Hello:
Alfter stable update some ATI graphics doesn´t work and system can not start
radeonCAICOS_pfp.bin failed with error-2
Seems to be a firmware issue you may face. radeon/CAICOS_pfp.bin
is not loading. Which kernel you use? Maybe switcch to a newer one.
Linux5.15 but linux4.14, I think kernel 4.14 is out but I have it in case fail 5.15, same problem
Make sure you’re up to date as linux-firmware
20240409.1addd7dc-1.1 should resolve the issue.
Hello:
System is up to date.
Is safe remove files in /var/log/journal/* sudo rm /var/log/journal/* because in this directory have one file corrupted and after update 20240513 start was slowly?
Is safe remove sudo rm /usr/lib/tmpfiles.d/* too?
Thank you.
tmpfiles.d is part of a configuration system of systemd to manage temporary files. A deep dive into the topic here: Managing temporary files with systemd-tmpfiles on RHEL 7 | Red Hat Developer
to know about how to cleanup logs you can follow this: https://www.baeldung.com/linux/systemd-journal-logs-clear
Hello:
I had removed logs journal older than 5 days before size /var/log/journal about 1GB after clean size about 300MB
Hello:
The problmen seems solved
- Remove files older than 5 days in /var/log/journal
- Reinstalling linux 515 xf86-video-ati linux-firmware
- pacman -Scc
- Update system
Now computer start fast
Regards
