After 2/22/21 All text is unreadably tiny after toggling display setting
I toggled the display setting from 200% to 100% and text is impossible to read. AND the gadget to toggle 100% / 200% went away. it is gone.
How should I proceed?
The FIX is to undo this setting if you had made the change in the past:
gsettings set sm.puri.phoc scale-to-fit false
However, if you disagree with my choice, please feel free to take any other answer as the solution to your question or even remove the solution altogether: You are in control! (If you disagree with my choice, just send me a personal message and explain why I shouldn’t have done this or :heart: or :+1: if you agree)
:innocent:
P.S. In the future, please don’t forget to come back and click the 3 dots below the answer to mark a solution like this below the answer that helped you most:
Solution
