I use Phosh on a Pinephone, and after the last update, the sound stopped working in VLC. I went to settings and tried to test the speakers but didn’t hear anything. I can ssh into the phone and run commands.
With me on “Gnome unstabel” sometimes the setting for sound get altered,
Sound switches to another source, and then there is no sound to be heard…
I found someone with the same warning I got, and a developer had to update the pulseaudio-alsa package. This was my warning: pulseaudio-alsa local newer than extra (2-5). The thread is from 2020 and on the Artix Linux Forum, but I can’t share the link. I’m using a Pinephone.
solved this with uninstalling alsa-ucm-pinephone and then reinstalling again. Hope this helps.
Thanks, reinstalling alsa-ucm-pinephone also fixed the same issue for me.
I had to reboot after reinstalling before the audio began working again.
