Hi there,
i’ve recently switched to pipewire and only got one small, but annoying problem with it: i can no longer set Automatically switch all running streams when a new output becomes available in the KDE sound settings - it’s greyed out with the message needs the pulse-audio module "module-gsettings"
i can’t find anything in that regards on web strangely, i find no packages that obviously relate to that and no mention of any of that in any wiki - so i’m kind of at a loss here. Hopefully someone here can help me out
Maybe something that has to be set in one of the config files in /etc/pipewire?
I’ve noticed that i don’t have a /etc/pulse/default.pa - i hope that is normal when using pipewire?
mate-desktop-schemas-gtk2 1.16.2-2 AUR
GSettings schemas for MATE Desktop (GTK2 version)
deepin-desktop-schemas-git 5.8.0.32.r14.gbffbf38-1 AUR
GSettings deepin desktop-wide schemas
qt5-gsettings-git v1.2.0.r9.g3132cd4-1 AUR
Qt-style wrapper for GSettings
qt5-gsettings 1.3.0-1 community
kdebugsettings 20.12.2-1 extra
An application to enable/disable qCDebug
gsettings-xsettings-schemas 3.36.1-1 AUR
Workaround for font rendering issues in Wayland clients, GSettings schema of the XSETTINGS plugin from GNOME Settings Daemon
gsettings-qt-bzr 0.1.r69-1 AUR
Qml bindings for GSettings.
gsettings-qt 0.1.20170110-3 community
gsettings-desktop-schemas-ubuntu 3.34.0-1 AUR
Shared GSettings schemas for the desktop
gsettings-desktop-schemas-git 3.37.1.r2.g4acad3c-1 AUR
gsettings-desktop-schemas-git 40.alpha+11+gd21183e-1 community
gsettings-desktop-schemas-dev 3.36.1-1 AUR
gsettings-desktop-schemas-dev 40.alpha+9+g41ca229-1 community
gsettings-desktop-schemas [Installed] 3.38.0-1 extra
so I’m guessing you need to install gsettings-desktop-schemas. Or that’s mine anyway.
Hope this helps.
Edit:
If it’s not that, I have no idea what it is or can be since I don’t use my PC’s sound due to a hearing problem.
Thanks for the answer, i forgot to mention that was already installed
The only other packages that are not installed and contain gsettings are gsettings-qt and qt5-gsettings, but those are only bindings if i understand correctly?
/etc/pulse/default.pa is the PulseAudio system file for loading modules
If that file is absent it would suggest that PulseAudio has been uninstalled
possibly from an update to pulseeffects
I suggest you go to Pipewire for support because there does not seem to be anyone here who knows much about Pipewire yet
Just to be clear if I understood correctly: so this is the reason why Pipewire doesn’t automatically switch to my headphones when I plug them in my laptop, right?
