Sorry for the delay. The issue didn’t happen for a while but apparently now it’s back!
Here’s the output of pactl list cards; pactl list sinks
with the earbuds working:
Card #0
Driver: module-alsa-card.c
Owner Module: 6
Properties:
alsa.card = "0"
alsa.card_name = "HD-Audio Generic"
alsa.long_card_name = "HD-Audio Generic at 0xd04c8000 irq 104"
device.bus_path = "pci-0000:03:00.1"
sysfs.path = "/devices/pci0000:00/0000:00:08.1/0000:03:00.1/sound/card0"
device.bus = "pci"
device.vendor.id = "1002"
device.vendor.name = "Advanced Micro Devices, Inc. [AMD/ATI]"
device.product.id = "1637"
device.product.name = "Renoir Radeon High Definition Audio Controller"
device.string = "0"
device.description = "Renoir Radeon High Definition Audio Controller"
module-udev-detect.discovered = "1"
device.icon_name = "audio-card-pci"
Profiles:
HiFi: Play HiFi quality Music (sinks: 2, sources: 0, priority: 10300, available: no)
off: Off (sinks: 0, sources: 0, priority: 0, available: yes)
Active Profile: off
Ports:
[Out] HDMI2: HDMI / DisplayPort 2 Output (type: HDMI, priority: 1200, latency offset: 0 usec, not available)
Part of profile(s): HiFi
[Out] HDMI1: HDMI / DisplayPort 1 Output (type: HDMI, priority: 1100, latency offset: 0 usec, not available)
Card #1
Owner Module: 8
Properties:
alsa.card = "1"
alsa.long_card_name = "HD-Audio Generic at 0xd04c0000 irq 105"
device.bus_path = "pci-0000:03:00.6"
sysfs.path = "/devices/pci0000:00/0000:00:08.1/0000:03:00.6/sound/card1"
device.bus = "pci"
device.vendor.id = "1022"
device.vendor.name = "Advanced Micro Devices, Inc. [AMD]"
device.product.id = "15e3"
device.product.name = "Family 17h/19h HD Audio Controller"
device.string = "1"
device.description = "Family 17h/19h HD Audio Controller"
Profiles:
HiFi (Mic1, Mic2, Speaker): Play HiFi quality Music (Mic1, Mic2, Speaker) (sinks: 1, sources: 2, priority: 41168, available: yes)
HiFi (Headphones, Mic1, Mic2): Play HiFi quality Music (Headphones, Mic1, Mic2) (sinks: 1, sources: 2, priority: 8500, available: yes)
Active Profile: HiFi (Mic1, Mic2, Speaker)
Ports:
[Out] Speaker: Speaker (type: Speaker, priority: 100, latency offset: 0 usec, availability unknown)
Part of profile(s): HiFi (Mic1, Mic2, Speaker)
[In] Mic2: Headphones Stereo Microphone (type: Mic, priority: 200, latency offset: 0 usec, not available)
Part of profile(s): HiFi (Mic1, Mic2, Speaker), HiFi (Headphones, Mic1, Mic2)
[In] Mic1: Digital Microphone (type: Mic, priority: 100, latency offset: 0 usec, availability unknown)
[Out] Headphones: Headphones (type: Headphones, priority: 200, latency offset: 0 usec, not available)
Part of profile(s): HiFi (Headphones, Mic1, Mic2)
Card #2
Driver: module-bluez5-device.c
Owner Module: 27
Properties:
device.description = "Galaxy Buds+ (E66B)"
device.string = "E8:7F:6B:65:E6:6B"
device.api = "bluez"
device.class = "sound"
device.bus = "bluetooth"
device.form_factor = "headset"
bluez.path = "/org/bluez/hci0/dev_E8_7F_6B_65_E6_6B"
bluez.class = "0x240404"
bluez.alias = "Galaxy Buds+ (E66B)"
device.icon_name = "audio-headset-bluetooth"
device.intended_roles = "phone"
bluetooth.codec = "sbc"
bluetooth.battery = "100%"
Profiles:
a2dp_sink: High Fidelity Playback (A2DP Sink) (sinks: 1, sources: 0, priority: 40, available: yes)
handsfree_head_unit: Handsfree Head Unit (HFP) (sinks: 1, sources: 1, priority: 30, available: yes)
Active Profile: a2dp_sink
Ports:
headset-output: Headset (type: Headset, priority: 0, latency offset: 0 usec, availability unknown)
Part of profile(s): a2dp_sink, handsfree_head_unit
headset-input: Headset (type: Headset, priority: 0, latency offset: 0 usec, availability unknown)
Part of profile(s): handsfree_head_unit
Sink #0
State: SUSPENDED
Description: Family 17h/19h HD Audio Controller Speaker
Sample Specification: s16le 2ch 48000Hz
Channel Map: front-left,front-right
Owner Module: 8
Mute: no
Volume: front-left: 52429 / 80% / -5.81 dB, front-right: 52429 / 80% / -5.81 dB
balance 0.00
Base Volume: 65536 / 100% / 0.00 dB
Monitor Source: alsa_output.pci-0000_03_00.6.HiFi__Speaker__sink.monitor
Latency: 0 usec, configured 0 usec
Flags: HARDWARE HW_MUTE_CTRL HW_VOLUME_CTRL DECIBEL_VOLUME LATENCY
Properties:
alsa.resolution_bits = "16"
device.api = "alsa"
alsa.class = "generic"
alsa.subclass = "generic-mix"
alsa.name = "ALC285 Analog"
alsa.id = "ALC285 Analog"
alsa.subdevice = "0"
alsa.subdevice_name = "subdevice #0"
alsa.device = "0"
alsa.card = "1"
device.bus = "pci"
device.string = "_ucm0003.hw:Generic_1"
device.buffering.buffer_size = "384000"
device.buffering.fragment_size = "192000"
device.access_mode = "mmap+timer"
device.profile.name = "HiFi: Speaker: sink"
device.profile.description = "Speaker"
alsa.mixer_device = "_ucm0003.hw:Generic_1"
device.description = "Family 17h/19h HD Audio Controller Speaker"
Ports:
[Out] Speaker: Speaker (type: Speaker, priority: 100, availability unknown)
Active Port: [Out] Speaker
Formats:
pcm
Sink #1
State: SUSPENDED
Description: Galaxy Buds+ (E66B)
Sample Specification: s16le 2ch 44100Hz
Owner Module: 27
Mute: no
Volume: front-left: 22938 / 35% / -27.36 dB, front-right: 22938 / 35% / -27.36 dB
balance 0.00
Monitor Source: bluez_sink.E8_7F_6B_65_E6_6B.a2dp_sink.monitor
Flags: HARDWARE HW_VOLUME_CTRL DECIBEL_VOLUME LATENCY
Properties:
bluetooth.protocol = "a2dp_sink"
Ports:
headset-output: Headset (type: Headset, priority: 0, availability unknown)
Active Port: headset-output
Formats:
pcm
And this is it after the earbuds stop working.
Card #0
Owner Module: 6
Properties:
alsa.card = "0"
device.bus = "pci"
device.string = "0"
Profiles:
Active Profile: off
Ports:
Card #1
Owner Module: 8
Properties:
alsa.card = "1"
device.bus = "pci"
device.string = "1"
Profiles:
Ports:
Card #2
Owner Module: 27
Properties:
bluetooth.battery = "93%"
Profiles:
a2dp_sink: High Fidelity Playback (A2DP Sink) (sinks: 1, sources: 0, priority: 40, available: no)
Active Profile: off
Ports:
Sink #0
State: SUSPENDED
Owner Module: 8
Mute: no
Volume: front-left: 29491 / 45% / -20.81 dB, front-right: 29491 / 45% / -20.81 dB
balance 0.00
Properties:
device.api = "alsa"
alsa.device = "0"
alsa.card = "1"
device.bus = "pci"
Ports:
Formats:
pcm
The only difference I see is that sink #1 disappears. I have no idea how to interpret that though
@nikgnomic do you have any ideas?
