After shutdown GRUB/Boot Not Working Properly
Hi, I’m again here :slightly_frowning_face:
Yesterday when I pressed shutdown, my laptop was frozen in the logo of manjaro when you shutdown the system. After 10 minutes I holded the reset button and I try to see if everything was ok but I didn’t have luck
In the first moment I received this message:
error: file `/boot/vmlinuz-6.6-x86_64’ not found.
error: you need to load the kernel first.
I came to the forum and google to try to see old post but I couldn’t.
I tried with a LiveUSB but I couldn’t.
In this moment, the error message that I wrote before is not appearing.
Now when I’m init my laptop is not finding the grub and open my BIOS SETTINGS automatically. If I quit there and I try again, the same. The grub and the message are not appearing right now.
Could you help me, please?
Now I’m not in my laptop but when I have access again to my home, I will reply and If you tell me here what information / commands I need to write to give information, I appreaciate and I will post everything.
Thanks for your time again!!
You can try
You can also chroot and try to reinstall the kernel, or install 6.1
pacman -Syu linux61
In the future, disable the preference in Add/Remove programs to update on shutdown. It is one of the worst ideas ever, i have no explanation how the developer came with that idea at all…your case is an illustration why.
It’s because most of today’s developers in the GNU/Linux ecosystem grew up on — and had their conception of computer science poisoned by — Microsoft Windows, which insists on conducting its update process on shutdown. :frowning_man:
Thanks for trying to help @Teo. I’m trying to do a lot of things but I’m a little bit lost.
This is my information:
manjaro /]# lsblk
NAME        MAJ:MIN RM   SIZE RO TYPE MOUNTPOINTS
loop0         7:0    0 140.2M  1 loop
loop1         7:1    0 971.5M  1 loop
loop2         7:2    0   1.3G  1 loop
loop3         7:3    0 791.9M  1 loop
sda           8:0    1  28.6G  0 disk
|-sda1        8:1    1   3.3G  0 part
`-sda2        8:2    1     4M  0 part
nvme0n1     259:0    0   1.9T  0 disk
|-nvme0n1p1 259:1    0   301M  0 part /boot/efi
|-nvme0n1p2 259:2    0   120G  0 part /
|-nvme0n1p3 259:3    0     8G  0 part
`-nvme0n1p4 259:4    0   1.3T  0 part /home
I tried to do pacman-mirrors -f 5 && pacman -Syyu and then update-grub but I had more errors:
[manjaro /]# pacman-mirrors -f 5 && pacman -Syyu
::INFO => Mirror status: https://repo.manjaro.org/status.json
::INFO Using default mirror file
::INFO Querying mirrors - This may take some time
  0.518 Bulgaria       : https://mirror.telepoint.bg/manjaro/
  0.324 Germany        : http://ftp.uni-kl.de/pub/linux/manjaro/
  0.557 Belarus        : http://mirror.datacenter.by/pub/mirrors/manjaro/
  0.429 Germany        : https://mirror.netcologne.de/manjaro/
  1.746 Kenya          : https://manjaro.mirror.liquidtelecom.com/
::INFO Writing mirror list
::Germany         : http://ftp.uni-kl.de/pub/linux/manjaro/stable
::Germany         : https://mirror.netcologne.de/manjaro/stable
::Bulgaria        : https://mirror.telepoint.bg/manjaro/stable
::Belarus         : http://mirror.datacenter.by/pub/mirrors/manjaro/stable
::Kenya           : https://manjaro.mirror.liquidtelecom.com/stable
::INFO Mirror list generated and saved to: /etc/pacman.d/mirrorlist
 core                  140.0 KiB   392 KiB/s 00:00 [######################] 100%
 extra                   8.3 MiB  8.62 MiB/s 00:01 [######################] 100%
 community              29.0   B   414   B/s 00:00 [######################] 100%
 multilib              144.7 KiB  2.52 MiB/s 00:00 [######################] 100%
 there is nothing to do
[manjaro /]# update-grub
grub-probe: error: cannot find a GRUB drive for /dev/sda1.  Check your device.map.
Root filesystem isn't btrfs
If you think an error has occurred, please file a bug report at "https://github.com/Antynea/grub-btrfs"
/usr/bin/grub-probe: warning: unknown device type nvme0n1.
Found memtest86+ EFI image: /boot/memtest86+/memtest.efi
done
I was trying to follow the tutorial that you wrote but I cannot understand so good and I’m afraid to destroy the system haha :frowning:
I will elaborate on why it is a bad idea a bit:
It does not show the log, what is really happening, it only shows a logo it seems; secondly, you are already out of the session so if something goes wrong you cannot start fixing right away, you have to hard-reboot, and you know you will not be able to properly boot, so you need live usb to chroot. Not fatal, but unnecessary extra step.
@ZeR0ByTe Ok maybe only the kernel is broken. It is normal that grub does not see the os, if there is no kernel :slight_smile:
so try
pacman -S linux66
or if there is a problem (it might be)
pacman -S linux61
and update grub and you should have at least 1 kernel and a booting system
Right now i’m in a LiveCD and the commands that I sent were from there.
I did manjaro-chroot -a:
[manjaro@manjaro ~]$ manjaro-chroot -a
==> Mounting (ManjaroLinux) [/dev/nvme0n1p2]
 --> mount: [/mnt]
 --> mount: [/mnt/boot/efi]
 --> mount: [/mnt/home]
Yes exactly. The prompt is now red #. Now install a kernel as shown above.
I did:
[manjaro /]# pacman -Syu linux61
 core is up to date
 extra is up to date
 community is up to date
 multilib is up to date
warning: linux61-6.1.92-1 is up to date -- reinstalling
resolving dependencies...
Packages (1) linux61-6.1.92-1
Total Installed Size:  143.67 MiB
Net Upgrade Size:        0.00 MiB
:: Proceed with installation? [Y/n] y
(1/1) checking keys in keyring                                 [##################################] 100%
(1/1) checking package integrity                               [##################################] 100%
(1/1) loading package files                                    [##################################] 100%
(1/1) checking for file conflicts                              [##################################] 100%
(1/1) checking available disk space                            [##################################] 100%
(1/2) Creating Timeshift snapshot before upgrade...
==> skipping timeshift-autosnap due skipRsyncAutosnap in /etc/timeshift-autosnap.conf set to TRUE.
(2/2) Remove upgraded DKMS modules
==> dkms remove --no-depmod vmware-workstation/17.5.1_23298084 -k 6.1.92-1-MANJARO
(1/1) reinstalling linux61                                     [##################################] 100%
(1/7) Arming ConditionNeedsUpdate...
(2/7) Updating module dependencies...
(3/7) Install DKMS modules
==> dkms install --no-depmod vmware-workstation/17.5.1_23298084 -k 6.1.92-1-MANJARO
==> depmod 6.1.92-1-MANJARO
(4/7) Updating linux initcpios...
==> Building image from preset: /etc/mkinitcpio.d/linux61.preset: 'default'
==> Using default configuration file: '/etc/mkinitcpio.conf'
  -> -k /boot/vmlinuz-6.1-x86_64 -g /boot/initramfs-6.1-x86_64.img
==> Starting build: '6.1.92-1-MANJARO'
  -> Running build hook: [base]
  -> Running build hook: [udev]
  -> Running build hook: [kms]
==> WARNING: Possibly missing firmware for module: 'xhci_pci'
  -> Running build hook: [consolefont]
==> WARNING: consolefont: no font found in configuration
  -> Running build hook: [plymouth]
  -> Running build hook: [resume]
  -> Running build hook: [fsck]
==> Creating zstd-compressed initcpio image: '/boot/initramfs-6.1-x86_64.img'
  -> Early uncompressed CPIO image generation successful
==> Initcpio image generation successful
==> Building image from preset: /etc/mkinitcpio.d/linux61.preset: 'fallback'
  -> -k /boot/vmlinuz-6.1-x86_64 -g /boot/initramfs-6.1-x86_64-fallback.img -S autodetect
==> WARNING: Possibly missing firmware for module: 'ast'
==> WARNING: Possibly missing firmware for module: 'qla1280'
==> WARNING: Possibly missing firmware for module: 'wd719x'
==> WARNING: Possibly missing firmware for module: 'qed'
==> WARNING: Possibly missing firmware for module: 'aic94xx'
==> WARNING: Possibly missing firmware for module: 'qla2xxx'
==> WARNING: Possibly missing firmware for module: 'bfa'
==> Creating zstd-compressed initcpio image: '/boot/initramfs-6.1-x86_64-fallback.img'
(5/7) Updating Kernel initcpios for Nvidia-DRM...
(6/7) Refreshing PackageKit...
Error connecting: Could not connect: No such file or directory
error: command failed to execute correctly
(7/7) Updating Grub-Bootmenu
Found linux image: /boot/vmlinuz-6.1-x86_64
Found initrd image: /boot/intel-ucode.img /boot/initramfs-6.1-x86_64.img
Found initrd fallback image: /boot/initramfs-6.1-x86_64-fallback.img
done
And also:
[manjaro /]# mhwd-kernel -li
Currently running: 6.9.0-1-MANJARO (linux69)
   * linux515
   * linux54
   * linux61
   * linux66
You should be now able to boot the 6.1 kernel. Note that you still have remnants of 3 other broken kernels, and untended pacnews, but is can be fixed at a later time.
Ohhh! Great @Teo, now I could enter to my system.
What is the next step? Is it ok be in Kernel 6.1 because I think I was in 6.6 before.
I will follow your suggestions about the update. I have never put this option but I will remove it if they are updating the system on shutdown
If I remove and I install again, is a good idea?
Because always I’m trying to be in the last LTS
Yes, you have to try to remove and reinstall 66 now. Not sure if it will work from the applet or mhwd. If not, try pacman.
It works perfectly!!
Thanks for your time, patience and help Teo, you are amazing!
Always the community rescue my system! xD
And also I removed the option. You were right, was checked and I didn’t know
Have a good weekend!
But even Windows actually tells you that it’s doing that, and not to power off. If pamac does it without any indication then I agree with @Teo, that’s an unbelievably stupid idea.
