Deleted those lines. Now when I attempt sudo pacman -Syu libvirt
it no longer gets the error and appears to go all the way through but I do not believe it saves as when I attempt to check for the files they do not appear and the system allows me to download it again.
:: Proceed with installation? [Y/n] y
(1/1) checking keys in keyring [#############################################################################] 100%
(1/1) checking package integrity [#############################################################################] 100%
(1/1) loading package files [#############################################################################] 100%
(1/1) checking for file conflicts [#############################################################################] 100%
(1/1) checking available disk space [#############################################################################] 100%
(1/1) Creating Timeshift snapshot before upgrade...
==> skipping timeshift-autosnap due skipRsyncAutosnap in /etc/timeshift-autosnap.conf set to TRUE.
(1/1) reinstalling libvirt [#############################################################################] 100%
(1/6) Creating system user accounts...
(2/6) Reloading system manager configuration...
(3/6) Applying kernel sysctl settings...
(4/6) Creating temporary files...
(5/6) Arming ConditionNeedsUpdate...
(6/6) Refreshing PackageKit...
Also deleted the pritunul one as that is rouge code from a failed attempt of downloading that program.
