So I was reading PDFs at the library and there was no socket to charge the laptop.
After the charge percentage dropped below 38%, the laptop suddenly beeps and turns off. The last thing I saw was 0% on the battery icon and then 100%.
Then returning home after 20 minutes, I plugged in the laptop without starting it. After around 1 hour when the battery-full LED indicator turned on, I disconnected the charger and opened it after a while. Since then, the battery is showing 100% charge.
Here’s a fun thing: It is showing 100%, but when I plug in the charger it shows 99% and charging, when I unplug it, it shows 98% but after around 10 seconds it again shows 100% and doesn’t change.
What can I do now? A binary state(100% or 0%) of battery percentage wouldn’t be pleasant at all.
output of `inxi -B`
inxi -B
ID-1: BAT0 charge: 38.7 Wh (100.0%) condition: 38.7/48.3 Wh (80.0%
output of `upower -d`
upower -d
Device: /org/freedesktop/UPower/devices/line_power_AC0
native-path: AC0
power supply: yes
updated: Mon 02 Oct 2023 05:19:21 PM +06 (449 seconds ago)
has history: no
has statistics: no
line-power
warning-level: none
online: no
icon-name: 'ac-adapter-symbolic'
Device: /org/freedesktop/UPower/devices/battery_BAT0
native-path: BAT0
vendor: OEM
model: AC14B8K
power supply: yes
updated: Mon 02 Oct 2023 05:26:31 PM +06 (19 seconds ago)
has history: yes
has statistics: yes
battery
present: yes
rechargeable: yes
state: discharging
warning-level: none
energy: 38.655 Wh
energy-empty: 0 Wh
energy-full: 38.655 Wh
energy-full-design: 48.3 Wh
energy-rate: 3.855 W
voltage: 15.631 V
charge-cycles: N/A
time to empty: 10.0 hours
percentage: 100%
capacity: 80.0311%
technology: lithium-ion
icon-name: 'battery-full-symbolic'
History (rate):
1696245991 3.855 discharging
1696245961 12.030 discharging
1696245931 4.035 discharging
1696245901 3.990 discharging
Device: /org/freedesktop/UPower/devices/DisplayDevice
power supply: yes
has history: no
has statistics: no
battery
present: yes
state: discharging
warning-level: none
energy: 38.655 Wh
charge-cycles: N/A
percentage: 100%
Daemon:
daemon-version: 1.90.0
on-battery: yes
lid-is-closed: no
lid-is-present: yes
critical-action: PowerOff
