I updated my system using pacman -Syu on 2020-11-06 and now rstudio-desktop-bin (most recent version from AUR, , v1.3.1093-1) does not open consistently. Sometimes it opens a window then closes it immediately, sometimes it’s a black window, and sometimes it opens a window and appears normal but crashes in short order. Anyone else having this problem?
Maybe something here! When I launch from terminal and it crashes, I see many lines of “nouveau: memory address” then this error. But sometimes it freezes everything and I have to force reboot.
nouveau: 0x001f001e
nouveau: 0x0020001f
nouveau: 0x00210020
nouveau: 0x00230022
nouveau: 0x80000585
nouveau: 0x200406c0
nouveau: 0x00000000
nouveau: 0x00014000
nouveau: 0x000004f9
nouveau: 0x1000f010
[3202:3203:20201109,161157.589632:ERROR file_io_posix.cc:148] open /home/mcsimenc/.r/crashpad_database/pending/0aa2ed44-3856-4a36-adc5-e852ff28e890.lock: File exists (17)
[3202:3202:20201109,161157.591859:ERROR process_memory_range.cc:86] read out of range
[3202:3202:20201109,161157.591865:ERROR elf_image_reader.cc:558] missing nul-terminator
[3202:3202:20201109,161157.591983:ERROR process_reader_linux.cc:445] no module mappings 0x7f737a0fd000
[3202:3202:20201109,161157.593840:ERROR elf_dynamic_array_reader.h:61] tag not found
[3202:3202:20201109,161157.593996:ERROR elf_dynamic_array_reader.h:61] tag not found
[3202:3202:20201109,161157.595087:ERROR elf_dynamic_array_reader.h:61] tag not found
[3202:3202:20201109,161157.595128:ERROR elf_dynamic_array_reader.h:61] tag not found
[3202:3202:20201109,161157.595943:ERROR elf_dynamic_array_reader.h:61] tag not found
[3202:3202:20201109,161157.595974:ERROR elf_dynamic_array_reader.h:61] tag not found
[3202:3202:20201109,161157.596004:ERROR elf_dynamic_array_reader.h:61] tag not found
[3202:3202:20201109,161157.596033:ERROR elf_dynamic_array_reader.h:61] tag not found
[3202:3202:20201109,161157.596064:ERROR elf_dynamic_array_reader.h:61] tag not found
[3202:3202:20201109,161157.596120:ERROR elf_dynamic_array_reader.h:61] tag not found
[3202:3202:20201109,161157.596151:ERROR elf_dynamic_array_reader.h:61] tag not found
[3202:3202:20201109,161157.596179:ERROR elf_dynamic_array_reader.h:61] tag not found
[3202:3202:20201109,161157.596209:ERROR elf_dynamic_array_reader.h:61] tag not found
[3202:3203:20201109,161157.598011:ERROR directory_reader_posix.cc:42] opendir: No such file or directory (2)
Segmentation fault (core dumped)
That won’t help because you just reinstalled the same binary files that were built against older libraries. Build rstudio-desktop or rstudio-desktop-git and you should be good to go.
Not sure what to tell you then. It could be an upstream issue. Have you poked the internet?
We don’t even have that in the Manjaro unstable branch yet. Arch just updated to 2.11.0.2-1 today. They may be holding it back to avoid breakage with packages that depend on it.
Might be a bit of a shot in the dark, but have you tried removing RStudio’s cache and config files (plus any other crud it leaves around the home directory)?
I’m currently using the latest rstudio-desktop-bin from the AUR without issue. Looking at your inxi output the main differences between our systems that ‘might’ make a difference are GFX card manufacturers (Intel + AMD vs Nvidia), desktop environment (Gnome vs XFCE), desktop session type (Wayland vs X11), kernel version (5.9 vs 5.8) and monitor resolution (2 x 1080p vs 2 x 4K). Not sure if that’s helpful or not, but might give some clues if removing the config/cache stuff doesn’t help.
Otherwise, have you checked the comments in the AUR?
Yeah, removing the config/cache directory didn’t affect the problem.
I tried installing kernel v5.9 using mhwd-kernel -i linux59 because pacman -S linux installs v5.8 even though v5.9.6 is the latest in the Arch repository. Changing my monitor resolution didn’t change RStudio’s behavior either. I’m under the impression that I can’t use Wayland with XFCE.
I tried to install Gnome using pacman -S gnome but I think it tells me I have gdm-dev installed and also that gdm-dev conflicts with libgdm-dev. But pacman -R gdm and pacman -R gdm-dev report target not found.
warning: removing 'gdm' from target list because it conflicts with 'gdm-dev'
error: unresolvable package conflicts detected
error: failed to prepare transaction (conflicting dependencies)
:: gdm-dev and libgdm-dev are in conflict
I didn’t see anything relevant in the AUR comments.
