Hi,
after the upgrade to plasma 6 (new Manjaro Version) i could not use my video projector with Wayland anymore. It is connected on the USB-C-Port of my laptop with an usb-c to hdmi adapter.
I see this error in journald:
Mai 29 23:48:01 user-pc kwin_wayland[1484]: kwin_wayland_drm: Couldn't parse EDID for connector DrmConnector(id=339, gpu=KWin::DrmGpu(0x60f9b57cb5c0), name="DP-3-unbekannt", connection="Connected", countMode=37)
Mai 29 23:48:01 user-pc kwin_wayland[1484]: kwin_core: parsing edid failed
Mai 29 23:48:01 user-pc kernel: usb 3-4: SerialNumber: 00000000000000000
Mai 29 23:48:01 user-pc kernel: usb 3-4: Manufacturer: Realtek
Mai 29 23:48:01 user-pc kernel: usb 3-4: Product: BillBoard Device
Mai 29 23:48:01 user-pc kernel: usb 3-4: New USB device strings: Mfr=17, Product=18, SerialNumber=19
Mai 29 23:48:01 user-pc kernel: usb 3-4: New USB device found, idVendor=0bda, idProduct=2172, bcdDevice= 1.00
Mai 29 23:48:00 user-pc kernel: usb 3-4: not running at top speed; connect to a high speed hub
Mai 29 23:48:00 user-pc kernel: usb 3-4: new full-speed USB device number 9 using xhci_hcd
It works fine if i use x11, so i think its a wayland+plasma6 thing. It worked before the last big Manjaroupgrade, where plasma 5 was used.
If this is helpful:
inxi -G
Device-1: Intel TigerLake-LP GT2 [Iris Xe Graphics] driver: i915 v: kernel
Device-2: Bison Integrated Camera driver: uvcvideo type: USB
Display: wayland server: X.org v: 1.21.1.13 with: Xwayland v: 24.1.0
compositor: kwin_wayland driver: X: loaded: modesetting dri: iris gpu: i915
resolution: 1: 1920x1080 2: 1920x1080
API: EGL v: 1.5 drivers: iris,swrast
platforms: wayland,x11,surfaceless,device
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 24.0.8-manjaro1.1
renderer: Mesa Intel Xe Graphics (TGL GT2)
API: Vulkan v: 1.3.279 drivers: intel surfaces: xcb,xlib,wayland
uname -a
Linux user-pc 6.9.2-1-MANJARO #1 SMP PREEMPT_DYNAMIC Mon May 27 03:56:18 UTC 2024 x86_64 GNU/Linux
