After 2026-05-02 stable update: (EE) [drm] Failed to open DRM device for pci:0000:01:00.0: -19 with GEForce GTX 1050 ti
Dual head system became single head after 5-2-2026 update. Xlog output:
[     9.063]
X.Org X Server 1.21.1.22
[     9.063] Current Operating System: Linux ken-z690aorusmaster 7.0.3-1-MANJARO #1 SMP PREEMPT_DYNAMIC Thu, 30 Apr 2026 17:29:37 +0000 x86_64
[     9.063] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-7.0-x86_64 root=UUID=a25eebbf-f730-452c-ac04-28c04696c1c3 rw quiet splash apparmor=1 security=apparmor udev.log_priority=3
[     9.063]
[     9.063] Current version of pixman: 0.46.4
[     9.063]    Before reporting problems, check http://wiki.x.org
[     9.063] Markers: (--) probed, (**) from config file, (==) default setting,
[     9.063] (==) Log file: "/var/log/Xorg.0.log", Time: Sun May  3 16:44:59 2026
[     9.063] (==) Using config directory: "/etc/X11/xorg.conf.d"
[     9.064] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[     9.064] (==) No Layout section.  Using the first Screen section.
[     9.064] (==) No screen section available. Using defaults.
[     9.064] (**) |-->Screen "Default Screen Section" (0)
[     9.064] (**) |   |-->Monitor "<default monitor>"
[     9.065] (==) No monitor specified for screen "Default Screen Section".
[     9.065] (**) Allowing byte-swapped clients
[     9.065] (==) Automatically adding devices
[     9.065] (==) Automatically enabling devices
[     9.065] (==) Automatically adding GPU devices
[     9.065] (==) Automatically binding GPU devices
[     9.065] (==) Max clients allowed: 256, resource mask: 0x1fffff
[     9.065] (WW) The directory "/usr/share/fonts/OTF" does not exist.
[     9.065]    Entry deleted from font path.
[     9.065] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[     9.065] (WW) The directory "/usr/share/fonts/100dpi" does not exist.
[     9.065] (WW) The directory "/usr/share/fonts/75dpi" does not exist.
[     9.065] (==) FontPath set to:
        /usr/share/fonts/misc,
        /usr/share/fonts/TTF
[     9.065] (==) ModulePath set to "/usr/lib/xorg/modules"
[     9.065] (II) The server relies on udev to provide the list of input devices.
[     9.065] (II) Module ABI versions:
[     9.065]    X.Org ANSI C Emulation: 0.4
[     9.065]    X.Org Video Driver: 25.2
[     9.065]    X.Org XInput driver : 24.4
[     9.065]    X.Org Server Extension : 10.0
[     9.066] (++) using VT number 7
[     9.066] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[     9.066] (II) xfree86: Adding drm device (/dev/dri/card0)
[     9.066] (II) Platform probe for /sys/devices/pci0000:00/0000:00:01.0/0000:01:00.0/simple-framebuffer.0/drm/card0
[     9.067] (II) xfree86: Adding drm device (/dev/dri/card1)
[     9.067] (II) Platform probe for /sys/devices/pci0000:00/0000:00:02.0/drm/card1
[     9.068] (--) PCI: (0@0:2:0) 8086:4680:1458:d000 rev 12, Mem @ 0x41000000/16777216, 0x50000000/268435456, I/O @ 0x00004000/64
[     9.068] (--) PCI:*(1@0:0:0) 10de:1c82:1043:862a rev 161, Mem @ 0x42000000/16777216, 0x60000000/268435456, 0x70000000/33554432, I/O @ 0x00003000/128, BIOS @ 0x????????/131072
[     9.068] (II) LoadModule: "glx"
[     9.069] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[     9.072] (II) Module glx: vendor="X.Org Foundation"
[     9.072]    compiled for 1.21.1.22, module version = 1.0.0
[     9.072]    ABI class: X.Org Server Extension, version 10.0
[    10.065] (==) Matched nouveau as autoconfigured driver 0
[    10.065] (==) Matched nv as autoconfigured driver 1
[    10.065] (==) Matched modesetting as autoconfigured driver 2
[    10.065] (==) Matched fbdev as autoconfigured driver 3
[    10.065] (==) Matched vesa as autoconfigured driver 4
[    10.065] (==) Assigned the driver to the xf86ConfigLayout
[    10.065] (II) LoadModule: "nouveau"
[    10.067] (II) Loading /usr/lib/xorg/modules/drivers/nouveau_drv.so
[    10.068] (II) Module nouveau: vendor="X.Org Foundation"
[    10.068]    compiled for 1.21.1.14, module version = 1.0.18
[    10.068]    Module class: X.Org Video Driver
[    10.068]    ABI class: X.Org Video Driver, version 25.2
[    10.068] (II) LoadModule: "nv"
[    10.069] (WW) Warning, couldn't open module nv
[    10.069] (EE) Failed to load module "nv" (module does not exist, 0)
[    10.069] (II) LoadModule: "modesetting"
[    10.069] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[    10.070] (II) Module modesetting: vendor="X.Org Foundation"
[    10.070]    compiled for 1.21.1.22, module version = 1.21.1
[    10.070]    Module class: X.Org Video Driver
[    10.070]    ABI class: X.Org Video Driver, version 25.2
[    10.070] (II) LoadModule: "fbdev"
[    10.071] (WW) Warning, couldn't open module fbdev
[    10.071] (EE) Failed to load module "fbdev" (module does not exist, 0)
[    10.071] (II) LoadModule: "vesa"
[    10.071] (WW) Warning, couldn't open module vesa
[    10.071] (EE) Failed to load module "vesa" (module does not exist, 0)
[    10.071] (II) NOUVEAU driver
[    10.071] (II) NOUVEAU driver for NVIDIA chipset families :
[    10.071]    RIVA TNT            (NV04)
[    10.071]    RIVA TNT2           (NV05)
[    10.071]    GeForce 256         (NV10)
[    10.071]    GeForce 2           (NV11, NV15)
[    10.071]    GeForce 4MX         (NV17, NV18)
[    10.071]    GeForce 3           (NV20)
[    10.071]    GeForce 4Ti         (NV25, NV28)
[    10.071]    GeForce FX          (NV3x)
[    10.071]    GeForce 6           (NV4x)
[    10.071]    GeForce 7           (G7x)
[    10.071]    GeForce 8           (G8x)
[    10.071]    GeForce 9           (G9x)
[    10.071]    GeForce GTX 2xx/3xx (GT2xx)
[    10.071]    GeForce GTX 4xx/5xx (GFxxx)
[    10.071]    GeForce GTX 6xx/7xx (GKxxx)
[    10.071]    GeForce GTX 9xx     (GMxxx)
[    10.071]    GeForce GTX 10xx    (GPxxx)
[    10.071] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[    10.073] (EE) [drm] Failed to open DRM device for (null): -22
[    10.572] (EE) [drm] Failed to open DRM device for pci:0000:01:00.0: -19
[    10.574] (II) modeset(0): using drv /dev/dri/card0
[    10.574] (II) modeset(G0): using drv /dev/dri/card1
[    10.574] (II) modeset(0): Creating default Display subsection in Screen section
        "Default Screen Section" for depth/fbbpp 24/32
[    10.574] (==) modeset(0): Depth 24, (==) framebuffer bpp 32
[    10.574] (==) modeset(0): RGB weight 888
[    10.574] (==) modeset(0): Default visual is TrueColor
[    10.574] (II) Loading sub module "glamoregl"
[    10.574] (II) LoadModule: "glamoregl"
[    10.574] (II) Loading /usr/lib/xorg/modules/libglamoregl.so
[    10.588] (II) Module glamoregl: vendor="X.Org Foundation"
[    10.589]    compiled for 1.21.1.22, module version = 1.0.1
[    10.589]    ABI class: X.Org ANSI C Emulation, version 0.4
[    10.843] (II) modeset(0): glamor: Using OpenGL 4.5 context.
[    10.843] (II) modeset(0): Refusing to try glamor on llvmpipe
[    10.844] (II) modeset(0): glamor initialization failed
[    10.844] (II) modeset(0): ShadowFB: preferred NO, enabled NO
[    10.845] (II) modeset(0): Output None-1 has no monitor section
[    10.845] (II) modeset(0): EDID for output None-1
[    10.845] (II) modeset(0): Printing probed modes for output None-1
[    10.845] (II) modeset(0): Modeline "1024x768"x60.0   47.19  1024 1024 1024 1024  768 768 768 768 (46.1 kHz eP)
[    10.845] (II) modeset(0): Output None-1 connected
[    10.845] (II) modeset(0): Using exact sizes for initial modes
[    10.845] (II) modeset(0): Output None-1 using initial mode 1024x768 +0+0
[    10.845] (==) modeset(0): Using gamma correction (1.0, 1.0, 1.0)
[    10.845] (==) modeset(0): DPI set to (96, 96)
[    10.845] (II) Loading sub module "fb"
[    10.845] (II) LoadModule: "fb"
[    10.845] (II) Module "fb" already built-in
[    10.845] (==) modeset(G0): Depth 24, (==) framebuffer bpp 32
[    10.845] (==) modeset(G0): RGB weight 888
[    10.845] (==) modeset(G0): Default visual is TrueColor
[    10.845] (II) Loading sub module "glamoregl"
[    10.845] (II) LoadModule: "glamoregl"
[    10.845] (II) Loading /usr/lib/xorg/modules/libglamoregl.so
[    10.845] (II) Module glamoregl: vendor="X.Org Foundation"
[    10.845]    compiled for 1.21.1.22, module version = 1.0.1
[    10.845]    ABI class: X.Org ANSI C Emulation, version 0.4
[    10.863] (II) modeset(G0): glamor: Using OpenGL 4.6 context.
[    10.864] (II) modeset(G0): glamor X acceleration enabled on Mesa Intel(R) UHD Graphics 770 (ADL-S GT1)
[    10.864] (II) modeset(G0): glamor initialized
[    10.868] (II) modeset(G0): Output DP-1-1 has no monitor section
[    10.872] (II) modeset(G0): Output HDMI-1-1 has no monitor section
[    10.877] (II) modeset(G0): EDID for output DP-1-1
[    10.881] (II) modeset(G0): EDID for output HDMI-1-1
[    10.881] (==) modeset(G0): Using gamma correction (1.0, 1.0, 1.0)
[    10.881] (==) modeset(G0): DPI set to (96, 96)
[    10.881] (II) Loading sub module "fb"
[    10.881] (II) LoadModule: "fb"
[    10.881] (II) Module "fb" already built-in
[    10.882] (==) modeset(0): Backing store enabled
[    10.882] (==) modeset(0): Silken mouse enabled
[    10.883] (II) modeset(0): Initializing kms color map for depth 24, 8 bpc.
[    10.883] (==) modeset(0): DPMS enabled
[    10.905] (==) modeset(G0): Backing store enabled
[    10.905] (==) modeset(G0): Silken mouse enabled
[    10.905] (II) modeset(G0): Initializing kms color map for depth 24, 8 bpc.
[    10.905] (==) modeset(G0): DPMS enabled
[    10.905] (II) modeset(G0): [DRI2] Setup complete
[    10.905] (II) modeset(G0): [DRI2]   DRI driver: iris
[    10.905] (II) modeset(G0): [DRI2]   VDPAU driver: va_gl
[    10.905] (II) modeset(G0): Disable reverse prime offload mode for i915.
[    10.905] (II) Initializing extension Generic Event Extension
[    10.905] (II) Initializing extension SHAPE
[    10.905] (II) Initializing extension MIT-SHM
[    10.905] (II) Initializing extension XInputExtension
[    10.905] (II) Initializing extension XTEST
[    10.906] (II) Initializing extension BIG-REQUESTS
[    10.906] (II) Initializing extension SYNC
[    10.906] (II) Initializing extension XKEYBOARD
[    10.906] (II) Initializing extension XC-MISC
[    10.906] (II) Initializing extension SECURITY
[    10.906] (II) Initializing extension XFIXES
[    10.906] (II) Initializing extension RENDER
[    10.906] (II) Initializing extension RANDR
[    10.906] (II) Initializing extension COMPOSITE
[    10.906] (II) Initializing extension DAMAGE
[    10.906] (II) Initializing extension MIT-SCREEN-SAVER
[    10.906] (II) Initializing extension DOUBLE-BUFFER
[    10.906] (II) Initializing extension RECORD
[    10.907] (II) Initializing extension DPMS
[    10.907] (II) Initializing extension Present
[    10.907] (II) Initializing extension DRI3
[    10.907] (II) Initializing extension X-Resource
[    10.907] (II) Initializing extension XVideo
[    10.907] (II) Initializing extension XVideo-MotionCompensation
[    10.907] (II) Initializing extension GLX
[    10.907] (II) AIGLX: Screen 0 is not DRI2 capable
[    10.914] (II) IGLX: Loaded and initialized swrast
[    10.914] (II) GLX: Initialized DRISWRAST GL provider for screen 0
[    10.914] (II) Initializing extension XFree86-VidModeExtension
[    10.914] (II) Initializing extension XFree86-DGA
[    10.914] (II) Initializing extension XFree86-DRI
[    10.914] (II) Initializing extension DRI2
[    10.915] (II) modeset(G0): Damage tracking initialized
[    10.915] (II) modeset(0): Damage tracking initialized
[    10.915] (II) modeset(0): Setting screen physical size to 270 x 203
[    10.947] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=3 (/dev/input/event10)
[    10.947] (II) No input driver specified, ignoring this device.
[    10.947] (II) This device may have been added with another device file.
[    10.947] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=7 (/dev/input/event11)
[    10.947] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=8 (/dev/input/event12)
[    10.948] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=9 (/dev/input/event13)
[    10.948] (II) No input driver specified, ignoring this device.
[    10.948] (II) This device may have been added with another device file.
[    10.948] (II) config/udev: Adding input device Dynex 5-Button Wired Optical Mouse (/dev/input/event4)
[    10.948] (**) Dynex 5-Button Wired Optical Mouse: Applying InputClass "evdev pointer catchall"
[    10.948] (**) Dynex 5-Button Wired Optical Mouse: Applying InputClass "libinput pointer catchall"
[    10.948] (II) LoadModule: "libinput"
[    10.948] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[    10.950] (II) Module libinput: vendor="X.Org Foundation"
[    10.950]    compiled for 1.21.1.13, module version = 1.5.0
[    10.950]    Module class: X.Org XInput Driver
[    10.950]    ABI class: X.Org XInput driver, version 24.4
[    10.950] (II) Using input driver 'libinput' for 'Dynex 5-Button Wired Optical Mouse'
[    10.950] (**) Dynex 5-Button Wired Optical Mouse: always reports core events
[    10.950] (**) Option "Device" "/dev/input/event4"
[    11.007] (II) event4  - Dynex 5-Button Wired Optical Mouse: is tagged by udev as: Mouse
[    11.008] (II) event4  - Dynex 5-Button Wired Optical Mouse: device is a pointer
[    11.009] (II) event4  - Dynex 5-Button Wired Optical Mouse: device removed
[    11.027] (II) libinput: Dynex 5-Button Wired Optical Mouse: Step value 0 was provided, libinput Fallback acceleration function is used.
[    11.027] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-10/1-10.4/1-10.4.1/1-10.4.1:1.0/0003:0461:4D42.0003/input/input4/event4"
[    11.027] (II) XINPUT: Adding extended input device "Dynex 5-Button Wired Optical Mouse" (type: MOUSE, id 6)
[    11.027] (**) Option "AccelerationScheme" "none"
[    11.027] (**) Dynex 5-Button Wired Optical Mouse: (accel) selected scheme none/0
[    11.027] (**) Dynex 5-Button Wired Optical Mouse: (accel) acceleration factor: 2.000
[    11.027] (**) Dynex 5-Button Wired Optical Mouse: (accel) acceleration threshold: 4
[    11.082] (II) event4  - Dynex 5-Button Wired Optical Mouse: is tagged by udev as: Mouse
[    11.083] (II) event4  - Dynex 5-Button Wired Optical Mouse: device is a pointer
[    11.085] (II) config/udev: Adding input device Dynex 5-Button Wired Optical Mouse (/dev/input/mouse0)
[    11.085] (II) No input driver specified, ignoring this device.
[    11.085] (II) This device may have been added with another device file.
[    11.085] (II) config/udev: Adding input device NOVATEK Kensington U+P Keyboard (/dev/input/event5)
[    11.085] (**) NOVATEK Kensington U+P Keyboard: Applying InputClass "evdev keyboard catchall"
[    11.085] (**) NOVATEK Kensington U+P Keyboard: Applying InputClass "libinput keyboard catchall"
[    11.085] (**) NOVATEK Kensington U+P Keyboard: Applying InputClass "system-keyboard"
[    11.085] (II) Using input driver 'libinput' for 'NOVATEK Kensington U+P Keyboard'
[    11.085] (**) NOVATEK Kensington U+P Keyboard: always reports core events
[    11.085] (**) Option "Device" "/dev/input/event5"
[    11.086] (II) event5  - NOVATEK Kensington U+P Keyboard: is tagged by udev as: Keyboard
[    11.086] (II) event5  - NOVATEK Kensington U+P Keyboard: device is a keyboard
[    11.086] (II) event5  - NOVATEK Kensington U+P Keyboard: device removed
[    11.094] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-10/1-10.4/1-10.4.3/1-10.4.3:1.0/0003:047D:2043.0004/input/input5/event5"
[    11.094] (II) XINPUT: Adding extended input device "NOVATEK Kensington U+P Keyboard" (type: KEYBOARD, id 7)
[    11.094] (**) Option "xkb_layout" "us"
[    11.098] (II) event5  - NOVATEK Kensington U+P Keyboard: is tagged by udev as: Keyboard
[    11.098] (II) event5  - NOVATEK Kensington U+P Keyboard: device is a keyboard
[    11.101] (II) config/udev: Adding input device NOVATEK Kensington U+P Keyboard System Control (/dev/input/event6)
[    11.101] (**) NOVATEK Kensington U+P Keyboard System Control: Applying InputClass "evdev keyboard catchall"
[    11.101] (**) NOVATEK Kensington U+P Keyboard System Control: Applying InputClass "libinput keyboard catchall"
[    11.101] (**) NOVATEK Kensington U+P Keyboard System Control: Applying InputClass "system-keyboard"
[    11.101] (II) Using input driver 'libinput' for 'NOVATEK Kensington U+P Keyboard System Control'
[    11.101] (**) NOVATEK Kensington U+P Keyboard System Control: always reports core events
[    11.101] (**) Option "Device" "/dev/input/event6"
[    11.104] (II) event6  - NOVATEK Kensington U+P Keyboard System Control: is tagged by udev as: Keyboard
[    11.104] (II) event6  - NOVATEK Kensington U+P Keyboard System Control: device is a keyboard
[    11.104] (II) event6  - NOVATEK Kensington U+P Keyboard System Control: device removed
[    11.114] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-10/1-10.4/1-10.4.3/1-10.4.3:1.1/0003:047D:2043.0005/input/input6/event6"
[    11.114] (II) XINPUT: Adding extended input device "NOVATEK Kensington U+P Keyboard System Control" (type: KEYBOARD, id 8)
[    11.114] (**) Option "xkb_layout" "us"
[    11.118] (II) event6  - NOVATEK Kensington U+P Keyboard System Control: is tagged by udev as: Keyboard
[    11.118] (II) event6  - NOVATEK Kensington U+P Keyboard System Control: device is a keyboard
[    11.120] (II) config/udev: Adding input device NOVATEK Kensington U+P Keyboard Consumer Control (/dev/input/event7)
[    11.120] (**) NOVATEK Kensington U+P Keyboard Consumer Control: Applying InputClass "evdev keyboard catchall"
[    11.120] (**) NOVATEK Kensington U+P Keyboard Consumer Control: Applying InputClass "libinput keyboard catchall"
[    11.120] (**) NOVATEK Kensington U+P Keyboard Consumer Control: Applying InputClass "system-keyboard"
[    11.120] (II) Using input driver 'libinput' for 'NOVATEK Kensington U+P Keyboard Consumer Control'
[    11.120] (**) NOVATEK Kensington U+P Keyboard Consumer Control: always reports core events
[    11.120] (**) Option "Device" "/dev/input/event7"
[    11.122] (II) event7  - NOVATEK Kensington U+P Keyboard Consumer Control: is tagged by udev as: Keyboard
[    11.122] (II) event7  - NOVATEK Kensington U+P Keyboard Consumer Control: device is a keyboard
[    11.123] (II) event7  - NOVATEK Kensington U+P Keyboard Consumer Control: device removed
[    11.140] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-10/1-10.4/1-10.4.3/1-10.4.3:1.1/0003:047D:2043.0005/input/input7/event7"
[    11.140] (II) XINPUT: Adding extended input device "NOVATEK Kensington U+P Keyboard Consumer Control" (type: KEYBOARD, id 9)
[    11.140] (**) Option "xkb_layout" "us"
[    11.144] (II) event7  - NOVATEK Kensington U+P Keyboard Consumer Control: is tagged by udev as: Keyboard
[    11.144] (II) event7  - NOVATEK Kensington U+P Keyboard Consumer Control: device is a keyboard
[    11.146] (II) config/udev: Adding input device HDA Intel PCH Rear Mic (/dev/input/event14)
[    11.146] (II) No input driver specified, ignoring this device.
[    11.146] (II) This device may have been added with another device file.
[    11.147] (II) config/udev: Adding input device HDA Intel PCH Front Mic (/dev/input/event15)
[    11.147] (II) No input driver specified, ignoring this device.
[    11.147] (II) This device may have been added with another device file.
[    11.148] (II) config/udev: Adding input device HDA Intel PCH Line (/dev/input/event16)
[    11.148] (II) No input driver specified, ignoring this device.
[    11.148] (II) This device may have been added with another device file.
[    11.148] (II) config/udev: Adding input device HDA Intel PCH Line Out Front (/dev/input/event17)
[    11.149] (II) config/udev: Adding input device HDA Intel PCH Line Out Surround (/dev/input/event18)
[    11.149] (II) No input driver specified, ignoring this device.
[    11.149] (II) This device may have been added with another device file.
[    11.150] (II) config/udev: Adding input device HDA Intel PCH Line Out CLFE (/dev/input/event19)
[    11.150] (II) No input driver specified, ignoring this device.
[    11.150] (II) This device may have been added with another device file.
[    11.150] (II) config/udev: Adding input device HDA Intel PCH Front Headphone (/dev/input/event20)
[    11.151] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=3 (/dev/input/event21)
[    11.151] (II) No input driver specified, ignoring this device.
[    11.151] (II) This device may have been added with another device file.
[    11.151] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=7 (/dev/input/event22)
[    11.152] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=8 (/dev/input/event23)
[    11.152] (II) No input driver specified, ignoring this device.
[    11.152] (II) This device may have been added with another device file.
[    11.152] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=9 (/dev/input/event24)
[    11.153] (II) config/udev: Adding input device Video Bus (/dev/input/event3)
[    11.153] (**) Video Bus: Applying InputClass "evdev keyboard catchall"
[    11.153] (**) Video Bus: Applying InputClass "libinput keyboard catchall"
[    11.153] (**) Video Bus: Applying InputClass "system-keyboard"
[    11.153] (II) Using input driver 'libinput' for 'Video Bus'
[    11.153] (**) Video Bus: always reports core events
[    11.153] (**) Option "Device" "/dev/input/event3"
[    11.153] (II) event3  - Video Bus: is tagged by udev as: Keyboard
[    11.154] (II) event3  - Video Bus: device is a keyboard
[    11.154] (II) event3  - Video Bus: device removed
[    11.170] (**) Option "config_info" "udev:/sys/devices/pci0000:00/acpi.video_bus.0/input/input3/event3"
[    11.170] (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 10)
[    11.170] (**) Option "xkb_layout" "us"
[    11.172] (II) event3  - Video Bus: is tagged by udev as: Keyboard
[    11.172] (II) event3  - Video Bus: device is a keyboard
[    11.173] (II) config/udev: Adding input device Intel HID events (/dev/input/event8)
[    11.173] (**) Intel HID events: Applying InputClass "evdev keyboard catchall"
[    11.173] (**) Intel HID events: Applying InputClass "libinput keyboard catchall"
[    11.173] (**) Intel HID events: Applying InputClass "system-keyboard"
[    11.173] (II) Using input driver 'libinput' for 'Intel HID events'
[    11.173] (**) Intel HID events: always reports core events
[    11.173] (**) Option "Device" "/dev/input/event8"
[    11.175] (II) event8  - Intel HID events: is tagged by udev as: Keyboard
[    11.175] (II) event8  - Intel HID events: device is a keyboard
[    11.175] (II) event8  - Intel HID events: device removed
[    11.185] (**) Option "config_info" "udev:/sys/devices/platform/INTC1070:00/input/input8/event8"
[    11.185] (II) XINPUT: Adding extended input device "Intel HID events" (type: KEYBOARD, id 11)
[    11.185] (**) Option "xkb_layout" "us"
[    11.187] (II) event8  - Intel HID events: is tagged by udev as: Keyboard
[    11.187] (II) event8  - Intel HID events: device is a keyboard
[    11.188] (II) config/udev: Adding input device Power Button (/dev/input/event2)
[    11.188] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[    11.188] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[    11.188] (**) Power Button: Applying InputClass "system-keyboard"
[    11.188] (II) Using input driver 'libinput' for 'Power Button'
[    11.188] (**) Power Button: always reports core events
[    11.188] (**) Option "Device" "/dev/input/event2"
[    11.190] (II) event2  - Power Button: is tagged by udev as: Keyboard
[    11.190] (II) event2  - Power Button: device is a keyboard
[    11.190] (II) event2  - Power Button: device removed
[    11.196] (**) Option "config_info" "udev:/sys/devices/platform/LNXPWRBN:00/input/input2/event2"
[    11.196] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 12)
[    11.196] (**) Option "xkb_layout" "us"
[    11.198] (II) event2  - Power Button: is tagged by udev as: Keyboard
[    11.198] (II) event2  - Power Button: device is a keyboard
[    11.199] (II) config/udev: Adding input device Power Button (/dev/input/event1)
[    11.199] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[    11.199] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[    11.199] (**) Power Button: Applying InputClass "system-keyboard"
[    11.199] (II) Using input driver 'libinput' for 'Power Button'
[    11.199] (**) Power Button: always reports core events
[    11.199] (**) Option "Device" "/dev/input/event1"
[    11.201] (II) event1  - Power Button: is tagged by udev as: Keyboard
[    11.201] (II) event1  - Power Button: device is a keyboard
[    11.201] (II) event1  - Power Button: device removed
[    11.207] (**) Option "config_info" "udev:/sys/devices/platform/PNP0C0C:00/input/input1/event1"
[    11.207] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 13)
[    11.207] (**) Option "xkb_layout" "us"
[    11.209] (II) event1  - Power Button: is tagged by udev as: Keyboard
[    11.209] (II) event1  - Power Button: device is a keyboard
[    11.210] (II) config/udev: Adding input device Sleep Button (/dev/input/event0)
[    11.210] (**) Sleep Button: Applying InputClass "evdev keyboard catchall"
[    11.210] (**) Sleep Button: Applying InputClass "libinput keyboard catchall"
[    11.210] (**) Sleep Button: Applying InputClass "system-keyboard"
[    11.210] (II) Using input driver 'libinput' for 'Sleep Button'
[    11.210] (**) Sleep Button: always reports core events
[    11.210] (**) Option "Device" "/dev/input/event0"
[    11.212] (II) event0  - Sleep Button: is tagged by udev as: Keyboard
[    11.212] (II) event0  - Sleep Button: device is a keyboard
[    11.212] (II) event0  - Sleep Button: device removed
[    11.220] (**) Option "config_info" "udev:/sys/devices/platform/PNP0C0E:00/input/input0/event0"
[    11.220] (II) XINPUT: Adding extended input device "Sleep Button" (type: KEYBOARD, id 14)
[    11.220] (**) Option "xkb_layout" "us"
[    11.222] (II) event0  - Sleep Button: is tagged by udev as: Keyboard
[    11.222] (II) event0  - Sleep Button: device is a keyboard
[    11.223] (II) config/udev: Adding input device PC Speaker (/dev/input/event9)
[    11.223] (II) No input driver specified, ignoring this device.
[    11.223] (II) This device may have been added with another device file.
DMESG output:
[    0.000000] Linux version 7.0.3-1-MANJARO (linux70@manjaro) (gcc (GCC) 15.2.1 20260209, GNU ld (GNU Binutils) 2.46) #1 SMP PREEMPT_DYNAMIC Thu, 30 Apr 2026 17:29:37 +0000
[    0.000000] Command line: BOOT_IMAGE=/boot/vmlinuz-7.0-x86_64 root=UUID=a25eebbf-f730-452c-ac04-28c04696c1c3 rw quiet splash apparmor=1 security=apparmor udev.log_priority=3
[    0.000000] x86/tme: not enabled by BIOS
[    0.000000] x86/split lock detection: #AC: crashing the kernel on kernel split_locks and warning on user-space split_locks
[    0.000000] BIOS-provided physical RAM map:
[    0.000000] BIOS-e820: [mem 0x0000000000000000-0x000000000005dfff]  System RAM
[    0.000000] BIOS-e820: [mem 0x000000000005e000-0x000000000005efff]  device reserved
[    0.000000] BIOS-e820: [mem 0x000000000005f000-0x000000000009ffff]  System RAM
[    0.000000] BIOS-e820: [mem 0x00000000000a0000-0x00000000000fffff]  device reserved
[    0.000000] BIOS-e820: [mem 0x0000000000100000-0x0000000031e7dfff]  System RAM
[    0.000000] BIOS-e820: [mem 0x0000000031e7e000-0x0000000034f7dfff]  device reserved
[    0.000000] BIOS-e820: [mem 0x0000000034f7e000-0x00000000350e6fff]  ACPI data
[    0.000000] BIOS-e820: [mem 0x00000000350e7000-0x0000000035602fff]  ACPI NVS
[    0.000000] BIOS-e820: [mem 0x0000000035603000-0x0000000035ffefff]  device reserved
[    0.000000] BIOS-e820: [mem 0x0000000035fff000-0x0000000035ffffff]  System RAM
[    0.000000] BIOS-e820: [mem 0x0000000036000000-0x0000000039ffffff]  device reserved
[    0.000000] BIOS-e820: [gap 0x000000003a000000-0x000000003a9fffff]
[    0.000000] BIOS-e820: [mem 0x000000003aa00000-0x000000003abfffff]  device reserved
[    0.000000] BIOS-e820: [gap 0x000000003ac00000-0x000000003affffff]
[    0.000000] BIOS-e820: [mem 0x000000003b000000-0x00000000403fffff]  device reserved
[    0.000000] BIOS-e820: [gap 0x0000000040400000-0x00000000bfffffff]
[    0.000000] BIOS-e820: [mem 0x00000000c0000000-0x00000000cfffffff]  device reserved
[    0.000000] BIOS-e820: [gap 0x00000000d0000000-0x00000000fbffffff]
[    0.000000] BIOS-e820: [mem 0x00000000fc000000-0x00000000fc01ffff]  device reserved
[    0.000000] BIOS-e820: [gap 0x00000000fc020000-0x00000000fdffffff]
[    0.000000] BIOS-e820: [mem 0x00000000fe000000-0x00000000fe010fff]  device reserved
[    0.000000] BIOS-e820: [gap 0x00000000fe011000-0x00000000febfffff]
[    0.000000] BIOS-e820: [mem 0x00000000fec00000-0x00000000fec00fff]  device reserved
[    0.000000] BIOS-e820: [gap 0x00000000fec01000-0x00000000fecfffff]
[    0.000000] BIOS-e820: [mem 0x00000000fed00000-0x00000000fed00fff]  device reserved
[    0.000000] BIOS-e820: [gap 0x00000000fed01000-0x00000000fed1ffff]
[    0.000000] BIOS-e820: [mem 0x00000000fed20000-0x00000000fed7ffff]  device reserved
[    0.000000] BIOS-e820: [gap 0x00000000fed80000-0x00000000fedfffff]
[    0.000000] BIOS-e820: [mem 0x00000000fee00000-0x00000000fee00fff]  device reserved
[    0.000000] BIOS-e820: [gap 0x00000000fee01000-0x00000000feffffff]
[    0.000000] BIOS-e820: [mem 0x00000000ff000000-0x00000000ffffffff]  device reserved
[    0.000000] BIOS-e820: [mem 0x0000000100000000-0x00000008bfbfffff]  System RAM
[    0.000000] NX (Execute Disable) protection: active
[    0.000000] APIC: Static calls initialized
[    0.000000] efi: EFI v2.8 by American Megatrends
[    0.000000] efi: ACPI=0x35540000 ACPI 2.0=0x35540014 TPMFinalLog=0x3550d000 SMBIOS=0x35d33000 SMBIOS 3.0=0x35d32000 MEMATTR=0x28fe9018 ESRT=0x2ebb1b98 INITRD=0x28feb518 RNG=0x34fc5018 TPMEventLog=0x34fbf018
[    0.000000] random: crng init done
[    0.000000] efi: Remove mem82: MMIO range=[0xc0000000-0xcfffffff] (256MB) from e820 map
[    0.000000] e820: remove [mem 0xc0000000-0xcfffffff] device reserved
[    0.000000] efi: Not removing mem83: MMIO range=[0xfc000000-0xfc01ffff] (128KB) from e820 map
[    0.000000] efi: Not removing mem84: MMIO range=[0xfe000000-0xfe010fff] (68KB) from e820 map
[    0.000000] efi: Not removing mem85: MMIO range=[0xfec00000-0xfec00fff] (4KB) from e820 map
[    0.000000] efi: Not removing mem86: MMIO range=[0xfed00000-0xfed00fff] (4KB) from e820 map
[    0.000000] efi: Not removing mem88: MMIO range=[0xfee00000-0xfee00fff] (4KB) from e820 map
[    0.000000] efi: Remove mem89: MMIO range=[0xff000000-0xffffffff] (16MB) from e820 map
[    0.000000] e820: remove [mem 0xff000000-0xffffffff] device reserved
[    0.000000] SMBIOS 3.4.0 present.
[    0.000000] DMI: Gigabyte Technology Co., Ltd. Z690 AORUS MASTER/Z690 AORUS MASTER, BIOS F6 12/17/2021
[    0.000000] DMI: Memory slots populated: 2/4
[    0.000000] tsc: Detected 3200.000 MHz processor
[    0.000000] tsc: Detected 3187.200 MHz TSC
[    0.000283] e820: update [mem 0x00000000-0x00000fff] System RAM ==> device reserved
[    0.000286] e820: remove [mem 0x000a0000-0x000fffff] System RAM
[    0.000293] last_pfn = 0x8bfc00 max_arch_pfn = 0x400000000
[    0.000298] total RAM covered: 62400M
[    0.000398] Found optimal setting for mtrr clean up
[    0.000398]  gran_size: 64K 	chunk_size: 128M 	num_reg: 6  	lose cover RAM: 0G
[    0.000402] MTRR map: 6 entries (3 fixed + 3 variable; max 23), built from 10 variable MTRRs
[    0.000403] x86/PAT: Configuration [0-7]: WB  WC  UC- UC  WB  WP  UC- WT
[    0.000947] e820: update [mem 0x3c000000-0xffffffff] System RAM ==> device reserved
[    0.000950] last_pfn = 0x36000 max_arch_pfn = 0x400000000
[    0.006915] found SMP MP-table at [mem 0x000fcee0-0x000fceef]
[    0.006927] esrt: Reserving ESRT space from 0x000000002ebb1b98 to 0x000000002ebb1c20.
[    0.006932] e820: update [mem 0x2ebb1000-0x2ebb1fff] System RAM ==> device reserved
[    0.006947] Using GB pages for direct mapping
[    0.007171] Secure boot disabled
[    0.007172] RAMDISK: [mem 0x1c81d000-0x255d7fff]
[    0.007273] ACPI: Early table checksum verification disabled
[    0.007275] ACPI: RSDP 0x0000000035540014 000024 (v02 ALASKA)
[    0.007279] ACPI: XSDT 0x000000003553F728 000114 (v01 ALASKA A M I    01072009 AMI  01000013)
[    0.007283] ACPI: FACP 0x00000000350E4000 000114 (v06 ALASKA A M I    01072009 AMI  01000013)
[    0.007287] ACPI: DSDT 0x000000003506F000 074045 (v02 ALASKA A M I    01072009 INTL 20200717)
[    0.007289] ACPI: FACS 0x0000000035602000 000040
[    0.007291] ACPI: FIDT 0x000000003506E000 00009C (v01 ALASKA A M I    01072009 AMI  00010013)
[    0.007294] ACPI: SSDT 0x0000000035064000 009D9D (v02 GBT    GSWApp   00000001 INTL 20200717)
[    0.007296] ACPI: SSDT 0x0000000035061000 002A72 (v02 INTEL  DTbtSsdt 00001000 INTL 20200717)
[    0.007298] ACPI: SSDT 0x00000000350E6000 00038C (v02 PmaxDv Pmax_Dev 00000001 INTL 20200717)
[    0.007300] ACPI: SSDT 0x000000003505B000 005D01 (v02 CpuRef CpuSsdt  00003000 INTL 20200717)
[    0.007302] ACPI: SSDT 0x0000000035058000 002AA1 (v02 SaSsdt SaSsdt   00003000 INTL 20200717)
[    0.007304] ACPI: SSDT 0x0000000035054000 003339 (v02 INTEL  IgfxSsdt 00003000 INTL 20200717)
[    0.007306] ACPI: HPET 0x00000000350E5000 000038 (v01 ALASKA A M I    01072009 AMI  01000013)
[    0.007308] ACPI: APIC 0x0000000035053000 0001DC (v05 ALASKA A M I    01072009 AMI  01000013)
[    0.007310] ACPI: MCFG 0x0000000035052000 00003C (v01 ALASKA A M I    01072009 AMI  01000013)
[    0.007312] ACPI: SSDT 0x0000000035049000 00899E (v02 ALASKA A M I    00001000 INTL 20200717)
[    0.007314] ACPI: SSDT 0x0000000035047000 001F1A (v02 ALASKA A M I    00001000 INTL 20200717)
[    0.007316] ACPI: NHLT 0x0000000035046000 00002D (v00 ALASKA A M I    01072009 AMI  01000013)
[    0.007318] ACPI: LPIT 0x0000000035045000 0000CC (v01 ALASKA A M I    01072009 AMI  01000013)
[    0.007320] ACPI: SSDT 0x0000000035041000 002A83 (v02 ALASKA A M I    00001000 INTL 20200717)
[    0.007322] ACPI: SSDT 0x000000003503E000 002357 (v02 ALASKA A M I    00000000 INTL 20200717)
[    0.007324] ACPI: DBGP 0x000000003503D000 000034 (v01 ALASKA A M I    01072009 AMI  01000013)
[    0.007326] ACPI: DBG2 0x000000003503C000 000054 (v00 ALASKA A M I    01072009 AMI  01000013)
[    0.007328] ACPI: SSDT 0x000000003503A000 001919 (v02 ALASKA A M I    00001000 INTL 20200717)
[    0.007330] ACPI: SSDT 0x0000000035038000 0015A8 (v02 INTEL  xh_adls3 00000000 INTL 20200717)
[    0.007332] ACPI: SSDT 0x0000000035034000 003AEA (v02 SocGpe SocGpe   00003000 INTL 20200717)
[    0.007334] ACPI: SSDT 0x0000000035031000 002B2A (v02 SocCmn SocCmn   00003000 INTL 20200717)
[    0.007336] ACPI: SSDT 0x0000000035030000 000144 (v02 Intel  ADebTabl 00001000 INTL 20200717)
[    0.007338] ACPI: BGRT 0x000000003502F000 000038 (v01 ALASKA A M I    01072009 AMI  00010013)
[    0.007340] ACPI: TPM2 0x000000003502E000 00004C (v04 ALASKA A M I    00000001 AMI  00000000)
[    0.007342] ACPI: WPBT 0x0000000034FC8000 000038 (v01 ALASKA A M I    00000001 GBT  20181220)
[    0.007344] ACPI: PHAT 0x0000000034FC7000 0005D1 (v00 ALASKA A M I    00000005 MSFT 0100000D)
[    0.007346] ACPI: WSMT 0x0000000035044000 000028 (v01 ALASKA A M I    01072009 AMI  00010013)
[    0.007348] ACPI: FPDT 0x0000000034FC6000 000044 (v01 ALASKA A M I    01072009 AMI  01000013)
[    0.007350] ACPI: Reserving FACP table memory at [mem 0x350e4000-0x350e4113]
[    0.007351] ACPI: Reserving DSDT table memory at [mem 0x3506f000-0x350e3044]
[    0.007352] ACPI: Reserving FACS table memory at [mem 0x35602000-0x3560203f]
[    0.007352] ACPI: Reserving FIDT table memory at [mem 0x3506e000-0x3506e09b]
[    0.007353] ACPI: Reserving SSDT table memory at [mem 0x35064000-0x3506dd9c]
[    0.007353] ACPI: Reserving SSDT table memory at [mem 0x35061000-0x35063a71]
[    0.007354] ACPI: Reserving SSDT table memory at [mem 0x350e6000-0x350e638b]
[    0.007355] ACPI: Reserving SSDT table memory at [mem 0x3505b000-0x35060d00]
[    0.007355] ACPI: Reserving SSDT table memory at [mem 0x35058000-0x3505aaa0]
[    0.007356] ACPI: Reserving SSDT table memory at [mem 0x35054000-0x35057338]
[    0.007356] ACPI: Reserving HPET table memory at [mem 0x350e5000-0x350e5037]
[    0.007357] ACPI: Reserving APIC table memory at [mem 0x35053000-0x350531db]
[    0.007357] ACPI: Reserving MCFG table memory at [mem 0x35052000-0x3505203b]
[    0.007358] ACPI: Reserving SSDT table memory at [mem 0x35049000-0x3505199d]
[    0.007358] ACPI: Reserving SSDT table memory at [mem 0x35047000-0x35048f19]
[    0.007359] ACPI: Reserving NHLT table memory at [mem 0x35046000-0x3504602c]
[    0.007359] ACPI: Reserving LPIT table memory at [mem 0x35045000-0x350450cb]
[    0.007360] ACPI: Reserving SSDT table memory at [mem 0x35041000-0x35043a82]
[    0.007360] ACPI: Reserving SSDT table memory at [mem 0x3503e000-0x35040356]
[    0.007361] ACPI: Reserving DBGP table memory at [mem 0x3503d000-0x3503d033]
[    0.007361] ACPI: Reserving DBG2 table memory at [mem 0x3503c000-0x3503c053]
[    0.007362] ACPI: Reserving SSDT table memory at [mem 0x3503a000-0x3503b918]
[    0.007362] ACPI: Reserving SSDT table memory at [mem 0x35038000-0x350395a7]
[    0.007363] ACPI: Reserving SSDT table memory at [mem 0x35034000-0x35037ae9]
[    0.007363] ACPI: Reserving SSDT table memory at [mem 0x35031000-0x35033b29]
[    0.007364] ACPI: Reserving SSDT table memory at [mem 0x35030000-0x35030143]
[    0.007364] ACPI: Reserving BGRT table memory at [mem 0x3502f000-0x3502f037]
[    0.007365] ACPI: Reserving TPM2 table memory at [mem 0x3502e000-0x3502e04b]
[    0.007365] ACPI: Reserving WPBT table memory at [mem 0x34fc8000-0x34fc8037]
[    0.007366] ACPI: Reserving PHAT table memory at [mem 0x34fc7000-0x34fc75d0]
[    0.007367] ACPI: Reserving WSMT table memory at [mem 0x35044000-0x35044027]
[    0.007367] ACPI: Reserving FPDT table memory at [mem 0x34fc6000-0x34fc6043]
[    0.007521] No NUMA configuration found
[    0.007521] Faking a node at [mem 0x0000000000000000-0x00000008bfbfffff]
[    0.007526] NODE_DATA(0) allocated [mem 0x8bfbd5280-0x8bfbfffff]
[    0.007909] ACPI: PM-Timer IO Port: 0x1808
[    0.007917] ACPI: LAPIC_NMI (acpi_id[0x01] high edge lint[0x1])
[    0.007918] ACPI: LAPIC_NMI (acpi_id[0x02] high edge lint[0x1])
[    0.007919] ACPI: LAPIC_NMI (acpi_id[0x03] high edge lint[0x1])
[    0.007919] ACPI: LAPIC_NMI (acpi_id[0x04] high edge lint[0x1])
[    0.007920] ACPI: LAPIC_NMI (acpi_id[0x05] high edge lint[0x1])
[    0.007920] ACPI: LAPIC_NMI (acpi_id[0x06] high edge lint[0x1])
[    0.007921] ACPI: LAPIC_NMI (acpi_id[0x07] high edge lint[0x1])
[    0.007921] ACPI: LAPIC_NMI (acpi_id[0x08] high edge lint[0x1])
[    0.007922] ACPI: LAPIC_NMI (acpi_id[0x09] high edge lint[0x1])
[    0.007922] ACPI: LAPIC_NMI (acpi_id[0x0a] high edge lint[0x1])
[    0.007923] ACPI: LAPIC_NMI (acpi_id[0x0b] high edge lint[0x1])
[    0.007923] ACPI: LAPIC_NMI (acpi_id[0x0c] high edge lint[0x1])
[    0.007924] ACPI: LAPIC_NMI (acpi_id[0x0d] high edge lint[0x1])
[    0.007924] ACPI: LAPIC_NMI (acpi_id[0x0e] high edge lint[0x1])
[    0.007925] ACPI: LAPIC_NMI (acpi_id[0x0f] high edge lint[0x1])
[    0.007925] ACPI: LAPIC_NMI (acpi_id[0x10] high edge lint[0x1])
[    0.007926] ACPI: LAPIC_NMI (acpi_id[0x11] high edge lint[0x1])
[    0.007926] ACPI: LAPIC_NMI (acpi_id[0x12] high edge lint[0x1])
[    0.007927] ACPI: LAPIC_NMI (acpi_id[0x13] high edge lint[0x1])
[    0.007927] ACPI: LAPIC_NMI (acpi_id[0x14] high edge lint[0x1])
[    0.007928] ACPI: LAPIC_NMI (acpi_id[0x15] high edge lint[0x1])
[    0.007928] ACPI: LAPIC_NMI (acpi_id[0x16] high edge lint[0x1])
[    0.007929] ACPI: LAPIC_NMI (acpi_id[0x17] high edge lint[0x1])
[    0.007929] ACPI: LAPIC_NMI (acpi_id[0x00] high edge lint[0x1])
[    0.007948] IOAPIC[0]: apic_id 2, version 32, address 0xfec00000, GSI 0-119
[    0.007950] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[    0.007952] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[    0.007955] ACPI: Using ACPI (MADT) for SMP configuration information
[    0.007956] ACPI: HPET id: 0x8086a201 base: 0xfed00000
[    0.007961] e820: update [mem 0x29bd7000-0x29c2dfff] System RAM ==> device reserved
[    0.007970] TSC deadline timer available
[    0.007972] CPU topo: Max. logical packages:   1
[    0.007973] CPU topo: Max. logical nodes:      1
[    0.007973] CPU topo: Num. nodes per package:  1
[    0.007974] CPU topo: Max. logical dies:       1
[    0.007975] CPU topo: Max. dies per package:   1
[    0.007977] CPU topo: Max. threads per core:   2
[    0.007977] CPU topo: Num. cores per package:    16
[    0.007978] CPU topo: Num. threads per package:  24
[    0.007979] CPU topo: Allowing 24 present CPUs plus 0 hotplug CPUs
[    0.007994] PM: hibernation: Registered nosave memory: [mem 0x00000000-0x00000fff]
[    0.007995] PM: hibernation: Registered nosave memory: [mem 0x0005e000-0x0005efff]
[    0.007997] PM: hibernation: Registered nosave memory: [mem 0x000a0000-0x000fffff]
[    0.007998] PM: hibernation: Registered nosave memory: [mem 0x29bd7000-0x29c2dfff]
[    0.007999] PM: hibernation: Registered nosave memory: [mem 0x2ebb1000-0x2ebb1fff]
[    0.008001] PM: hibernation: Registered nosave memory: [mem 0x31e7e000-0x35ffefff]
[    0.008002] PM: hibernation: Registered nosave memory: [mem 0x36000000-0xffffffff]
[    0.008003] [gap 0x40400000-0xfbffffff] available for PCI devices
[    0.008004] Booting paravirtualized kernel on bare hardware
[    0.008005] clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1910969940391419 ns
[    0.014670] Zone ranges:
[    0.014671]   DMA      [mem 0x0000000000001000-0x0000000000ffffff]
[    0.014673]   DMA32    [mem 0x0000000001000000-0x00000000ffffffff]
[    0.014674]   Normal   [mem 0x0000000100000000-0x00000008bfbfffff]
[    0.014676]   Device   empty
[    0.014676] Movable zone start for each node
[    0.014677] Early memory node ranges
[    0.014678]   node   0: [mem 0x0000000000001000-0x000000000005dfff]
[    0.014679]   node   0: [mem 0x000000000005f000-0x000000000009ffff]
[    0.014679]   node   0: [mem 0x0000000000100000-0x0000000031e7dfff]
[    0.014680]   node   0: [mem 0x0000000035fff000-0x0000000035ffffff]
[    0.014681]   node   0: [mem 0x0000000100000000-0x00000008bfbfffff]
[    0.014683] Initmem setup node 0 [mem 0x0000000000001000-0x00000008bfbfffff]
[    0.014687] On node 0, zone DMA: 1 pages in unavailable ranges
[    0.014689] On node 0, zone DMA: 1 pages in unavailable ranges
[    0.014704] On node 0, zone DMA: 96 pages in unavailable ranges
[    0.015642] On node 0, zone DMA32: 16769 pages in unavailable ranges
[    0.050863] On node 0, zone Normal: 8192 pages in unavailable ranges
[    0.050870] On node 0, zone Normal: 1024 pages in unavailable ranges
[    0.050875] setup_percpu: NR_CPUS:8192 nr_cpumask_bits:24 nr_cpu_ids:24 nr_node_ids:1
[    0.051562] percpu: Embedded 63 pages/cpu s221184 r8192 d28672 u262144
[    0.051568] pcpu-alloc: s221184 r8192 d28672 u262144 alloc=1*2097152
[    0.051570] pcpu-alloc: [0] 00 01 02 03 04 05 06 07 [0] 08 09 10 11 12 13 14 15
[    0.051576] pcpu-alloc: [0] 16 17 18 19 20 21 22 23
[    0.051593] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-7.0-x86_64 root=UUID=a25eebbf-f730-452c-ac04-28c04696c1c3 rw quiet splash apparmor=1 security=apparmor udev.log_priority=3
[    0.051659] Unknown kernel command line parameters "splash", will be passed to user space.
[    0.051670] printk: log_buf_len individual max cpu contribution: 4096 bytes
[    0.051671] printk: log_buf_len total cpu_extra contributions: 94208 bytes
[    0.051672] printk: log_buf_len min size: 131072 bytes
[    0.051826] printk: log buffer data + meta data: 262144 + 1114112 = 1376256 bytes
[    0.051827] printk: early log buf free: 114824(87%)
[    0.054117] Dentry cache hash table entries: 4194304 (order: 13, 33554432 bytes, linear)
[    0.055263] Inode-cache hash table entries: 2097152 (order: 12, 16777216 bytes, linear)
[    0.055503] software IO TLB: area num 32.
[    0.064771] Fallback order for Node 0: 0
[    0.064774] Built 1 zonelists, mobility grouping on.  Total pages: 8329757
[    0.064775] Policy zone: Normal
[    0.064954] mem auto-init: stack:all(zero), heap alloc:on, heap free:off
[    0.110094] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=24, Nodes=1
[    0.116903] ftrace: allocating 58173 entries in 228 pages
[    0.116904] ftrace: allocated 228 pages with 4 groups
[    0.116994] Dynamic Preempt: full
[    0.117081] rcu: Preemptible hierarchical RCU implementation.
[    0.117082] rcu: 	RCU restricting CPUs from NR_CPUS=8192 to nr_cpu_ids=24.
[    0.117083] rcu: 	RCU priority boosting: priority 1 delay 500 ms.
[    0.117084] 	Trampoline variant of Tasks RCU enabled.
[    0.117085] 	Rude variant of Tasks RCU enabled.
[    0.117085] 	Tracing variant of Tasks RCU enabled.
[    0.117086] rcu: RCU calculated value of scheduler-enlistment delay is 100 jiffies.
[    0.117086] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=24
[    0.117101] RCU Tasks: Setting shift to 5 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=24.
[    0.117104] RCU Tasks Rude: Setting shift to 5 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=24.
[    0.121792] NR_IRQS: 524544, nr_irqs: 2248, preallocated irqs: 16
[    0.122005] rcu: srcu_init: Setting srcu_struct sizes based on contention.
[    0.122202] kfence: initialized - using 2097152 bytes for 255 objects at 0x(____ptrval____)-0x(____ptrval____)
[    0.122252] Console: colour dummy device 80x25
[    0.122254] printk: legacy console [tty0] enabled
[    0.122308] ACPI: Core revision 20251212
[    0.122603] hpet: HPET dysfunctional in PC10. Force disabled.
[    0.122645] APIC: Switch to symmetric I/O mode setup
[    0.123279] x2apic: IRQ remapping doesn't support X2APIC mode
[    0.125748] clocksource: tsc-early: mask: 0xffffffffffffffff max_cycles: 0x2df10e7656b, max_idle_ns: 440795364873 ns
[    0.125753] Calibrating delay loop (skipped), value calculated using timer frequency.. 6374.40 BogoMIPS (lpj=3187200)
[    0.125815] CPU0: Thermal monitoring enabled (TM1)
[    0.125818] x86/cpu: User Mode Instruction Prevention (UMIP) activated
[    0.125937] CET detected: Indirect Branch Tracking enabled
[    0.125938] Last level iTLB entries: 4KB 0, 2MB 0, 4MB 0
[    0.125939] Last level dTLB entries: 4KB 0, 2MB 0, 4MB 0, 1GB 0
[    0.125942] process: using mwait in idle threads
[    0.125944] mitigations: Enabled attack vectors: user_kernel, user_user, guest_host, guest_guest, SMT mitigations: auto
[    0.125948] Speculative Store Bypass: Mitigation: Speculative Store Bypass disabled via prctl
[    0.125950] Spectre V2 : Mitigation: Enhanced / Automatic IBRS
[    0.125950] Register File Data Sampling: Mitigation: Clear Register File
[    0.125951] VMSCAPE: Mitigation: IBPB before exit to userspace
[    0.125952] Spectre V1 : Mitigation: usercopy/swapgs barriers and __user pointer sanitization
[    0.125953] Spectre V2 : Spectre v2 / PBRSB-eIBRS: Retire a single CALL on VMEXIT
[    0.125954] Spectre V2 : mitigation: Enabling conditional Indirect Branch Prediction Barrier
[    0.125967] x86/fpu: Supporting XSAVE feature 0x001: 'x87 floating point registers'
[    0.125968] x86/fpu: Supporting XSAVE feature 0x002: 'SSE registers'
[    0.125969] x86/fpu: Supporting XSAVE feature 0x004: 'AVX registers'
[    0.125970] x86/fpu: Supporting XSAVE feature 0x200: 'Protection Keys User registers'
[    0.125971] x86/fpu: Supporting XSAVE feature 0x800: 'Control-flow User registers'
[    0.125972] x86/fpu: Supporting XSAVE feature 0x1000: 'Control-flow Kernel registers (KVM only)'
[    0.125973] x86/fpu: xstate_offset[2]:  576, xstate_sizes[2]:  256
[    0.125974] x86/fpu: xstate_offset[9]:  832, xstate_sizes[9]:    8
[    0.125975] x86/fpu: xstate_offset[11]:  840, xstate_sizes[11]:   16
[    0.125976] x86/fpu: xstate_offset[12]:  856, xstate_sizes[12]:   24
[    0.125977] x86/fpu: Enabled xstate features 0x1a07, context size is 880 bytes, using 'compacted' format.
[    0.126752] Freeing SMP alternatives memory: 56K
[    0.126752] pid_max: default: 32768 minimum: 301
[    0.126752] landlock: Up and running.
[    0.126752] Yama: becoming mindful.
[    0.126752] LSM support for eBPF active
[    0.126752] AppArmor: AppArmor initialized
[    0.126752] Mount-cache hash table entries: 65536 (order: 7, 524288 bytes, linear)
[    0.126752] Mountpoint-cache hash table entries: 65536 (order: 7, 524288 bytes, linear)
[    0.126752] VFS: Finished mounting rootfs on nullfs
[    0.126752] smpboot: CPU0: 12th Gen Intel(R) Core(TM) i9-12900K (family: 0x6, model: 0x97, stepping: 0x2)
[    0.126752] Performance Events: XSAVE Architectural LBR, PEBS fmt4+-baseline,  AnyThread deprecated, Alderlake Hybrid events, 32-deep LBR, full-width counters, Intel PMU driver.
[    0.126752] core: cpu_core PMU driver:
[    0.126752] ... version:                   5
[    0.126752] ... bit width:                 48
[    0.126752] ... generic counters:          8
[    0.126752] ... generic bitmap:            00000000000000ff
[    0.126752] ... fixed-purpose counters:    4
[    0.126752] ... fixed-purpose bitmap:      000000000000000f
[    0.126752] ... value mask:                0000ffffffffffff
[    0.126752] ... max period:                00007fffffffffff
[    0.126752] ... global_ctrl mask:          0001000f000000ff
[    0.126752] signal: max sigframe size: 3632
[    0.126752] Estimated ratio of average max frequency by base frequency (times 1024): 1600
[    0.127861] rcu: Hierarchical SRCU implementation.
[    0.127862] rcu: 	Max phase no-delay instances is 400.
[    0.127902] Timer migration: 2 hierarchy levels; 8 children per group; 2 crossnode level
[    0.128913] NMI watchdog: Enabled. Permanently consumes one hw-PMU counter.
[    0.129048] smp: Bringing up secondary CPUs ...
[    0.129110] smpboot: x86: Booting SMP configuration:
[    0.129111] .... node  #0, CPUs:        #2  #4  #6  #8 #10 #12 #14 #16 #17 #18 #19 #20 #21 #22 #23
[    0.004657] core: cpu_atom PMU driver:
[    0.004657] ... version:                   5
[    0.004657] ... bit width:                 48
[    0.004657] ... generic counters:          6
[    0.004657] ... generic bitmap:            000000000000003f
[    0.004657] ... fixed-purpose counters:    3
[    0.004657] ... fixed-purpose bitmap:      0000000000000007
[    0.004657] ... value mask:                0000ffffffffffff
[    0.004657] ... max period:                00007fffffffffff
[    0.004657] ... global_ctrl mask:          000000070000003f
[    0.137822]   #1  #3  #5  #7  #9 #11 #13 #15
[    0.143807] smp: Brought up 1 node, 24 CPUs
[    0.143807] smpboot: Total of 24 processors activated (152985.60 BogoMIPS)
[    0.144925] Memory: 32290424K/33319028K available (20734K kernel code, 3076K rwdata, 16840K rodata, 4804K init, 4396K bss, 995536K reserved, 0K cma-reserved)
[    0.145586] devtmpfs: initialized
[    0.145586] x86/mm: Memory block size: 128MB
[    0.147460] ACPI: PM: Registering ACPI NVS region [mem 0x350e7000-0x35602fff] (5357568 bytes)
[    0.147460] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275000 ns
[    0.147460] posixtimers hash table entries: 16384 (order: 6, 262144 bytes, linear)
[    0.147460] futex hash table entries: 8192 (524288 bytes on 1 NUMA nodes, total 512 KiB, linear).
[    0.147460] PM: RTC time: 20:44:50, date: 2026-05-03
[    0.147460] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[    0.147642] DMA: preallocated 4096 KiB GFP_KERNEL pool for atomic allocations
[    0.147912] DMA: preallocated 4096 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[    0.148207] DMA: preallocated 4096 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[    0.148211] audit: initializing netlink subsys (disabled)
[    0.148762] audit: type=2000 audit(1777841090.023:1): state=initialized audit_enabled=0 res=1
[    0.148821] thermal_sys: Registered thermal governor 'fair_share'
[    0.148822] thermal_sys: Registered thermal governor 'bang_bang'
[    0.148823] thermal_sys: Registered thermal governor 'step_wise'
[    0.148824] thermal_sys: Registered thermal governor 'user_space'
[    0.148825] thermal_sys: Registered thermal governor 'power_allocator'
[    0.148829] cpuidle: using governor ladder
[    0.148829] cpuidle: using governor menu
[    0.152230] efi: Freeing EFI boot services memory: 141928K
[    0.152233] ACPI FADT declares the system doesn't support PCIe ASPM, so disable it
[    0.152234] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[    0.152325] PCI: ECAM [mem 0xc0000000-0xcfffffff] (base 0xc0000000) for domain 0000 [bus 00-ff]
[    0.152339] PCI: Using configuration type 1 for base access
[    0.152786] kprobes: kprobe jump-optimization is enabled. All kprobes are optimized if possible.
[    0.158760] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
[    0.158760] HugeTLB: 16380 KiB vmemmap can be freed for a 1.00 GiB page
[    0.158760] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
[    0.158760] HugeTLB: 28 KiB vmemmap can be freed for a 2.00 MiB page
[    0.159756] raid6: skipped pq benchmark and selected avx2x4
[    0.159756] raid6: using avx2x2 recovery algorithm
[    0.159756] ACPI: Added _OSI(Module Device)
[    0.159756] ACPI: Added _OSI(Processor Device)
[    0.159756] ACPI: Added _OSI(Processor Aggregator Device)
[    0.233981] ACPI BIOS Error (bug): Failure creating named object [\ADBG], AE_ALREADY_EXISTS (20251212/dswload2-326)
[    0.233988] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20251212/psobject-220)
[    0.233990] ACPI: Skipping parse of AML opcode: Method (0x0014)
[    0.244680] ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PC00.I2C1.TPL1], AE_NOT_FOUND (20251212/dswload2-162)
[    0.244687] ACPI Error: AE_NOT_FOUND, During name lookup/catalog (20251212/psobject-220)
[    0.244689] ACPI: Skipping parse of AML opcode: Scope (0x0010)
[    0.253480] ACPI: 16 ACPI AML tables successfully acquired and loaded
[    1.366658] ACPI: \_SB_: platform _OSC: OS support mask [006e7eff]
[    1.370200] ACPI: \_SB_: platform _OSC: OS control mask [006a7eff]
[    1.371542] ACPI: Dynamic OEM Table Load:
[    1.371551] ACPI: SSDT 0xFFFF8E0903021000 000394 (v02 PmRef  Cpu0Cst  00003001 INTL 20200717)
[    1.372845] ACPI: Dynamic OEM Table Load:
[    1.372851] ACPI: SSDT 0xFFFF8E0901996800 000647 (v02 PmRef  Cpu0Ist  00003000 INTL 20200717)
[    1.374151] ACPI: Dynamic OEM Table Load:
[    1.374156] ACPI: SSDT 0xFFFF8E0902A9EE00 0001AB (v02 PmRef  Cpu0Psd  00003000 INTL 20200717)
[    1.375324] ACPI: Dynamic OEM Table Load:
[    1.375329] ACPI: SSDT 0xFFFF8E0901992000 000476 (v02 PmRef  Cpu0Hwp  00003000 INTL 20200717)
[    1.376989] ACPI: Dynamic OEM Table Load:
[    1.376997] ACPI: SSDT 0xFFFF8E090198C000 001BAF (v02 PmRef  ApIst    00003000 INTL 20200717)
[    1.378954] ACPI: Dynamic OEM Table Load:
[    1.378960] ACPI: SSDT 0xFFFF8E090198E000 001038 (v02 PmRef  ApHwp    00003000 INTL 20200717)
[    1.380689] ACPI: Dynamic OEM Table Load:
[    1.380696] ACPI: SSDT 0xFFFF8E090198A000 001349 (v02 PmRef  ApPsd    00003000 INTL 20200717)
[    1.382491] ACPI: Dynamic OEM Table Load:
[    1.382497] ACPI: SSDT 0xFFFF8E090199E000 000FBB (v02 PmRef  ApCst    00003000 INTL 20200717)
[    1.395116] ACPI: Interpreter enabled
[    1.395178] ACPI: PM: (supports S0 S3 S4 S5)
[    1.395180] ACPI: Using IOAPIC for interrupt routing
[    1.396630] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[    1.396631] PCI: Using E820 reservations for host bridge windows
[    1.397823] ACPI: Enabled 6 GPEs in block 00 to 7F
[    1.399162] ACPI: \_SB_.PC00.PEG1.PXP_: New power resource
[    1.419562] ACPI: \_SB_.PC00.XHCI.RHUB.HS14.BTRT: New power resource
[    1.421101] ACPI: \_SB_.PC00.PAUD: New power resource
[    1.424280] ACPI: \_SB_.PC00.I2C1.PXTC: New power resource
[    1.426935] ACPI: \_SB_.PC00.CNVW.WRST: New power resource
[    1.427208] ACPI: \SPR7: New power resource
[    1.441182] ACPI: \_TZ_.FN00: New power resource
[    1.441243] ACPI: \_TZ_.FN01: New power resource
[    1.441300] ACPI: \_TZ_.FN02: New power resource
[    1.441356] ACPI: \_TZ_.FN03: New power resource
[    1.441415] ACPI: \_TZ_.FN04: New power resource
[    1.441949] ACPI: \PIN_: New power resource
[    1.442152] ACPI: \SPR4: New power resource
[    1.442218] ACPI: \SPR5: New power resource
[    1.442280] ACPI: \SPR6: New power resource
[    1.442617] ACPI: PCI Root Bridge [PC00] (domain 0000 [bus 00-fe])
[    1.442623] acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI EDR HPX-Type3]
[    1.444253] acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug SHPCHotplug PME AER PCIeCapability LTR DPC]
[    1.444254] acpi PNP0A08:00: FADT indicates ASPM is unsupported, using BIOS configuration
[    1.445764] PCI host bridge to bus 0000:00
[    1.445767] pci_bus 0000:00: root bus resource [io  0x0000-0x0cf7 window]
[    1.445769] pci_bus 0000:00: root bus resource [io  0x0d00-0xffff window]
[    1.445771] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff window]
[    1.445772] pci_bus 0000:00: root bus resource [mem 0x40400000-0xbfffffff window]
[    1.445773] pci_bus 0000:00: root bus resource [bus 00-fe]
[    1.546686] pci 0000:00:00.0: [8086:4660] type 00 class 0x060000 conventional PCI endpoint
[    1.546814] pci 0000:00:01.0: [8086:460d] type 01 class 0x060400 PCIe Root Port
[    1.546826] pci 0000:00:01.0: PCI bridge to [bus 01]
[    1.546828] pci 0000:00:01.0:   bridge window [io  0x3000-0x3fff]
[    1.546831] pci 0000:00:01.0:   bridge window [mem 0x42000000-0x430fffff]
[    1.546835] pci 0000:00:01.0:   bridge window [mem 0x60000000-0x71ffffff 64bit pref]
[    1.546871] pci 0000:00:01.0: PME# supported from D0 D3hot D3cold
[    1.546892] pci 0000:00:01.0: PTM enabled (root), 4ns granularity
[    1.547501] pci 0000:00:02.0: [8086:4680] type 00 class 0x038000 PCIe Root Complex Integrated Endpoint
[    1.547514] pci 0000:00:02.0: BAR 0 [mem 0x41000000-0x41ffffff 64bit]
[    1.547516] pci 0000:00:02.0: BAR 2 [mem 0x50000000-0x5fffffff 64bit pref]
[    1.547517] pci 0000:00:02.0: BAR 4 [io  0x4000-0x403f]
[    1.547527] pci 0000:00:02.0: DMAR: Skip IOMMU disabling for graphics
[    1.547551] pci 0000:00:02.0: VF BAR 0 [mem 0x00000000-0x00ffffff 64bit]
[    1.547552] pci 0000:00:02.0: VF BAR 0 [mem 0x00000000-0x06ffffff 64bit]: contains BAR 0 for 7 VFs
[    1.547555] pci 0000:00:02.0: VF BAR 2 [mem 0x00000000-0x1fffffff 64bit pref]
[    1.547556] pci 0000:00:02.0: VF BAR 2 [mem 0x00000000-0xdfffffff 64bit pref]: contains BAR 2 for 7 VFs
[    1.547718] pci 0000:00:0a.0: [8086:467d] type 00 class 0x118000 PCIe Root Complex Integrated Endpoint
[    1.547733] pci 0000:00:0a.0: BAR 0 [mem 0x43b10000-0x43b17fff 64bit]
[    1.547739] pci 0000:00:0a.0: enabling Extended Tags
[    1.547850] pci 0000:00:14.0: [8086:7ae0] type 00 class 0x0c0330 conventional PCI endpoint
[    1.547889] pci 0000:00:14.0: BAR 0 [mem 0x43b00000-0x43b0ffff 64bit]
[    1.547933] pci 0000:00:14.0: PME# supported from D3hot D3cold
[    1.550773] pci 0000:00:14.2: [8086:7aa7] type 00 class 0x050000 conventional PCI endpoint
[    1.550820] pci 0000:00:14.2: BAR 0 [mem 0x43b20000-0x43b23fff 64bit]
[    1.550824] pci 0000:00:14.2: BAR 2 [mem 0x43b2f000-0x43b2ffff 64bit]
[    1.550968] pci 0000:00:14.3: [8086:7af0] type 00 class 0x028000 PCIe Root Complex Integrated Endpoint
[    1.551037] pci 0000:00:14.3: BAR 0 [mem 0x43b1c000-0x43b1ffff 64bit]
[    1.551136] pci 0000:00:14.3: PME# supported from D0 D3hot D3cold
[    1.551533] pci 0000:00:15.0: [8086:7acc] type 00 class 0x0c8000 conventional PCI endpoint
[    1.551640] pci 0000:00:15.0: BAR 0 [mem 0x00000000-0x00000fff 64bit]
[    1.562070] pci 0000:00:15.1: [8086:7acd] type 00 class 0x0c8000 conventional PCI endpoint
[    1.562133] pci 0000:00:15.1: BAR 0 [mem 0x00000000-0x00000fff 64bit]
[    1.572095] pci 0000:00:15.2: [8086:7ace] type 00 class 0x0c8000 conventional PCI endpoint
[    1.572155] pci 0000:00:15.2: BAR 0 [mem 0x00000000-0x00000fff 64bit]
[    1.582113] pci 0000:00:15.3: [8086:7acf] type 00 class 0x0c8000 conventional PCI endpoint
[    1.582181] pci 0000:00:15.3: BAR 0 [mem 0x00000000-0x00000fff 64bit]
[    1.592124] pci 0000:00:16.0: [8086:7ae8] type 00 class 0x078000 conventional PCI endpoint
[    1.592174] pci 0000:00:16.0: BAR 0 [mem 0x43b2b000-0x43b2bfff 64bit]
[    1.592226] pci 0000:00:16.0: PME# supported from D3hot
[    1.592902] pci 0000:00:17.0: [8086:7ae2] type 00 class 0x010601 conventional PCI endpoint
[    1.592939] pci 0000:00:17.0: BAR 0 [mem 0x43b24000-0x43b25fff]
[    1.592941] pci 0000:00:17.0: BAR 1 [mem 0x43b2a000-0x43b2a0ff]
[    1.592943] pci 0000:00:17.0: BAR 2 [io  0x4090-0x4097]
[    1.592945] pci 0000:00:17.0: BAR 3 [io  0x4080-0x4083]
[    1.592947] pci 0000:00:17.0: BAR 4 [io  0x4060-0x407f]
[    1.592949] pci 0000:00:17.0: BAR 5 [mem 0x43b29000-0x43b297ff]
[    1.592984] pci 0000:00:17.0: PME# supported from D3hot
[    1.593365] pci 0000:00:19.0: [8086:7afc] type 00 class 0x0c8000 conventional PCI endpoint
[    1.593428] pci 0000:00:19.0: BAR 0 [mem 0x00000000-0x00000fff 64bit]
[    1.604116] pci 0000:00:19.1: [8086:7afd] type 00 class 0x0c8000 conventional PCI endpoint
[    1.604215] pci 0000:00:19.1: BAR 0 [mem 0x00000000-0x00000fff 64bit]
[    1.614138] pci 0000:00:1c.0: [8086:7ab8] type 01 class 0x060400 PCIe Root Port
[    1.614162] pci 0000:00:1c.0: PCI bridge to [bus 02]
[    1.614168] pci 0000:00:1c.0:   bridge window [mem 0x43400000-0x438fffff]
[    1.614250] pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold
[    1.614287] pci 0000:00:1c.0: PTM enabled (root), 4ns granularity
[    1.614996] pci 0000:00:1c.4: [8086:7abc] type 01 class 0x060400 PCIe Root Port
[    1.615020] pci 0000:00:1c.4: PCI bridge to [bus 03]
[    1.615026] pci 0000:00:1c.4:   bridge window [mem 0x43a00000-0x43afffff]
[    1.615108] pci 0000:00:1c.4: PME# supported from D0 D3hot D3cold
[    1.615145] pci 0000:00:1c.4: PTM enabled (root), 4ns granularity
[    1.615850] pci 0000:00:1f.0: [8086:7a84] type 00 class 0x060100 conventional PCI endpoint
[    1.616238] pci 0000:00:1f.3: [8086:7ad0] type 00 class 0x040300 conventional PCI endpoint
[    1.616336] pci 0000:00:1f.3: BAR 0 [mem 0x43b18000-0x43b1bfff 64bit]
[    1.616347] pci 0000:00:1f.3: BAR 4 [mem 0x43900000-0x439fffff 64bit]
[    1.616440] pci 0000:00:1f.3: PME# supported from D3hot D3cold
[    1.617164] pci 0000:00:1f.4: [8086:7aa3] type 00 class 0x0c0500 conventional PCI endpoint
[    1.617214] pci 0000:00:1f.4: BAR 0 [mem 0x43b26000-0x43b260ff 64bit]
[    1.617221] pci 0000:00:1f.4: BAR 4 [io  0xefa0-0xefbf]
[    1.617509] pci 0000:00:1f.5: [8086:7aa4] type 00 class 0x0c8000 conventional PCI endpoint
[    1.617562] pci 0000:00:1f.5: BAR 0 [mem 0xfe010000-0xfe010fff]
[    1.617662] pci 0000:01:00.0: [10de:1c82] type 00 class 0x030000 PCIe Legacy Endpoint
[    1.617691] pci 0000:01:00.0: BAR 0 [mem 0x42000000-0x42ffffff]
[    1.617694] pci 0000:01:00.0: BAR 1 [mem 0x60000000-0x6fffffff 64bit pref]
[    1.617697] pci 0000:01:00.0: BAR 3 [mem 0x70000000-0x71ffffff 64bit pref]
[    1.617699] pci 0000:01:00.0: BAR 5 [io  0x3000-0x307f]
[    1.617700] pci 0000:01:00.0: ROM [mem 0x43000000-0x4307ffff pref]
[    1.617726] pci 0000:01:00.0: Video device with shadowed ROM at [mem 0x000c0000-0x000dffff]
[    1.617830] pci 0000:01:00.0: 32.000 Gb/s available PCIe bandwidth, limited by 2.5 GT/s PCIe x16 link at 0000:00:01.0 (capable of 126.016 Gb/s with 8.0 GT/s PCIe x16 link)
[    1.617909] pci 0000:01:00.1: [10de:0fb9] type 00 class 0x040300 PCIe Endpoint
[    1.617939] pci 0000:01:00.1: BAR 0 [mem 0x43080000-0x43083fff]
[    1.618044] pci 0000:00:01.0: PCI bridge to [bus 01]
[    1.618137] pci 0000:02:00.0: [1d6a:14c0] type 00 class 0x020000 PCIe Endpoint
[    1.618188] pci 0000:02:00.0: BAR 0 [mem 0x43800000-0x4387ffff 64bit]
[    1.618192] pci 0000:02:00.0: BAR 2 [mem 0x438a0000-0x438a0fff 64bit]
[    1.618196] pci 0000:02:00.0: BAR 4 [mem 0x43400000-0x437fffff 64bit]
[    1.618198] pci 0000:02:00.0: ROM [mem 0x43880000-0x4389ffff pref]
[    1.618322] pci 0000:02:00.0: supports D1 D2
[    1.618323] pci 0000:02:00.0: PME# supported from D0 D1 D3hot D3cold
[    1.618635] pci 0000:00:1c.0: PCI bridge to [bus 02]
[    1.618719] pci 0000:03:00.0: [144d:a808] type 00 class 0x010802 PCIe Endpoint
[    1.618771] pci 0000:03:00.0: BAR 0 [mem 0x43a00000-0x43a03fff 64bit]
[    1.619082] pci 0000:00:1c.4: PCI bridge to [bus 03]
[    1.621952] ACPI: PCI: Interrupt link LNKA configured for IRQ 0
[    1.622071] ACPI: PCI: Interrupt link LNKB configured for IRQ 1
[    1.622189] ACPI: PCI: Interrupt link LNKC configured for IRQ 0
[    1.622306] ACPI: PCI: Interrupt link LNKD configured for IRQ 0
[    1.622422] ACPI: PCI: Interrupt link LNKE configured for IRQ 0
[    1.622539] ACPI: PCI: Interrupt link LNKF configured for IRQ 0
[    1.622658] ACPI: PCI: Interrupt link LNKG configured for IRQ 0
[    1.622777] ACPI: PCI: Interrupt link LNKH configured for IRQ 0
[    1.631269] iommu: Default domain type: Translated
[    1.631269] iommu: DMA domain TLB invalidation policy: lazy mode
[    1.631868] SCSI subsystem initialized
[    1.631877] libata version 3.00 loaded.
[    1.631877] ACPI: bus type USB registered
[    1.631877] usbcore: registered new interface driver usbfs
[    1.631877] usbcore: registered new interface driver hub
[    1.631877] usbcore: registered new device driver usb
[    1.631877] EDAC MC: Ver: 3.0.0
[    1.631945] efivars: Registered efivars operations
[    1.632003] NetLabel: Initializing
[    1.632005] NetLabel:  domain hash size = 128
[    1.632005] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
[    1.632022] NetLabel:  unlabeled traffic allowed by default
[    1.632026] mctp: management component transport protocol core
[    1.632026] NET: Registered PF_MCTP protocol family
[    1.632036] PCI: Using ACPI for IRQ routing
[    1.641454] PCI: pci_cache_line_size set to 64 bytes
[    1.641511] pci 0000:00:1f.5: BAR 0 [mem 0xfe010000-0xfe010fff]: can't claim; no compatible bridge window
[    1.641560] e820: register RAM buffer resource [mem 0x0005e000-0x0005ffff]
[    1.641562] e820: register RAM buffer resource [mem 0x29bd7000-0x2bffffff]
[    1.641563] e820: register RAM buffer resource [mem 0x2ebb1000-0x2fffffff]
[    1.641564] e820: register RAM buffer resource [mem 0x31e7e000-0x33ffffff]
[    1.641565] e820: register RAM buffer resource [mem 0x36000000-0x37ffffff]
[    1.641565] e820: register RAM buffer resource [mem 0x8bfc00000-0x8bfffffff]
[    1.641775] pci 0000:01:00.0: vgaarb: setting as boot VGA device
[    1.641775] pci 0000:01:00.0: vgaarb: bridge control possible
[    1.641775] pci 0000:01:00.0: vgaarb: VGA device added: decodes=io+mem,owns=io+mem,locks=none
[    1.641775] vgaarb: loaded
[    1.642752] clocksource: Switched to clocksource tsc-early
[    1.642770] VFS: Disk quotas dquot_6.6.0
[    1.642770] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    1.643034] AppArmor: AppArmor Filesystem Enabled
[    1.643243] acpi PNP0C02:00: Reserved [io  0x0a00-0x0a2f]
[    1.643245] acpi PNP0C02:00: Reserved [io  0x0a30-0x0a3f]
[    1.643248] acpi PNP0C02:00: Reserved [io  0x0a40-0x0a4f]
[    1.643254] acpi PNP0C02:01: Skipped [io  0x002e-0x002f]
[    1.643255] acpi PNP0C02:01: Skipped [io  0x004e-0x004f]
[    1.643256] acpi PNP0C02:01: Skipped [io  0x0061]
[    1.643257] acpi PNP0C02:01: Skipped [io  0x0063]
[    1.643258] acpi PNP0C02:01: Skipped [io  0x0065]
[    1.643259] acpi PNP0C02:01: Skipped [io  0x0067]
[    1.643259] acpi PNP0C02:01: Skipped [io  0x0070]
[    1.643260] acpi PNP0C02:01: Skipped [io  0x0080]
[    1.643261] acpi PNP0C02:01: Skipped [io  0x0092]
[    1.643262] acpi PNP0C02:01: Skipped [io  0x00b2-0x00b3]
[    1.643263] acpi PNP0C02:01: Reserved [io  0x0680-0x069f]
[    1.643264] acpi PNP0C02:01: Reserved [io  0x164e-0x164f]
[    1.643361] acpi PNP0C02:02: Reserved [mem 0xfedc0000-0xfedc7fff]
[    1.643363] acpi PNP0C02:02: Reserved [mem 0xfeda0000-0xfeda0fff]
[    1.643364] acpi PNP0C02:02: Reserved [mem 0xfeda1000-0xfeda1fff]
[    1.643365] acpi PNP0C02:02: Reserved [mem 0xc0000000-0xcfffffff]
[    1.643366] acpi PNP0C02:02: Could not reserve [mem 0xfed20000-0xfed7ffff]
[    1.643368] acpi PNP0C02:02: Reserved [mem 0xfed90000-0xfed93fff]
[    1.643369] acpi PNP0C02:02: Could not reserve [mem 0xfed45000-0xfed8ffff]
[    1.643370] acpi PNP0C02:02: Could not reserve [mem 0xfee00000-0xfeefffff]
[    1.643433] acpi PNP0C02:03: Reserved [mem 0xfc000000-0xfc01ffff]
[    1.643748] acpi PNP0C02:04: Could not reserve [mem 0xfe000000-0xfe01ffff]
[    1.643749] acpi PNP0C02:04: Reserved [mem 0xfe04c000-0xfe04ffff]
[    1.643751] acpi PNP0C02:04: Reserved [mem 0xfe050000-0xfe0affff]
[    1.643752] acpi PNP0C02:04: Reserved [mem 0xfe0d0000-0xfe0fffff]
[    1.643753] acpi PNP0C02:04: Reserved [mem 0xfe200000-0xfe7fffff]
[    1.643754] acpi PNP0C02:04: Reserved [mem 0xff000000-0xffffffff]
[    1.643755] acpi PNP0C02:04: Could not reserve [io  0x1800-0x18fe]
[    1.643756] acpi PNP0C02:04: Reserved [mem 0xe0000000-0xe068ffff]
[    1.643758] acpi PNP0C02:04: Reserved [mem 0xe06c0000-0xe06cffff]
[    1.643759] acpi PNP0C02:04: Reserved [mem 0xe06f0000-0xefffffff]
[    1.643959] acpi PNP0C02:05: Reserved [io  0x2000-0x20fe]
[    1.644415] pnp: PnP ACPI init
[    1.646591] pnp: PnP ACPI: found 0 devices
[    1.651973] clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
[    1.652031] NET: Registered PF_INET protocol family
[    1.652211] IP idents hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[    1.666691] tcp_listen_portaddr_hash hash table entries: 16384 (order: 6, 262144 bytes, linear)
[    1.666723] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[    1.666888] TCP established hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[    1.667234] TCP bind hash table entries: 65536 (order: 9, 2097152 bytes, linear)
[    1.667325] TCP: Hash tables configured (established 262144 bind 65536)
[    1.667448] MPTCP token hash table entries: 32768 (order: 8, 786432 bytes, linear)
[    1.667573] UDP hash table entries: 16384 (order: 8, 1048576 bytes, linear)
[    1.667722] UDP-Lite hash table entries: 16384 (order: 8, 1048576 bytes, linear)
[    1.667832] NET: Registered PF_UNIX/PF_LOCAL protocol family
[    1.667838] NET: Registered PF_XDP protocol family
[    1.667850] pci 0000:00:02.0: VF BAR 2 [mem size 0xe0000000 64bit pref]: can't assign; no space
[    1.667853] pci 0000:00:02.0: VF BAR 2 [mem size 0xe0000000 64bit pref]: failed to assign
[    1.667857] pci 0000:00:02.0: VF BAR 0 [mem 0x44000000-0x4affffff 64bit]: assigned
[    1.667860] resource: avoiding allocation from e820 entry [mem 0x000a0000-0x000fffff]
[    1.667862] pci 0000:00:15.0: BAR 0 [mem 0x40400000-0x40400fff 64bit]: assigned
[    1.667881] resource: avoiding allocation from e820 entry [mem 0x000a0000-0x000fffff]
[    1.667882] pci 0000:00:15.1: BAR 0 [mem 0x40401000-0x40401fff 64bit]: assigned
[    1.667894] resource: avoiding allocation from e820 entry [mem 0x000a0000-0x000fffff]
[    1.667895] pci 0000:00:15.2: BAR 0 [mem 0x40402000-0x40402fff 64bit]: assigned
[    1.667906] resource: avoiding allocation from e820 entry [mem 0x000a0000-0x000fffff]
[    1.667907] pci 0000:00:15.3: BAR 0 [mem 0x40403000-0x40403fff 64bit]: assigned
[    1.667919] resource: avoiding allocation from e820 entry [mem 0x000a0000-0x000fffff]
[    1.667920] pci 0000:00:19.0: BAR 0 [mem 0x40404000-0x40404fff 64bit]: assigned
[    1.667931] resource: avoiding allocation from e820 entry [mem 0x000a0000-0x000fffff]
[    1.667932] pci 0000:00:19.1: BAR 0 [mem 0x40405000-0x40405fff 64bit]: assigned
[    1.667944] resource: avoiding allocation from e820 entry [mem 0x000a0000-0x000fffff]
[    1.667945] pci 0000:00:1f.5: BAR 0 [mem 0x40406000-0x40406fff]: assigned
[    1.667957] pci 0000:00:01.0: PCI bridge to [bus 01]
[    1.667959] pci 0000:00:01.0:   bridge window [io  0x3000-0x3fff]
[    1.667961] pci 0000:00:01.0:   bridge window [mem 0x42000000-0x430fffff]
[    1.667963] pci 0000:00:01.0:   bridge window [mem 0x60000000-0x71ffffff 64bit pref]
[    1.667967] pci 0000:00:1c.0: PCI bridge to [bus 02]
[    1.667974] pci 0000:00:1c.0:   bridge window [mem 0x43400000-0x438fffff]
[    1.667981] pci 0000:00:1c.4: PCI bridge to [bus 03]
[    1.667984] pci 0000:00:1c.4:   bridge window [mem 0x43a00000-0x43afffff]
[    1.667991] pci_bus 0000:00: Some PCI device resources are unassigned, try booting with pci=realloc
[    1.667992] pci_bus 0000:00: resource 4 [io  0x0000-0x0cf7 window]
[    1.667994] pci_bus 0000:00: resource 5 [io  0x0d00-0xffff window]
[    1.667995] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff window]
[    1.667996] pci_bus 0000:00: resource 7 [mem 0x40400000-0xbfffffff window]
[    1.667997] pci_bus 0000:01: resource 0 [io  0x3000-0x3fff]
[    1.667998] pci_bus 0000:01: resource 1 [mem 0x42000000-0x430fffff]
[    1.667999] pci_bus 0000:01: resource 2 [mem 0x60000000-0x71ffffff 64bit pref]
[    1.668000] pci_bus 0000:02: resource 1 [mem 0x43400000-0x438fffff]
[    1.668001] pci_bus 0000:03: resource 1 [mem 0x43a00000-0x43afffff]
[    1.668459] pci 0000:01:00.1: extending delay after power-on from D3hot to 20 msec
[    1.668482] pci 0000:01:00.1: D0 power state depends on 0000:01:00.0
[    1.668498] PCI: CLS 64 bytes, default 64
[    1.668515] PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
[    1.668515] software IO TLB: mapped [mem 0x000000001881d000-0x000000001c81d000] (64MB)
[    1.668560] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x2df10e7656b, max_idle_ns: 440795364873 ns
[    1.668564] Trying to unpack rootfs image as initramfs...
[    1.668650] clocksource: Switched to clocksource tsc
[    1.668672] platform rtc_cmos: registered platform RTC device (no PNP device found)
[    1.675171] Initialise system trusted keyrings
[    1.675183] Key type blacklist registered
[    1.675270] workingset: timestamp_bits=36 max_order=23 bucket_order=0
[    1.675510] fuse: init (API version 7.45)
[    1.676123] integrity: Platform Keyring initialized
[    1.676125] integrity: Machine keyring initialized
[    1.684935] xor: automatically using best checksumming function   avx
[    1.684937] Key type asymmetric registered
[    1.684938] Asymmetric key parser 'x509' registered
[    1.684959] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
[    1.685055] io scheduler mq-deadline registered
[    1.685056] io scheduler kyber registered
[    1.685067] io scheduler bfq registered
[    1.685974] ledtrig-cpu: registered to indicate activity on CPUs
[    1.686175] pcieport 0000:00:01.0: PME: Signaling with IRQ 120
[    1.686284] pcieport 0000:00:01.0: AER: enabled with IRQ 120
[    1.686493] pcieport 0000:00:1c.0: PME: Signaling with IRQ 121
[    1.686600] pcieport 0000:00:1c.0: AER: enabled with IRQ 121
[    1.686840] pcieport 0000:00:1c.4: PME: Signaling with IRQ 122
[    1.686931] pcieport 0000:00:1c.4: AER: enabled with IRQ 122
[    1.687193] input: Sleep Button as /devices/platform/PNP0C0E:00/input/input0
[    1.687208] ACPI: button: Sleep Button [SLPB]
[    1.687238] input: Power Button as /devices/platform/PNP0C0C:00/input/input1
[    1.687254] ACPI: button: Power Button [PWRB]
[    1.687275] input: Power Button as /devices/platform/LNXPWRBN:00/input/input2
[    1.687301] ACPI: button: Power Button [PWRF]
[    1.687567] Monitor-Mwait will be used to enter C-1 state
[    1.687575] Monitor-Mwait will be used to enter C-2 state
[    1.687580] Monitor-Mwait will be used to enter C-3 state
[    1.693136] acpi LNXTHERM:00: registered as thermal_zone0
[    1.693138] ACPI: thermal: Thermal Zone [TZ00] (28 C)
[    1.693307] Serial: 8250/16550 driver, 32 ports, IRQ sharing enabled
[    1.694679] hpet_acpi_add: no address or irqs in _CRS
[    1.694722] Non-volatile memory driver v1.3
[    1.694723] Linux agpgart interface v0.103
[    1.729984] ACPI: bus type drm_connector registered
[    1.732926] ahci 0000:00:17.0: AHCI vers 0001.0301, 32 command slots, 6 Gbps, SATA mode
[    1.732930] ahci 0000:00:17.0: 8/8 ports implemented (port mask 0xff)
[    1.732931] ahci 0000:00:17.0: flags: 64bit ncq sntf led clo only pio slum part ems deso sadm sds
[    1.747099] scsi host0: ahci
[    1.747286] scsi host1: ahci
[    1.747386] scsi host2: ahci
[    1.747480] scsi host3: ahci
[    1.747553] scsi host4: ahci
[    1.747615] scsi host5: ahci
[    1.747690] scsi host6: ahci
[    1.747763] scsi host7: ahci
[    1.747802] ata1: SATA max UDMA/133 abar m2048@0x43b29000 port 0x43b29100 irq 123 lpm-pol 3
[    1.747805] ata2: SATA max UDMA/133 abar m2048@0x43b29000 port 0x43b29180 irq 123 lpm-pol 3
[    1.747807] ata3: SATA max UDMA/133 abar m2048@0x43b29000 port 0x43b29200 irq 123 lpm-pol 3
[    1.747808] ata4: SATA max UDMA/133 abar m2048@0x43b29000 port 0x43b29280 irq 123 lpm-pol 3
[    1.747810] ata5: SATA max UDMA/133 abar m2048@0x43b29000 port 0x43b29300 irq 123 lpm-pol 3
[    1.747812] ata6: SATA max UDMA/133 abar m2048@0x43b29000 port 0x43b29380 irq 123 lpm-pol 3
[    1.747813] ata7: SATA max UDMA/133 abar m2048@0x43b29000 port 0x43b29400 irq 123 lpm-pol 3
[    1.747815] ata8: SATA max UDMA/133 abar m2048@0x43b29000 port 0x43b29480 irq 123 lpm-pol 3
[    1.748160] xhci_hcd 0000:00:14.0: xHCI Host Controller
[    1.748166] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 1
[    1.749252] xhci_hcd 0000:00:14.0: hcc params 0x20007fc1 hci version 0x120 quirks 0x0000000200009810
[    1.749523] xhci_hcd 0000:00:14.0: xHCI Host Controller
[    1.749527] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 2
[    1.749529] xhci_hcd 0000:00:14.0: Host supports USB 3.2 Enhanced SuperSpeed
[    1.749559] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 7.00
[    1.749561] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.749563] usb usb1: Product: xHCI Host Controller
[    1.749564] usb usb1: Manufacturer: Linux 7.0.3-1-MANJARO xhci-hcd
[    1.749565] usb usb1: SerialNumber: 0000:00:14.0
[    1.749661] hub 1-0:1.0: USB hub found
[    1.749684] hub 1-0:1.0: 16 ports detected
[    1.751868] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 7.00
[    1.751871] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.751872] usb usb2: Product: xHCI Host Controller
[    1.751873] usb usb2: Manufacturer: Linux 7.0.3-1-MANJARO xhci-hcd
[    1.751874] usb usb2: SerialNumber: 0000:00:14.0
[    1.751922] hub 2-0:1.0: USB hub found
[    1.751939] hub 2-0:1.0: 8 ports detected
[    1.753205] usbcore: registered new interface driver usbserial_generic
[    1.753208] usbserial: USB Serial support registered for generic
[    1.753228] i8042: PNP: No PS/2 controller found.
[    1.753288] rtc_cmos rtc_cmos: RTC can wake from S4
[    1.753749] rtc_cmos rtc_cmos: registered as rtc0
[    1.753841] rtc_cmos rtc_cmos: setting system clock to 2026-05-03T20:44:52 UTC (1777841092)
[    1.753873] rtc_cmos rtc_cmos: alarms up to one month, y3k, 114 bytes nvram
[    1.756160] Freeing initrd memory: 145132K
[    1.756724] intel_pstate: Intel P-state driver initializing
[    1.758501] intel_pstate: HWP enabled
[    1.758671] Relocating firmware framebuffer to offset 0x0000000001000000[d] within [mem 0x70000000-0x71ffffff flags 0x14220c]
[    1.758747] simple-framebuffer simple-framebuffer.0: [drm] Registered 1 planes with drm panic
[    1.758757] [drm] Initialized simpledrm 1.0.0 for simple-framebuffer.0 on minor 0
[    1.759088] fbcon: Deferring console take-over
[    1.759089] simple-framebuffer simple-framebuffer.0: [drm] fb0: simpledrmdrmfb frame buffer device
[    1.759108] hid: raw HID events driver (C) Jiri Kosina
[    1.759117] usbcore: registered new interface driver usbhid
[    1.759117] usbhid: USB HID core driver
[    1.759158] drop_monitor: Initializing network drop monitor service
[    1.759218] NET: Registered PF_INET6 protocol family
[    1.759362] Segment Routing with IPv6
[    1.759363] RPL Segment Routing with IPv6
[    1.759366] In-situ OAM (IOAM) with IPv6
[    1.759375] NET: Registered PF_PACKET protocol family
[    1.760497] microcode: Current revision: 0x0000003e
[    1.760498] microcode: Updated early from: 0x00000015
[    1.760758] resctrl: L2 allocation detected
[    1.760771] IPI shorthand broadcast: enabled
[    1.761651] sched_clock: Marking stable (1757097961, 3657680)->(1797859576, -37103935)
[    1.761770] registered taskstats version 1
[    1.762026] Loading compiled-in X.509 certificates
[    1.765373] Loaded X.509 cert 'Build time autogenerated kernel key: 917c23c04b4ef20cee6b1dde1e124e756c875d63'
[    1.766408] zswap: loaded using pool zstd
[    1.766433] Demotion targets for Node 0: null
[    1.766504] Key type .fscrypt registered
[    1.766504] Key type fscrypt-provisioning registered
[    1.766622] Btrfs loaded, zoned=yes, fsverity=yes
[    1.766634] Key type big_key registered
[    1.766635] AppArmor: AppArmor sha256 policy hashing enabled
[    1.766874] PM:   Magic number: 10:26:750
[    1.766881] ata_link link1: hash matches
[    1.766882]  link1: hash matches
[    1.766887] tty ttyS1: hash matches
[    1.766988] RAS: Correctable Errors collector initialized.
[    1.767079] clk: Disabling unused clocks
[    1.767080] PM: genpd: Disabling unused power domains
[    1.989826] usb 1-6: new high-speed USB device number 2 using xhci_hcd
[    2.052948] ata8: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[    2.053880] ata8.00: ATA-10: WDC WD10EZEX-22MFCA0, 01.01A01, max UDMA/133
[    2.055692] ata8.00: 1953525168 sectors, multi 16: LBA48 NCQ (depth 32), AA
[    2.055716] ata8.00: Features: HIPM NCQ-prio
[    2.057907] ata8.00: configured for UDMA/133
[    2.061630] ata1: SATA link down (SStatus 4 SControl 300)
[    2.061711] ata3: SATA link down (SStatus 4 SControl 300)
[    2.061768] ata6: SATA link down (SStatus 4 SControl 300)
[    2.061825] ata2: SATA link down (SStatus 4 SControl 300)
[    2.061908] ata4: SATA link down (SStatus 4 SControl 300)
[    2.061965] ata7: SATA link down (SStatus 4 SControl 300)
[    2.062023] ata5: SATA link down (SStatus 4 SControl 300)
[    2.062471] scsi 7:0:0:0: Direct-Access     ATA      WDC WD10EZEX-22M 1A01 PQ: 0 ANSI: 5
[    2.063436] sd 7:0:0:0: [sda] 1953525168 512-byte logical blocks: (1.00 TB/932 GiB)
[    2.063449] sd 7:0:0:0: [sda] 4096-byte physical blocks
[    2.063472] sd 7:0:0:0: [sda] Write Protect is off
[    2.063478] sd 7:0:0:0: [sda] Mode Sense: 00 3a 00 00
[    2.063506] sd 7:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[    2.063557] sd 7:0:0:0: [sda] Preferred minimum I/O size 4096 bytes
[    2.137734] usb 1-6: New USB device found, idVendor=0bda, idProduct=5420, bcdDevice= 1.70
[    2.137751] usb 1-6: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    2.137757] usb 1-6: Product: 4-Port USB 2.0 Hub
[    2.137762] usb 1-6: Manufacturer: Generic
[    2.140793] hub 1-6:1.0: USB hub found
[    2.142315] hub 1-6:1.0: 4 ports detected
[    2.157815]  sda: sda1 sda2 sda3 sda4 < sda5 sda6 sda7 >
[    2.159738] sd 7:0:0:0: [sda] Attached SCSI disk
[    2.169616] Freeing unused decrypted memory: 2028K
[    2.170209] Freeing unused kernel image (initmem) memory: 4804K
[    2.170222] Write protecting the kernel read-only data: 40960k
[    2.170919] Freeing unused kernel image (text/rodata gap) memory: 1792K
[    2.171190] Freeing unused kernel image (rodata/data gap) memory: 1592K
[    2.176326] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[    2.176329] rodata_test: all tests were successful
[    2.176332] Run /init as init process
[    2.176333]   with arguments:
[    2.176334]     /init
[    2.176334]     splash
[    2.176335]   with environment:
[    2.176335]     HOME=/
[    2.176336]     TERM=linux
[    2.241412] usb 2-4: new SuperSpeed Plus Gen 2x1 USB device number 2 using xhci_hcd
[    2.271589] usb 2-4: New USB device found, idVendor=0bda, idProduct=0420, bcdDevice= 1.70
[    2.271592] usb 2-4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    2.271593] usb 2-4: Product: 4-Port USB 3.0 Hub
[    2.271594] usb 2-4: Manufacturer: Generic
[    2.278805] hub 2-4:1.0: USB hub found
[    2.280381] hub 2-4:1.0: 4 ports detected
[    2.332288] ACPI: video: Video Device [GFX0] (multi-head: yes  rom: no  post: no)
[    2.332610] input: Video Bus as /devices/pci0000:00/acpi.video_bus.0/input/input3
[    2.333163] intel-lpss 0000:00:15.0: enabling device (0004 -> 0006)
[    2.333363] idma64 idma64.0: Found Intel integrated DMA 64-bit
[    2.336901] intel-lpss 0000:00:15.1: enabling device (0004 -> 0006)
[    2.337023] idma64 idma64.1: Found Intel integrated DMA 64-bit
[    2.339770] Key type psk registered
[    2.340456] intel-lpss 0000:00:15.2: enabling device (0004 -> 0006)
[    2.340585] idma64 idma64.2: Found Intel integrated DMA 64-bit
[    2.344069] intel-lpss 0000:00:15.3: enabling device (0004 -> 0006)
[    2.344238] idma64 idma64.3: Found Intel integrated DMA 64-bit
[    2.346423] nvme 0000:03:00.0: platform quirk: setting simple suspend
[    2.346489] nvme nvme0: pci function 0000:03:00.0
[    2.347745] intel-lpss 0000:00:19.0: enabling device (0004 -> 0006)
[    2.347876] idma64 idma64.4: Found Intel integrated DMA 64-bit
[    2.351268] intel-lpss 0000:00:19.1: enabling device (0004 -> 0006)
[    2.351381] idma64 idma64.5: Found Intel integrated DMA 64-bit
[    2.353031] nvme nvme0: missing or invalid SUBNQN field.
[    2.353162] nvme nvme0: D3 entry latency set to 8 seconds
[    2.374630] nvme nvme0: 24/0/0 default/read/poll queues
[    2.376668] usb 1-9: new high-speed USB device number 3 using xhci_hcd
[    2.378508]  nvme0n1: p1 p2 p3
[    2.516117] usb 1-9: New USB device found, idVendor=0bda, idProduct=5411, bcdDevice= 1.50
[    2.516119] usb 1-9: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    2.516120] usb 1-9: Product: 4-Port USB 2.0 Hub
[    2.516121] usb 1-9: Manufacturer: Generic
[    2.518000] hub 1-9:1.0: USB hub found
[    2.519035] hub 1-9:1.0: 4 ports detected
[    2.614719] i915 0000:00:02.0: enabling device (0006 -> 0007)
[    2.614810] i915 0000:00:02.0: [drm] Found alderlake_s (device ID 4680) integrated display version 12.00 stepping C0
[    2.615560] i915 0000:00:02.0: [drm] Using Transparent Hugepages
[    2.619995] i915 0000:00:02.0: [drm] Finished loading DMC firmware i915/adls_dmc_ver2_01.bin (v2.1)
[    2.621243] usb 2-7: new SuperSpeed USB device number 3 using xhci_hcd
[    2.633884] i915 0000:00:02.0: [drm] GT0: GuC firmware i915/tgl_guc_70.bin version 70.49.4
[    2.633887] i915 0000:00:02.0: [drm] GT0: HuC firmware i915/tgl_huc.bin version 7.9.3
[    2.647675] i915 0000:00:02.0: [drm] GT0: HuC: authenticated for all workloads
[    2.647690] i915 0000:00:02.0: [drm] GT0: GUC: submission disabled
[    2.647694] i915 0000:00:02.0: [drm] GT0: GUC: SLPC disabled
[    2.648564] i915 0000:00:02.0: [drm] Protected Xe Path (PXP) protected content support initialized
[    2.649343] i915 0000:00:02.0: [drm] Registered 4 planes with drm panic
[    2.649348] [drm] Initialized i915 1.6.0 for 0000:00:02.0 on minor 1
[    2.649548] usb 2-7: New USB device found, idVendor=0bda, idProduct=0411, bcdDevice= 1.50
[    2.649553] usb 2-7: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    2.649555] usb 2-7: Product: 2-Port USB 3.0 Hub
[    2.649557] usb 2-7: Manufacturer: Generic
[    2.656340] hub 2-7:1.0: USB hub found
[    2.657796] i915 0000:00:02.0: [drm] Cannot find any crtc or sizes
[    2.658788] hub 2-7:1.0: 4 ports detected
[    2.674080] i915 0000:00:02.0: [drm] Cannot find any crtc or sizes
[    2.682162] i915 0000:00:02.0: [drm] Cannot find any crtc or sizes
[    2.754665] usb 1-10: new high-speed USB device number 4 using xhci_hcd
[    2.896375] usb 1-10: New USB device found, idVendor=0bda, idProduct=5411, bcdDevice= 1.50
[    2.896378] usb 1-10: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    2.896378] usb 1-10: Product: 4-Port USB 2.0 Hub
[    2.896379] usb 1-10: Manufacturer: Generic
[    2.897842] hub 1-10:1.0: USB hub found
[    2.898827] hub 1-10:1.0: 4 ports detected
[    2.999778] usb 2-8: new SuperSpeed USB device number 4 using xhci_hcd
[    3.030733] usb 2-8: New USB device found, idVendor=0bda, idProduct=0411, bcdDevice= 1.50
[    3.030750] usb 2-8: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    3.030756] usb 2-8: Product: 2-Port USB 3.0 Hub
[    3.030761] usb 2-8: Manufacturer: Generic
[    3.040424] hub 2-8:1.0: USB hub found
[    3.041970] hub 2-8:1.0: 4 ports detected
[    3.133894] usb 1-12: new high-speed USB device number 5 using xhci_hcd
[    3.259401] usb 1-12: New USB device found, idVendor=05e3, idProduct=0608, bcdDevice=60.90
[    3.259418] usb 1-12: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[    3.259424] usb 1-12: Product: USB2.0 Hub
[    3.261994] hub 1-12:1.0: USB hub found
[    3.262427] hub 1-12:1.0: 4 ports detected
[    3.330841] usb 1-10.2: new full-speed USB device number 6 using xhci_hcd
[    3.419866] usb 1-10.2: New USB device found, idVendor=051d, idProduct=0002, bcdDevice= 0.90
[    3.419884] usb 1-10.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[    3.419890] usb 1-10.2: Product: Back-UPS XS 1500M FW:947.d11 .D USB FW:d11
[    3.419894] usb 1-10.2: Manufacturer: American Power Conversion
[    3.419898] usb 1-10.2: SerialNumber: 4B2207P19346
[    3.428129] hid-generic 0003:051D:0002.0001: hiddev96,hidraw0: USB HID v1.00 Device [American Power Conversion Back-UPS XS 1500M FW:947.d11 .D USB FW:d11     ] on usb-0000:00:14.0-10.2/input0
[    3.528836] usb 1-13: new full-speed USB device number 7 using xhci_hcd
[    3.663020] usb 1-13: New USB device found, idVendor=048d, idProduct=5702, bcdDevice= 0.01
[    3.663038] usb 1-13: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    3.663043] usb 1-13: Product: ITE Device
[    3.663047] usb 1-13: Manufacturer: ITE Tech. Inc.
[    3.669494] hid-generic 0003:048D:5702.0002: hiddev97,hidraw1: USB HID v1.12 Device [ITE Tech. Inc. ITE Device] on usb-0000:00:14.0-13/input0
[    3.727888] usb 1-10.4: new full-speed USB device number 8 using xhci_hcd
[    3.812327] usb 1-10.4: not running at top speed; connect to a high speed hub
[    3.813312] usb 1-10.4: New USB device found, idVendor=1a40, idProduct=0101, bcdDevice= 1.11
[    3.813330] usb 1-10.4: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[    3.813336] usb 1-10.4: Product: USB 2.0 Hub [Safe]
[    3.816967] hub 1-10.4:1.0: USB hub found
[    3.817120] hub 1-10.4:1.0: 4 ports detected
[    3.923817] usb 1-14: new full-speed USB device number 9 using xhci_hcd
[    4.049707] usb 1-14: New USB device found, idVendor=8087, idProduct=0033, bcdDevice= 0.00
[    4.049724] usb 1-14: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    4.221887] usb 1-10.4.1: new low-speed USB device number 10 using xhci_hcd
[    4.415008] usb 1-10.4.1: New USB device found, idVendor=0461, idProduct=4d42, bcdDevice= 1.00
[    4.415026] usb 1-10.4.1: New USB device strings: Mfr=0, Product=2, SerialNumber=0
[    4.415032] usb 1-10.4.1: Product: Dynex 5-Button Wired Optical Mouse
[    4.421690] input: Dynex 5-Button Wired Optical Mouse as /devices/pci0000:00/0000:00:14.0/usb1/1-10/1-10.4/1-10.4.1/1-10.4.1:1.0/0003:0461:4D42.0003/input/input4
[    4.422231] hid-generic 0003:0461:4D42.0003: input,hidraw2: USB HID v1.11 Mouse [Dynex 5-Button Wired Optical Mouse] on usb-0000:00:14.0-10.4.1/input0
[    4.597840] usb 1-10.4.3: new low-speed USB device number 11 using xhci_hcd
[    4.792526] usb 1-10.4.3: New USB device found, idVendor=047d, idProduct=2043, bcdDevice= 1.04
[    4.792544] usb 1-10.4.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    4.792549] usb 1-10.4.3: Product: Kensington U+P Keyboard
[    4.792554] usb 1-10.4.3: Manufacturer: NOVATEK
[    4.802987] input: NOVATEK Kensington U+P Keyboard as /devices/pci0000:00/0000:00:14.0/usb1/1-10/1-10.4/1-10.4.3/1-10.4.3:1.0/0003:047D:2043.0004/input/input5
[    4.872237] hid-generic 0003:047D:2043.0004: input,hidraw3: USB HID v1.10 Keyboard [NOVATEK Kensington U+P Keyboard] on usb-0000:00:14.0-10.4.3/input0
[    4.877229] input: NOVATEK Kensington U+P Keyboard System Control as /devices/pci0000:00/0000:00:14.0/usb1/1-10/1-10.4/1-10.4.3/1-10.4.3:1.1/0003:047D:2043.0005/input/input6
[    4.928250] input: NOVATEK Kensington U+P Keyboard Consumer Control as /devices/pci0000:00/0000:00:14.0/usb1/1-10/1-10.4/1-10.4.3/1-10.4.3:1.1/0003:047D:2043.0005/input/input7
[    4.928745] hid-generic 0003:047D:2043.0005: input,hidraw4: USB HID v1.10 Device [NOVATEK Kensington U+P Keyboard] on usb-0000:00:14.0-10.4.3/input1
[    5.071086] EXT4-fs (nvme0n1p3): mounted filesystem a25eebbf-f730-452c-ac04-28c04696c1c3 r/w with ordered data mode. Quota mode: none.
[    5.185856] systemd[1]: /etc/systemd/system.conf:67: Failed to parse DefaultLimitCORE=unlimited, ignoring: Invalid argument
[    5.854366] systemd[1]: systemd 260.1-2-manjaro running in system mode (+PAM +AUDIT -SELINUX +APPARMOR -IMA +IPE +SMACK +SECCOMP +GCRYPT +GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 +KMOD +LIBCRYPTSETUP +LIBCRYPTSETUP_PLUGINS +LIBFDISK +PCRE2 +PWQUALITY +P11KIT +QRENCODE +TPM2 +BZIP2 +LZ4 +XZ +ZLIB +ZSTD +BPF_FRAMEWORK +BTF +XKBCOMMON +UTMP +LIBARCHIVE)
[    5.854393] systemd[1]: Detected architecture x86-64.
[    5.864560] systemd[1]: Hostname set to <ken-z690aorusmaster>.
[    5.933555] systemd[1]: bpf-restrict-fs: LSM BPF program attached
[    6.127310] systemd[1]: Queued start job for default target Graphical Interface.
[    6.145674] systemd[1]: Created slice CUPS Slice.
[    6.146075] systemd[1]: Created slice Slice /system/dirmngr.
[    6.146411] systemd[1]: Created slice Slice /system/getty.
[    6.146738] systemd[1]: Created slice Slice /system/gpg-agent.
[    6.147054] systemd[1]: Created slice Slice /system/gpg-agent-browser.
[    6.147360] systemd[1]: Created slice Slice /system/gpg-agent-extra.
[    6.147647] systemd[1]: Created slice Slice /system/gpg-agent-ssh.
[    6.148005] systemd[1]: Created slice Slice /system/keyboxd.
[    6.148283] systemd[1]: Created slice Slice /system/modprobe.
[    6.148564] systemd[1]: Created slice Slice /system/systemd-fsck.
[    6.148744] systemd[1]: Created slice User and Session Slice.
[    6.148781] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[    6.148876] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[    6.148889] systemd[1]: Expecting device /dev/disk/by-uuid/33F7-CDB2...
[    6.148896] systemd[1]: Expecting device /dev/sda2...
[    6.148907] systemd[1]: Reached target Login Prompts.
[    6.148917] systemd[1]: Reached target Image Downloads.
[    6.148924] systemd[1]: Reached target Local Integrity Protected Volumes.
[    6.148945] systemd[1]: Reached target Remote File Systems.
[    6.148953] systemd[1]: Reached target Slice Units.
[    6.148964] systemd[1]: Reached target Mounting snaps.
[    6.148987] systemd[1]: Reached target Local Verity Protected Volumes.
[    6.149039] systemd[1]: Listening on Device-mapper event daemon FIFOs.
[    6.149088] systemd[1]: Listening on LVM2 poll daemon socket.
[    6.149716] systemd[1]: Listening on Query the User Interactively for a Password.
[    6.150407] systemd[1]: Listening on Process Core Dump Socket.
[    6.150821] systemd[1]: Listening on Credential Encryption/Decryption.
[    6.151363] systemd[1]: Listening on Factory Reset Management.
[    6.151404] systemd[1]: Listening on Journal Socket (/dev/log).
[    6.151436] systemd[1]: Listening on Journal Sockets.
[    6.152061] systemd[1]: Listening on Console Output Muting Service Socket.
[    6.152122] systemd[1]: Listening on Network Management Resolve Hook Socket.
[    6.152171] systemd[1]: Listening on Network Management Metrics Varlink Socket.
[    6.152220] systemd[1]: Listening on Network Management Varlink Socket.
[    6.152265] systemd[1]: Listening on Network Management Netlink Socket.
[    6.152405] systemd[1]: TPM PCR Measurements skipped, unmet condition check ConditionSecurity=measured-uki
[    6.152413] systemd[1]: Make TPM PCR Policy skipped, unmet condition check ConditionSecurity=measured-uki
[    6.152796] systemd[1]: Listening on Disk Repartitioning Service Socket.
[    6.152825] systemd[1]: Listening on Resolve Monitor Varlink Socket.
[    6.152850] systemd[1]: Listening on Resolve Service Varlink Socket.
[    6.152875] systemd[1]: Listening on udev Control Socket.
[    6.152900] systemd[1]: Listening on udev Kernel Socket.
[    6.152920] systemd[1]: Listening on udev Varlink Socket.
[    6.152942] systemd[1]: Listening on User Database Manager Socket.
[    6.153459] systemd[1]: Mounting Huge Pages File System...
[    6.153827] systemd[1]: Mounting POSIX Message Queue File System...
[    6.154156] systemd[1]: Mounting Kernel Debug File System...
[    6.154500] systemd[1]: Mounting Kernel Trace File System...
[    6.154943] systemd[1]: Starting Load AppArmor profiles...
[    6.155355] systemd[1]: Starting Create List of Static Device Nodes...
[    6.155690] systemd[1]: Starting Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling...
[    6.155703] systemd[1]: Load Kernel Module configfs skipped, unmet condition check ConditionKernelModuleLoaded=!configfs
[    6.156055] systemd[1]: Mounting Kernel Configuration File System...
[    6.156066] systemd[1]: Load Kernel Module drm skipped, unmet condition check ConditionKernelModuleLoaded=!drm
[    6.156079] systemd[1]: Load Kernel Module fuse skipped, unmet condition check ConditionKernelModuleLoaded=!fuse
[    6.156395] systemd[1]: Mounting FUSE Control File System...
[    6.156438] systemd[1]: File System Check on Root Device skipped, unmet condition check ConditionPathIsReadWrite=!/
[    6.156455] systemd[1]: Clear Stale Hibernate Storage Info skipped, unmet condition check ConditionPathExists=/sys/firmware/efi/efivars/HibernateLocation-8cf2644b-4b0b-428f-9387-6d876050dc67
[    6.157194] systemd[1]: Starting Journal Service...
[    6.157819] systemd[1]: Starting Load Kernel Modules...
[    6.158290] systemd[1]: Starting Generate Network Units from Kernel Command Line...
[    6.158319] systemd[1]: TPM PCR Machine ID Measurement skipped, unmet condition check ConditionSecurity=measured-uki
[    6.158776] systemd[1]: Starting Remount Root and Kernel File Systems...
[    6.158803] systemd[1]: Early TPM SRK Setup skipped, unmet condition check ConditionSecurity=measured-uki
[    6.159295] systemd[1]: Starting Load udev Rules from Credentials...
[    6.160484] systemd[1]: Starting Coldplug All udev Devices...
[    6.161130] systemd[1]: Starting Virtual Console Setup...
[    6.162609] systemd[1]: Mounted Huge Pages File System.
[    6.162693] systemd[1]: Mounted POSIX Message Queue File System.
[    6.162752] systemd[1]: Mounted Kernel Debug File System.
[    6.162805] systemd[1]: Mounted Kernel Trace File System.
[    6.163018] systemd[1]: Finished Create List of Static Device Nodes.
[    6.164866] systemd[1]: Mounted Kernel Configuration File System.
[    6.164932] systemd[1]: Mounted FUSE Control File System.
[    6.165251] systemd[1]: Finished Generate Network Units from Kernel Command Line.
[    6.165753] systemd[1]: Reached target Preparation for Network.
[    6.166563] systemd[1]: Starting Create Static Device Nodes in /dev gracefully...
[    6.169087] systemd[1]: Finished Load udev Rules from Credentials.
[    6.169701] systemd[1]: Finished Virtual Console Setup.
[    6.171552] systemd-journald[480]: Collecting audit messages is disabled.
[    6.173883] device-mapper: uevent: version 1.0.3
[    6.173928] device-mapper: ioctl: 4.50.0-ioctl (2025-04-28) initialised: dm-devel@lists.linux.dev
[    6.174176] systemd[1]: Finished Load Kernel Modules.
[    6.174649] systemd[1]: Starting Apply Kernel Variables...
[    6.178318] audit: type=1400 audit(1777841096.923:2): apparmor="STATUS" operation="profile_load" profile="unconfined" name="flatpak" pid=524 comm="apparmor_parser"
[    6.178321] audit: type=1400 audit(1777841096.923:3): apparmor="STATUS" operation="profile_load" profile="unconfined" name="1password" pid=502 comm="apparmor_parser"
[    6.178323] audit: type=1400 audit(1777841096.923:4): apparmor="STATUS" operation="profile_load" profile="unconfined" name="cam" pid=512 comm="apparmor_parser"
[    6.178324] audit: type=1400 audit(1777841096.923:5): apparmor="STATUS" operation="profile_load" profile="unconfined" name="ch-run" pid=514 comm="apparmor_parser"
[    6.178325] audit: type=1400 audit(1777841096.923:6): apparmor="STATUS" operation="profile_load" profile="unconfined" name="evolution" pid=522 comm="apparmor_parser"
[    6.178326] audit: type=1400 audit(1777841096.923:7): apparmor="STATUS" operation="profile_load" profile="unconfined" name="ch-checkns" pid=513 comm="apparmor_parser"
[    6.178326] audit: type=1400 audit(1777841096.923:8): apparmor="STATUS" operation="profile_load" profile="unconfined" name="vscode" pid=517 comm="apparmor_parser"
[    6.178327] audit: type=1400 audit(1777841096.923:9): apparmor="STATUS" operation="profile_load" profile="unconfined" name="buildah" pid=510 comm="apparmor_parser"
[    6.178328] audit: type=1400 audit(1777841096.923:10): apparmor="STATUS" operation="profile_load" profile="unconfined" name="balena-etcher" pid=507 comm="apparmor_parser"
[    6.178329] audit: type=1400 audit(1777841096.923:11): apparmor="STATUS" operation="profile_load" profile="unconfined" name="brave" pid=509 comm="apparmor_parser"
[    6.180982] systemd[1]: Finished Apply Kernel Variables.
[    6.183549] systemd[1]: Starting User Database Manager...
[    6.184785] systemd[1]: Starting CLI Netfilter Manager...
[    6.187881] EXT4-fs (nvme0n1p3): re-mounted a25eebbf-f730-452c-ac04-28c04696c1c3.
[    6.191989] systemd[1]: Finished Remount Root and Kernel File Systems.
[    6.192848] systemd[1]: Rebuild Hardware Database skipped, unmet condition check ConditionNeedsUpdate=/etc
[    6.194732] systemd[1]: Starting Load/Save OS Random Seed...
[    6.194759] systemd[1]: TPM SRK Setup skipped, unmet condition check ConditionSecurity=measured-uki
[    6.194782] systemd[1]: TPM PCR NvPCR Initialization Separator skipped, unmet condition check ConditionSecurity=measured-uki
[    6.194799] systemd[1]: TPM NvPCR Product ID Measurement skipped, unmet condition check ConditionSecurity=measured-uki
[    6.194876] systemd[1]: proc-sys-fs-binfmt_misc.automount: Got automount request for /proc/sys/fs/binfmt_misc, triggered by 572 ((systemd-userd))
[    6.199544] systemd[1]: Finished CLI Netfilter Manager.
[    6.211933] systemd[1]: Finished Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling.
[    6.212863] systemd[1]: Finished Load/Save OS Random Seed.
[    6.214178] systemd[1]: Started Journal Service.
[    6.228422] systemd-journald[480]: Received client request to flush runtime journal.
[    7.413741] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[    7.416530] Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[    7.416633] Loaded X.509 cert 'wens: 61c038651aabdcf94bd0ac7ff06c7248db18c600'
[    7.416941] input: Intel HID events as /devices/platform/INTC1070:00/input/input8
[    7.417135] intel-hid INTC1070:00: failed to enable HID power button
[    7.433064] EDAC ie31200: No ECC support
[    7.433870] mousedev: PS/2 mouse device common for all mice
[    7.434045] EDAC ie31200: No ECC support
[    7.441264] mei_me 0000:00:16.0: enabling device (0000 -> 0002)
[    7.463759] input: PC Speaker as /devices/platform/pcspkr/input/input9
[    7.463852] iwlwifi 0000:00:14.3: enabling device (0000 -> 0002)
[    7.469954] iwlwifi 0000:00:14.3: Detected crf-id 0x400410, cnv-id 0x80401 wfpm id 0x80000020
[    7.469978] iwlwifi 0000:00:14.3: PCI dev 7af0/0094, rev=0x430, rfid=0x2010d000
[    7.469980] iwlwifi 0000:00:14.3: Detected Intel(R) Wi-Fi 6E AX211 160MHz
[    7.478910] pps_core: LinuxPPS API ver. 1 registered
[    7.478912] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    7.478932] Bluetooth: Core ver 2.22
[    7.478939] NET: Registered PF_BLUETOOTH protocol family
[    7.478940] Bluetooth: HCI device and connection manager initialized
[    7.478945] Bluetooth: HCI socket layer initialized
[    7.478946] Bluetooth: L2CAP socket layer initialized
[    7.478948] Bluetooth: SCO socket layer initialized
[    7.479175] gigabyte-wmi DEADBEEF-2001-0000-00A0-C90629100000-8: No temperature sensors usable
[    7.479939] mei_pxp 0000:00:16.0-fbf6fcf1-96cf-4e2e-a6a6-1bab8cbe36b1: bound 0000:00:02.0 (ops i915_pxp_tee_component_ops [i915])
[    7.493764] intel_pmc_core INT33A1:00:  initialized
[    7.496476] PTP clock support registered
[    7.499068] spi-nor spi0.0: supply vcc not found, using dummy regulator
[    7.499092] MACsec IEEE 802.1AE
[    7.499608] i801_smbus 0000:00:1f.4: SMBus using PCI interrupt
[    7.500784] iwlwifi 0000:00:14.3: loaded firmware version 89.735b75a4.0 so-a0-gf-a0-89.ucode op_mode iwlmvm
[    7.501512] Creating 1 MTD partitions on "0000:00:1f.5":
[    7.501515] 0x000000000000-0x000002000000 : "BIOS"
[    7.501584] i2c i2c-16: Successfully instantiated SPD at 0x51
[    7.502102] i2c i2c-16: Successfully instantiated SPD at 0x53
[    7.504197] Adding 33554428k swap on /dev/sda2.  Priority:-1 extents:1 across:33554428k
[    7.532803] spd5118 16-0051: DDR5 temperature sensor: vendor 0x00:0xb3 revision 2.2
[    7.534416] RAPL PMU: API unit is 2^-32 Joules, 3 fixed counters, 655360 ms ovfl timer
[    7.534419] RAPL PMU: hw unit of domain pp0-core 2^-14 Joules
[    7.534420] RAPL PMU: hw unit of domain package 2^-14 Joules
[    7.534421] RAPL PMU: hw unit of domain pp1-gpu 2^-14 Joules
[    7.535033] usbcore: registered new interface driver btusb
[    7.535042] iTCO_wdt iTCO_wdt: Found a Intel PCH TCO device (Version=6, TCOBASE=0x0400)
[    7.535113] iTCO_wdt iTCO_wdt: initialized. heartbeat=30 sec (nowayout=0)
[    7.537090] Bluetooth: hci0: Device revision is 0
[    7.537099] Bluetooth: hci0: Secure boot is enabled
[    7.537102] Bluetooth: hci0: OTP lock is enabled
[    7.537104] Bluetooth: hci0: API lock is enabled
[    7.537106] Bluetooth: hci0: Debug lock is disabled
[    7.537108] Bluetooth: hci0: Minimum firmware build 1 week 10 2014
[    7.537111] Bluetooth: hci0: Bootloader timestamp 2019.40 buildtype 1 build 38
[    7.537229] Bluetooth: hci0: DSM reset method type: 0x00
[    7.538697] spd5118 16-0053: DDR5 temperature sensor: vendor 0x00:0xb3 revision 2.2
[    7.566264] Bluetooth: hci0: Found device firmware: intel/ibt-1040-0041.sfi
[    7.566272] Bluetooth: hci0: Boot Address: 0x100800
[    7.566273] Bluetooth: hci0: Firmware Version: 202-5.26
[    7.570761] atlantic: Detect ATL2FW 1030007
[    7.592850] atlantic 0000:02:00.0 enp2s0: renamed from eth0
[    7.600333] snd_hda_intel 0000:00:1f.3: enabling device (0000 -> 0002)
[    7.600504] snd_hda_intel 0000:00:1f.3: bound 0000:00:02.0 (ops intel_audio_component_bind_ops [i915])
[    7.600710] snd_hda_intel 0000:01:00.1: Disabling MSI
[    7.600715] snd_hda_intel 0000:01:00.1: Handle vga_switcheroo audio client
[    7.631354] input: HDA NVidia HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input10
[    7.631385] input: HDA NVidia HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input11
[    7.631404] input: HDA NVidia HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input12
[    7.631424] input: HDA NVidia HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input13
[    7.634867] snd_hda_codec_alc882 hdaudioC0D0: ALC1220: picked fixup  for PCI SSID 1458:a0d5
[    7.635579] snd_hda_codec_alc882 hdaudioC0D0: autoconfig for ALC1220: line_outs=3 (0x1b/0x15/0x16/0x0/0x0) type:line
[    7.635583] snd_hda_codec_alc882 hdaudioC0D0:    speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[    7.635585] snd_hda_codec_alc882 hdaudioC0D0:    hp_outs=1 (0x14/0x0/0x0/0x0/0x0)
[    7.635586] snd_hda_codec_alc882 hdaudioC0D0:    mono: mono_out=0x0
[    7.635587] snd_hda_codec_alc882 hdaudioC0D0:    dig-out=0x1e/0x0
[    7.635588] snd_hda_codec_alc882 hdaudioC0D0:    inputs:
[    7.635589] snd_hda_codec_alc882 hdaudioC0D0:      Rear Mic=0x18
[    7.635590] snd_hda_codec_alc882 hdaudioC0D0:      Front Mic=0x19
[    7.635591] snd_hda_codec_alc882 hdaudioC0D0:      Line=0x1a
[    7.636728] intel_tcc_cooling: TCC Offset locked
[    7.683302] input: HDA Intel PCH Rear Mic as /devices/pci0000:00/0000:00:1f.3/sound/card0/input14
[    7.683338] input: HDA Intel PCH Front Mic as /devices/pci0000:00/0000:00:1f.3/sound/card0/input15
[    7.683355] input: HDA Intel PCH Line as /devices/pci0000:00/0000:00:1f.3/sound/card0/input16
[    7.683371] input: HDA Intel PCH Line Out Front as /devices/pci0000:00/0000:00:1f.3/sound/card0/input17
[    7.683387] input: HDA Intel PCH Line Out Surround as /devices/pci0000:00/0000:00:1f.3/sound/card0/input18
[    7.683404] input: HDA Intel PCH Line Out CLFE as /devices/pci0000:00/0000:00:1f.3/sound/card0/input19
[    7.683423] input: HDA Intel PCH Front Headphone as /devices/pci0000:00/0000:00:1f.3/sound/card0/input20
[    7.683440] input: HDA Intel PCH HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input21
[    7.683460] input: HDA Intel PCH HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input22
[    7.683476] input: HDA Intel PCH HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input23
[    7.683491] input: HDA Intel PCH HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input24
[    7.696634] intel_rapl_msr: PL4 support detected.
[    7.696727] intel_rapl_common: Found RAPL domain package
[    7.696734] intel_rapl_common: Found RAPL domain core
[    7.696737] intel_rapl_common: Found RAPL domain uncore
[    7.791205] iwlwifi 0000:00:14.3: WFPM_UMAC_PD_NOTIFICATION: 0x20
[    7.791235] iwlwifi 0000:00:14.3: WFPM_LMAC2_PD_NOTIFICATION: 0x1f
[    7.791244] iwlwifi 0000:00:14.3: WFPM_AUTH_KEY_0: 0x90
[    7.791252] iwlwifi 0000:00:14.3: CNVI_SCU_SEQ_DATA_DW9: 0x0
[    7.791278] iwlwifi 0000:00:14.3: Detected RF GF, rfid=0x2010d000
[    7.792379] iwlwifi 0000:00:14.3: RFIm is deactivated, reason = 5
[    7.877841] iwlwifi 0000:00:14.3: base HW address: 60:dd:8e:01:f1:76
[    7.903992] iwlwifi 0000:00:14.3 wlo1: renamed from wlan0
[    8.191025] loop: module loaded
[    8.194012] loop0: detected capacity change from 0 to 100888
[    8.194074] loop2: detected capacity change from 0 to 643872
[    8.194113] loop3: detected capacity change from 0 to 151456
[    8.194158] loop1: detected capacity change from 0 to 677624
[    8.194478] loop5: detected capacity change from 0 to 99056
[    8.194592] loop4: detected capacity change from 0 to 151512
[    8.197777] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    8.398271] loop6: detected capacity change from 0 to 8
[    8.399567] NET: Registered PF_QIPCRTR protocol family
[    8.615628] iwlwifi 0000:00:14.3: WFPM_UMAC_PD_NOTIFICATION: 0x20
[    8.615688] iwlwifi 0000:00:14.3: WFPM_LMAC2_PD_NOTIFICATION: 0x1f
[    8.615696] iwlwifi 0000:00:14.3: WFPM_AUTH_KEY_0: 0x90
[    8.615704] iwlwifi 0000:00:14.3: CNVI_SCU_SEQ_DATA_DW9: 0x0
[    8.616747] iwlwifi 0000:00:14.3: RFIm is deactivated, reason = 5
[    8.845919] Bluetooth: hci0: Waiting for firmware download to complete
[    8.846044] Bluetooth: hci0: Firmware loaded in 1249782 usecs
[    8.846073] Bluetooth: hci0: Waiting for device to boot
[    8.862135] Bluetooth: hci0: Device booted in 15698 usecs
[    8.866108] Bluetooth: hci0: Found Intel DDC parameters: intel/ibt-1040-0041.ddc
[    8.868164] Bluetooth: hci0: Applying Intel DDC parameters completed
[    8.871185] Bluetooth: hci0: Firmware timestamp 2026.5 buildtype 1 build 82122
[    8.871188] Bluetooth: hci0: Firmware SHA1: 0x2925677d
[    8.875132] Bluetooth: hci0: Fseq status: Success (0x00)
[    8.875134] Bluetooth: hci0: Fseq executed: 00.00.02.41
[    8.875135] Bluetooth: hci0: Fseq BT Top: 00.00.02.41
[    8.904244] iwlwifi 0000:00:14.3: WFPM_UMAC_PD_NOTIFICATION: 0x20
[    8.904254] iwlwifi 0000:00:14.3: WFPM_LMAC2_PD_NOTIFICATION: 0x1f
[    8.904262] iwlwifi 0000:00:14.3: WFPM_AUTH_KEY_0: 0x90
[    8.904270] iwlwifi 0000:00:14.3: CNVI_SCU_SEQ_DATA_DW9: 0x0
[    8.905419] iwlwifi 0000:00:14.3: RFIm is deactivated, reason = 5
[   13.597911] atlantic 0000:02:00.0 enp2s0: atlantic: link change old 0 new 100
[   19.177403] nvme nvme0: using unchecked data buffer
[   72.396919] TCP: enp2s0: Driver has suspect GRO implementation, TCP performance may be compromised.
[  127.871932] kauditd_printk_skb: 160 callbacks suppressed
[  127.871935] audit: type=1400 audit(1777841218.563:172): apparmor="STATUS" operation="profile_load" profile="unconfined" name="docker-default" pid=5169 comm="apparmor_parser"
[  128.340050] Initializing XFRM netlink socket
[  128.366945] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[  128.427027] atlantic 0000:02:00.0 enp2s0: atlantic: link change old 100 new 0
[  133.523947] atlantic 0000:02:00.0 enp2s0: atlantic: link change old 0 new 100
Anything else you need to help me out?
Thanks,
Ken
Mod Edit: Fixed formatting
Whilst I don’t have experience with (or access to) NVidia hardware (so can’t really help here) it will likely be beneficial if you also post your system information:
inxi -zv8
Please remember to use proper code formatting. :slight_smile:
Mini How-To for code formatting
Select and copy all the text in the Terminal window, then paste the output in between two lines containing three backticks ``` or three tildes ~~~ (or paste then highlight the text and click the </> button at the top of the reply window, easier for smaller outputs).
inxi -zv8
  Kernel: 7.0.3-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
    parameters: BOOT_IMAGE=/boot/vmlinuz-7.0-x86_64
    root=UUID=a25eebbf-f730-452c-ac04-28c04696c1c3 rw quiet splash apparmor=1
  Desktop: Xfce v: 4.20.2 tk: Gtk v: 3.24.52 wm: xfwm4 v: 4.20.0
    with: xfce4-panel tools: xfce4-screensaver vt: 7 dm: LightDM v: 1.32.0
  Type: Desktop System: Gigabyte product: Z690 AORUS MASTER v: -CF
    serial: <superuser required>
  Mobo: Gigabyte model: Z690 AORUS MASTER v: x.x
    serial: <superuser required> uuid: <superuser required> Firmware: UEFI
    vendor: American Megatrends LLC. v: F6 date: 12/17/2021
  System RAM: total: 32 GiB available: 31.11 GiB used: 2.48 GiB (8.0%)
  Array-1: capacity: 256 GiB slots: 4 modules: 2 EC: None
    max-module-size: 64 GiB note: est.
  Device-1: Controller0-ChannelA-DIMM0 type: no module installed
  Device-2: Controller0-ChannelA-DIMM1 type: DDR5 detail: synchronous
    size: 16 GiB speed: 4800 MT/s volts: curr: 1 min: 1 max: 1.25 width (bits):
    data: 64 total: 64 manufacturer: Corsair part-no: CMT32GX5M2X5600C36
    serial: N/A
  Device-3: Controller1-ChannelA-DIMM0 type: no module installed
  Device-4: Controller1-ChannelA-DIMM1 type: DDR5 detail: synchronous
    serial: N/A
  Info: model: 12th Gen Intel Core i9-12900K bits: 64 type: MST AMCP
    arch: Alder Lake gen: core 12 level: v3 note: check built: 2021+
    process: Intel 7 (10nm ESF) family: 6 model-id: 0x97 (151) stepping: 2
    microcode: 0x3E
  Topology: cpus: 1x dies: 1 clusters: 10 cores: 16 threads: 24 mt: 8 tpc: 2
    st: 8 smt: enabled cache: L1: 1.4 MiB desc: d-8x32 KiB, 8x48 KiB; i-8x32
    KiB, 8x64 KiB L2: 14 MiB desc: 8x1.2 MiB, 2x2 MiB L3: 30 MiB
    desc: 1x30 MiB
  Speed (MHz): avg: 2402 min/max: 800/5100:5200:3900 scaling:
    driver: intel_pstate governor: powersave cores: 1: 2402 2: 2402 3: 2402
    4: 2402 5: 2402 6: 2402 7: 2402 8: 2402 9: 2402 10: 2402 11: 2402 12: 2402
    13: 2402 14: 2402 15: 2402 16: 2402 17: 2402 18: 2402 19: 2402 20: 2402
    21: 2402 22: 2402 23: 2402 24: 2402 bogomips: 152985
    bts cat_l2 cdp_l2 clflush clflushopt clwb cmov constant_tsc cpuid
    cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts ept ept_ad erms est f16c
    flexpriority flush_l1d fma fpu fsgsbase fsrm fxsr gfni hfi ht hwp
    hwp_act_window hwp_epp hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ibt
    ida intel_pt invpcid lahf_lm lm mca mce md_clear mmx monitor movbe
    movdir64b movdiri msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pcid
    pclmulqdq pconfig pdcm pdpe1gb pebs pge pku pln pni popcnt pse pse36 pts
    rdpid rdrand rdseed rdt_a rdtscp rep_good sdbg sep serialize sha_ni smap
    smep smx split_lock_detect ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp
    syscall tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer
    tsc_known_freq umip user_shstk vaes vme vmx vnmi vpclmulqdq vpid waitpkg
    x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
    conditional; PBRSB-eIBRS: SW sequence; BHI: BHI_DIS_S
  Device-1: Intel Alder Lake-S GT1 [UHD Graphics 770] vendor: Gigabyte
    driver: i915 v: kernel alternate: xe arch: Xe process: Intel 10nm
    built: 2020-21 ports: active: none empty: DP-1,HDMI-A-1 bus-ID: 00:02.0
    chip-ID: 8086:4680 class-ID: 0380
  Device-2: NVIDIA GP107 [GeForce GTX 1050 Ti] vendor: ASUSTeK driver: N/A
    alternate: nouveau non-free: 550-580.xx+ status: current (as of 2025-11;
    EOL~2026-12-xx) arch: Pascal code: GP10x process: TSMC 16nm
    built: 2016-2021 pcie: gen: 1 speed: 2.5 GT/s lanes: 16 link-max: gen: 3
    speed: 8 GT/s bus-ID: 01:00.0 chip-ID: 10de:1c82 class-ID: 0300
  Display: x11 server: X.org v: 1.21.1.22 compositor: xfwm4 v: 4.20.0
    driver: X: loaded: modesetting,nouveau alternate: fbdev,nv,vesa dri: iris
    gpu: i915 display-ID: :0.0 note: <missing: xdpyinfo/xrandr>
  Monitor-1: Unknown-1 size-res: N/A modes: 1024x768
    device: 1 drv: swrast gbm: drv: iris surfaceless: drv: iris x11: drv: swrast
    inactive: wayland
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: mesa v: 26.0.6-arch1.1 glx-v: 1.4
    direct-render: yes renderer: llvmpipe (LLVM 22.1.3 256 bits)
    device-ID: ffffffff:ffffffff memory: 30.38 GiB unified: yes
    gpu: nvidia-smi x11: xprop
  Device-1: Intel Alder Lake-S HD Audio vendor: Gigabyte driver: snd_hda_intel
    v: kernel alternate: snd_soc_avs,snd_sof_pci_intel_tgl bus-ID: 00:1f.3
    chip-ID: 8086:7ad0 class-ID: 0403
  Device-2: NVIDIA GP107GL High Definition Audio vendor: ASUSTeK
    driver: snd_hda_intel v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 16
    link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.1 chip-ID: 10de:0fb9
    class-ID: 0403
  API: ALSA v: k7.0.3-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.6.4 status: active with: 1: pipewire-pulse
    4: pw-jack type: plugin tools: pactl,pw-cat,pw-cli,wpctl
  Device-1: Intel Alder Lake-S PCH CNVi WiFi driver: iwlwifi v: kernel
    bus-ID: 00:14.3 chip-ID: 8086:7af0 class-ID: 0280
  IF: wlo1 state: down mac: <filter>
  Device-2: Aquantia AQC113C NBase-T/IEEE 802.3an Ethernet [Marvell
    Scalable mGig] vendor: Gigabyte driver: atlantic v: kernel pcie: gen: 3
    speed: 8 GT/s lanes: 2 port: N/A bus-ID: 02:00.0 chip-ID: 1d6a:14c0
    class-ID: 0200 temp: 31.0 C
  IF: enp2s0 state: up speed: 100 Mbps duplex: full mac: <filter>
  IF-ID-1: docker0 state: down mac: <filter>
  Info: services: httpd, NetworkManager, systemd-networkd,
    systemd-timesyncd, wpa_supplicant
  Device-1: Intel AX211 Bluetooth driver: btusb v: 0.8 type: USB rev: 2.0
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:9 chip-ID: 8087:0033
    class-ID: e001
  Report: btmgmt ID: hci0 rfk-id: 0 state: down bt-service: disabled
    rfk-block: hardware: no software: no address: N/A
  Local Storage: total: 1.36 TiB used: 79.01 GiB (5.7%)
    model: SSD 970 EVO Plus 500GB size: 465.76 GiB block-size: physical: 512 B
    fw-rev: 2B2QEXM7 temp: 33.9 C scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 vendor: Western Digital
    model: WD10EZEX-22MFCA0 size: 931.51 GiB block-size: physical: 4096 B
    logical: 512 B speed: 6.0 Gb/s tech: HDD rpm: 7200 serial: <filter>
    fw-rev: 1A01 scheme: MBR
  ID-1: / raw-size: 100 GiB size: 97.87 GiB (97.87%) used: 79 GiB (80.7%)
    fs: ext4 block-size: 4096 B dev: /dev/nvme0n1p3 maj-min: 259:3 label: N/A
    uuid: a25eebbf-f730-452c-ac04-28c04696c1c3
  ID-2: /boot/efi raw-size: 100 MiB size: 98.4 MiB (98.45%)
    used: 17.3 MiB (17.6%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p2
    maj-min: 259:2 label: N/A uuid: 33F7-CDB2
  ID-1: swap-1 type: partition size: 32 GiB used: 0 KiB (0.0%) priority: -1
    dev: /dev/sda2 maj-min: 8:2 label: N/A
    uuid: e86003ab-2caa-4dd6-b71c-169083f56901
  ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 50 GiB fs: ext4 label: N/A
    uuid: 8be22ad4-6819-4c8c-90e8-cf2a941c3a99
  ID-2: /dev/sda1 maj-min: 8:1 size: 50 GiB fs: ext4 label: N/A
    uuid: b77a586e-1b3b-4d9a-a8a7-c76619420579
  ID-3: /dev/sda3 maj-min: 8:3 size: 1024 MiB fs: vfat label: N/A
    uuid: 8346-4499
  ID-4: /dev/sda4 maj-min: 8:4 size: 1 KiB fs: <superuser required>
    label: N/A uuid: N/A
  ID-5: /dev/sda5 maj-min: 8:5 size: 50 GiB fs: ext4 label: N/A
    uuid: e4b0808a-66ea-4962-810f-65b29bcff8ca
  ID-6: /dev/sda6 maj-min: 8:6 size: 400 GiB fs: ext4 label: Photos
    uuid: 75caa3c2-c566-4202-b7ee-724fb8ea7ef1
  ID-7: /dev/sda7 maj-min: 8:7 size: 398.51 GiB fs: ext4 label: Music
    uuid: 4b615696-97c2-48e9-8185-71c43173d073
  Hub-2: 1-6:2 info: Realtek 4-Port USB 2.0 Hub ports: 4 rev: 2.1
    chip-ID: 0bda:5420 class-ID: 0900
  Hub-3: 1-9:3 info: Realtek RTS5411 Hub ports: 4 rev: 2.1
    chip-ID: 0bda:5411 class-ID: 0900
  Hub-4: 1-10:4 info: Realtek RTS5411 Hub ports: 4 rev: 2.1
  Device-1: 1-10.2:6 info: American Power Conversion Uninterruptible Supply
    type: HID driver: hid-generic,usbhid interfaces: 1 rev: 2.0
    speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 2mA
    chip-ID: 051d:0002 class-ID: 0300 serial: <filter>
  Hub-5: 1-10.4:8 info: Terminus Hub ports: 4 rev: 2.0
    chip-ID: 1a40:0101 class-ID: 0900
  Device-1: 1-10.4.1:10 info: Primax Dynex 5-Button Wired Optical Mouse
    type: mouse driver: hid-generic,usbhid interfaces: 1 rev: 2.0
    chip-ID: 0461:4d42 class-ID: 0301
  Device-2: 1-10.4.3:11 info: Kensington U+P Keyboard type: keyboard,HID
    chip-ID: 047d:2043 class-ID: 0300
  Hub-6: 1-12:5 info: Genesys Logic Hub ports: 4 rev: 2.0
  Device-1: 1-13:7 info: Integrated Express RGB LED Controller type: HID
    lanes: 1 mode: 1.1 power: 100mA chip-ID: 048d:5702 class-ID: 0300
  Device-2: 1-14:9 info: Intel AX211 Bluetooth type: bluetooth driver: btusb
    power: 100mA chip-ID: 8087:0033 class-ID: e001
  Hub-7: 2-0:1 info: super-speed hub ports: 8 rev: 3.1
  Hub-8: 2-4:2 info: Realtek 4-Port USB 3.0 Hub ports: 4 rev: 3.2
    speed: 10 Gb/s (1.16 GiB/s) lanes: 1 mode: 3.2 gen-2x1 power: 96mA
    chip-ID: 0bda:0420 class-ID: 0900
  Hub-9: 2-7:3 info: Realtek Hub ports: 4 rev: 3.2
    speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 power: 96mA
    chip-ID: 0bda:0411 class-ID: 0900
  Hub-10: 2-8:4 info: Realtek Hub ports: 4 rev: 3.2
  System Temperatures: cpu: 28.5 C mobo: N/A
  Fan Speeds (rpm): N/A
  Packages: 1395 pm: pacman pkgs: 1391 libs: 402 tools: pamac,yay pm: flatpak
    pkgs: 0 pm: snap pkgs: 4
    1: https://mirrors.ocf.berkeley.edu/manjaro/stable/$repo/$arch
    2: https://manjaro.mirrors.uk2.net/stable/$repo/$arch
    3: https://mirror.raiolanetworks.com/manjaro/stable/$repo/$arch
    4: https://mirrors.up.pt/pub/manjaro/stable/$repo/$arch
    5: https://ftp.rz.tu-bs.de/pub/mirror/manjaro.org/repos/stable/$repo/$arch
    6: https://gsl-syd.mm.fcix.net/manjaro/stable/$repo/$arch
    7: https://mirror.easyname.at/manjaro/stable/$repo/$arch
    8: https://mirror.xeonbd.com/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 424
  1: cpu: 0.8% command: firefox pid: 3396 mem: 949.1 MiB (2.9%)
  2: cpu: 0.3% command: Xorg pid: 1219 mem: 148.4 MiB (0.4%)
  3: cpu: 0.3% command: firefox pid: 10231 mem: 378.0 MiB (1.1%)
  4: cpu: 0.2% command: xfwm4 pid: 2226 mem: 86.2 MiB (0.2%)
  5: cpu: 0.1% command: containerd pid: 1105 mem: 57.9 MiB (0.1%)
  Memory top: 5 of 424
  1: mem: 949.1 MiB (2.9%) command: firefox pid: 3396 cpu: 0.8%
  2: mem: 378.0 MiB (1.1%) command: firefox pid: 10231 cpu: 0.3%
  3: mem: 288.7 MiB (0.9%) command: firefox pid: 3891 cpu: 0.0%
  4: mem: 254.3 MiB (0.7%) command: claws-mail pid: 10995 cpu: 0.0%
  5: mem: 169.9 MiB (0.5%) command: firefox pid: 3560 cpu: 0.0%
  Processes: 424 Power: uptime: 21h 28m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 12.33 GiB
    services: upowerd,xfce4-power-manager Init: systemd v: 260
  Compilers: gcc: 15.2.1 Shell: Bash v: 5.3.9 running-in: xfce4-terminal
    inxi: 3.3.40
Does anyone know of a way to set a pamac checkpoint so that you could do a complete rollback to that checkpoint if you have problems like this?
pamac cannot do that. As the matter of fact, you would need btrfs as the filesystem, with a fresh snapshot made before you do the update.
