After the latest update, my screen brightness is bugged on my Lenovo Legion 5 Laptop. I tried the 6.12 kernel, and it worked fine on it.
Also, there is a specific workaround to get the brightness to %100 again, which is to close the lid of the laptop and re-open the laptop, and unlock the screen (triggers hibernation).
inxi -zv8
Kernel: 6.18.26-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
clocksource: hpet avail: acpi_pm
root=UUID=b395b351-d6f7-40f1-88ff-43ee89d7e608 rw usbcore.autosuspend=-1
quiet acpi_osi=off apparmor=1 security=apparmor udev.log_priority=3
acpi_backlight=native nowatchdog
Desktop: KDE Plasma v: 6.6.4 tk: Qt v: N/A info: frameworks v: 6.25.0
wm: kwin_wayland with: docker vt: 1 dm: SDDM Distro: Manjaro
base: Arch Linux
Type: Laptop System: LENOVO product: 82B5 v: Lenovo Legion 5 15ARH05
serial: <superuser required> Chassis: type: 10 v: Lenovo Legion 5 15ARH05
Mobo: LENOVO model: LNVNB161216 v: SDK0J40709 WIN
serial: <superuser required> part-nu: LENOVO_MT_82B5_BU_idea_FM_Legion 5
15ARH05 uuid: <superuser required> Firmware: UEFI vendor: LENOVO
v: EUCN41WW date: 09/20/2023
ID-1: BAT0 charge: 26.1 Wh (59%) condition: 44.2/60 Wh (73.7%) volts: 15.76
min: 15.44 model: SMP L19M4PC0 type: Li-poly serial: <filter> charging:
status: not charging type: long_life avail: long_life,standard
cycles: 1407
System RAM: total: 16 GiB available: 14.99 GiB used: 8.41 GiB (56.1%)
(unregistered) size: 8 GiB speed: 3200 MT/s volts: note: check curr: 1
min: 1 max: 1 width (bits): data: 64 total: 64 manufacturer: Kingston
part-no: LV32D4S2S8HD-8 serial: <filter>
min: 1 max: 1 width (bits): data: 64 total: 64 manufacturer: Samsung
part-no: M471A1G44AB0-CWE serial: <filter>
Info: model: AMD Ryzen 5 4600H with Radeon Graphics bits: 64 type: MT MCP
arch: Zen 2 gen: 2 level: v3 note: check built: 2020-22
process: TSMC n7 (7nm) family: 0x17 (23) model-id: 0x60 (96) stepping: 1
microcode: 0x860010D
desc: 6x512 KiB L3: 8 MiB desc: 2x4 MiB
Speed (MHz): avg: 1771 min/max: 1400/3000 boost: enabled scaling:
driver: acpi-cpufreq governor: ondemand cores: 1: 1771 2: 1771 3: 1771
4: 1771 5: 1771 6: 1771 7: 1771 8: 1771 9: 1771 10: 1771 11: 1771 12: 1771
bogomips: 71866
f16c flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibrs
ibs irperf lahf_lm lbrv lm mba mca mce misalignsse mmx mmxext monitor
movbe msr mtrr mwaitx nonstop_tsc nopl npt nrip_save nx osvw
overflow_recov pae pat pausefilter pclmulqdq pdpe1gb perfctr_core
perfctr_llc perfctr_nb pfthreshold pge pni popcnt pse pse36 rapl rdpid
rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni skinit smap smca
smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor svm svm_lock
syscall tce topoext tsc tsc_scale umip v_spec_ctrl v_vmsave_vmload vgif
vmcb_clean vme vmmcall wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr
xsaveopt xtopology
Type: retbleed mitigation: untrained return thunk; SMT enabled with STIBP
protection
always-on; RSB filling; PBRSB-eIBRS: Not affected; BHI: Not affected
Device-1: NVIDIA TU117M [GeForce GTX 1650 Ti Mobile] vendor: Lenovo
driver: nvidia v: 595.71.05 alternate: nouveau,nova_core,nvidia_drm
non-free: 550-580.xx+ status: current (as of 2025-11; EOL~2026-12-xx)
arch: Turing code: TUxxx process: TSMC 12nm FF built: 2018-2022 pcie:
gen: 3 speed: 8 GT/s lanes: 8 link-max: lanes: 16 ports: active: none
empty: DP-1,HDMI-A-1,eDP-2 bus-ID: 01:00.0 chip-ID: 10de:1f95
class-ID: 0300
Device-2: Advanced Micro Devices [AMD/ATI] Renoir [Radeon Vega Series /
Radeon Mobile Series] vendor: Lenovo driver: amdgpu v: kernel arch: GCN-5
code: Vega process: GF 14nm built: 2017-20 pcie: gen: 4 speed: 16 GT/s
lanes: 16 ports: active: eDP-1 empty: none bus-ID: 05:00.0
chip-ID: 1002:1636 class-ID: 0300 temp: 41.0 C
Device-3: Bison Integrated Camera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-3:2 chip-ID: 5986:212b
class-ID: 0e02
compositor: kwin_wayland driver: X: loaded: amdgpu,nvidia
unloaded: modesetting,nouveau alternate: fbdev,nv,vesa dri: radeonsi
gpu: amdgpu display-ID: 0
Monitor-1: eDP-1 model: AU Optronics 0xd1ed built: 2019 res:
mode: 1920x1080 hz: 120 scale: 100% (1) dpi: 142 gamma: 1.2 chroma: red:
x: 0.561 y: 0.341 green: x: 0.349 y: 0.573 blue: x: 0.161 y: 0.118 white:
x: 0.314 y: 0.329 size: 344x193mm (13.54x7.6") diag: 394mm (15.5")
ratio: 16:9 modes: 1920x1080, 1680x1050, 1280x1024, 1440x900, 1280x800,
1280x720, 1024x768, 800x600, 640x480
API: EGL v: 1.5 hw: drv: nvidia drv: amd radeonsi platforms: device: 0
drv: nvidia device: 2 drv: radeonsi device: 3 drv: swrast gbm: drv: nvidia
surfaceless: drv: nvidia wayland: drv: radeonsi x11: drv: radeonsi
inactive: device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: amd mesa v: 26.0.6-arch1.1
renoir ACO DRM 3.64 6.18.26-1-MANJARO) device-ID: 1002:1636
memory: 500 MiB unified: yes display-ID: :1.0
API: Vulkan v: 1.4.341 layers: 8 device: 0 type: integrated-gpu name: AMD
Radeon Graphics (RADV RENOIR) driver: mesa radv v: 26.0.6-arch1.1
device-ID: 1002:1636 surfaces: N/A device: 1 type: discrete-gpu
name: NVIDIA GeForce GTX 1650 Ti driver: nvidia v: 595.71.05
device-ID: 10de:1f95 surfaces: N/A
de: kscreen-console,kscreen-doctor gpu: nvidia-smi wl: wayland-info
x11: xdpyinfo, xprop, xrandr
Device-1: NVIDIA driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s
lanes: 8 link-max: lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:10fa
class-ID: 0403
Device-2: Advanced Micro Devices [AMD] Audio Coprocessor vendor: Lenovo
driver: N/A alternate: snd_pci_acp3x, snd_rn_pci_acp3x, snd_pci_acp5x,
snd_pci_acp6x, snd_acp_pci, snd_rpl_pci_acp6x, snd_pci_ps,
snd_sof_amd_renoir, snd_sof_amd_rembrandt, snd_sof_amd_vangogh,
snd_sof_amd_acp63, snd_sof_amd_acp70 pcie: gen: 4 speed: 16 GT/s lanes: 16
bus-ID: 05:00.5 chip-ID: 1022:15e2 class-ID: 0480
Device-3: Advanced Micro Devices [AMD] Ryzen HD Audio vendor: Lenovo
bus-ID: 05:00.6 chip-ID: 1022:15e3 class-ID: 0403
API: ALSA v: k6.18.26-1-MANJARO status: kernel-api with: 1: aoss
type: oss-emulator 2: apulse type: pulse-emulator
Server-2: PipeWire v: 1.6.4 status: active with: 1: pipewire-pulse
4: pw-jack type: plugin tools: pactl,pw-cat,pw-cli,wpctl
vendor: Lenovo driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
port: 2000 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-2: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel pcie: gen: 2
speed: 5 GT/s lanes: 1 bus-ID: 04:00.0 chip-ID: 8086:2723 class-ID: 0280
IF: wlp4s0 state: up mac: <filter>
IF-ID-1: br-a29a26287470 state: down mac: <filter>
IF-ID-2: docker0 state: down mac: <filter>
IF-ID-3: vmnet1 state: unknown speed: N/A duplex: N/A mac: <filter>
IP v6: <filter> virtual: proto kernel_ll scope: link
IF-ID-4: vmnet8 state: unknown speed: N/A duplex: N/A mac: <filter>
Info: services: NetworkManager, systemd-networkd, systemd-timesyncd,
wpa_supplicant
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-3:6 chip-ID: 8087:0029
class-ID: e001
Report: btmgmt ID: hci0 rfk-id: 5 state: up address: <filter> bt-v: 5.2
lmp-v: 11 status: discoverable: no pairing: no class-ID: 6c010c
Local Storage: total: 1.14 TiB used: 593.81 GiB (50.8%)
model: MZVLB256HBHQ-000L2 size: 238.47 GiB block-size: physical: 512 B
fw-rev: 3L1QEXH7 temp: 43.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Western Digital model: WD10SPSX-08A6W
tech: HDD rpm: 7200 serial: <filter> fw-rev: 1A01 scheme: GPT
ID-1: / raw-size: 51.29 GiB size: 50.31 GiB (98.08%) used: 46.3 GiB (92.0%)
fs: ext4 dev: /dev/nvme0n1p5 maj-min: 259:5 label: N/A
uuid: b395b351-d6f7-40f1-88ff-43ee89d7e608
used: 53.5 MiB (55.8%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
label: N/A uuid: 0C75-E2CB
ID-3: /home raw-size: 68.07 GiB size: 66.45 GiB (97.62%)
used: 58.06 GiB (87.4%) fs: ext4 dev: /dev/nvme0n1p7 maj-min: 259:7
label: N/A uuid: 8688e415-56b2-481d-827b-210e7dfd1197
ID-4: /run/media/yamo/9640794240792A5F raw-size: 97.58 GiB
size: 97.58 GiB (100.00%) used: 69.15 GiB (70.9%) fs: ntfs
dev: /dev/nvme0n1p3 maj-min: 259:3 label: N/A uuid: 4C924D4C924D3BA8
ID-5: /run/media/yamo/dev raw-size: 150.39 GiB size: 146.97 GiB (97.73%)
used: 22.08 GiB (15.0%) fs: ext4 dev: /dev/sda4 maj-min: 8:4 label: dev
uuid: 282ad770-afcf-4122-a65c-cc2ce3ae8ed4
ID-6: /run/media/yamo/edu raw-size: 300 GiB size: 299.99 GiB (100.00%)
used: 211.23 GiB (70.4%) fs: exfat dev: /dev/sda3 maj-min: 8:3 label: edu
uuid: EFC6-65D4
ID-7: /run/media/yamo/shared raw-size: 131.11 GiB
size: 131.1 GiB (100.00%) used: 43.61 GiB (33.3%) fs: exfat dev: /dev/sda5
maj-min: 8:5 label: shared uuid: F9C9-E5D6
ID-8: /run/media/yamo/storage raw-size: 350 GiB size: 343.44 GiB (98.13%)
used: 141.88 GiB (41.3%) fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: storage
uuid: e5489775-d90c-4696-a864-e63bb4b4852f
ID-1: swap-1 type: partition size: 20.48 GiB used: 1.46 GiB (7.1%)
priority: -2 dev: /dev/nvme0n1p6 maj-min: 259:6 label: N/A
uuid: ae9bb7f8-1320-4d92-9e21-1ebd6e555f8a
ID-1: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-2: /dev/nvme0n1p4 maj-min: 259:4 size: 962 MiB fs: ntfs label: N/A
uuid: A65C81855C81514B
ID-3: /dev/sda1 maj-min: 8:1 size: 16 MiB fs: <superuser required>
Device-1: 1-3:2 info: Bison Integrated Camera type: video driver: uvcvideo
interfaces: 2 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0
power: 500mA chip-ID: 5986:212b class-ID: 0e02
Hub-4: 3-1:2 info: Genesys Logic Hub ports: 2 rev: 2.1
Device-1: 3-1.1:4 info: Razer USA Cobra type: mouse,keyboard
driver: razermouse,usbhid interfaces: 3 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s)
lanes: 1 mode: 1.1 power: 500mA chip-ID: 1532:00a3 class-ID: 0300
Device-2: 3-3:6 info: Intel AX200 Bluetooth type: bluetooth driver: btusb
power: 100mA chip-ID: 8087:0029 class-ID: e001
Device-3: 3-4:5 info: Integrated Express ITE Device(8910) type: keyboard
lanes: 1 mode: 1.1 power: 100mA chip-ID: 048d:c100 class-ID: 0301
Hub-5: 4-0:1 info: super-speed hub ports: 2 rev: 3.1
Hub-6: 4-1:2 info: Genesys Logic GL3523 Hub ports: 2 rev: 3.2
speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 05e3:0620
System Temperatures: cpu: 54.1 C mobo: N/A gpu: amdgpu temp: 41.0 C
Fan Speeds (rpm): N/A
Packages: 2384 pm: dpkg pkgs: 0 pm: pacman pkgs: 2352 libs: 547
tools: pamac,yay pm: flatpak pkgs: 17 pm: snap pkgs: 15
1: http://ossmirror.mycloud.services/os/linux/manjaro/stable/$repo/$arch
2: https://mirror.math.princeton.edu/pub/manjaro/stable/$repo/$arch
3: https://mirrors.eric.ovh/manjaro/stable/$repo/$arch
4: https://mirror.raiolanetworks.com/manjaro/stable/$repo/$arch
5: https://nocix.mm.fcix.net/manjaro/stable/$repo/$arch
6: https://repo.ialab.dsu.edu/manjaro/stable/$repo/$arch
7: https://mirror.23m.com/manjaro/stable/$repo/$arch
8: https://mirror.xenyth.net/manjaro/stable/$repo/$arch
9: https://mirrors.ucr.ac.cr/manjaro/stable/$repo/$arch
10: https://ftp.nluug.nl/pub/os/Linux/distr/manjaro/stable/$repo/$arch
11: https://kartolo.sby.datautama.net.id/manjaro/stable/$repo/$arch
12: https://mirrors.gigenet.com/manjaro/stable/$repo/$arch
13: https://manjaro.ipacct.com/manjaro/stable/$repo/$arch
14: https://forksystems.mm.fcix.net/manjaro/stable/$repo/$arch
15: https://opencolo.mm.fcix.net/manjaro/stable/$repo/$arch
16: https://mirror.fcix.net/manjaro/stable/$repo/$arch
17: https://mirror.datacenter.by/pub/mirrors/manjaro/stable/$repo/$arch
18: https://mirror.it4i.cz/manjaro/stable/$repo/$arch
19: https://mirror.alpix.eu/manjaro/stable/$repo/$arch
20: https://mirror.dkm.cz/manjaro/stable/$repo/$arch
21: https://nnenix.mm.fcix.net/manjaro/stable/$repo/$arch
22: https://mirror.alwyzon.net/manjaro/stable/$repo/$arch
23: https://manjaro.mirror.garr.it/manjaro/stable/$repo/$arch
24: https://mirrors.ocf.berkeley.edu/manjaro/stable/$repo/$arch
25: https://manjaro.mirrors.uk2.net/stable/$repo/$arch
26: https://ftp.psnc.pl/linux/manjaro/stable/$repo/$arch
27: https://gsl-syd.mm.fcix.net/manjaro/stable/$repo/$arch
28: https://mirror.netcologne.de/manjaro/stable/$repo/$arch
29: https://codingflyboy.mm.fcix.net/manjaro/stable/$repo/$arch
30: https://manjaro.ynh.ovh/stable/$repo/$arch
31: https://mirrors.dotsrc.org/manjaro/stable/$repo/$arch
32: https://southfront.mm.fcix.net/manjaro/stable/$repo/$arch
33: https://mirrors.sjtug.sjtu.edu.cn/manjaro/stable/$repo/$arch
34: https://ziply.mm.fcix.net/manjaro/stable/$repo/$arch
35: https://manjaro.mirrors.lavatech.top/stable/$repo/$arch
36: https://www.mirrorservice.org/sites/repo.manjaro.org/repos/stable/$repo/$arch
37: https://mirror1.sox.rs/manjaro/stable/$repo/$arch
38: https://ct.mirror.garr.it/mirrors/manjaro/stable/$repo/$arch
39: https://ftp.halifax.rwth-aachen.de/manjaro/stable/$repo/$arch
40: https://ftp.tu-chemnitz.de/pub/linux/manjaro/stable/$repo/$arch
41: https://mirror.freedif.org/Manjaro/stable/$repo/$arch
42: https://distrohub.kyiv.ua/manjaro/stable/$repo/$arch
43: https://ftp.yz.yamagata-u.ac.jp/pub/linux/manjaro/stable/$repo/$arch
44: https://mirrors2.manjaro.org/stable/$repo/$arch
45: https://ftp.snt.utwente.nl/pub/linux/manjaro/stable/$repo/$arch
46: https://ask4.mm.fcix.net/manjaro/stable/$repo/$arch
47: https://mirrors.manjaro.org/repo/stable/$repo/$arch
48: https://mirror.bouwhuis.network/manjaro/stable/$repo/$arch
49: https://ftp.lysator.liu.se/pub/manjaro/stable/$repo/$arch
50: https://manjaro.grena.ge/stable/$repo/$arch
51: https://fosszone.csd.auth.gr/manjaro/stable/$repo/$arch
52: https://mirrors.up.pt/pub/manjaro/stable/$repo/$arch
53: https://irltoolkit.mm.fcix.net/manjaro/stable/$repo/$arch
54: https://ohioix.mm.fcix.net/manjaro/stable/$repo/$arch
55: https://ftp.linux.org.tr/manjaro/stable/$repo/$arch
56: https://mirror.2degrees.nz/manjaro/stable/$repo/$arch
57: https://manjaro.mirror.wearetriple.com/stable/$repo/$arch
58: https://manjaro.c3sl.ufpr.br/stable/$repo/$arch
59: https://mirror.init7.net/manjaro/stable/$repo/$arch
60: https://mirror.xeonbd.com/manjaro/stable/$repo/$arch
61: https://muug.ca/mirror/manjaro/stable/$repo/$arch
62: https://ftp.rz.tu-bs.de/pub/mirror/manjaro.org/repos/stable/$repo/$arch
63: https://coresite.mm.fcix.net/manjaro/stable/$repo/$arch
64: https://mirror.easyname.at/manjaro/stable/$repo/$arch
65: https://mirror.telepoint.bg/manjaro/stable/$repo/$arch
66: https://mirrors.cicku.me/manjaro/stable/$repo/$arch
67: https://mirror.vinehost.net/manjaro/stable/$repo/$arch
68: https://cofractal-ewr.mm.fcix.net/manjaro/stable/$repo/$arch
69: https://mirror.dimensiondata.com/mirrors/manjaro.org/stable/$repo/$arch
70: https://mirror.phoepsilonix.love/manjaro/stable/$repo/$arch
71: https://mirrors.ft.uam.es/manjaro/stable/$repo/$arch
72: https://mirror.futureweb.be/manjaro/stable/$repo/$arch
73: https://ftp.gwdg.de/pub/linux/manjaro/stable/$repo/$arch
74: https://manjaro.repo.cure.edu.uy/stable/$repo/$arch
75: https://ftp.tsukuba.wide.ad.jp/Linux/manjaro/stable/$repo/$arch
76: https://ba.mirror.garr.it/mirrors/manjaro/stable/$repo/$arch
77: https://manjaro.mirror-services.net/pub/stable/$repo/$arch
78: https://volico.mm.fcix.net/manjaro/stable/$repo/$arch
Processes:
CPU top: 5 of 464
1: cpu: 81.1% command: code pid: 50451 mem: 291.1 MiB (1.8%)
2: cpu: 62.4% command: exe pid: 50856 mem: 736.6 MiB (4.7%)
3: cpu: 50.0% command: ps pid: 62369 mem: 4.41 MiB (0.0%)
4: cpu: 31.4% command: vivaldi-bin pid: 54095 mem: 976.9 MiB (6.3%)
5: cpu: 16.6% command: vivaldi-bin pid: 54815 mem: 364.3 MiB (2.3%)
Memory top: 5 of 464
1: mem: 976.9 MiB (6.3%) command: vivaldi-bin pid: 54095 cpu: 31.4%
2: mem: 736.6 MiB (4.7%) command: exe pid: 50856 cpu: 62.4%
3: mem: 539.4 MiB (3.5%) command: vivaldi-bin pid: 54209 cpu: 12.2%
4: mem: 507.8 MiB (3.3%) command: exe pid: 50877 cpu: 2.6%
5: mem: 488.7 MiB (3.1%) command: zen pid: 7620 cpu: 0.4%
Processes: 464 Power: uptime: 6h 11m states: freeze,mem,disk suspend: deep
avail: s2idle wakeups: 1 hibernate: platform avail: shutdown, reboot,
suspend, test_resume image: 5.89 GiB services: org_kde_powerdevil,upowerd
Init: systemd v: 260 default: graphical tool: systemctl
Compilers: clang: 22.1.3 gcc: 15.2.1 Shell: Zsh v: 5.9 running-in: kitty
inxi: 3.3.40
I didn’t get any responses on this, but posting a workaround for people who might have faced the same issue.
I completely ditched kernel 6.18 and will upgrade when the 7.1 becomes LTS, for now I am using kernel 6.12 which is more stable for my usage.
Well, since I’ve already registered here to troubleshoot other thing, I guess I can help you gain traction with your problem, and post same observation made from POV of Lenovo Ideapad U330 Touch.
Yes, brightness regulation doesn’t have any effect whatsoever on newer kernels. It won’t work either commanded by laptop keyboard keys, nor Gnome slider.
Kernel: 7.1.0-rc5-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 16.1.1
parameters: BOOT_IMAGE=/boot/vmlinuz-7.1-x86_64
root=UUID=2dd184d2-3d3f-4f79-8df5-7fd5fc55ba51 rw quiet
udev.log_priority=3
Desktop: GNOME v: 50.1 tk: GTK v: 3.24.52 wm: gnome-shell
tools: gsd-screensaver-proxy dm: GDM v: 50.0 Distro: Manjaro
base: Arch Linux
Type: Laptop System: LENOVO product: 20268 v: IdeaPad U330 Touch
serial: <superuser required> Chassis: type: 10 v: IdeaPad U330 Touch
Mobo: LENOVO model: Cherry 3A Touch v: 31900058WIN
serial: <superuser required> part-nu: LENOVO_MT_20268
uuid: <superuser required> Firmware: UEFI-[Legacy] vendor: LENOVO
v: 7CCN60WW date: 07/21/2014
ID-1: BAT1 charge: 11.1 Wh (55%) condition: 20.2/40.6 Wh (49.8%) volts: 7.54
min: 7.4 model: SMP L12M4P61 type: Li-ion serial: N/A charging:
status: not charging type: long_life avail: long_life,standard cycles: N/A
System RAM: total: 4 GiB available: 3.75 GiB used: 1.35 GiB (36.0%)
Array-1: capacity: 32 GiB slots: 4 modules: 1 EC: None
Device-1: DIMM0 type: DDR3 detail: synchronous size: 4 GiB
speed: 1600 MT/s volts: N/A width (bits): data: 64 total: 64
manufacturer: Hynix part-no: HMT451S6AFR8A-PB serial: <filter>
Device-2: DIMM1 type: no module installed
Device-3: DIMM2 type: no module installed
Device-4: DIMM3 type: no module installed
Info: model: Intel Core i3-4030U bits: 64 type: MT MCP arch: Haswell
gen: core 4 level: v3 note: check built: 2013-15 process: Intel 22nm
family: 6 model-id: 0x45 (69) stepping: 1 microcode: 0x26
Topology: cpus: 1x dies: 1 clusters: 2 cores: 2 threads: 4 tpc: 2
smt: enabled cache: L1: 128 KiB desc: d-2x32 KiB; i-2x32 KiB L2: 512 KiB
desc: 2x256 KiB L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 800 min/max: 800/1900 scaling: driver: intel_cpufreq
governor: schedutil cores: 1: 800 2: 800 3: 800 4: 800 bogomips: 15165
Flags: abm acpi aes aperfmperf apic arat arch_perfmon avx avx2 bmi1 bmi2
bts clflush cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64
fsgsbase fxsr ht ibpb ibrs ida invpcid lahf_lm lm mca mce md_clear mmx
monitor movbe msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq
pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand rdtscp
rep_good sdbg sep smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall
tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer vme vmx vnmi vpid
x2apic xsave xsaveopt xtopology xtpr
vulnerable
STIBP: conditional; RSB filling; PBRSB-eIBRS: Not affected; BHI: Not
affected
Device-1: Intel Haswell-ULT Integrated Graphics vendor: Lenovo driver: i915
v: kernel arch: Gen-7.5 process: Intel 22nm built: 2013 ports: active: eDP-1
empty: HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:0a16 class-ID: 0300
Device-2: Realtek Lenovo EasyCamera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-5:4 chip-ID: 0bda:572a
compositor: gnome-shell driver: gpu: i915 display-ID: 0
Monitor-1: eDP-1 model: InfoVision Optronics/Kunshan 0x0533 built: 2012
res: 1366x768 dpi: 118 gamma: 1.2 chroma: red: x: 0.569 y: 0.337 green:
x: 0.325 y: 0.573 blue: x: 0.157 y: 0.118 white: x: 0.314 y: 0.329
size: 293x165mm (11.54x6.5") diag: 336mm (13.2") ratio: 16:9
modes: 1366x768
API: EGL v: 1.5 hw: drv: intel crocus platforms: device: 0 drv: crocus
device: 1 drv: swrast gbm: drv: crocus surfaceless: drv: crocus wayland:
drv: crocus x11: drv: crocus
API: OpenGL v: 4.6 vendor: intel mesa v: 26.1.1-arch1.2 glx-v: 1.4
direct-render: yes renderer: Mesa Intel HD Graphics 4400 (HSW GT2)
device-ID: 8086:0a16 memory: 1.46 GiB unified: yes display-ID: :0.0
Info: Tools: api: eglinfo,glxinfo gpu: gputop, intel_gpu_top, lsgpu
x11: xprop,xrandr
Device-1: Intel Haswell-ULT HD Audio vendor: Lenovo driver: snd_hda_intel
v: kernel bus-ID: 00:03.0 chip-ID: 8086:0a0c class-ID: 0403
Device-2: Intel 8 Series HD Audio vendor: Lenovo driver: snd_hda_intel
v: kernel bus-ID: 00:1b.0 chip-ID: 8086:9c20 class-ID: 0403
API: ALSA v: k7.1.0-rc5-1-MANJARO status: kernel-api with: aoss
Server-3: PipeWire v: 1.6.5 status: active with: 1: pipewire-pulse
Device-1: Intel Wireless 7260 driver: iwlwifi v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 bus-ID: 02:00.0 chip-ID: 8086:08b2 class-ID: 0280
Device-1: Intel Bluetooth wireless interface driver: btusb v: 0.8 type: USB
rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-6:5 chip-ID: 8087:07dc
class-ID: e001
Report: rfkill ID: hci0 rfk-id: 2 state: down bt-service: enabled,running
Local Storage: total: 465.76 GiB used: 429.04 GiB (92.1%)
ID-1: /dev/sda maj-min: 8:0 model: UE800 size: 465.76 GiB block-size:
physical: 512 B logical: 512 B type: USB rev: 2.1 spd: 480 Mb/s lanes: 1
mode: 2.0 tech: SSD serial: <filter> fw-rev: 1000 scheme: MBR
ID-1: / raw-size: 465.64 GiB size: 465.64 GiB (100.00%)
used: 429.04 GiB (92.1%) fs: f2fs dev: /dev/sda2 maj-min: 8:2 label: N/A
uuid: 2dd184d2-3d3f-4f79-8df5-7fd5fc55ba51
ID-1: swap-1 type: file size: 4 GiB used: 0 KiB (0.0%) priority: -1
file: /swapfile
ID-1: /dev/sda1 maj-min: 8:1 size: 120 MiB fs: ext4 label: N/A
uuid: caae26c3-44fd-432b-9c98-04ce0a25f91b
Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 9 rev: 2.0
Device-1: 1-1:2 info: Elan Micro Touchscreen type: HID
driver: hid-multitouch,usbhid interfaces: 1 rev: 2.0
chip-ID: 04f3:007e class-ID: 0300
Device-2: 1-4:3 info: Silicon Motion - Taiwan (formerly Feiya ) UE800
type: mass storage driver: usb-storage interfaces: 1 rev: 2.1
chip-ID: 090c:de80 class-ID: 0806 serial: <filter>
Device-3: 1-5:4 info: Realtek Lenovo EasyCamera type: video
lanes: 1 mode: 2.0 power: 500mA chip-ID: 0bda:572a class-ID: 0e02
serial: <filter>
Device-4: 1-6:5 info: Intel Bluetooth wireless interface type: bluetooth
mode: 1.1 power: 100mA chip-ID: 8087:07dc class-ID: e001
Hub-2: 2-0:1 info: full speed or root hub ports: 2 rev: 2.0
Hub-3: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 8 rev: 2.0
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 8087:8000
Hub-4: 3-0:1 info: super-speed hub ports: 4 rev: 3.0
System Temperatures: cpu: 41.0 C mobo: N/A
Packages: pm: pacman pkgs: 1745 libs: 419 tools: gnome-software,pamac,yay
pm: flatpak pkgs: 0
1: https://ftp.snt.utwente.nl/pub/linux/manjaro/stable/$repo/$arch
2: https://ftp.caliu.cat/pub/distribucions/manjaro/stable/$repo/$arch
3: https://ftp.rz.tu-bs.de/pub/mirror/manjaro.org/repos/stable/$repo/$arch
4: https://mirrors.cicku.me/manjaro/stable/$repo/$arch
5: https://mirror.archlinux.tw/Manjaro/stable/$repo/$arch
6: https://mirror.kku.ac.th/manjaro/stable/$repo/$arch
7: https://ziply.mm.fcix.net/manjaro/stable/$repo/$arch
8: https://mirrors.ucr.ac.cr/manjaro/stable/$repo/$arch
Processes:
CPU top: 5 of 223
1: cpu: 14.5% command: localsearch-extractor-3 pid: 4043
mem: 36.8 MiB (0.9%)
2: cpu: 6.9% command: gnome-shell pid: 1641 mem: 297.9 MiB (7.7%)
3: cpu: 6.5% command: kgx pid: 3551 mem: 113.9 MiB (2.9%)
4: cpu: 3.8% command: ibus-extension-gtk3 pid: 1906 mem: 40.9 MiB (1.0%)
5: cpu: 3.6% command: flatpak-system-helper pid: 3317 mem: 20.8 MiB (0.5%)
Memory top: 5 of 223
1: mem: 297.9 MiB (7.7%) command: gnome-shell pid: 1641 cpu: 6.9%
2: mem: 172.2 MiB (4.4%) command: easyeffects pid: 1791 cpu: 1.1%
3: mem: 161.9 MiB (4.2%) command: python3 pid: 576 cpu: 0.9%
4: mem: 113.9 MiB (2.9%) command: kgx pid: 3551 cpu: 6.5%
5: mem: 92.0 MiB (2.3%) command: mutter-x11-frames pid: 2475 cpu: 1.2%
Processes: 223 Power: uptime: 3m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 1.48 GiB services: gsd-power,
power-profiles-daemon, upowerd Init: systemd v: 260 default: graphical
tool: systemctl
Compilers: clang: 22.1.5 gcc: 16.1.1 Shell: Zsh v: 5.9 running-in: kgx
inxi: 3.3.40
@Yamo If you want newer kernel than 6.12, you can try linux-zen-versioned-bin
My laptop regained ability to control brightness on that kernel and it’s supposedly more responsive than ordinary brewed ones, so who knows, maybe it’s worth taking shot?
@Empatheon
Thanks, for the suggestion.
Just to give you a bit of context so far the brightness has been working for me, it has been ever since kernel 5.10 or something—not sure exactly when it’s been 5 years :D—It was also working since 6.18 became LTS so far, up until the latest update, I had to rollback to my fallback kernel.
All is good now.
