Lets put inxi -eza here first:
inxi -eza
Kernel: 6.6.103-3-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
root=UUID=564935af-3006-485e-9671-c9597f5e97b2 rw udev.log_priority=3
Desktop: KDE Plasma v: 6.3.6 tk: Qt v: N/A info: frameworks v: 6.17.0
Type: Desktop System: ASUS product: All Series v: N/A
serial: <superuser required>
Mobo: ASUSTeK model: Z87-A v: Rev 1.xx serial: <superuser required>
part-nu: All uuid: <superuser required> UEFI: American Megatrends v: 2103
date: 08/15/2014
Info: model: Intel Core i7-4770K bits: 64 type: MT MCP arch: Haswell
gen: core 4 level: v3 note: check built: 2013-15 process: Intel 22nm
family: 6 model-id: 0x3C (60) stepping: 3 microcode: 0x28
Topology: cpus: 1x dies: 1 clusters: 4 cores: 4 threads: 8 tpc: 2
smt: enabled cache: L1: 256 KiB desc: d-4x32 KiB; i-4x32 KiB L2: 1024 KiB
desc: 4x256 KiB L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 800 min/max: 800/3900 scaling: driver: intel_cpufreq
governor: schedutil cores: 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800 7: 800
8: 800 bogomips: 56025
Flags-basic: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3
Type: itlb_multihit status: KVM: VMX unsupported
STIBP: conditional; RSB filling; PBRSB-eIBRS: Not affected; BHI: Not
affected
Device-1: NVIDIA GP104 [GeForce GTX 1070 Ti] vendor: ASUSTeK driver: nvidia
v: 575.64.05 alternate: nouveau,nvidia_drm non-free: 550-580.xx+
status: current (as of 2025-08; EOL~2026-12-xx) arch: Pascal code: GP10x
process: TSMC 16nm built: 2016-2021 pcie: gen: 3 speed: 8 GT/s lanes: 16
ports: active: none off: HDMI-A-2 empty: DP-1, DP-2, DVI-D-1, HDMI-A-1
bus-ID: 01:00.0 chip-ID: 10de:1b82 class-ID: 0300
compositor: kwin_wayland driver: X: loaded: nvidia
gpu: nvidia,nvidia-nvswitch display-ID: 0
Monitor-1: HDMI-A-2 model: Samsung T24D390 built: 2013 res:
mode: 1920x1080 hz: 60 scale: 100% (1) dpi: 94 gamma: 1.2
size: 521x293mm (20.51x11.54") diag: 598mm (23.5") ratio: 16:9 modes:
max: 1920x1080 min: 640x480
API: EGL v: 1.5 hw: drv: nvidia platforms: device: 0 drv: nvidia device: 2
drv: swrast gbm: drv: nvidia surfaceless: drv: nvidia wayland: drv: nvidia
x11: drv: nvidia inactive: device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 575.64.05
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce GTX 1070 Ti/PCIe/SSE2
memory: 7.81 GiB display-ID: :1.0
API: Vulkan v: 1.4.321 layers: 7 device: 0 type: discrete-gpu name: NVIDIA
GeForce GTX 1070 Ti driver: nvidia v: 575.64.05 device-ID: 10de:1b82
surfaces: N/A
Device-1: Intel 8 Series/C220 Series High Definition Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:8c20
class-ID: 0403
Device-2: NVIDIA GP104 High Definition Audio vendor: ASUSTeK
bus-ID: 01:00.1 chip-ID: 10de:10f0 class-ID: 0403
API: ALSA v: k6.6.103-3-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.4.7 status: active with: 1: pipewire-pulse
vendor: ASUSTeK AM1I-A driver: r8168 v: 8.055.00-NAPI modules: r8169 pcie:
gen: 1 speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 03:00.0
Device-2: TP-Link Archer T9UH v1 [Realtek RTL8814AU] driver: rtl8814au
type: USB rev: 3.0 speed: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 bus-ID: 4-5:2
chip-ID: 2357:0106 class-ID: 0000 serial: <filter>
IF: wlp0s20u5 state: up mac: <filter>
Local Storage: total: 2.96 TiB used: 489.06 GiB (16.2%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 840 EVO 250GB
size: 232.89 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: BB6Q scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Toshiba model: DT01ACA300
size: 2.73 TiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
tech: HDD rpm: 7200 serial: <filter> fw-rev: ABB0 scheme: GPT
ID-1: / raw-size: 78.12 GiB size: 76.35 GiB (97.73%) used: 24.64 GiB (32.3%)
fs: ext4 dev: /dev/sdb1 maj-min: 8:17
ID-2: /boot/efi raw-size: 350 MiB size: 346 MiB (98.86%)
used: 26 MiB (7.5%) fs: vfat dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 511 GiB size: 511 GiB (100.00%)
used: 464.4 GiB (90.9%) fs: btrfs dev: /dev/sdb5 maj-min: 8:21
ID-1: swap-1 type: partition size: 2 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sdb3 maj-min: 8:19
System Temperatures: cpu: 42.0 C mobo: N/A
Fan Speeds (rpm): N/A
Memory: total: 16 GiB available: 15.56 GiB used: 6.3 GiB (40.5%)
Processes: 351 Power: uptime: 1h 58m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 6.15 GiB services: org_kde_powerdevil,
tool: systemctl
Packages: 1525 pm: pacman pkgs: 1510 libs: 406 tools: pamac pm: flatpak
pkgs: 15 Compilers: clang: 20.1.8 gcc: 15.2.1 Shell: Zsh v: 5.9
running-in: konsole inxi: 3.3.39
So, I found I had need for FFmpeg. I didn’t realize it was already installed, so when I used sudo pacman -Syu ffmpeg I did the mistake of not properly reading what was printed on screen by pacman. I thought the codecs were just part and parcel of installing FFmpeg. So I got vivaldi-ffmpeg-codecs installed.
That’s when I started getting this list of errors when starting Vivaldi from CLI:
First error list
[0919/135305.589947:ERROR:chromium/third_party/crashpad/crashpad/snapshot/elf/elf_dynamic_array_reader.h:64] tag not found
[0919/135305.602603:ERROR:chromium/third_party/crashpad/crashpad/util/file/directory_reader_posix.cc:43] opendir /home/ilkka/.config/vivaldi/Crash Reports/attachments/1d5671d1-1e0d-4f2e-9ea9-c92f288f0455: No such file or directory (2)
[26329:26329:0919/135306.405240:ERROR:chromium/content/browser/gpu/gpu_process_host.cc:966] GPU process exited unexpectedly: exit_code=139
[0919/135306.520571:ERROR:chromium/third_party/crashpad/crashpad/snapshot/elf/elf_dynamic_array_reader.h:64] tag not found
[0919/135306.528427:ERROR:chromium/third_party/crashpad/crashpad/util/file/directory_reader_posix.cc:43] opendir /home/ilkka/.config/vivaldi/Crash Reports/attachments/740916e4-07b1-47d8-bc13-5d444b2e6bb6: No such file or directory (2)
[26329:26329:0919/135307.073362:ERROR:chromium/content/browser/gpu/gpu_process_host.cc:966] GPU process exited unexpectedly: exit_code=139
[0919/135307.193145:ERROR:chromium/third_party/crashpad/crashpad/snapshot/elf/elf_dynamic_array_reader.h:64] tag not found
[0919/135307.201157:ERROR:chromium/third_party/crashpad/crashpad/util/file/directory_reader_posix.cc:43] opendir /home/ilkka/.config/vivaldi/Crash Reports/attachments/8f9a1302-fc34-4a91-baad-33ea99a1d588: No such file or directory (2)
[26329:26329:0919/135307.744361:ERROR:chromium/content/browser/gpu/gpu_process_host.cc:966] GPU process exited unexpectedly: exit_code=139
[0919/135307.751012:ERROR:chromium/third_party/crashpad/crashpad/snapshot/elf/elf_dynamic_array_reader.h:64] tag not found
[0919/135307.756169:ERROR:chromium/third_party/crashpad/crashpad/util/file/directory_reader_posix.cc:43] opendir /home/ilkka/.config/vivaldi/Crash Reports/attachments/a84ce512-7b8e-4d79-8a5c-e66095d2ebe4: No such file or directory (2)
[26329:26329:0919/135308.067781:ERROR:chromium/content/browser/gpu/gpu_process_host.cc:966] GPU process exited unexpectedly: exit_code=139
[0919/135308.074329:ERROR:chromium/third_party/crashpad/crashpad/snapshot/elf/elf_dynamic_array_reader.h:64] tag not found
[0919/135308.079477:ERROR:chromium/third_party/crashpad/crashpad/util/file/directory_reader_posix.cc:43] opendir /home/ilkka/.config/vivaldi/Crash Reports/attachments/9dc1c22d-6abe-4035-9087-c59931d85cef: No such file or directory (2)
[26329:26329:0919/135308.399479:ERROR:chromium/content/browser/gpu/gpu_process_host.cc:966] GPU process exited unexpectedly: exit_code=139
[0919/135308.405759:ERROR:chromium/third_party/crashpad/crashpad/snapshot/elf/elf_dynamic_array_reader.h:64] tag not found
[0919/135308.410875:ERROR:chromium/third_party/crashpad/crashpad/util/file/directory_reader_posix.cc:43] opendir /home/ilkka/.config/vivaldi/Crash Reports/attachments/e6545200-3fb3-4db2-8e8b-b6d372d04492: No such file or directory (2)
[26329:26329:0919/135309.359083:ERROR:chromium/content/browser/gpu/gpu_process_host.cc:966] GPU process exited unexpectedly: exit_code=139
[26329:26329:0919/135309.359096:FATAL:chromium/content/browser/gpu/gpu_data_manager_impl_private.cc:415] GPU process isn't usable. Goodbye.
[0919/135309.362024:ERROR:chromium/third_party/crashpad/crashpad/snapshot/elf/elf_dynamic_array_reader.h:64] tag not found
[0919/135309.366204:ERROR:chromium/third_party/crashpad/crashpad/snapshot/elf/elf_dynamic_array_reader.h:64] tag not found
[0919/135309.366902:ERROR:chromium/third_party/crashpad/crashpad/snapshot/elf/elf_dynamic_array_reader.h:64] tag not found
[0919/135309.367015:ERROR:chromium/third_party/crashpad/crashpad/snapshot/elf/elf_dynamic_array_reader.h:64] tag not found
[0919/135309.367101:ERROR:chromium/third_party/crashpad/crashpad/snapshot/elf/elf_dynamic_array_reader.h:64] tag not found
[0919/135309.369990:ERROR:chromium/third_party/crashpad/crashpad/snapshot/elf/elf_dynamic_array_reader.h:64] tag not found
[0919/135309.371097:ERROR:chromium/third_party/crashpad/crashpad/snapshot/elf/elf_dynamic_array_reader.h:64] tag not found
[0919/135309.371218:ERROR:chromium/third_party/crashpad/crashpad/snapshot/elf/elf_dynamic_array_reader.h:64] tag not found
[0919/135309.371488:ERROR:chromium/third_party/crashpad/crashpad/snapshot/elf/elf_dynamic_array_reader.h:64] tag not found
[0919/135309.371833:ERROR:chromium/third_party/crashpad/crashpad/util/process/process_memory_range.cc:75] read out of range
[0919/135309.371842:ERROR:chromium/third_party/crashpad/crashpad/util/process/process_memory_range.cc:75] read out of range
[0919/135309.376918:ERROR:chromium/third_party/crashpad/crashpad/util/process/process_memory_range.cc:75] read out of range
[0919/135309.376937:ERROR:chromium/third_party/crashpad/crashpad/util/process/process_memory_range.cc:75] read out of range
[0919/135309.376947:ERROR:chromium/third_party/crashpad/crashpad/util/process/process_memory_range.cc:75] read out of range
[0919/135309.376954:ERROR:chromium/third_party/crashpad/crashpad/util/process/process_memory_range.cc:75] read out of range
[0919/135309.381159:ERROR:chromium/third_party/crashpad/crashpad/util/file/directory_reader_posix.cc:43] opendir /home/ilkka/.config/vivaldi/Crash Reports/attachments/0604358d-51e0-489f-94b7-e80f51a124ae: No such file or directory (2)
[1] 26329 trace trap (core dumped)
What I’ve tried:
- I uninstalled vivaldi-ffmpeg-codecs
- I reinstalled Vivaldi
- I reinstalled vivaldi-ffmpeg-codecs
- I uninstalled both, purged the cache with
pacman -Sccand reinstalled first Vivaldi, then the codecs after trying to start - Tried
vivaldi --disable-gpu - Sudoed Vivaldi and got
'sudo vivaldi' errors
'Proprietary media' support is not installed. Attempting to fix this now.
Downloading...
Proprietary media codecs (120726) has been installed (PLEASE RESTART VIVALDI)
[17879:17879:0919/131145.861363:ERROR:chromium/content/browser/zygote_host/zygote_host_impl_linux.cc:110] Running as root without --no-sandbox is not supported. See https://crbug.com/638180.
- Tried sudoing with
--no-sandboxwhich resulted in:
'sudo vivaldi --no-sandbox' errors
QStandardPaths: XDG_RUNTIME_DIR not set, defaulting to '/tmp/runtime-root'
[18462:18482:0919/131222.293434:ERROR:chromium/dbus/bus.cc:408] Failed to connect to the bus: Could not parse server address
: Unknown address type (examples of valid types are "tcp" and on UNIX "unix")
Authorization required, but no authorization protocol specified
[18462:18462:0919/131222.329186:ERROR:chromium/dbus/bus.cc:408] Failed to connect to the bus: Could not parse server address
[18462:18462:0919/131222.329197:ERROR:chromium/components/os_crypt/sync/kwallet_dbus.cc:113] Error contacting kwalletd (isEn
abled)
[18462:18462:0919/131222.329229:ERROR:chromium/dbus/bus.cc:408] Failed to connect to the bus: Could not parse server address
[18462:18462:0919/131222.329238:ERROR:chromium/components/os_crypt/sync/kwallet_dbus.cc:82] Error contacting klauncher to st
art kwalletd
[18462:18462:0919/131222.329276:ERROR:chromium/dbus/bus.cc:408] Failed to connect to the bus: Could not parse server address
[18462:18462:0919/131222.329281:ERROR:chromium/components/os_crypt/sync/kwallet_dbus.cc:408] Error contacting kwalletd (clos
e)
[18462:18462:0919/131222.330292:ERROR:components/search_engines/search_engines_managers_factory.cc:78] File can't be read: /
root/.config/vivaldi/search_engines.json
[18462:18462:0919/131222.331626:ERROR:components/search_engines/search_engines_managers_factory.cc:78] File can't be read: /
root/.config/vivaldi/search_engines_prompt.json
[18462:18482:0919/131222.345173:ERROR:chromium/dbus/bus.cc:408] Failed to connect to the bus: Could not parse server address
pci id for fd 25: 10de:1b82, driver (null)
kmsro: driver missing
[18462:18482:0919/131222.497615:ERROR:chromium/dbus/bus.cc:408] Failed to connect to the bus: Could not parse server address
[18462:18462:0919/131222.500186:ERROR:chromium/dbus/object_proxy.cc:573] Failed to call method: org.freedesktop.DBus.NameHas
Owner: object_path= /org/freedesktop/DBus: unknown error type:
[18462:18482:0919/131222.500237:ERROR:chromium/dbus/bus.cc:408] Failed to connect to the bus: Could not parse server address
[18462:18482:0919/131222.500247:ERROR:chromium/dbus/bus.cc:408] Failed to connect to the bus: Could not parse server address
[18462:18482:0919/131222.500254:ERROR:chromium/dbus/bus.cc:408] Failed to connect to the bus: Could not parse server address
[18462:18482:0919/131222.500259:ERROR:chromium/dbus/bus.cc:408] Failed to connect to the bus: Could not parse server address
[18462:18482:0919/131222.500278:ERROR:chromium/dbus/bus.cc:408] Failed to connect to the bus: Could not parse server address
[18462:18462:0919/131222.502697:ERROR:chromium/dbus/object_proxy.cc:573] Failed to call method: org.freedesktop.DBus.NameHas
[18462:18462:0919/131222.523386:ERROR:chromium/dbus/object_proxy.cc:573] Failed to call method: org.freedesktop.DBus.NameHas
[18462:18482:0919/131222.523457:ERROR:chromium/dbus/bus.cc:408] Failed to connect to the bus: Could not parse server address
[18462:18462:0919/131222.523805:ERROR:chromium/dbus/object_proxy.cc:573] Failed to call method: org.freedesktop.DBus.NameHas
[18462:18462:0919/131222.523849:ERROR:chromium/dbus/object_proxy.cc:573] Failed to call method: org.freedesktop.DBus.NameHas
[18462:18462:0919/131222.530995:ERROR:chromium/dbus/object_proxy.cc:573] Failed to call method: org.freedesktop.DBus.NameHas
[18462:18482:0919/131222.531064:ERROR:chromium/dbus/bus.cc:408] Failed to connect to the bus: Could not parse server address
[18462:18462:0919/131222.536585:ERROR:chromium/dbus/object_proxy.cc:573] Failed to call method: org.freedesktop.DBus.NameHas
[18462:18482:0919/131222.536644:ERROR:chromium/dbus/bus.cc:408] Failed to connect to the bus: Could not parse server address
[18462:18462:0919/131222.540477:ERROR:chromium/dbus/object_proxy.cc:573] Failed to call method: org.freedesktop.DBus.NameHas
[18462:18482:0919/131222.540566:ERROR:chromium/dbus/bus.cc:408] Failed to connect to the bus: Could not parse server address
[18462:18462:0919/131222.543805:ERROR:chromium/dbus/object_proxy.cc:573] Failed to call method: org.freedesktop.DBus.NameHas
[18502:18502:0919/131222.739787:ERROR:chromium/ui/gl/angle_platform_impl.cc:42] Display.cpp:1089 (initialize): ANGLE Display
::initialize error 12289: Could not open the default X display.
ERR: Display.cpp:1089 (initialize): ANGLE Display::initialize error 12289: Could not open the default X display.
[18502:18502:0919/131222.739952:ERROR:chromium/ui/gl/egl_util.cc:92] EGL Driver message (Critical) eglInitialize: Could not
[18502:18502:0919/131222.740032:ERROR:chromium/ui/gl/gl_display.cc:640] eglInitialize OpenGL failed with error EGL_NOT_INITI
ALIZED, trying next display type
[18502:18502:0919/131222.740215:ERROR:chromium/ui/gl/angle_platform_impl.cc:42] Display.cpp:1089 (initialize): ANGLE Display
[18502:18502:0919/131222.740267:ERROR:chromium/ui/gl/egl_util.cc:92] EGL Driver message (Critical) eglInitialize: Could not
[18502:18502:0919/131222.740303:ERROR:chromium/ui/gl/gl_display.cc:640] eglInitialize OpenGLES failed with error EGL_NOT_INI
TIALIZED
[18502:18502:0919/131222.740336:ERROR:chromium/ui/gl/gl_display.cc:675] Initialization of all EGL display types failed.
[18502:18502:0919/131222.740367:ERROR:chromium/ui/ozone/common/gl_ozone_egl.cc:26] GLDisplayEGL::Initialize failed.
[18502:18502:0919/131222.820642:ERROR:chromium/ui/gl/angle_platform_impl.cc:42] Display.cpp:1089 (initialize): ANGLE Display
[18502:18502:0919/131222.820766:ERROR:chromium/ui/gl/egl_util.cc:92] EGL Driver message (Critical) eglInitialize: Could not
[18502:18502:0919/131222.820825:ERROR:chromium/ui/gl/gl_display.cc:640] eglInitialize OpenGL failed with error EGL_NOT_INITI
[18502:18502:0919/131222.820966:ERROR:chromium/ui/gl/angle_platform_impl.cc:42] Display.cpp:1089 (initialize): ANGLE Display
[18502:18502:0919/131222.821004:ERROR:chromium/ui/gl/egl_util.cc:92] EGL Driver message (Critical) eglInitialize: Could not
[18502:18502:0919/131222.821030:ERROR:chromium/ui/gl/gl_display.cc:640] eglInitialize OpenGLES failed with error EGL_NOT_INI
TIALIZED
[18502:18502:0919/131222.821057:ERROR:chromium/ui/gl/gl_display.cc:675] Initialization of all EGL display types failed.
[18502:18502:0919/131222.821081:ERROR:chromium/ui/ozone/common/gl_ozone_egl.cc:26] GLDisplayEGL::Initialize failed.
[18502:18502:0919/131222.822224:ERROR:chromium/components/viz/service/main/viz_main_impl.cc:189] Exiting GPU process due to
errors during initialization
[18601:18601:0919/131222.947023:ERROR:chromium/ui/gl/angle_platform_impl.cc:42] DisplayVkXcb.cpp:58 (initialize): xcb_connec
t() failed, error 1
ERR: DisplayVkXcb.cpp:58 (initialize): xcb_connect() failed, error 1
[18601:18601:0919/131222.947130:ERROR:chromium/ui/gl/angle_platform_impl.cc:42] Display.cpp:1089 (initialize): ANGLE Display
::initialize error 0: Not initialized.
ERR: Display.cpp:1089 (initialize): ANGLE Display::initialize error 0: Not initialized.
[18601:18601:0919/131222.947213:ERROR:chromium/ui/gl/egl_util.cc:92] EGL Driver message (Critical) eglInitialize: Not initia
lized.
[18601:18601:0919/131222.947275:ERROR:chromium/ui/gl/gl_display.cc:640] eglInitialize SwANGLE failed with error EGL_NOT_INIT
IALIZED
[18601:18601:0919/131222.947321:ERROR:chromium/ui/gl/gl_display.cc:675] Initialization of all EGL display types failed.
[18601:18601:0919/131222.947353:ERROR:chromium/ui/ozone/common/gl_ozone_egl.cc:26] GLDisplayEGL::Initialize failed.
[18601:18601:0919/131223.029674:ERROR:chromium/ui/gl/angle_platform_impl.cc:42] DisplayVkXcb.cpp:58 (initialize): xcb_connec
t() failed, error 1
[18601:18601:0919/131223.029794:ERROR:chromium/ui/gl/angle_platform_impl.cc:42] Display.cpp:1089 (initialize): ANGLE Display
[18601:18601:0919/131223.029868:ERROR:chromium/ui/gl/egl_util.cc:92] EGL Driver message (Critical) eglInitialize: Not initia
lized.
[18601:18601:0919/131223.029925:ERROR:chromium/ui/gl/gl_display.cc:640] eglInitialize SwANGLE failed with error EGL_NOT_INIT
IALIZED
[18601:18601:0919/131223.030004:ERROR:chromium/ui/gl/gl_display.cc:675] Initialization of all EGL display types failed.
[18601:18601:0919/131223.030093:ERROR:chromium/ui/ozone/common/gl_ozone_egl.cc:26] GLDisplayEGL::Initialize failed.
[18601:18601:0919/131223.031120:ERROR:chromium/components/viz/service/main/viz_main_impl.cc:189] Exiting GPU process due to
[18610:18617:0919/131223.041256:ERROR:chromium/ui/base/x/x11_software_bitmap_presenter.cc:147] XGetWindowAttributes failed f
or window 16777220
[18462:18485:0919/131226.218332:ERROR:chromium/google_apis/gcm/engine/registration_request.cc:291] Registration response err
or message: DEPRECATED_ENDPOINT
[18462:18485:0919/131248.531930:ERROR:chromium/google_apis/gcm/engine/registration_request.cc:291] Registration response err
[18462:18485:0919/131331.075366:ERROR:chromium/google_apis/gcm/engine/registration_request.cc:291] Registration response err
^C
[18462:18485:0919/131454.594385:ERROR:chromium/google_apis/gcm/engine/registration_request.cc:291] Registration response err
[1] 18459 trace trap sudo vivaldi --no-sandbox
- Found out there is no
./chromium/under~/.config/vivaldi/ - Found out there is no
~/.config/chromium/third_party/either. - Also found the lack of
~/.config/chromium/content/too - Installed Chromium browser just to see if it’d do anything. It didn’t.
I’m out of ideas.
