Yeah, but just ignore it, it worked great before so just forget it.
Also I uninstalled pantheon-terminal since gnome-terminal was working correctly with correct locals configuration.
I removed pusleeffects using command sudo pacman -Rscn pulseeffects, installed pipewire and again installed pusleeffects.
I can’t uninstall pulseaudio because it will break some native dependencies
ramofx@manjaro ~/Projects/app/web/react/tasks: $ sudo pacman -R pulseaudio
checking dependencies...
:: removing pulseaudio breaks dependency 'pulseaudio' required by gnome-settings-daemon
:: removing pulseaudio breaks dependency 'pulseaudio' required by manjaro-pulse
:: removing pulseaudio breaks dependency 'pulseaudio' required by pulseaudio-alsa
:: removing pulseaudio breaks dependency 'pulseaudio=14.2-2' required by pulseaudio-bluetooth
:: removing pulseaudio breaks dependency 'pulseaudio' required by pulseaudio-ctl
:: removing pulseaudio breaks dependency 'pulseaudio=14.2-2' required by pulseaudio-equalizer
:: removing pulseaudio breaks dependency 'pulseaudio=14.2-2' required by pulseaudio-jack
:: removing pulseaudio breaks dependency 'pulseaudio=14.2-2' required by pulseaudio-lirc
:: removing pulseaudio breaks dependency 'pulseaudio=14.2-2' required by pulseaudio-rtp
:: removing pulseaudio breaks dependency 'pulseaudio=14.2-2' required by pulseaudio-zeroconf
No effect, but pulseeffect’s interface little bit changed (https://pasteboard.co/JNUSeNM.png)
Sorry for that, it works as expected. Thank you!
When removing some software using manjaro-application-utility it shows following warnings:
ramofx@manjaro ~: $ manjaro-application-utility
WARNING:root:File not exist ? /usr/share/application-utility/gnome.json
WARNING:root:warning: packages not uninstalled
