Sometimes my touchpad stucks in the “two finger scroll” mode.
So i created a “script” for this:
#!/usr/bin/env bash
sudo modprobe -r psmouse
sudo modprobe psmouse
[i3hunor@HunorT480 ~]$ inxi --admin --verbosity=7 --filter --width
Kernel: 5.15.32-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 11.2.0
root=UUID=cc7be21e-d9d4-4881-841a-b047d2a1253a rw quiet
udev.log_priority=3
Desktop: i3 v: 4.20.1 info: xfce4-panel vt: 7 dm: LightDM v: 1.30.0
Type: Laptop System: LENOVO product: 20L6S1LV2F v: ThinkPad T480
Mobo: LENOVO model: 20L6S1LV2F v: SDK0J40697 WIN
serial: <superuser required> UEFI: LENOVO v: N24ET67W (1.42 )
date: 11/17/2021
ID-1: BAT0 charge: 3.8 Wh (20.5%) condition: 18.5/23.9 Wh (77.4%)
volts: 11.2 min: 11.4 model: LGC 01AV489 type: Li-poly serial: <filter>
status: discharging cycles: 149
ID-2: BAT1 charge: 10.9 Wh (84.5%) condition: 12.9/24.0 Wh (53.8%)
volts: 12.0 min: 11.5 model: SMP 01AV452 type: Li-poly serial: <filter>
status: not charging cycles: 224
RAM: total: 7.51 GiB used: 3.92 GiB (52.2%)
RAM Report:
Info: model: Intel Core i5-8350U bits: 64 type: MT MCP arch: Coffee Lake
family: 6 model-id: 0x8E (142) stepping: 0xA (10) microcode: 0xEC
L3: 6 MiB desc: 1x6 MiB
Speed (MHz): avg: 800 min/max: 400/3600 scaling: driver: intel_pstate
governor: powersave cores: 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800 7: 800
8: 800 bogomips: 30409
arch_capabilities arch_perfmon art avx avx2 bmi1 bmi2 bts clflush clflushopt
cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts
epb ept ept_ad erms est f16c flexpriority flush_l1d fma fpu fsgsbase fxsr
ht hwp hwp_act_window hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid
invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe mpx msr mtrr
nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pln
pni popcnt pse pse36 pti pts rdrand rdseed rdtscp rep_good sdbg sep sgx
smap smep smx ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2
Type: l1tf
Device-1: Intel UHD Graphics 620 vendor: Lenovo driver: i915 v: kernel
ports: active: eDP-1 empty: DP-1, DP-2, HDMI-A-1, HDMI-A-2 bus-ID: 00:02.0
chip-ID: 8086:5917 class-ID: 0300
Device-2: Chicony Integrated Camera (1280x720@30) type: USB
driver: uvcvideo bus-ID: 1-8:3 chip-ID: 04f2:b604 class-ID: 0e02
serial: <filter>
Display: x11 server: X.Org v: 1.21.1.3 compositor: Picom v: git-7e568
driver: X: loaded: modesetting alternate: fbdev,vesa gpu: i915
display-ID: :0 screens: 1
s-diag: 582mm (22.93")
Monitor-1: eDP-1 model: LG Display 0x0521 built: 2016 res: 1920x1080
dpi: 158 gamma: 1.2 size: 309x174mm (12.17x6.85") diag: 355mm (14")
ratio: 16:9 modes: 1920x1080
OpenGL: renderer: Mesa Intel UHD Graphics 620 (KBL GT2) v: 4.6 Mesa 21.3.8
direct render: Yes
Device-1: Intel Sunrise Point-LP HD Audio vendor: Lenovo ThinkPad T480
driver: snd_hda_intel v: kernel alternate: snd_soc_skl bus-ID: 00:1f.3
chip-ID: 8086:9d71 class-ID: 0403
Sound Server-1: ALSA v: k5.15.32-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.49 running: no
Device-1: Intel Wireless 8265 / 8275 driver: iwlwifi v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 bus-ID: 03:00.0 chip-ID: 8086:24fd class-ID: 0280
Local Storage: total: 238.47 GiB used: 59.8 GiB (25.1%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Intel model: SSDPEKKF256G8L
size: 238.47 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 type: SSD serial: <filter> rev: L15P temp: 27.9 C scheme: GPT
ID-1: / raw-size: 118.93 GiB size: 116.5 GiB (97.96%)
used: 59.78 GiB (51.3%) fs: ext4 dev: /dev/nvme0n1p5 maj-min: 259:5
label: N/A uuid: cc7be21e-d9d4-4881-841a-b047d2a1253a
used: 25.3 MiB (26.3%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
label: N/A uuid: 2EAD-1B08
ID-1: swap-1 type: file size: 8 GiB used: 0 KiB (0.0%) priority: -2
file: /swapfile
ID-1: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-2: /dev/nvme0n1p3 maj-min: 259:3 size: 118.93 GiB fs: ntfs label: N/A
uuid: 3648B0CC48B08C5D
ID-3: /dev/nvme0n1p4 maj-min: 259:4 size: 509 MiB fs: ntfs label: N/A
uuid: 1804C52004C5022C
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 12 rev: 2.0
Device-1: 1-8:3 info: Chicony Integrated Camera (1280x720@30) type: Video
chip-ID: 04f2:b604 class-ID: 0e02 serial: <filter>
Hub-2: 2-0:1 info: Super-speed hub ports: 6 rev: 3.0 speed: 5 Gb/s
Hub-3: 3-0:1 info: Hi-speed hub with single TT ports: 2 rev: 2.0
Hub-4: 4-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 35.0 C pch: 31.5 C mobo: N/A
Processes: 231 Uptime: 8h 5m wakeups: 9 Init: systemd v: 250 tool: systemctl
Compilers: gcc: 11.2.0 clang: 13.0.1 Packages: pacman: 1242 lib: 358
Shell: Bash v: 5.1.16 running-in: xfce4-terminal inxi: 3.3.15
[i3hunor@HunorT480 ~]$ xinput
⎡ Virtual core pointer id=2 [master pointer (3)]
⎜ ↳ Virtual core XTEST pointer id=4 [slave pointer (2)]
⎜ ↳ Synaptics TM3276-022 id=12 [slave pointer (2)]
⎜ ↳ TPPS/2 IBM TrackPoint id=13 [slave pointer (2)]
⎣ Virtual core keyboard id=3 [master keyboard (2)]
↳ Virtual core XTEST keyboard id=5 [slave keyboard (3)]
↳ Power Button id=6 [slave keyboard (3)]
↳ Video Bus id=7 [slave keyboard (3)]
↳ Sleep Button id=8 [slave keyboard (3)]
↳ Integrated Camera: Integrated C id=9 [slave keyboard (3)]
↳ AT Translated Set 2 keyboard id=10 [slave keyboard (3)]
↳ ThinkPad Extra Buttons id=11 [slave keyboard (3)]
Did I do something in a wrong way?
