Hi j8a,
thank you for your message!
See the following commands:
~ inxi -v8azy ✔ pynput-env
Kernel: 6.12.38-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.1.1
root=UUID=319bf7d3-8a5c-4792-8db7-4df6981a2bbc rw quiet splash apparmor=1
security=apparmor resume=UUID=fc9e3ee8-7dee-416a-a1ec-e6d6b877967c
udev.log_priority=3 nvidia-drm.modeset=1
Desktop: GNOME v: 48.3 tk: GTK v: 3.24.49 wm: gnome-shell
tools: gsd-screensaver-proxy dm: GDM v: 48.0 Distro: Manjaro base: Arch Linux
Mobo: ASUSTeK model: ROG CROSSHAIR VIII DARK HERO v: Rev X.0x
UEFI: American Megatrends v: 4805 date: 03/18/2024
System RAM: total: 64 GiB available: 62.7 GiB used: 12.22 GiB (19.5%)
Device-1: DIMM_A1 type: DDR4 detail: synchronous unbuffered (unregistered)
size: 16 GiB speed: 2666 MT/s volts: note: check curr: 1 min: 1 max: 1
width (bits): data: 64 total: 64 manufacturer: Corsair
part-no: CMD32GX4M2C3200C16 serial: N/A
Device-2: DIMM_A2 type: DDR4 detail: synchronous unbuffered (unregistered)
part-no: CMD32GX4M2B3000C15 serial: N/A
Device-3: DIMM_B1 type: DDR4 detail: synchronous unbuffered (unregistered)
Device-4: DIMM_B2 type: DDR4 detail: synchronous unbuffered (unregistered)
Info: model: AMD Ryzen 9 5950X bits: 64 type: MT MCP arch: Zen 3+ gen: 3
model-id: 0x21 (33) stepping: 0 microcode: 0xA20102E
Topology: cpus: 1x dies: 1 clusters: 1 cores: 16 threads: 32 tpc: 2
smt: enabled cache: L1: 1024 KiB desc: d-16x32 KiB; i-16x32 KiB L2: 8 MiB
desc: 16x512 KiB L3: 64 MiB desc: 2x32 MiB
Speed (MHz): avg: 3817 min/max: 550/5084 boost: enabled scaling:
driver: amd-pstate-epp governor: performance cores: 1: 3817 2: 3817 3: 3817
4: 3817 5: 3817 6: 3817 7: 3817 8: 3817 9: 3817 10: 3817 11: 3817 12: 3817
13: 3817 14: 3817 15: 3817 16: 3817 17: 3817 18: 3817 19: 3817 20: 3817
21: 3817 22: 3817 23: 3817 24: 3817 25: 3817 26: 3817 27: 3817 28: 3817
29: 3817 30: 3817 31: 3817 32: 3817 bogomips: 217670
cqm_occup_llc cr8_legacy cx16 cx8 de debug_swap decodeassists erms extapic
extd_apicid f16c flushbyasid fma fpu fsgsbase fsrm fxsr fxsr_opt ht
hw_pstate ibpb ibrs ibs invpcid irperf lahf_lm lbrv lm mba mca mce
pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pku pni popcnt
pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni
skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor
svm svm_lock syscall tce topoext tsc tsc_scale umip user_shstk v_spec_ctrl
v_vmsave_vmload vaes vgif vmcb_clean vme vmmcall vpclmulqdq wbnoinvd wdt
x2apic xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves xtopology
affected
Device-1: NVIDIA AD102 [GeForce RTX 4090] vendor: ZOTAC driver: nvidia
v: 575.64.03 alternate: nouveau,nvidia_drm non-free: 550-570.xx+
status: current (as of 2025-04) arch: Lovelace code: AD1xx
process: TSMC n4 (5nm) built: 2022+ pcie: gen: 1 speed: 2.5 GT/s lanes: 16
link-max: gen: 4 speed: 16 GT/s ports: active: none off: DP-1,DP-2,DP-3
empty: HDMI-A-1 bus-ID: 0c:00.0 chip-ID: 10de:2684 class-ID: 0300
Device-2: Logitech Webcam C930e driver: snd-usb-audio,uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 5-3.1:4
chip-ID: 046d:0843 class-ID: 0102 serial: <filter>
compositor: gnome-shell driver: X: loaded: nvidia gpu: nvidia,nvidia-nvswitch
display-ID: 0
Monitor-1: DP-1 model: Philips PHL 329P1 serial: <filter> built: 2022
res: 3840x2160 dpi: 140 gamma: 1.2 chroma: red: x: 0.682 y: 0.314 green:
x: 0.286 y: 0.659 blue: x: 0.153 y: 0.039 white: x: 0.314 y: 0.329
size: 697x392mm (27.44x15.43") diag: 800mm (31.5") ratio: 16:9
modes: 3840x2160, 1920x2160, 2560x1440, 1920x1080, 1680x1050, 1280x1024,
1440x900, 1280x960, 1280x720, 1024x768, 800x600, 720x576, 720x480, 640x480
Monitor-2: DP-2 model: Gigabyte AORUS FO32U2P serial: <filter> built: 2024
res: 3840x2160 dpi: 141 gamma: 1.2 chroma: red: x: 0.686 y: 0.306 green:
x: 0.243 y: 0.710 blue: x: 0.141 y: 0.055 white: x: 0.314 y: 0.329
size: 699x395mm (27.52x15.55") diag: 793mm (31.2") ratio: 16:9
modes: 3840x2160, 2560x1440, 1920x1080, 1680x1050, 1600x900, 1280x1024,
1440x900, 1280x960, 1280x800, 1152x864, 1280x720, 1024x768, 1440x480,
800x600, 720x480, 640x480
EDID-Warnings: 1: parse_edid: unhandled CEA mode 97 2: parse_edid:
unhandled CEA mode 117 3: parse_edid: unhandled CEA mode 118 4: parse_edid:
unhandled CEA mode 94 5: parse_edid: unhandled CEA mode 95 6: parse_edid:
unhandled CEA mode 96 7: parse_edid: unknown tag 112
Monitor-3: DP-3 model: Acer XV322QK KV serial: <filter> built: 2022
res: 3840x2160 dpi: 140 gamma: 1.2 chroma: red: x: 0.678 y: 0.314 green:
x: 0.271 y: 0.627 blue: x: 0.145 y: 0.051 white: x: 0.314 y: 0.329
modes: 3840x2160, 2560x1440, 1920x1080, 1680x1050, 1280x1024, 1440x900,
1280x960, 1152x864, 1280x720, 1024x768, 800x600, 720x576, 720x480, 640x480
unhandled CEA mode 118 3: parse_edid: unknown tag 112
API: EGL v: 1.5 hw: drv: nvidia platforms: device: 0 drv: nvidia device: 2
drv: swrast gbm: drv: nvidia surfaceless: drv: nvidia wayland: drv: nvidia
x11: drv: nvidia inactive: device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 575.64.03
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 4090/PCIe/SSE2
memory: 23.43 GiB display-ID: :0.0
API: Vulkan v: 1.4.313 layers: 6 device: 0 type: discrete-gpu
name: NVIDIA GeForce RTX 4090 driver: nvidia v: 575.64.03
device-ID: 10de:2684 surfaces: N/A
Info: Tools: api: eglinfo, glxinfo, vulkaninfo
gpu: nvidia-settings,nvidia-smi x11: xprop,xrandr
Device-1: NVIDIA AD102 High Definition Audio vendor: ZOTAC
bus-ID: 0c:00.1 chip-ID: 10de:22ba class-ID: 0403
vendor: ASUSTeK driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s
lanes: 16 bus-ID: 0e:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: Logitech Webcam C930e driver: snd-usb-audio,uvcvideo type: USB
API: ALSA v: k6.12.38-1-MANJARO status: kernel-api with: aoss
Server-3: PipeWire v: 1.4.6 status: active with: 1: pipewire-pulse
Device-1: Aquantia AQtion AQC107 NBase-T/IEEE 802.3an Ethernet [Atlantic 10G]
vendor: ASUSTeK driver: atlantic v: kernel pcie: gen: 3 speed: 8 GT/s
lanes: 4 port: N/A bus-ID: 05:00.0 chip-ID: 1d6a:07b1 class-ID: 0200
IF: enp5s0 state: down mac: <filter>
Device-2: Realtek RTL8125 2.5GbE vendor: ASUSTeK driver: r8169 v: kernel
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: e000 bus-ID: 06:00.0
IF: enp6s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-3: Intel I211 Gigabit Network vendor: ASUSTeK driver: igb v: kernel
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 07:00.0
IF: enp7s0 state: down mac: <filter>
Device-4: Intel Wi-Fi 6 AX200 driver: N/A modules: iwlwifi pcie: gen: 2
speed: 5 GT/s lanes: 1 bus-ID: 08:00.0 chip-ID: 8086:2723 class-ID: 0280
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-6:5 chip-ID: 8087:0029
class-ID: e001
Report: btmgmt ID: hci0 rfk-id: 0 state: up address: N/A
Local Storage: total: 4.89 TiB used: 3.06 TiB (62.6%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 960 PRO 1TB
size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: 2B6QCXP7 temp: 43.9 C
scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:4 vendor: Lexar model: SSD NM790 4TB
size: 3.73 TiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: 12237 temp: 55.9 C scheme: GPT
ID-3: /dev/sda maj-min: 8:0 vendor: OCZ model: VERTEX4 size: 238.47 GiB
block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s tech: SSD
serial: <filter> fw-rev: 1.5 scheme: GPT
ID-1: / raw-size: 3.66 TiB size: 3.6 TiB (98.40%) used: 2.19 TiB (60.7%)
fs: ext4 dev: /dev/nvme1n1p2 maj-min: 259:6 label: N/A
uuid: 319bf7d3-8a5c-4792-8db7-4df6981a2bbc
used: 296 KiB (0.1%) fs: vfat dev: /dev/nvme1n1p1 maj-min: 259:5 label: N/A
uuid: 1B4B-4B52
ID-3: /mnt/data raw-size: 952.65 GiB size: 936.63 GiB (98.32%)
used: 795.47 GiB (84.9%) fs: ext4 dev: /dev/nvme0n1p3 maj-min: 259:3
label: N/A uuid: ac045e9d-3702-464e-b302-e3f3272276ee
ID-4: /mnt/data2 raw-size: 237.5 GiB size: 232.71 GiB (97.98%)
used: 93.07 GiB (40.0%) fs: ext4 dev: /dev/sda3 maj-min: 8:3 label: N/A
uuid: 5ee340bd-d824-4be0-9bf9-ca6b25e2cd31
ID-5: /run/media/leder/127196f1-376c-432a-a3ce-482b654b06f9
raw-size: 732 MiB size: 703.1 MiB (96.05%) used: 331.2 MiB (47.1%) fs: ext4
dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A
uuid: 127196f1-376c-432a-a3ce-482b654b06f9
ID-1: swap-1 type: partition size: 68.98 GiB used: 4.56 GiB (6.6%)
priority: -2 dev: /dev/nvme1n1p3 maj-min: 259:7 label: swap
uuid: fc9e3ee8-7dee-416a-a1ec-e6d6b877967c
ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 512 MiB fs: vfat label: N/A
uuid: C03F-3115
Hub-2: 1-1:9 info: Realtek RTS5411 Hub ports: 6 rev: 2.1
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 0bda:5411
Device-1: 1-1.3:10 info: Integrated Express ITE Device(8595) type: keyboard
lanes: 1 mode: 1.1 power: 100mA chip-ID: 048d:8295 class-ID: 0301
Device-2: 1-1.6:11 info: Realtek HID Device type: HID
chip-ID: 0bda:1100 class-ID: 0300
Hub-3: 1-3:2 info: ATEN USB2.1 Hub ports: 4 rev: 2.1
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 0557:5411
Device-1: 1-3.1:4 info: Google Titan Security Key v2 type: HID
lanes: 1 mode: 1.1 power: 60mA chip-ID: 18d1:9470 class-ID: 0300
serial: <filter>
Hub-4: 1-3.3:6 info: ATEN Hub ports: 4 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s)
lanes: 1 mode: 1.1 power: 100mA chip-ID: 0557:8021 class-ID: 0900
Device-1: 1-3.3.1:8 info: ATEN CS1942DP_1944DP type: keyboard,mouse
driver: hid-generic,usbhid interfaces: 2 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s)
lanes: 1 mode: 1.1 power: 100mA chip-ID: 0557:2200 class-ID: 0301
Hub-5: 1-5:3 info: Genesys Logic Hub ports: 4 rev: 2.0
Device-1: 1-5.3:7 info: ASUSTek AURA LED Controller type: HID
lanes: 1 mode: 1.1 power: 16mA chip-ID: 0b05:18f3 class-ID: 0300
serial: <filter>
Device-2: 1-6:5 info: Intel AX200 Bluetooth type: bluetooth driver: btusb
power: 100mA chip-ID: 8087:0029 class-ID: e001
Hub-6: 2-0:1 info: super-speed hub ports: 4 rev: 3.1
Hub-7: 2-3:2 info: Realtek Hub ports: 2 rev: 3.2
speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 0bda:0411
Hub-8: 3-0:1 info: hi-speed hub with single TT ports: 6 rev: 2.0
Hub-9: 3-2:2 info: ASMedia ASM1074 High-Speed hub ports: 4 rev: 2.1
chip-ID: 174c:2074 class-ID: 0900
Hub-10: 4-0:1 info: super-speed hub ports: 4 rev: 3.1
Hub-11: 4-2:2 info: ASMedia ASM1074 SuperSpeed hub ports: 4 rev: 3.0
speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 power: 8mA
chip-ID: 174c:3074 class-ID: 0900
Hub-12: 5-0:1 info: hi-speed hub with single TT ports: 4 rev: 2.0
Hub-13: 5-3:2 info: VIA Labs USB2.0 Hub ports: 4 rev: 2.1
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 2109:2817
Device-1: 5-3.1:4 info: Logitech Webcam C930e type: video,audio
Device-2: 5-3.2:5 info: Logitech PRO X 2 DEX type: mouse,keyboard,HID
lanes: 1 mode: 1.1 power: 500mA chip-ID: 046d:c0a0 class-ID: 0300
serial: <filter>
Device-3: 5-3.3:6 info: Keychron Q0 type: keyboard,HID
lanes: 1 mode: 1.1 power: 500mA chip-ID: 3434:0130 class-ID: 0300
serial: <filter>
Device-4: 5-3.4:7 info: Keychron Q3 keychron/q3/iso_encoder
type: keyboard,HID driver: hid-generic,usbhid interfaces: 3 rev: 2.0
chip-ID: 3434:0123 class-ID: 0300 serial: <filter>
Device-5: 5-4:3 info: Reiner SCT Kartensysteme GmbH cyberJack RFID comfort
dual interface smartcard reader type: <vendor specific> driver: N/A
interfaces: 1 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1
power: 350mA chip-ID: 0c4b:0501 class-ID: 0000 serial: <filter>
Hub-14: 6-0:1 info: super-speed hub ports: 4 rev: 3.1
Hub-15: 6-3:2 info: VIA Labs USB3.0 Hub ports: 4 rev: 3.2
speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 2109:0817
System Temperatures: cpu: 63.0 C mobo: 38.0 C
Fan Speeds (rpm): cpu: 0
Packages: 2506 pm: pacman pkgs: 2475 libs: 521
tools: gnome-software,pamac,yay pm: flatpak pkgs: 31
1: https://mirror.init7.net/manjaro/testing/$repo/$arch
2: https://mirror.telepoint.bg/manjaro/testing/$repo/$arch
3: https://mirror.hostiko.network/manjaro/testing/$repo/$arch
4: https://ftpmirror1.infania.net/mirror/manjaro/testing/$repo/$arch
5: https://mnvoip.mm.fcix.net/manjaro/testing/$repo/$arch
6: https://mirror.xenyth.net/manjaro/testing/$repo/$arch
7: https://nocix.mm.fcix.net/manjaro/testing/$repo/$arch
8: https://volico.mm.fcix.net/manjaro/testing/$repo/$arch
Processes:
CPU top: 5 of 741
1: cpu: 20.1% command: steamapp_pipeline_cache.foz
started-by: fossilize_replay pid: 9656 mem: 189.4 MiB (0.2%)
2: cpu: 20.0% command: steamapp_pipeline_cache.foz
started-by: fossilize_replay pid: 9655 mem: 182.5 MiB (0.2%)
3: cpu: 19.9% command: steamapp_pipeline_cache.foz
started-by: fossilize_replay pid: 9653 mem: 182.7 MiB (0.2%)
4: cpu: 19.9% command: steamapp_pipeline_cache.foz
started-by: fossilize_replay pid: 9654 mem: 181.2 MiB (0.2%)
5: cpu: 19.8% command: steamapp_pipeline_cache.foz
started-by: fossilize_replay pid: 9652 mem: 181.0 MiB (0.2%)
Memory top: 5 of 741
1: mem: 2203.6 MiB (3.4%) command: thunderbird pid: 4239 cpu: 5.1%
2: mem: 1447.6 MiB (2.2%) command: data2 started-by: baobab pid: 10081
cpu: 3.2%
3: mem: 974.0 MiB (1.5%) command: gnome-shell pid: 2024 cpu: 9.1%
4: mem: 432.5 MiB (0.6%) command: vivaldi-bin pid: 4668 cpu: 1.0%
5: mem: 431.4 MiB (0.6%) command: exe pid: 7816 cpu: 6.6%
Processes: 741 Power: uptime: 1h 41m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 24.99 GiB services: gsd-power,
tool: systemctl
Compilers: clang: 20.1.7 gcc: 15.1.1 alt: 13/14 Shell: Zsh v: 5.9
running-in: kgx inxi: 3.3.38
~ ip a 127 ✘ pynput-env
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
inet 127.0.0.1/8 scope host lo
valid_lft forever preferred_lft forever
inet6 ::1/128 scope host noprefixroute
2: enp7s0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc mq state DOWN group default qlen 1000
link/ether 3c:7c:3f:d6:04:b6 brd ff:ff:ff:ff:ff:ff
altname enx3c7c3fd604b6
3: enp6s0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc fq_codel state UP group default qlen 1000
link/ether 3c:7c:3f:d6:04:b7 brd ff:ff:ff:ff:ff:ff
altname enx3c7c3fd604b7
inet 192.168.178.53/24 brd 192.168.178.255 scope global dynamic noprefixroute enp6s0
valid_lft 857883sec preferred_lft 857883sec
inet6 2003:ee:8715:3500:d52a:2bc1:5478:e10d/64 scope global dynamic noprefixroute
valid_lft 7044sec preferred_lft 1067sec
inet6 fdea:b8d4:f4ca:0:6d4a:2045:9a46:1be2/64 scope global dynamic noprefixroute
valid_lft 7044sec preferred_lft 3444sec
inet6 fe80::91f9:63ed:f519:3065/64 scope link noprefixroute
4: enp5s0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc mq state DOWN group default qlen 1000
link/ether 3c:7c:3f:41:1c:6e brd ff:ff:ff:ff:ff:ff
altname enx3c7c3f411c6e
~ lspci -v ✔ pynput-env
00:00.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Root Complex
Subsystem: ASUSTeK Computer Inc. Device 8808
Flags: fast devsel
00:00.2 IOMMU: Advanced Micro Devices, Inc. [AMD] Starship/Matisse IOMMU
Flags: fast devsel, IRQ 26
Capabilities: <access denied>
00:01.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
Flags: fast devsel, IOMMU group 0
00:01.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse GPP Bridge (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 28, IOMMU group 1
Bus: primary=00, secondary=01, subordinate=01, sec-latency=0
I/O behind bridge: [disabled] [32-bit]
Memory behind bridge: fc600000-fc6fffff [size=1M] [32-bit]
Prefetchable memory behind bridge: [disabled] [64-bit]
Kernel driver in use: pcieport
00:01.2 PCI bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse GPP Bridge (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 29, IOMMU group 2
Bus: primary=00, secondary=02, subordinate=0b, sec-latency=0
I/O behind bridge: d000-efff [size=8K] [16-bit]
Memory behind bridge: fb400000-fc1fffff [size=14M] [32-bit]
00:02.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
DeviceName: Onboard IGD
Flags: fast devsel, IOMMU group 3
00:03.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
Flags: fast devsel, IOMMU group 4
00:03.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse GPP Bridge (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 30, IOMMU group 5
Bus: primary=00, secondary=0c, subordinate=0c, sec-latency=0
I/O behind bridge: f000-ffff [size=4K] [16-bit]
Memory behind bridge: fa000000-fb0fffff [size=17M] [32-bit]
Prefetchable memory behind bridge: 7000000000-7801ffffff [size=32800M] [32-bit]
00:04.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
Flags: fast devsel, IOMMU group 6
00:05.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
Flags: fast devsel, IOMMU group 7
00:07.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
Flags: fast devsel, IOMMU group 8
00:07.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Internal PCIe GPP Bridge 0 to bus[E:B] (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 32, IOMMU group 9
Bus: primary=00, secondary=0d, subordinate=0d, sec-latency=0
Memory behind bridge: [disabled] [32-bit]
00:08.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
Flags: fast devsel, IOMMU group 10
00:08.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Internal PCIe GPP Bridge 0 to bus[E:B] (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 33, IOMMU group 11
Bus: primary=00, secondary=0e, subordinate=0e, sec-latency=0
Memory behind bridge: fc300000-fc5fffff [size=3M] [32-bit]
00:14.0 SMBus: Advanced Micro Devices, Inc. [AMD] FCH SMBus Controller (rev 61)
Subsystem: ASUSTeK Computer Inc. Device 87c0
Flags: 66MHz, medium devsel, IOMMU group 12
Kernel driver in use: piix4_smbus
Kernel modules: i2c_piix4, sp5100_tco
00:14.3 ISA bridge: Advanced Micro Devices, Inc. [AMD] FCH LPC Bridge (rev 51)
Flags: bus master, 66MHz, medium devsel, latency 0, IOMMU group 12
00:18.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Matisse/Vermeer Data Fabric: Device 18h; Function 0
Flags: fast devsel, IOMMU group 13
00:18.1 Host bridge: Advanced Micro Devices, Inc. [AMD] Matisse/Vermeer Data Fabric: Device 18h; Function 1
00:18.2 Host bridge: Advanced Micro Devices, Inc. [AMD] Matisse/Vermeer Data Fabric: Device 18h; Function 2
00:18.3 Host bridge: Advanced Micro Devices, Inc. [AMD] Matisse/Vermeer Data Fabric: Device 18h; Function 3
Kernel driver in use: k10temp
Kernel modules: k10temp
00:18.4 Host bridge: Advanced Micro Devices, Inc. [AMD] Matisse/Vermeer Data Fabric: Device 18h; Function 4
00:18.5 Host bridge: Advanced Micro Devices, Inc. [AMD] Matisse/Vermeer Data Fabric: Device 18h; Function 5
00:18.6 Host bridge: Advanced Micro Devices, Inc. [AMD] Matisse/Vermeer Data Fabric: Device 18h; Function 6
00:18.7 Host bridge: Advanced Micro Devices, Inc. [AMD] Matisse/Vermeer Data Fabric: Device 18h; Function 7
01:00.0 Non-Volatile memory controller: Samsung Electronics Co Ltd NVMe SSD Controller SM961/PM961/SM963 (prog-if 02 [NVM Express])
Subsystem: Samsung Electronics Co Ltd SM963 2.5" NVMe PCIe SSD
Flags: bus master, fast devsel, latency 0, IRQ 81, IOMMU group 14
Memory at fc600000 (64-bit, non-prefetchable) [size=16K]
Kernel driver in use: nvme
Kernel modules: nvme
02:00.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] Matisse Switch Upstream (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 24, IOMMU group 15
Bus: primary=02, secondary=03, subordinate=0b, sec-latency=0
03:01.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] Matisse PCIe GPP Bridge (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 34, IOMMU group 16
Bus: primary=03, secondary=04, subordinate=04, sec-latency=0
Memory behind bridge: fc100000-fc1fffff [size=1M] [32-bit]
03:02.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] Matisse PCIe GPP Bridge (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 35, IOMMU group 17
Bus: primary=03, secondary=05, subordinate=05, sec-latency=0
Memory behind bridge: fb400000-fb8fffff [size=5M] [32-bit]
03:03.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] Matisse PCIe GPP Bridge (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 36, IOMMU group 18
Bus: primary=03, secondary=06, subordinate=06, sec-latency=0
I/O behind bridge: e000-efff [size=4K] [16-bit]
Memory behind bridge: fc000000-fc0fffff [size=1M] [32-bit]
03:05.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] Matisse PCIe GPP Bridge (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 37, IOMMU group 19
Bus: primary=03, secondary=07, subordinate=07, sec-latency=0
I/O behind bridge: d000-dfff [size=4K] [16-bit]
Memory behind bridge: fbf00000-fbffffff [size=1M] [32-bit]
03:06.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] Matisse PCIe GPP Bridge (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 38, IOMMU group 20
Bus: primary=03, secondary=08, subordinate=08, sec-latency=0
Memory behind bridge: fbe00000-fbefffff [size=1M] [32-bit]
03:08.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] Matisse PCIe GPP Bridge (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 39, IOMMU group 21
Bus: primary=03, secondary=09, subordinate=09, sec-latency=0
Memory behind bridge: fba00000-fbbfffff [size=2M] [32-bit]
03:09.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] Matisse PCIe GPP Bridge (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 41, IOMMU group 22
Bus: primary=03, secondary=0a, subordinate=0a, sec-latency=0
Memory behind bridge: fbd00000-fbdfffff [size=1M] [32-bit]
03:0a.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] Matisse PCIe GPP Bridge (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 43, IOMMU group 23
Bus: primary=03, secondary=0b, subordinate=0b, sec-latency=0
Memory behind bridge: fbc00000-fbcfffff [size=1M] [32-bit]
04:00.0 Non-Volatile memory controller: Shenzhen Longsys Electronics Co., Ltd. Lexar NM790 NVME SSD (DRAM-less) (rev 01) (prog-if 02 [NVM Express])
Subsystem: Shenzhen Longsys Electronics Co., Ltd. Lexar NM790 NVME SSD (DRAM-less)
Flags: bus master, fast devsel, latency 0, IRQ 40, IOMMU group 24
Memory at fc100000 (64-bit, non-prefetchable) [size=16K]
05:00.0 Ethernet controller: Aquantia Corp. AQtion AQC107 NBase-T/IEEE 802.3an Ethernet Controller [Atlantic 10G] (rev 02)
Subsystem: ASUSTeK Computer Inc. Device 8741
Flags: bus master, fast devsel, latency 0, IRQ 42, IOMMU group 25
Memory at fb840000 (64-bit, non-prefetchable) [size=64K]
Memory at fb850000 (64-bit, non-prefetchable) [size=4K]
Memory at fb400000 (64-bit, non-prefetchable) [size=4M]
Expansion ROM at fb800000 [disabled] [size=256K]
Kernel driver in use: atlantic
Kernel modules: atlantic
06:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8125 2.5GbE Controller
Subsystem: ASUSTeK Computer Inc. Device 879b
Flags: bus master, fast devsel, latency 0, IRQ 115, IOMMU group 26
I/O ports at e000 [size=256]
Memory at fc010000 (64-bit, non-prefetchable) [size=64K]
Memory at fc020000 (64-bit, non-prefetchable) [size=16K]
Expansion ROM at fc000000 [disabled] [size=64K]
Kernel driver in use: r8169
Kernel modules: r8169
07:00.0 Ethernet controller: Intel Corporation I211 Gigabit Network Connection (rev 03)
Subsystem: ASUSTeK Computer Inc. Device 85f0
Flags: bus master, fast devsel, latency 0, IRQ 40, IOMMU group 27
Memory at fbf00000 (32-bit, non-prefetchable) [size=128K]
I/O ports at d000 [size=32]
Memory at fbf20000 (32-bit, non-prefetchable) [size=16K]
Kernel driver in use: igb
Kernel modules: igb
08:00.0 Network controller: Intel Corporation Wi-Fi 6 AX200 (rev 1a)
Subsystem: Intel Corporation Wi-Fi 6 AX200NGW
Flags: fast devsel, IRQ 42, IOMMU group 28
Memory at fbe00000 (64-bit, non-prefetchable) [size=16K]
Kernel modules: iwlwifi
09:00.0 Non-Essential Instrumentation [1300]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Reserved SPP
Flags: fast devsel, IOMMU group 21
09:00.1 USB controller: Advanced Micro Devices, Inc. [AMD] Matisse USB 3.0 Host Controller (prog-if 30 [XHCI])
Flags: bus master, fast devsel, latency 0, IRQ 61, IOMMU group 21
Memory at fbb00000 (64-bit, non-prefetchable) [size=1M]
Kernel driver in use: xhci_hcd
09:00.3 USB controller: Advanced Micro Devices, Inc. [AMD] Matisse USB 3.0 Host Controller (prog-if 30 [XHCI])
Subsystem: Advanced Micro Devices, Inc. [AMD] Device 148c
Flags: bus master, fast devsel, latency 0, IRQ 42, IOMMU group 21
Memory at fba00000 (64-bit, non-prefetchable) [size=1M]
0a:00.0 SATA controller: Advanced Micro Devices, Inc. [AMD] FCH SATA Controller [AHCI mode] (rev 51) (prog-if 01 [AHCI 1.0])
Subsystem: Advanced Micro Devices, Inc. [AMD] FCH SATA Controller [AHCI mode]
Flags: bus master, fast devsel, latency 0, IRQ 44, IOMMU group 22
Memory at fbd00000 (32-bit, non-prefetchable) [size=2K]
Kernel driver in use: ahci
0b:00.0 SATA controller: Advanced Micro Devices, Inc. [AMD] FCH SATA Controller [AHCI mode] (rev 51) (prog-if 01 [AHCI 1.0])
Flags: bus master, fast devsel, latency 0, IRQ 60, IOMMU group 23
Memory at fbc00000 (32-bit, non-prefetchable) [size=2K]
0c:00.0 VGA compatible controller: NVIDIA Corporation AD102 [GeForce RTX 4090] (rev a1) (prog-if 00 [VGA controller])
Subsystem: ZOTAC International (MCO) Ltd. Device 1675
Flags: bus master, fast devsel, latency 0, IRQ 80, IOMMU group 29
Memory at fa000000 (32-bit, non-prefetchable) [size=16M]
Memory at 7000000000 (64-bit, prefetchable) [size=32G]
Memory at 7800000000 (64-bit, prefetchable) [size=32M]
I/O ports at f000 [size=128]
Expansion ROM at fb000000 [virtual] [disabled] [size=512K]
Kernel driver in use: nvidia
Kernel modules: nouveau, nvidia_drm, nvidia
0c:00.1 Audio device: NVIDIA Corporation AD102 High Definition Audio Controller (rev a1)
Flags: bus master, fast devsel, latency 0, IRQ 127, IOMMU group 29
Memory at fb080000 (32-bit, non-prefetchable) [size=16K]
Kernel driver in use: snd_hda_intel
Kernel modules: snd_hda_intel
0d:00.0 Non-Essential Instrumentation [1300]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Function
Flags: fast devsel, IOMMU group 30
0e:00.0 Non-Essential Instrumentation [1300]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Reserved SPP
Flags: fast devsel, IOMMU group 31
0e:00.1 Encryption controller: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Cryptographic Coprocessor PSPCPP
Flags: bus master, fast devsel, latency 0, IRQ 107, IOMMU group 32
Memory at fc400000 (32-bit, non-prefetchable) [size=1M]
Memory at fc508000 (32-bit, non-prefetchable) [size=8K]
Kernel driver in use: ccp
Kernel modules: ccp
0e:00.3 USB controller: Advanced Micro Devices, Inc. [AMD] Matisse USB 3.0 Host Controller (prog-if 30 [XHCI])
Flags: bus master, fast devsel, latency 0, IRQ 70, IOMMU group 33
Memory at fc300000 (64-bit, non-prefetchable) [size=1M]
0e:00.4 Audio device: Advanced Micro Devices, Inc. [AMD] Starship/Matisse HD Audio Controller
Subsystem: ASUSTeK Computer Inc. Device 87c4
Flags: bus master, fast devsel, latency 0, IRQ 129, IOMMU group 34
Memory at fc500000 (32-bit, non-prefetchable) [size=32K]
~ sudo dmesg | grep iwlwifi 1|127 ✘ 12s pynput-env
[sudo] Passwort für leder:
[ 10.128342] iwlwifi 0000:08:00.0: enabling device (0000 -> 0002)
[ 10.163505] iwlwifi 0000:08:00.0: CSR_RESET = 0x10
[ 10.163509] iwlwifi 0000:08:00.0: Host monitor block 0x0 vector 0x0
[ 10.163513] iwlwifi 0000:08:00.0: value [iter 0]: 0x3f7f8830
[ 10.163517] iwlwifi 0000:08:00.0: value [iter 1]: 0x3f7f8030
[ 10.163520] iwlwifi 0000:08:00.0: value [iter 2]: 0x3f7f0430
[ 10.163524] iwlwifi 0000:08:00.0: value [iter 3]: 0x3f7f8430
[ 10.163527] iwlwifi 0000:08:00.0: value [iter 4]: 0x3f7f0430
[ 10.163530] iwlwifi 0000:08:00.0: value [iter 5]: 0x3f7f0430
[ 10.163534] iwlwifi 0000:08:00.0: value [iter 6]: 0x3f7f0c30
[ 10.163537] iwlwifi 0000:08:00.0: value [iter 7]: 0x3f7f0830
[ 10.163541] iwlwifi 0000:08:00.0: value [iter 8]: 0x3f7f0830
[ 10.163544] iwlwifi 0000:08:00.0: value [iter 9]: 0x3f7f0030
[ 10.163547] iwlwifi 0000:08:00.0: value [iter 10]: 0x3f7f0030
[ 10.163551] iwlwifi 0000:08:00.0: value [iter 11]: 0x3f7f8430
[ 10.163554] iwlwifi 0000:08:00.0: value [iter 12]: 0x3f7f0430
[ 10.163558] iwlwifi 0000:08:00.0: value [iter 13]: 0x3f7f0430
[ 10.163561] iwlwifi 0000:08:00.0: value [iter 14]: 0x3f7f8c30
[ 10.163562] iwlwifi 0000:08:00.0: Host monitor block 0x0 vector 0x1
[ 10.163566] iwlwifi 0000:08:00.0: value [iter 0]: 0x044466c2
[ 10.163570] iwlwifi 0000:08:00.0: value [iter 1]: 0x044466c2
[ 10.163573] iwlwifi 0000:08:00.0: value [iter 2]: 0x044466c2
[ 10.163576] iwlwifi 0000:08:00.0: value [iter 3]: 0x044466c2
[ 10.163580] iwlwifi 0000:08:00.0: value [iter 4]: 0x044466c2
[ 10.163583] iwlwifi 0000:08:00.0: value [iter 5]: 0x044466c2
[ 10.163587] iwlwifi 0000:08:00.0: value [iter 6]: 0x044466c2
[ 10.163597] iwlwifi 0000:08:00.0: value [iter 7]: 0x044466c2
[ 10.163601] iwlwifi 0000:08:00.0: value [iter 8]: 0x044466c2
[ 10.163604] iwlwifi 0000:08:00.0: value [iter 9]: 0x044466c2
[ 10.163608] iwlwifi 0000:08:00.0: value [iter 10]: 0x044466c2
[ 10.163611] iwlwifi 0000:08:00.0: value [iter 11]: 0x044466c2
[ 10.163615] iwlwifi 0000:08:00.0: value [iter 12]: 0x044466c2
[ 10.163618] iwlwifi 0000:08:00.0: value [iter 13]: 0x044466c2
[ 10.163622] iwlwifi 0000:08:00.0: value [iter 14]: 0x044466c2
[ 10.163623] iwlwifi 0000:08:00.0: Host monitor block 0x0 vector 0x6
[ 10.163627] iwlwifi 0000:08:00.0: value [iter 0]: 0xe00c4471
[ 10.163630] iwlwifi 0000:08:00.0: value [iter 1]: 0xa00c4471
[ 10.163634] iwlwifi 0000:08:00.0: value [iter 2]: 0xa00c4471
[ 10.163637] iwlwifi 0000:08:00.0: value [iter 3]: 0xa00c4471
[ 10.163640] iwlwifi 0000:08:00.0: value [iter 4]: 0xa00c4471
[ 10.163644] iwlwifi 0000:08:00.0: value [iter 5]: 0xf00c4471
[ 10.163647] iwlwifi 0000:08:00.0: value [iter 6]: 0xf00c4471
[ 10.163650] iwlwifi 0000:08:00.0: value [iter 7]: 0xf00c4471
[ 10.163654] iwlwifi 0000:08:00.0: value [iter 8]: 0xb00c4471
[ 10.163657] iwlwifi 0000:08:00.0: value [iter 9]: 0xa00c4471
[ 10.163661] iwlwifi 0000:08:00.0: value [iter 10]: 0xa00c4471
[ 10.163664] iwlwifi 0000:08:00.0: value [iter 11]: 0xa00c4471
[ 10.163667] iwlwifi 0000:08:00.0: value [iter 12]: 0xe00c4471
[ 10.163671] iwlwifi 0000:08:00.0: value [iter 13]: 0xe00c4471
[ 10.163674] iwlwifi 0000:08:00.0: value [iter 14]: 0xf00c4471
[ 10.163676] iwlwifi 0000:08:00.0: Host monitor block 0x22 vector 0x0
[ 10.163679] iwlwifi 0000:08:00.0: value [iter 0]: 0x00000000
[ 10.163904] iwlwifi 0000:08:00.0: probe with driver iwlwifi failed with error -110
