It might be port-detection doesn’t work entirely. Unplugging headphones now doesn’t switch to speakers and vice versa. It plays on both simultaneously at a strange/lower volume when Manjaro starts.
Please, tell me what more information to provide, if needed. I did some reading on this a while ago, but didn’t find a solution. Ideally, it would mute speakers entirely (manual, even when no headphones), but use headphones whenever available (auto-switch). But the obvious and acceptable default is to auto-switch both. I tried setting auto-mute in alsamixer, but it didn’t help at all.
[fish@FishLap ~]$ inxi -Fazy
Kernel: 5.10.2-2-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
root=UUID=a6c5c50a-638e-4157-9472-63bd28678637 ro quiet
resume=UUID=84f2a87a-2b0c-4121-a8f1-d48225d48559 udev.log_priority=3
Desktop: Xfce 4.14.3 tk: Gtk 3.24.23 info: xfce4-panel wm: xfwm4
dm: LightDM 1.30.0 Distro: Manjaro Linux
Type: Laptop System: ASUSTeK product: TUF Gaming FX705GM_FX705GM v: 1.0
serial: <filter>
Mobo: ASUSTeK model: FX705GM v: 1.0 serial: <filter>
UEFI: American Megatrends v: FX705GM.307 date: 05/25/2020
ID-1: BAT0 charge: 60.6 Wh condition: 61.0/64.1 Wh (95%) volts: 15.2/15.6
model: Simplo SDI ICR18650 type: Li-ion serial: <filter> status: Unknown
cycles: 41
Info: Quad Core model: Intel Core i5-8300H bits: 64 type: MT MCP
arch: Kaby Lake note: check family: 6 model-id: 9E (158) stepping: A (10)
microcode: DE L2 cache: 8 MiB
bogomips: 36812
Speed: 900 MHz min/max: 800/4000 MHz Core speeds (MHz): 1: 900 2: 900 3: 900
4: 900 5: 900 6: 900 7: 900 8: 900
Type: l1tf
Device-1: Intel UHD Graphics 630 vendor: ASUSTeK driver: i915 v: kernel
bus ID: 00:02.0 chip ID: 8086:3e9b
Device-2: NVIDIA GP106M [GeForce GTX 1060 Mobile] vendor: ASUSTeK
driver: nvidia v: 455.45.01 alternate: nouveau,nvidia_drm bus ID: 01:00.0
chip ID: 10de:1c20
Device-3: IMC Networks USB2.0 HD UVC WebCam type: USB driver: uvcvideo
bus ID: 1-11:3 chip ID: 13d3:56a2 serial: <filter>
Display: x11 server: X.Org 1.20.10 driver: modesetting,nvidia
alternate: fbdev,intel,nouveau,nv,vesa display ID: :0.0 screens: 1
s-diag: 582mm (22.9")
Monitor-1: eDP-1 res: 1920x1080 dpi: 128 size: 382x215mm (15.0x8.5")
diag: 438mm (17.3")
OpenGL: renderer: Mesa Intel UHD Graphics 630 (CFL GT2) v: 4.6 Mesa 20.3.1
direct render: Yes
Device-1: Intel Cannon Lake PCH cAVS vendor: ASUSTeK driver: sof-audio-pci
alternate: snd_hda_intel,snd_soc_skl,snd_sof_pci bus ID: 00:1f.3
chip ID: 8086:a348
Sound Server: ALSA v: k5.10.2-2-MANJARO
Device-1: Intel Wireless-AC 9560 [Jefferson Peak] driver: iwlwifi v: kernel
port: 5000 bus ID: 00:14.3 chip ID: 8086:a370
vendor: ASUSTeK driver: r8169 v: kernel port: 3000 bus ID: 03:00.0
chip ID: 10ec:8168
Local Storage: total: 476.94 GiB used: 19.56 GiB (4.1%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Intel model: SSDPEKNW512G8
size: 476.94 GiB block size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 serial: <filter> rev: 002C temp: 25.9 C
ID-1: / raw size: 467.84 GiB size: 459.5 GiB (98.22%) used: 19.56 GiB (4.3%)
fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
ID-2: /boot/efi raw size: 300 MiB size: 299.4 MiB (99.80%)
used: 312 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
dev: /dev/nvme0n1p3 maj-min: 259:3
System Temperatures: cpu: 35.0 C mobo: 27.8 C
Fan Speeds (RPM): cpu: 0
Processes: 257 Uptime: 3m wakeups: 1 Memory: 7.63 GiB used: 2.13 GiB (27.9%)
Init: systemd v: 247 Compilers: gcc: N/A Packages: pacman: 1090 lib: 402
Shell: Bash v: 5.1.0 running in: xfce4-terminal inxi: 3.2.01
