After latest update, picom says that there is another compositor already running
Hi. I’m using manjaro i3.
After I updated, I get an error message on start up, something about picom and glx-no-stencil, and to check picom in the CLI for more info. When I do so, I get the following error message:
❯ picom
[ 05/13/2026 11:36:15.681 c2_parse_target WARN ] Type specifier is deprecated. Type "a" specified on target "_NET_WM_STATE" will be ignored, you can remove it.
[ 05/13/2026 11:36:15.681 c2_parse_target WARN ] Format specifier is deprecated. Format "32" specified on target "_NET_WM_STATE" will be ignored, you can remove it.
[ 05/13/2026 11:36:15.681 c2_parse_target WARN ] Type specifier is deprecated. Type "c" specified on target "_GTK_FRAME_EXTENTS" will be ignored, you can remove it.
[ 05/13/2026 11:36:15.681 report_deprecated_option WARN ] Option "glx-no-stencil" is deprecated, please remove it from your config file and/or command line options.
[ 05/13/2026 11:36:15.682 session_init FATAL ERROR ] Another composite manager is already running
[ 05/13/2026 11:36:15.682 main FATAL ERROR ] Failed to create new session.
So then I check with pgrep -l and also inxi -Gxx | grep compositor, and the output is that Picom v is the compositor.
Anyone know how I would get rid of the error messages?
Here’s my inxi:
❯ inxi -zv8
  Kernel: 7.0.3-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
    parameters: BOOT_IMAGE=/boot/vmlinuz-7.0-x86_64
    root=UUID=30df83e3-f608-4071-98b0-7cea88d40a9d rw quiet
    cryptdevice=UUID=3bafe492-8b5a-4e57-8eb0-41bc6d7137c1:luks-3bafe492-8b5a-4e57-8eb0-41bc6d7137c1
    root=/dev/mapper/luks-3bafe492-8b5a-4e57-8eb0-41bc6d7137c1 apparmor=1
    security=apparmor
    resume=/dev/mapper/luks-3858f910-eea1-4d79-b2c7-13e364708e79
    udev.log_priority=3
  Desktop: i3 v: 4.25.1 with: i3bar tools: avail: i3lock,xautolock vt: 2 dm:
    1: LightDM v: 1.32.0 note: stopped 2: SDDM Distro: Manjaro base: Arch Linux
  Type: Desktop Mobo: Micro-Star model: PRO B650M-A WIFI (MS-7D77) v: 1.0
    serial: <superuser required> uuid: <superuser required> Firmware: UEFI
    vendor: American Megatrends LLC. v: 1.F1 date: 01/04/2024
  System RAM: total: 128 GiB available: 124.99 GiB used: 3.99 GiB (3.2%)
  Device-1: DIMMA1 type: DDR5 detail: synchronous unbuffered (unregistered)
    size: 32 GiB speed: spec: 4800 MT/s actual: 3600 MT/s volts: note: check
    curr: 1 min: 1 max: 1 width (bits): data: 64 total: 64
    manufacturer: Kingston part-no: KF560C36-32 serial: <filter>
  Device-2: DIMMA2 type: DDR5 detail: synchronous unbuffered (unregistered)
  Device-3: DIMMB1 type: DDR5 detail: synchronous unbuffered (unregistered)
  Device-4: DIMMB2 type: DDR5 detail: synchronous unbuffered (unregistered)
  Info: model: AMD Ryzen 7 7800X3D bits: 64 type: MT MCP arch: Zen 4 gen: 4
    level: v4 note: check built: 2022+ process: TSMC n5 (5nm) family: 0x19 (25)
    model-id: 0x61 (97) stepping: 2 microcode: 0xA60120A
    smt: enabled cache: L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 8 MiB
    desc: 8x1024 KiB L3: 96 MiB desc: 1x96 MiB
  Speed (MHz): avg: 2983 min/max: 426/5053 boost: enabled scaling:
    driver: amd-pstate-epp governor: powersave cores: 1: 2983 2: 2983 3: 2983
    4: 2983 5: 2983 6: 2983 7: 2983 8: 2983 9: 2983 10: 2983 11: 2983 12: 2983
    13: 2983 14: 2983 15: 2983 16: 2983 bogomips: 134395
    apic arat avic avx avx2 avx512_bf16 avx512_bitalg avx512_vbmi2
    avx512_vnni avx512_vpopcntdq avx512bw avx512cd avx512dq avx512f
    avx512ifma avx512vbmi avx512vl bmi1 bmi2 bpext cat_l3 cdp_l3 clflush
    clflushopt clwb clzero cmov cmp_legacy constant_tsc cpb cppc cpuid
    cpuid_fault cqm cqm_llc cqm_mbm_local cqm_mbm_total cqm_occup_llc
    cr8_legacy cx16 cx8 de decodeassists erms extapic extd_apicid f16c
    flush_l1d flushbyasid fma fpu fsgsbase fsrm fxsr fxsr_opt gfni ht
    hw_pstate ibpb ibrs ibrs_enhanced ibs invpcid irperf lahf_lm lbrv lm mba
    mca mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx nonstop_tsc
    nopl npt nrip_save nx ospke osvw overflow_recov pae pat pausefilter
    pclmulqdq pdpe1gb perfctr_core perfctr_llc perfctr_nb perfmon_v2
    pfthreshold pge pku pni popcnt pse pse36 rapl rdpid rdpru rdrand rdseed
    rdt_a rdtscp rep_good sep sha_ni skinit smap smca smep ssbd sse sse2
    sse4_1 sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce topoext
    tsc tsc_scale umip user_shstk v_spec_ctrl vaes vgif vmcb_clean vme
    vmmcall vnmi vpclmulqdq wbnoinvd wdt x2avic xgetbv1 xsave xsavec
    xsaveerptr xsaveopt xsaves xtopology
    conditional; STIBP: always-on; PBRSB-eIBRS: Not affected; BHI: Not
    affected
  Device-1: NVIDIA AD107 [GeForce RTX 4060] vendor: Micro-Star MSI
    driver: nvidia v: 595.71.05 alternate: nouveau,nvidia_drm
    non-free: 550-580.xx+ status: current (as of 2025-11) arch: Lovelace
    code: AD1xx process: TSMC n4 (5nm) built: 2022+ pcie: gen: 1
    speed: 2.5 GT/s lanes: 8 link-max: gen: 4 speed: 16 GT/s ports:
    active: none off: HDMI-A-2 empty: DP-4,DP-5,DP-6 bus-ID: 01:00.0
    chip-ID: 10de:2882 class-ID: 0300
  Device-2: Advanced Micro Devices [AMD/ATI] Raphael vendor: Micro-Star MSI
    driver: amdgpu v: kernel arch: RDNA-2 code: Navi-2x process: TSMC n7 (7nm)
    built: 2020-22 pcie: gen: 4 speed: 16 GT/s lanes: 16 ports: active: none
    empty: DP-1, DP-2, DP-3, HDMI-A-1, Writeback-1 bus-ID: 10:00.0
    chip-ID: 1002:164e class-ID: 0300 temp: 36.0 C
  Display: x11 server: X.Org v: 21.1.22 with: Xwayland v: 24.1.11
    compositor: Picom v: 13 driver: X: loaded: amdgpu,nvidia
    unloaded: modesetting,nouveau alternate: fbdev,nv,vesa dri: radeonsi
    gpu: nv_platform,nvidia,nvidia-nvswitch display-ID: :0 screens: 1
  Screen-1: 0 s-res: 1920x1080 s-dpi: 92 s-size: 530x301mm (20.87x11.85")
    s-diag: 610mm (24")
  Monitor-1: HDMI-A-2 mapped: HDMI-0 note: disabled
    model: LG (GoldStar) FULL HD built: 2016 res: mode: 1920x1080 hz: 60
    scale: 100% (1) dpi: 93 gamma: 1.2 chroma: red: x: 0.647 y: 0.333 green:
    x: 0.306 y: 0.631 blue: x: 0.149 y: 0.047 white: x: 0.314 y: 0.329
    size: 527x296mm (20.75x11.65") diag: 604mm (23.8") ratio: 16:9
    modes: 1920x1080, 1680x1050, 1400x1050, 1600x900, 1280x1024, 1440x900,
    1280x800, 1152x864, 1280x720, 1024x768, 800x600, 720x576, 720x480,
    640x480
  API: EGL v: 1.5 hw: drv: nvidia drv: amd radeonsi platforms: device: 0
    drv: nvidia device: 2 drv: radeonsi device: 3 drv: swrast gbm: drv: nvidia
    surfaceless: drv: nvidia x11: drv: nvidia inactive: wayland,device-1
  API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 595.71.05
    glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 4060/PCIe/SSE2
    memory: 7.81 GiB
  API: Vulkan v: 1.4.341 layers: 8 device: 0 type: discrete-gpu
    name: NVIDIA GeForce RTX 4060 driver: nvidia v: 595.71.05
    device-ID: 10de:2882 surfaces: N/A device: 1 type: integrated-gpu name: AMD
    Ryzen 7 7800X3D 8-Core Processor (RADV RAPHAEL_MENDOCINO)
    driver: mesa radv v: 26.0.6-arch1.1 device-ID: 1002:164e surfaces: N/A
  Device-1: NVIDIA AD107 High Definition Audio vendor: Micro-Star MSI
    driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 8
    bus-ID: 01:00.1 chip-ID: 10de:22be class-ID: 0403
  Device-2: Advanced Micro Devices [AMD/ATI] Radeon High Definition Audio
    vendor: Micro-Star MSI driver: snd_hda_intel v: kernel pcie: gen: 4
    speed: 16 GT/s lanes: 16 bus-ID: 10:00.1 chip-ID: 1002:1640 class-ID: 0403
  Device-3: Advanced Micro Devices [AMD] Ryzen HD Audio
    speed: 16 GT/s lanes: 16 bus-ID: 10:00.6 chip-ID: 1022:15e3 class-ID: 0403
  API: ALSA v: k7.0.3-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.6.4 status: active with: 1: pipewire-pulse
    4: pw-jack type: plugin tools: pactl,pw-cat,pw-cli,wpctl
  Device-1: Realtek RTL8125 2.5GbE vendor: Micro-Star MSI driver: r8169
    v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 port: e000 bus-ID: 0c:00.0
  IF: enp12s0 state: down mac: <filter>
  Device-2: MEDIATEK MT7922 802.11ax PCI Express Wireless Network Adapter
    driver: mt7921e v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1
    bus-ID: 0d:00.0 chip-ID: 14c3:0616 class-ID: 0280
  IF: wlp13s0 state: up mac: <filter>
  Device-1: MediaTek Wireless_Device driver: btusb v: 0.8 type: USB rev: 2.1
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-12:6 chip-ID: 0e8d:0616
  Report: btmgmt ID: hci0 rfk-id: 0 state: down bt-service: enabled,running
    rfk-block: hardware: no software: yes address: <filter> bt-v: 5.3 lmp-v: 12
    status: discoverable: no pairing: no
  Device-1: luks-3bafe492-8b5a-4e57-8eb0-41bc6d7137c1 maj-min: 253:0
    type: LUKS dm: dm-0 size: 1.81 TiB
  Components:
  p-1: nvme0n1p2 maj-min: 259:2 size: 1.81 TiB
  Device-2: luks-3858f910-eea1-4d79-b2c7-13e364708e79 maj-min: 253:1
    type: LUKS dm: dm-1 size: 8.8 GiB
  Components:
  p-1: nvme0n1p3 maj-min: 259:3 size: 8.8 GiB
  Local Storage: total: 3.18 TiB used: 1.73 TiB (54.2%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: SFYRD2000G
    lanes: 4 tech: SSD serial: <filter> fw-rev: EIFK31.6 temp: 27.9 C
    scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 vendor: Smart Modular Tech.
    model: SHGS31-500GS-2 size: 465.76 GiB block-size: physical: 4096 B
    logical: 512 B speed: 6.0 Gb/s tech: SSD serial: <filter> fw-rev: 0Q00
  ID-3: /dev/sdb maj-min: 8:16 vendor: HGST (Hitachi) model: HTS541010A9E680
    tech: HDD rpm: 5400 serial: <filter> fw-rev: A560 scheme: GPT
  ID-1: / raw-size: 1.81 TiB size: 1.78 TiB (98.37%) used: 826.07 GiB (45.3%)
    fs: ext4 dev: /dev/dm-0 maj-min: 253:0
    mapped: luks-3bafe492-8b5a-4e57-8eb0-41bc6d7137c1 label: N/A
    uuid: 30df83e3-f608-4071-98b0-7cea88d40a9d
    used: 448 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
    uuid: D761-C6C4
  ID-3: /mnt/AuxDrive raw-size: 931.51 GiB size: 915.82 GiB (98.32%)
    used: 749.01 GiB (81.8%) fs: ext4 dev: /dev/sdb1 maj-min: 8:17
    label: auxdrive uuid: d6001d23-14b8-455a-b087-b6d8444672e6
  ID-4: /mnt/AuxSSD raw-size: 465.76 GiB size: 457.38 GiB (98.20%)
    used: 191.38 GiB (41.8%) fs: ext4 dev: /dev/sda maj-min: 8:0 label: AuxSSD
    uuid: fbd19cb0-8e1c-404b-834a-5ddba5084071
  ID-1: swap-1 type: partition size: 8.8 GiB used: 0 KiB (0.0%) priority: -1
    dev: /dev/dm-1 maj-min: 253:1
    mapped: luks-3858f910-eea1-4d79-b2c7-13e364708e79 label: swap
    uuid: ee7dd785-4294-4578-9576-0a6bee069a33
  Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
  Device-1: 1-3:2 info: Apple Aluminium Keyboard (ANSI) type: keyboard,mouse
    driver: apple,usbhid interfaces: 2 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s)
    lanes: 1 mode: 1.1 power: 100mA chip-ID: 05ac:024f class-ID: 0301
  Device-2: 1-4:3 info: Areson Corp 2.4G Wireless Receiver
    type: keyboard,mouse driver: hid-generic,usbhid interfaces: 2 rev: 1.1
    chip-ID: 25a7:fa11 class-ID: 0301
  Device-3: 1-8:4 info: ASETEK [NZXT Kraken X60] type: <vendor specific>
    driver: N/A interfaces: 1 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s) lanes: 1
    mode: 1.1 power: 50mA chip-ID: 2433:b200 class-ID: 0000 serial: <filter>
  Device-4: 1-11:5 info: Micro Star MYSTIC LIGHT type: HID
    lanes: 1 mode: 1.1 power: 500mA chip-ID: 1462:7d77 class-ID: 0300
    serial: <filter>
  Device-5: 1-12:6 info: MediaTek Wireless_Device type: bluetooth
    mode: 2.0 power: 100mA chip-ID: 0e8d:0616 class-ID: e001 serial: <filter>
  Hub-2: 2-0:1 info: super-speed hub ports: 6 rev: 3.1
  Hub-5: 5-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
  Hub-6: 5-1:2 info: ASMedia ASM1074 High-Speed hub ports: 4 rev: 2.1
    chip-ID: 174c:2074 class-ID: 0900
  Hub-7: 6-0:1 info: super-speed hub ports: 2 rev: 3.1
  Hub-8: 6-1:2 info: ASMedia ASM1074 SuperSpeed hub ports: 4 rev: 3.0
    speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 power: 8mA
    chip-ID: 174c:3074 class-ID: 0900
  Hub-9: 7-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
  System Temperatures: cpu: 39.1 C mobo: N/A
  Fan Speeds (rpm): N/A
  GPU: device: nvidia screen: :0.0 temp: 44 C fan: 0% device: amdgpu
    temp: 36.0 C
  Packages: pm: pacman pkgs: 1989 libs: 474 tools: pamac,yay pm: flatpak
    pkgs: 0
    1: https://gsl-syd.mm.fcix.net/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 365
  1: cpu: 13.1% command: firefox pid: 5921 mem: 85.1 MiB (0.0%)
  2: cpu: 6.6% command: firefox pid: 5807 mem: 1304.7 MiB (1.0%)
  3: cpu: 2.1% command: firefox pid: 20522 mem: 374.5 MiB (0.2%)
  4: cpu: 1.5% command: Xorg pid: 1105 mem: 126.6 MiB (0.0%)
  5: cpu: 0.9% command: picom pid: 1703 mem: 76.4 MiB (0.0%)
  Memory top: 5 of 365
  1: mem: 1304.7 MiB (1.0%) command: firefox pid: 5807 cpu: 6.6%
  2: mem: 374.5 MiB (0.2%) command: firefox pid: 20522 cpu: 2.1%
  3: mem: 349.4 MiB (0.2%) command: firefox pid: 6175 cpu: 0.1%
  4: mem: 228.0 MiB (0.1%) command: firefox pid: 5911 cpu: 0.0%
  5: mem: 222.6 MiB (0.1%) command: firefox pid: 5977 cpu: 0.0%
  Processes: 365 Power: uptime: 1h 46m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 49.89 GiB
    services: upowerd,xfce4-power-manager Init: systemd v: 260
  Compilers: clang: 22.1.3 gcc: 15.2.1 alt: 13/14 Shell: Zsh v: 5.9
    running-in: urxvtd inxi: 3.3.40
If you have picom running twice - I suggest checking your configuration scripts
I’ve checked my .i3/config. There’s only one instance that picom is called on startup.
Hi @neurofire
The “another compositor already running” error you got from the terminal is expected — picom was already running from your i3 autostart. You were just trying to start a second one manually to investigate. So no double-start issue.
The actual problem is the glx-no-stencil line in your picom config — it’s been deprecated and picom now refuses to start cleanly with it.
Open your picom config and remove or comment out the glx-no-stencil line.
Thank you! That fixed it
