af83a9b3
Module libharfbuzz.so.0 with build-id a11faa61f71b258fb92b717723757fc7dd141c01
Module libthai.so.0 with build-id a7ac5010b4275c49308021200d23690533952702
Module libfribidi.so.0 with build-id fe9f35ac2a0074108c8306c517793f7279bd9b37
Module libXdmcp.so.6 with build-id 8ca0792d23c8b8b4c0864297512349292bea5955
Module libXau.so.6 with build-id 1c67764663e07bec24d8951e5fd93f4d165979ff
Module libmount.so.1 with build-id 4436aeea0cd8c01b5a77969e0531184f8b3513ce
Module libgmodule-2.0.so.0 with build-id c6df28882f153ee03d0fb33bb8aac2b219ebaacc
Module libplc4.so with build-id e194130401ccec0067df40f72affdde25bb9a383
Module libplds4.so with build-id d91a9c5ee69e8a373b87bfc3eec221b5c1e2950c
Module libpcre.so.1 with build-id 845483dd0acba86de9f0313102bebbaf3ce52767
Module libffi.so.8 with build-id f0a9586cf0f42d2b9971bd1065ca3a6b19f4a2c2
Module libz.so.1 with build-id fefe3219a96d682ec98fcfb78866b8594298b5a2
Module libbrotlidec.so.1 with build-id 66c54e9301f7e102ecc1d88547e5f0e8a056fe22
Module libzstd.so.1 with build-id 3bccb8fe08e48d5ea135b1d0f99de0d771dd752f
Module libgssapi_krb5.so.2 with build-id 1813217c8baf82a1078772eed0d868310cd59f8b
Module libcrypto.so.1.1 with build-id d54a7ee1e288aeae436d073277ff986e03994b15
Module libssl.so.1.1 with build-id 25a55106cb13dec5d495c34ca1caf2c2f3114f11
Module libpsl.so.5 with build-id 0229a201aaf5652186c9fdc192ebe52baf19d7f1
Module libssh2.so.1 with build-id a4adfe44cc7ebd295b3b783361acc3dcfcea1d50
Module libidn2.so.0 with build-id 1ce2b50ad9f9821c2c629b521cf5a3c99593d332
Module libnghttp2.so.14 with build-id f2738fead8e6593084b4fb8756f460aa8cf5535a
Module ld-linux-x86-64.so.2 with build-id c09c6f50f6bcec73c64a0b4be77eadb8f7202410
Module libc.so.6 with build-id 85766e9d8458b16e9c7ce6e07c712c02b8471dbc
Module libgcc_s.so.1 with build-id 5d817452a709ca3a213341555ddcf446ecee37fa
Module libatspi.so.0 with build-id 87bca381f073faea3b0ffd1ab06f5f8f204e24cf
Module libasound.so.2 with build-id b17fc1317a484842433c772360376623b64ec3d8
Module libXrandr.so.2 with build-id d4e869b5c72541e1de8f96b456248987ea52d51b
Module libXfixes.so.3 with build-id 0a05c7e8714522bfbdd7c0027c3e2a94965664b0
Module libXext.so.6 with build-id d70f24beb4fad748d6becffdcc13e51be0a2ebfa
Module libXdamage.so.1 with build-id a1d867e093c16944b2c0083be98050ef35c9e5c2
Module libXcomposite.so.1 with build-id f1bb5ffb6203ab2907ac044a204ce3902a79f1c1
Module libX11.so.6 with build-id d8e0be8e0323aa421366f19065ecd1c76405c130
Module libm.so.6 with build-id 596b63a006a4386dcab30912d2b54a7a61827b07
Module libgbm.so.1 with build-id db6b1ee6abbf947245bc04cad40a6732ed6440d9
Module libcups.so.2 with build-id 52ccc84fcb1bd56821c25e88ff624550698087f5
Module libdbus-1.so.3 with build-id 7f4b16b4b407cbae2d7118d6f99610e29a18a56a
Module libcairo.so.2 with build-id 254ac8421ae2a823be8ff4eaa219fd220b015bba
Module libpango-1.0.so.0 with build-id 7e27c1e46a1d958f6b16e1ba199f8bdb3f100566
Module libatk-bridge-2.0.so.0 with build-id 1161ebbcc5aa791075dfa026671875e5417287bd
Module libatk-1.0.so.0 with build-id c2de8b4fcbd9681cef225fe3956a9608a2a664bb
Module libxkbcommon.so.0 with build-id 3a9338b2085f0af41217bc0a90ffcc941938a16e
Module libxcb.so.1 with build-id 13d677412a71468381b11092915d231f664d18d3
Module libdrm.so.2 with build-id 00816f0a71c7e4e388c10db6245dbb9c031732a9
Module libexpat.so.1 with build-id 113bb5a3e9ad856801bfcfc029102c9bdc13d67e
Module libgio-2.0.so.0 with build-id 8c411770513e0bc758a1bbe661af14c972e2a3c4
Module libnspr4.so with build-id 0fcca981168b16e07684217e645e9b3b716a0c57
Module libsmime3.so with build-id 2950ba6b2aa311f260d83a6f27ea82f51205c57a
Module libnssutil3.so with build-id 1a64415cbb9d33b86f22e1bc4028411fd5bd9484
Module libnss3.so with build-id 63b30181a431facad7300e8fa3855db13d822da1
Module libglib-2.0.so.0 with build-id e268e80e668ce871312cf50e9969f88b086e33f2
Module libgobject-2.0.so.0 with build-id 4337ec84b2f33ec39a95863d47bfca0a28afd488
Module libpthread.so.0 with build-id 7fa8b52fae071a370ba4ca32bf9490a30aff31c4
Module libdl.so.2 with build-id bb9bd2657bfba9f60bd34d2050cc63a7eb024bc4
Module libcurl.so.4 with build-id 7e29b0677f65e934f18c62877d6558b2d4896e61
Module libffmpeg.so with build-id b3ed59169bacb05d
Module opera with build-id 227a3e97bf626e97d4338e756d0def2427bbd7bc
Stack trace of thread 1168:
#0 0x0000556b6299c248 n/a (opera + 0x7e18248)
#1 0x0000556b6299bf1b n/a (opera + 0x7e17f1b)
#2 0x0000556b5f0a386a n/a (opera + 0x451f86a)
#3 0x0000556b5d44ab19 n/a (opera + 0x28c6b19)
#4 0x0000556b5e26be75 n/a (opera + 0x36e7e75)
#5 0x0000556b5e26c7b6 n/a (opera + 0x36e87b6)
#6 0x0000556b5e268b12 n/a (opera + 0x36e4b12)
#7 0x0000556b602f2508 n/a (opera + 0x576e508)
#8 0x0000556b602f3934 n/a (opera + 0x576f934)
#9 0x0000556b602f34cb n/a (opera + 0x576f4cb)
#10 0x0000556b602f0993 n/a (opera + 0x576c993)
#11 0x0000556b602f1225 n/a (opera + 0x576d225)
#12 0x0000556b5ccf900e ChromeMain (opera + 0x217500e)
#13 0x00007f948517b310 __libc_start_call_main (libc.so.6 + 0x2d310)
#14 0x00007f948517b3c1 __libc_start_main@@GLIBC_2.34 (libc.so.6 + 0x2d3c1)
#15 0x0000556b5c9922ea _start (opera + 0x1e0e2ea)
Stack trace of thread 1176:
#0 0x00007f948522b4cf wait4 (libc.so.6 + 0xdd4cf)
#1 0x0000556b603ddc1d n/a (opera + 0x5859c1d)
#2 0x0000556b603dbae0 n/a (opera + 0x5857ae0)
#3 0x0000556b603e2b2e n/a (opera + 0x585eb2e)
#4 0x00007f94851db5c2 start_thread (libc.so.6 + 0x8d5c2)
#5 0x00007f9485260584 __clone (libc.so.6 + 0x112584)
Stack trace of thread 1177:
#0 0x00007f94851d815a __futex_abstimed_wait_common (libc.so.6 + 0x8a15a)
#1 0x00007f94851dac64 pthread_cond_timedwait@@GLIBC_2.3.2 (libc.so.6 + 0x8cc64)
#2 0x0000556b603def44 n/a (opera + 0x585af44)
#3 0x0000556b603df678 n/a (opera + 0x585b678)
#4 0x0000556b603b8a69 n/a (opera + 0x5834a69)
#5 0x0000556b603b8c03 n/a (opera + 0x5834c03)
#6 0x0000556b603e2b2e n/a (opera + 0x585eb2e)
#7 0x00007f94851db5c2 start_thread (libc.so.6 + 0x8d5c2)
#8 0x00007f9485260584 __clone (libc.so.6 + 0x112584)
Stack trace of thread 1178:
#0 0x00007f94852609ae epoll_wait (libc.so.6 + 0x1129ae)
#1 0x0000556b60556c1e n/a (opera + 0x59d2c1e)
#2 0x0000556b6055462a n/a (opera + 0x59d062a)
#3 0x0000556b604049f6 n/a (opera + 0x58809f6)
#4 0x0000556b603a662d n/a (opera + 0x582262d)
#5 0x0000556b6037c05c n/a (opera + 0x57f805c)
#6 0x0000556b603bd1f8 n/a (opera + 0x58391f8)
#7 0x0000556b603ac67d n/a (opera + 0x582867d)
#8 0x0000556b603bd382 n/a (opera + 0x5839382)
#9 0x0000556b603e2b2e n/a (opera + 0x585eb2e)
#10 0x00007f94851db5c2 start_thread (libc.so.6 + 0x8d5c2)
#11 0x00007f9485260584 __clone (libc.so.6 + 0x112584)
Stack trace of thread 1179:
#4 0x0000556b603b6ca3 n/a (opera + 0x5832ca3)
#5 0x0000556b603b77b1 n/a (opera + 0x58337b1)
#6 0x0000556b603b729d n/a (opera + 0x583329d)
#7 0x0000556b603e2b2e n/a (opera + 0x585eb2e)
#8 0x00007f94851db5c2 start_thread (libc.so.6 + 0x8d5c2)
#9 0x00007f9485260584 __clone (libc.so.6 + 0x112584)
Stack trace of thread 1180:
Stack trace of thread 1181:
#7 0x0000556b5e26d840 n/a (opera + 0x36e9840)
Stack trace of thread 1182:
#5 0x0000556b603b73fb n/a (opera + 0x58333fb)
Stack trace of thread 1183:
#1 0x00007f94851da960 pthread_cond_wait@@GLIBC_2.3.2 (libc.so.6 + 0x8c960)
#2 0x0000556b603deddd n/a (opera + 0x585addd)
#3 0x0000556b603df661 n/a (opera + 0x585b661)
#4 0x0000556b603df2ff n/a (opera + 0x585b2ff)
#5 0x0000556b6035fb66 n/a (opera + 0x57dbb66)
#6 0x0000556b603a662d n/a (opera + 0x582262d)
#7 0x0000556b6037c05c n/a (opera + 0x57f805c)
#8 0x0000556b603bd1f8 n/a (opera + 0x58391f8)
#9 0x0000556b603bd382 n/a (opera + 0x5839382)
#10 0x0000556b603e2b2e n/a (opera + 0x585eb2e)
#11 0x00007f94851db5c2 start_thread (libc.so.6 + 0x8d5c2)
#12 0x00007f9485260584 __clone (libc.so.6 + 0x112584)
Stack trace of thread 1170:
#0 0x00007f94852542af __poll (libc.so.6 + 0x1062af)
#1 0x0000556b5e79e302 n/a (opera + 0x3c1a302)
#2 0x0000556b603e2b2e n/a (opera + 0x585eb2e)
#3 0x00007f94851db5c2 start_thread (libc.so.6 + 0x8d5c2)
#4 0x00007f9485260584 __clone (libc.so.6 + 0x112584)
мая 19 14:53:32 manjaro systemd-coredump[1336]: Process 1303 (chrome) of user 1000 dumped core.
Module chrome with build-id 8e55e2725f48e17adb1d4ac8ef5d66a44b50b81f
Stack trace of thread 1303:
#0 0x000055b2ba8bb461 n/a (chrome + 0x435a461)
#1 0x000055b2ba8bab72 n/a (chrome + 0x4359b72)
#2 0x000055b2ba6f7b4f n/a (chrome + 0x4196b4f)
#3 0x000055b2ba7fcc10 n/a (chrome + 0x429bc10)
#4 0x000055b2ba7fc702 n/a (chrome + 0x429b702)
#5 0x000055b2b9d4db5b n/a (chrome + 0x37ecb5b)
#6 0x000055b2b9d4d4af n/a (chrome + 0x37ec4af)
#7 0x000055b2b9d3ff28 n/a (chrome + 0x37def28)
#8 0x000055b2b9e1576c n/a (chrome + 0x38b476c)
#9 0x000055b2b9e12ee5 ChromeMain (chrome + 0x38b1ee5)
#10 0x00007f1577b3d310 __libc_start_call_main (libc.so.6 + 0x2d310)
#11 0x00007f1577b3d3c1 __libc_start_main@@GLIBC_2.34 (libc.so.6 + 0x2d3c1)
#12 0x000055b2bb1696da _start (chrome + 0x4c086da)
Stack trace of thread 1328:
#0 0x00007f1577b9a15a __futex_abstimed_wait_common (libc.so.6 + 0x8a15a)
#1 0x00007f1577b9cc64 pthread_cond_timedwait@@GLIBC_2.3.2 (libc.so.6 + 0x8cc64)
#2 0x000055b2b89fe202 n/a (chrome + 0x249d202)
#3 0x000055b2b89fde5a n/a (chrome + 0x249ce5a)
#4 0x000055b2b889a089 n/a (chrome + 0x2339089)
#5 0x000055b2b889981d n/a (chrome + 0x233881d)
#6 0x000055b2b9d32103 n/a (chrome + 0x37d1103)
#7 0x00007f1577b9d5c2 start_thread (libc.so.6 + 0x8d5c2)
#8 0x00007f1577c22584 __clone (libc.so.6 + 0x112584)
Stack trace of thread 1330:
Stack trace of thread 1331:
#4 0x000055b2b8899a28 n/a (chrome + 0x2338a28)
Stack trace of thread 1332:
#0 0x00007f1577c229ae epoll_wait (libc.so.6 + 0x1129ae)
#1 0x000055b2b874bd0b n/a (chrome + 0x21ead0b)
#2 0x000055b2b9d64e08 n/a (chrome + 0x3803e08)
#3 0x000055b2b9d64ad3 n/a (chrome + 0x3803ad3)
#4 0x000055b2ba017025 n/a (chrome + 0x3ab6025)
#5 0x000055b2ba01665a n/a (chrome + 0x3ab565a)
#6 0x000055b2ba016498 n/a (chrome + 0x3ab5498)
#7 0x000055b2baedfe12 n/a (chrome + 0x497ee12)
#8 0x000055b2b9eb8150 n/a (chrome + 0x3957150)
#9 0x000055b2b9d32103 n/a (chrome + 0x37d1103)
#10 0x00007f1577b9d5c2 start_thread (libc.so.6 + 0x8d5c2)
#11 0x00007f1577c22584 __clone (libc.so.6 + 0x112584)
Stack trace of thread 1334:
#0 0x00007f1577c162af __poll (libc.so.6 + 0x1062af)
#1 0x000055b2bafb2834 n/a (chrome + 0x4a51834)
#2 0x000055b2b9d32103 n/a (chrome + 0x37d1103)
#3 0x00007f1577b9d5c2 start_thread (libc.so.6 + 0x8d5c2)
#4 0x00007f1577c22584 __clone (libc.so.6 + 0x112584)
Stack trace of thread 1329:
Stack trace of thread 1333:
#1 0x00007f1577b9c960 pthread_cond_wait@@GLIBC_2.3.2 (libc.so.6 + 0x8c960)
#2 0x000055b2b89fe38f n/a (chrome + 0x249d38f)
#3 0x000055b2b89fe034 n/a (chrome + 0x249d034)
#4 0x000055b2b8a0fb9e n/a (chrome + 0x24aeb9e)
#5 0x000055b2b89fdba2 n/a (chrome + 0x249cba2)
#6 0x000055b2ba017025 n/a (chrome + 0x3ab6025)
#7 0x000055b2ba01665a n/a (chrome + 0x3ab565a)
#8 0x000055b2ba016498 n/a (chrome + 0x3ab5498)
#9 0x000055b2b9eb8150 n/a (chrome + 0x3957150)
#10 0x000055b2b9d32103 n/a (chrome + 0x37d1103)
#11 0x00007f1577b9d5c2 start_thread (libc.so.6 + 0x8d5c2)
#12 0x00007f1577c22584 __clone (libc.so.6 + 0x112584)
Stack trace of thread 1327:
#3 0x000055b2b9d64be0 n/a (chrome + 0x3803be0)
#7 0x000055b2ba01643d n/a (chrome + 0x3ab543d)
Stack trace of thread 1326:
#4 0x000055b2bafb0937 n/a (chrome + 0x4a4f937)
#5 0x000055b2bd8df768 n/a (chrome + 0x737e768)
Stack trace of thread 1325:
#0 0x00007f1577bed4cf wait4 (libc.so.6 + 0xdd4cf)
#1 0x000055b2ba88c120 n/a (chrome + 0x432b120)
#2 0x000055b2bafb26c8 n/a (chrome + 0x4a516c8)
#3 0x000055b2b9d32103 n/a (chrome + 0x37d1103)
#4 0x00007f1577b9d5c2 start_thread (libc.so.6 + 0x8d5c2)
#5 0x00007f1577c22584 __clone (libc.so.6 + 0x112584)
Stack trace of thread 1317:
#1 0x000055b2babaf503 n/a (chrome + 0x464e503)
these logs show only those core dumps … can you post the whole error you get with the libicuuc.so.70 library
post output from: ls -l /usr/lib/libicuuc.*
edit: try installing something, doesnt matter what, it will probably give you errors, so copy those errors here
Can you actually run pacman you told that pamac doesn’t work, so is there the same error message?
I wonder why it’s booting at all if there is an actual misplaced icu version. Do you remember setting any environment variables in /etc/environment or /etc/profile.d/* or somewhere else?
So did you actually run sudo pacman -Syyuu successfully? (Meaning at least without the error as above but maybe another error.)
lrwxrwxrwx 1 root root 16 apr 14 20:09 /usr/lib/libicuuc.so -> libicuuc.so.71.1
lrwxrwxrwx 1 root root 16 apr 14 20:09 /usr/lib/libicuuc.so.71 -> libicuuc.so.71.1
-rwxr-xr-x 1 root root 2078584 apr 14 20:09 /usr/lib/libicuuc.so.71.1
I have successfully installed via pacman palemoon-bin and via paru sublime-tex-3. And firefox yesterday, but they don’t start
pacman works well, shows no errors and installs what is needed. I haven’t done anything with environment variables for a long time.
For the 1000th time: You have to REBUILD broken AUR packages after update. For other apps provide errors when started.
Не понял что вы говорите.
so try to reinstall these:
sudo pacman -S icu
sudo pacman -S lib32-icu
reboot and check
Maybe the mirrors are outdated and he’s in a partial update state?
sudo pacman-mirrors ---geoip --method rank
Followed by a sudo pacman -Syyuu (and then possibly above packages, icu and/or lib32-icu)
so did it worked or not?
Sorry, no, it didn’t work out.
