So, essentially, I went to install Arch on my main ~256gb SSD(I have a 2nd 2tb ssd that I installed Manjaro onto) and after bungling it, the smaller drive basically disappeared. I was able to clear all it’s partitions using a Windows install disk, and figured after it was clear I would be able to use gparted or command line to manually set up EFI/swap over Manjaro.
This was not the case. I was forced to install on my larger drive(not an issue, I just want to recover my other one) and now fdisk -l doesn’t detect it, nor does other distro installers. Did I brick it? Is there a program I can use to possibly recover it?
Thanks in advance,
edit: posting inxi info.
Kernel: 5.10.42-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=cb875d8d-f1e9-41ca-a7f6-47922bf65258 rw quiet apparmor=1
Desktop: Xfce 4.16.0 tk: Gtk 3.24.29 info: xfce4-panel wm: xfwm4
Type: Laptop System: Acer product: Aspire A515-54 v: V1.07 serial: <filter>
Mobo: WHL model: Doc_WC v: V1.07 serial: <filter> UEFI: Insyde v: 1.07
date: 06/28/2019
ID-1: BAT1 charge: 16.8 Wh (37.8%) condition: 44.5/48.9 Wh (90.9%)
volts: 14.8 min: 15.2 model: LGC AB14B8KK type: Li-ion serial: <filter>
status: Discharging
RAM: total: 3.69 GiB used: 2.98 GiB (80.6%)
Array-1: capacity: 32 GiB slots: 2 EC: None max-module-size: 16 GiB
note: est.
Device-1: ChannelA-DIMM0 size: No Module Installed
Device-2: ChannelB-DIMM0 size: 4 GiB speed: spec: 2667 MT/s
actual: 2400 MT/s type: DDR4 detail: synchronous bus-width: 64 bits
total: 64 bits manufacturer: SK Hynix part-no: HMA851S6CJR6N-VK serial: N/A
Info: Dual Core model: Intel Core i3-8145U socket: BGA1528 (U3E1)
note: check bits: 64 type: MT MCP arch: Kaby Lake note: check family: 6
model-id: 8E (142) stepping: B (11) microcode: DE cache: L2: 4 MiB
bogomips: 18406
Speed: 800 MHz min/max: 400/3900 MHz base/boost: 2079/8300 volts: 0.7 V
ext-clock: 100 MHz Core speeds (MHz): 1: 800 2: 800 3: 800 4: 801
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_capabilities
arch_perfmon art avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc
cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts epb ept ept_ad erms
est f16c flexpriority flush_l1d fma fpu fsgsbase fxsr ht hwp hwp_act_window
hwp_epp ibpb ibrs ida intel_pt invpcid invpcid_single lahf_lm lm mca mce
md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae pat pbe pcid
pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pts rdrand rdseed
rdtscp rep_good sdbg sep smap smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3
stibp syscall tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer vme vmx
vnmi vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
Device-1: Intel UHD Graphics 620 vendor: Acer Incorporated ALI driver: i915
v: kernel bus-ID: 00:02.0 chip-ID: 8086:3ea0 class-ID: 0300
Device-2: Quanta HD User Facing type: USB driver: uvcvideo bus-ID: 1-5:3
chip-ID: 0408:a061 class-ID: 0e02
Display: server: X..Org 1.20.11 driver: loaded: intel unloaded: modesetting
alternate: fbdev,vesa display-ID: :0.0 screens: 1
s-diag: 582mm (22.9")
Monitor-1: eDP1 res: 1920x1080 hz: 60 dpi: 143 size: 340x190mm (13.4x7.5")
diag: 389mm (15.3")
OpenGL: renderer: Mesa Intel UHD Graphics 620 (WHL GT2) v: 4.6 Mesa 21.1.2
direct render: Yes
Device-1: Intel Cannon Point-LP High Definition Audio
vendor: Acer Incorporated ALI driver: snd_hda_intel v: kernel
alternate: snd_soc_skl,snd_sof_pci bus-ID: 00:1f.3 chip-ID: 8086:9dc8
class-ID: 0403
Sound Server-1: ALSA v: k5.10.42-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.30 running: no
vendor: Acer Incorporated ALI driver: r8169 v: kernel port: 3000
bus-ID: 01:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp1s0 state: down mac: <filter>
Device-2: Ralink RT5372 Wireless Adapter type: USB driver: rt2800usb
bus-ID: 1-1:2 chip-ID: 148f:5372 class-ID: 0000
IF: wlp0s20f0u1 state: up mac: <filter>
Hardware-1: Intel 82801 Mobile SATA Controller [RAID mode] driver: ahci
v: 3.0 port: 4060 bus-ID: 00:17.0 chip-ID: 8086.282a rev: 30 class-ID: 0104
Local Storage: total: 1.82 TiB used: 16.77 GiB (0.9%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST2000LX001-1RG174
rotation: 5400 rpm serial: <filter> rev: SDM1 scheme: GPT
ID-1: / raw-size: 1.82 TiB size: 1.79 TiB (98.37%) used: 16.77 GiB (0.9%)
fs: ext4 block-size: 4096 B dev: /dev/sda2 maj-min: 8:2 label: N/A
uuid: cb875d8d-f1e9-41ca-a7f6-47922bf65258
used: 288 KiB (0.1%) fs: vfat block-size: 512 B dev: /dev/sda1 maj-min: 8:1
label: NO_LABEL uuid: 62E2-282B
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 12 rev: 2.0
Device-1: 1-1:2 info: Ralink RT5372 Wireless Adapter type: Network
driver: rt2800usb interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 450mA
Device-2: 1-5:3 info: Quanta HD User Facing type: Video driver: uvcvideo
interfaces: 2 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 0408:a061
class-ID: 0e02
Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 6 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 41.0 C mobo: N/A
