After booting up, manjaro directly enters the command line interface and cannot enter the graphical interface
After the lock screen program showed that it was damaged, I forced a restart of the computer. As a result, I can’t enter the graphical interface, but I can enter commands. How can I solve this problem?
You may need to provide additional information so someone can help you.
You haven’t even mentioned which graphical environment you’re using or which greeter.
Welcome to Manjaro! :smiling_face_with_three_hearts:
  1. Please read the information behind this link. It will help you to post necessary information.
  1. Please press the 3 dots … below your post and then press the :pencil2:
  • If you give us information about your system, we can see what we’re talking about and make better suggestions.
  • You can do this by using inxi -czv8 as root in a terminal or in console.
sudo inxi --color --filter --verbosity=8
  • Personally identifiable information such as serial numbers and MAC addresses are filtered out by this command
  • Presenting the information in this way allows everyone to be familiar with the format and quickly find the items they need without missing anything.
  1. Copy the output from inxi (including the command) and paste it into your post.
  • To make it more readable, add 3 backticks ``` on an extra line before and after the pasted text.
  1. Or we can try to play hide and seek :wink:
    Have you already :mag: for your problem in the forum ? (Wisdom lies in asking → listening → reading :wink: )
From the console, login. Then run command systemctl status display-manager
What does this show?
I solved it, it was because I updated libllvm, which caused X.Org to fail to start
