I have a strange issue with qBittorrent. After I start qBittorrent, the whole system halts: first, my network and Bluetooth die, and after a while, everything becomes unresponsive
Here is my setup:
Kernel: 6.6.40-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
Desktop: KDE Plasma v: 6.0.5 Distro: Manjaro base: Arch Linux
Type: Laptop System: HP product: HP ProBook 455 G7 v: SBKPF
serial: <superuser required>
Mobo: HP model: 8730 v: KBC Version 13.2B.00 serial: <superuser required>
UEFI: HP v: S79 Ver. 01.16.00 date: 02/02/2024
Info: 8-core model: AMD Ryzen 7 4700U with Radeon Graphics bits: 64
type: MCP arch: Zen 2 rev: 1 cache: L1: 512 KiB L2: 4 MiB L3: 8 MiB
Speed (MHz): avg: 1398 high: 1400 min/max: 1400/2000 boost: enabled cores:
1: 1397 2: 1397 3: 1396 4: 1397 5: 1400 6: 1400 7: 1400 8: 1397
bogomips: 31954
Device-1: AMD Renoir [Radeon Vega Series / Radeon Mobile Series]
vendor: Hewlett-Packard driver: amdgpu v: kernel arch: GCN-5 bus-ID: 05:00.0
temp: 45.0 C
That a log from journalctl
юли 25 19:35:44 vanrea systemd[1190]: Started qBittorrent - BitTorrent client.
юли 25 19:35:44 vanrea kded6[1313]: Registering ":1.100/StatusNotifierItem" to system tray
юли 25 19:35:44 vanrea kded6[1313]: Service ":1.100" unregistered
юли 25 19:35:44 vanrea kded6[1313]: Registering ":1.101/StatusNotifierItem" to system tray
юли 25 19:35:44 vanrea plasmashell[1346]: QFont::setPointSizeF: Point size <= 0 (0.000000), must be greater than 0
юли 25 19:36:34 vanrea kernel: watchdog: BUG: soft lockup - CPU#6 stuck for 26s! [swapper/6:0]
юли 25 19:36:34 vanrea kernel: Modules linked in: rfcomm nft_masq nft_ct nft_reject_ipv4 nf_reject_ipv4 nft_reject nft_chain_nat nf_nat nf_conntrack nf_defrag_ipv6 nf_defrag_ipv4 nf_tables libcrc32c bridge stp>
юли 25 19:36:34 vanrea kernel: btintel uvc videobuf2_memops vfat snd_ump hp_wmi btbcm cryptd fat snd_hda_core snd_rawmidi videobuf2_v4l2 sparse_keymap btmtk rapl pcspkr platform_profile wmi_bmof acpi_cpufreq >
юли 25 19:36:34 vanrea kernel: CPU: 6 PID: 0 Comm: swapper/6 Tainted: G OE 6.6.40-1-MANJARO #1 bfd252e6ed3e282536601509dfc356fb9d948bbf
юли 25 19:36:34 vanrea kernel: Hardware name: HP HP ProBook 455 G7/8730, BIOS S79 Ver. 01.16.00 02/02/2024
юли 25 19:36:34 vanrea kernel: RIP: 0010:_raw_spin_unlock_irqrestore+0x1d/0x40
юли 25 19:36:34 vanrea kernel: Code: 90 90 90 90 90 90 90 90 90 90 90 90 90 f3 0f 1e fa 0f 1f 44 00 00 c6 07 00 0f 1f 00 f7 c6 00 02 00 00 74 06 fb 0f 1f 44 00 00 <65> ff 0d a4 25 a5 63 74 05 e9 d5 19 00 00 e8>
юли 25 19:36:34 vanrea kernel: RSP: 0018:ffffc90000360e78 EFLAGS: 00000206
юли 25 19:36:34 vanrea kernel: RAX: ffff88810c6f4d00 RBX: 0000000000000206 RCX: ffff88810c6f4d00
юли 25 19:36:34 vanrea kernel: RDX: ffff88810c6f4bc8 RSI: 0000000000000206 RDI: ffff88810c6f4d44
юли 25 19:36:34 vanrea kernel: RBP: ffffc90000360f40 R08: ffff88810c6f4d00 R09: 0000000000000000
юли 25 19:36:34 vanrea kernel: R10: ffff88811b110000 R11: ffff888261abb2f0 R12: ffff88810c6f4c20
юли 25 19:36:34 vanrea kernel: R13: ffff88810c6f4e60 R14: ffff88810c6f4b70 R15: ffff88810c6f4d00
юли 25 19:36:34 vanrea kernel: FS: 0000000000000000(0000) GS:ffff8885f7780000(0000) knlGS:0000000000000000
юли 25 19:36:34 vanrea kernel: CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
юли 25 19:36:34 vanrea kernel: CR2: 00005586841e91a8 CR3: 00000003d6a20000 CR4: 0000000000350ee0
юли 25 19:36:34 vanrea kernel: Call Trace:
юли 25 19:36:34 vanrea kernel: <IRQ>
юли 25 19:36:34 vanrea kernel: ? watchdog_timer_fn+0x1b1/0x220
юли 25 19:36:34 vanrea kernel: ? __pfx_watchdog_timer_fn+0x10/0x10
юли 25 19:36:34 vanrea kernel: ? __hrtimer_run_queues+0x132/0x2a0
юли 25 19:36:34 vanrea kernel: ? hrtimer_interrupt+0xf8/0x230
юли 25 19:36:34 vanrea kernel: ? __sysvec_apic_timer_interrupt+0x4d/0x140
юли 25 19:36:34 vanrea kernel: ? sysvec_apic_timer_interrupt+0x39/0x90
юли 25 19:36:34 vanrea kernel: ? asm_sysvec_apic_timer_interrupt+0x1a/0x20
юли 25 19:36:34 vanrea kernel: ? _raw_spin_unlock_irqrestore+0x1d/0x40
юли 25 19:36:34 vanrea kernel: bottom_half+0x132/0xe30 [r8152 569298d4d934a0eb18adbf69b42f09ac5c846006]
юли 25 19:36:34 vanrea kernel: ? __napi_poll+0x2b/0x1b0
юли 25 19:36:34 vanrea kernel: tasklet_action_common.isra.0+0xc3/0x230
юли 25 19:36:34 vanrea kernel: handle_softirqs+0xe5/0x2e0
юли 25 19:36:34 vanrea kernel: __irq_exit_rcu+0xa5/0xc0
юли 25 19:36:34 vanrea kernel: common_interrupt+0x86/0xa0
юли 25 19:36:34 vanrea kernel: </IRQ>
юли 25 19:36:34 vanrea kernel: <TASK>
юли 25 19:36:34 vanrea kernel: asm_common_interrupt+0x26/0x40
юли 25 19:36:34 vanrea kernel: RIP: 0010:cpuidle_enter_state+0xc6/0x430
юли 25 19:36:34 vanrea kernel: Code: 00 00 e8 5d b2 36 ff e8 b8 f3 ff ff 49 89 c5 0f 1f 44 00 00 31 ff e8 39 ae 35 ff 45 84 ff 0f 85 ae 01 00 00 fb 0f 1f 44 00 00 <45> 85 f6 0f 88 88 01 00 00 49 63 d6 48 8d 04>
юли 25 19:36:34 vanrea kernel: RSP: 0018:ffffc900001d7e90 EFLAGS: 00000246
юли 25 19:36:34 vanrea kernel: RAX: ffff8885f77b41c0 RBX: 0000000000000003 RCX: 0000000000000000
юли 25 19:36:34 vanrea kernel: RDX: 00000013aab4255e RSI: fffffffd0ead0fdd RDI: 0000000000000000
юли 25 19:36:34 vanrea kernel: RBP: ffff8881018f8c00 R08: 0000000000000002 R09: 0000000000000000
юли 25 19:36:34 vanrea kernel: R10: 0000000000000000 R11: 000000000000ffff R12: ffffffff9d74d6a0
юли 25 19:36:34 vanrea kernel: R13: 00000013aab4255e R14: 0000000000000003 R15: 0000000000000000
юли 25 19:36:34 vanrea kernel: cpuidle_enter+0x2d/0x40
юли 25 19:36:34 vanrea kernel: do_idle+0x1d8/0x230
юли 25 19:36:34 vanrea kernel: cpu_startup_entry+0x2a/0x30
юли 25 19:36:34 vanrea kernel: start_secondary+0x11e/0x140
юли 25 19:36:34 vanrea kernel: secondary_startup_64_no_verify+0x18f/0x19b
юли 25 19:36:34 vanrea kernel: </TASK>
юли 25 19:36:51 vanrea systemd[1]: libvirtd.service: Deactivated successfully.
юли 25 19:36:51 vanrea systemd[1]: libvirtd.service: Unit process 1166 (dnsmasq) remains running after unit stopped.
юли 25 19:36:51 vanrea systemd[1]: libvirtd.service: Unit process 1167 (dnsmasq) remains running after unit stopped.
юли 25 19:37:02 vanrea kernel: watchdog: BUG: soft lockup - CPU#6 stuck for 52s! [swapper/6:0]
юли 25 19:37:02 vanrea kernel: Modules linked in: rfcomm nft_masq nft_ct nft_reject_ipv4 nf_reject_ipv4 nft_reject nft_chain_nat nf_nat nf_conntrack nf_defrag_ipv6 nf_defrag_ipv4 nf_tables libcrc32c bridge stp>
юли 25 19:37:02 vanrea kernel: btintel uvc videobuf2_memops vfat snd_ump hp_wmi btbcm cryptd fat snd_hda_core snd_rawmidi videobuf2_v4l2 sparse_keymap btmtk rapl pcspkr platform_profile wmi_bmof acpi_cpufreq >
юли 25 19:37:02 vanrea kernel: CPU: 6 PID: 0 Comm: swapper/6 Tainted: G OEL 6.6.40-1-MANJARO #1 bfd252e6ed3e282536601509dfc356fb9d948bbf
юли 25 19:37:02 vanrea kernel: Hardware name: HP HP ProBook 455 G7/8730, BIOS S79 Ver. 01.16.00 02/02/2024
юли 25 19:37:02 vanrea kernel: RIP: 0010:netif_tx_unlock+0x31/0x50
юли 25 19:37:02 vanrea kernel: Code: 00 00 55 48 89 fd 53 8b 87 08 04 00 00 85 c0 74 2a 31 db 48 8d 3c 9b 48 c1 e7 06 48 03 bd 00 04 00 00 f0 80 a7 90 00 00 00 fb <e8> 8a 08 f9 ff 48 83 c3 01 3b 9d 08 04 00 00>
юли 25 19:37:02 vanrea kernel: RSP: 0018:ffffc90000360e68 EFLAGS: 00000202
юли 25 19:37:02 vanrea kernel: RAX: 0000000000000001 RBX: 0000000000000000 RCX: ffff8882822790e8
юли 25 19:37:02 vanrea kernel: RDX: 0000000000000001 RSI: 0000000000000008 RDI: ffff88810865e600
юли 25 19:37:02 vanrea kernel: RBP: ffff88810c6f4000 R08: ffff88810c6f4d00 R09: 0000000000000000
юли 25 19:37:02 vanrea kernel: R10: ffff888110c00000 R11: ffff888261abb2f0 R12: ffff88821f19b6e8
юли 25 19:37:02 vanrea kernel: R13: ffff88810c6f4e60 R14: ffff88810c6f4b70 R15: ffff88821f19b6e8
юли 25 19:37:02 vanrea kernel: FS: 0000000000000000(0000) GS:ffff8885f7780000(0000) knlGS:0000000000000000
юли 25 19:37:02 vanrea kernel: CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
юли 25 19:37:02 vanrea kernel: CR2: 00005586841e91a8 CR3: 00000003d6a20000 CR4: 0000000000350ee0
юли 25 19:37:02 vanrea kernel: Call Trace:
юли 25 19:37:02 vanrea kernel: <IRQ>
юли 25 19:37:02 vanrea kernel: ? watchdog_timer_fn+0x1b1/0x220
юли 25 19:37:02 vanrea kernel: ? __pfx_watchdog_timer_fn+0x10/0x10
юли 25 19:37:02 vanrea kernel: ? __hrtimer_run_queues+0x132/0x2a0
юли 25 19:37:02 vanrea kernel: ? hrtimer_interrupt+0xf8/0x230
юли 25 19:37:02 vanrea kernel: ? __sysvec_apic_timer_interrupt+0x4d/0x140
юли 25 19:37:02 vanrea kernel: ? sysvec_apic_timer_interrupt+0x39/0x90
юли 25 19:37:02 vanrea kernel: ? asm_sysvec_apic_timer_interrupt+0x1a/0x20
юли 25 19:37:02 vanrea kernel: ? netif_tx_unlock+0x31/0x50
юли 25 19:37:02 vanrea kernel: bottom_half+0x529/0xe30 [r8152 569298d4d934a0eb18adbf69b42f09ac5c846006]
юли 25 19:37:02 vanrea kernel: ? __napi_poll+0x2b/0x1b0
юли 25 19:37:02 vanrea kernel: tasklet_action_common.isra.0+0xc3/0x230
юли 25 19:37:02 vanrea kernel: handle_softirqs+0xe5/0x2e0
юли 25 19:37:02 vanrea kernel: __irq_exit_rcu+0xa5/0xc0
юли 25 19:37:02 vanrea kernel: common_interrupt+0x86/0xa0
юли 25 19:37:02 vanrea kernel: </IRQ>
юли 25 19:37:02 vanrea kernel: <TASK>
юли 25 19:37:02 vanrea kernel: asm_common_interrupt+0x26/0x40
юли 25 19:37:02 vanrea kernel: RIP: 0010:cpuidle_enter_state+0xc6/0x430
юли 25 19:37:02 vanrea kernel: Code: 00 00 e8 5d b2 36 ff e8 b8 f3 ff ff 49 89 c5 0f 1f 44 00 00 31 ff e8 39 ae 35 ff 45 84 ff 0f 85 ae 01 00 00 fb 0f 1f 44 00 00 <45> 85 f6 0f 88 88 01 00 00 49 63 d6 48 8d 04>
юли 25 19:37:02 vanrea kernel: RSP: 0018:ffffc900001d7e90 EFLAGS: 00000246
юли 25 19:37:02 vanrea kernel: RAX: ffff8885f77b41c0 RBX: 0000000000000003 RCX: 0000000000000000
юли 25 19:37:02 vanrea kernel: RDX: 00000013aab4255e RSI: fffffffd0ead0fdd RDI: 0000000000000000
юли 25 19:37:02 vanrea kernel: RBP: ffff8881018f8c00 R08: 0000000000000002 R09: 0000000000000000
юли 25 19:37:02 vanrea kernel: R10: 0000000000000000 R11: 000000000000ffff R12: ffffffff9d74d6a0
юли 25 19:37:02 vanrea kernel: R13: 00000013aab4255e R14: 0000000000000003 R15: 0000000000000000
юли 25 19:37:02 vanrea kernel: cpuidle_enter+0x2d/0x40
юли 25 19:37:02 vanrea kernel: do_idle+0x1d8/0x230
юли 25 19:37:02 vanrea kernel: cpu_startup_entry+0x2a/0x30
юли 25 19:37:02 vanrea kernel: start_secondary+0x11e/0x140
юли 25 19:37:02 vanrea kernel: secondary_startup_64_no_verify+0x18f/0x19b
юли 25 19:37:02 vanrea kernel: </TASK>
юли 25 19:37:06 vanrea kernel: rcu: INFO: rcu_preempt detected stalls on CPUs/tasks:
юли 25 19:37:06 vanrea kernel: rcu: 6-....: (1 GPs behind) idle=0c4c/1/0x4000000000000002 softirq=14062/14063 fqs=5212
юли 25 19:37:06 vanrea kernel: rcu: (detected by 5, t=18002 jiffies, g=22413, q=16931 ncpus=8)
юли 25 19:37:06 vanrea kernel: Sending NMI from CPU 5 to CPUs 6:
юли 25 19:37:06 vanrea kernel: NMI backtrace for cpu 6
юли 25 19:37:06 vanrea kernel: CPU: 6 PID: 0 Comm: swapper/6 Tainted: G OEL 6.6.40-1-MANJARO #1 bfd252e6ed3e282536601509dfc356fb9d948bbf
юли 25 19:37:06 vanrea kernel: Hardware name: HP HP ProBook 455 G7/8730, BIOS S79 Ver. 01.16.00 02/02/2024
юли 25 19:37:06 vanrea kernel: RIP: 0010:_raw_spin_unlock_irqrestore+0x1d/0x40
юли 25 19:37:06 vanrea kernel: Code: 90 90 90 90 90 90 90 90 90 90 90 90 90 f3 0f 1e fa 0f 1f 44 00 00 c6 07 00 0f 1f 00 f7 c6 00 02 00 00 74 06 fb 0f 1f 44 00 00 <65> ff 0d a4 25 a5 63 74 05 e9 d5 19 00 00 e8>
юли 25 19:37:06 vanrea kernel: RSP: 0018:ffffc90000360e78 EFLAGS: 00000206
юли 25 19:37:06 vanrea kernel: RAX: 0000000000000001 RBX: 0000000000000246 RCX: ffff8882822790e8
юли 25 19:37:06 vanrea kernel: RDX: ffff88810c6f4c78 RSI: 0000000000000246 RDI: ffff88810c6f4d44
юли 25 19:37:06 vanrea kernel: RBP: ffffc90000360f40 R08: ffff88810c6f4d00 R09: 0000000000000000
юли 25 19:37:06 vanrea kernel: R10: ffff888110c00000 R11: ffff888261abb2f0 R12: ffff88810c6f4c78
юли 25 19:37:06 vanrea kernel: R13: ffff88810c6f4e60 R14: ffff88810c6f4b70 R15: ffff88810c6f4d00
юли 25 19:37:06 vanrea kernel: FS: 0000000000000000(0000) GS:ffff8885f7780000(0000) knlGS:0000000000000000
юли 25 19:37:06 vanrea kernel: CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
юли 25 19:37:06 vanrea kernel: CR2: 00005586841e91a8 CR3: 00000003d6a20000 CR4: 0000000000350ee0
юли 25 19:37:06 vanrea kernel: Call Trace:
юли 25 19:37:06 vanrea kernel: <NMI>
юли 25 19:37:06 vanrea kernel: ? nmi_cpu_backtrace+0x9f/0x110
юли 25 19:37:06 vanrea kernel: ? nmi_cpu_backtrace_handler+0x11/0x20
юли 25 19:37:06 vanrea kernel: ? nmi_handle+0x61/0x150
юли 25 19:37:06 vanrea kernel: ? default_do_nmi+0x40/0x100
юли 25 19:37:06 vanrea kernel: ? exc_nmi+0x125/0x1a0
юли 25 19:37:06 vanrea kernel: ? end_repeat_nmi+0x16/0x67
юли 25 19:37:06 vanrea kernel: ? _raw_spin_unlock_irqrestore+0x1d/0x40
юли 25 19:37:06 vanrea kernel: </NMI>
юли 25 19:37:06 vanrea kernel: <IRQ>
юли 25 19:37:06 vanrea kernel: bottom_half+0x807/0xe30 [r8152 569298d4d934a0eb18adbf69b42f09ac5c846006]
юли 25 19:37:06 vanrea kernel: ? __napi_poll+0x2b/0x1b0
юли 25 19:37:06 vanrea kernel: tasklet_action_common.isra.0+0xc3/0x230
юли 25 19:37:06 vanrea kernel: handle_softirqs+0xe5/0x2e0
юли 25 19:37:06 vanrea kernel: __irq_exit_rcu+0xa5/0xc0
юли 25 19:37:06 vanrea kernel: common_interrupt+0x86/0xa0
юли 25 19:37:06 vanrea kernel: </IRQ>
юли 25 19:37:06 vanrea kernel: <TASK>
юли 25 19:37:06 vanrea kernel: asm_common_interrupt+0x26/0x40
юли 25 19:37:06 vanrea kernel: RIP: 0010:cpuidle_enter_state+0xc6/0x430
юли 25 19:37:06 vanrea kernel: Code: 00 00 e8 5d b2 36 ff e8 b8 f3 ff ff 49 89 c5 0f 1f 44 00 00 31 ff e8 39 ae 35 ff 45 84 ff 0f 85 ae 01 00 00 fb 0f 1f 44 00 00 <45> 85 f6 0f 88 88 01 00 00 49 63 d6 48 8d 04>
юли 25 19:37:06 vanrea kernel: RSP: 0018:ffffc900001d7e90 EFLAGS: 00000246
юли 25 19:37:06 vanrea kernel: RAX: ffff8885f77b41c0 RBX: 0000000000000003 RCX: 0000000000000000
юли 25 19:37:06 vanrea kernel: RDX: 00000013aab4255e RSI: fffffffd0ead0fdd RDI: 0000000000000000
юли 25 19:37:06 vanrea kernel: RBP: ffff8881018f8c00 R08: 0000000000000002 R09: 0000000000000000
юли 25 19:37:06 vanrea kernel: R10: 0000000000000000 R11: 000000000000ffff R12: ffffffff9d74d6a0
юли 25 19:37:06 vanrea kernel: R13: 00000013aab4255e R14: 0000000000000003 R15: 0000000000000000
юли 25 19:37:06 vanrea kernel: cpuidle_enter+0x2d/0x40
юли 25 19:37:06 vanrea kernel: do_idle+0x1d8/0x230
юли 25 19:37:06 vanrea kernel: cpu_startup_entry+0x2a/0x30
юли 25 19:37:06 vanrea kernel: start_secondary+0x11e/0x140
юли 25 19:37:06 vanrea kernel: secondary_startup_64_no_verify+0x18f/0x19b
юли 25 19:37:06 vanrea kernel: </TASK>
юли 25 19:37:34 vanrea kernel: watchdog: BUG: soft lockup - CPU#6 stuck for 82s! [swapper/6:0]
юли 25 19:37:34 vanrea kernel: Modules linked in: rfcomm nft_masq nft_ct nft_reject_ipv4 nf_reject_ipv4 nft_reject nft_chain_nat nf_nat nf_conntrack nf_defrag_ipv6 nf_defrag_ipv4 nf_tables libcrc32c bridge stp>
юли 25 19:37:34 vanrea kernel: btintel uvc videobuf2_memops vfat snd_ump hp_wmi btbcm cryptd fat snd_hda_core snd_rawmidi videobuf2_v4l2 sparse_keymap btmtk rapl pcspkr platform_profile wmi_bmof acpi_cpufreq >
юли 25 19:37:34 vanrea kernel: CPU: 6 PID: 0 Comm: swapper/6 Tainted: G OEL 6.6.40-1-MANJARO #1 bfd252e6ed3e282536601509dfc356fb9d948bbf
юли 25 19:37:34 vanrea kernel: Hardware name: HP HP ProBook 455 G7/8730, BIOS S79 Ver. 01.16.00 02/02/2024
юли 25 19:37:34 vanrea kernel: RIP: 0010:memset_orig+0x30/0xb0
юли 25 19:37:34 vanrea kernel: Code: fa 40 0f b6 ce 48 b8 01 01 01 01 01 01 01 01 48 0f af c1 41 89 f9 41 83 e1 07 75 70 48 89 d1 48 c1 e9 06 74 35 0f 1f 44 00 00 <48> ff c9 48 89 07 48 89 47 08 48 89 47 10 48>
юли 25 19:37:34 vanrea kernel: RSP: 0018:ffffc90000360e68 EFLAGS: 00000213
юли 25 19:37:34 vanrea kernel: RAX: 0000000000000000 RBX: 0000000000000011 RCX: 0000000000000008
юли 25 19:37:34 vanrea kernel: RDX: 0000000000000220 RSI: 0000000000000000 RDI: ffff88811ad8c000
The things I have tried so far are:
- Recompiling all packages listed by pacman -Qoq /usr/lib/python3.11/.
- Reverting to qBittorrent version 4.6.4-1. Unfortunately, neither of these steps helped.
