I downloaded the Standalone flash player and it’s working fine, but I can not seem to find the saves for this. Anyone know where to look?
Hi @mknight91,
Unfortunately, no. I do, horever, know that flash (so I’m thinking flash player as well) is dead and no longer supported. Unless that is just the websites version. So there is a chace I don’t understand it correctly.
Hope this helps.
You can still play old flash files if you have them exported to your pc using a standalone player. I just can export my saves because I can’t find where they are stored in linux.
The easiest, I think, or it’s what I would’ve done were it me, was do a save with a name somewhere. Note the name, or if you should choose, choose one you’d remember, though.
When done, search for the file, in the terminal, either with,
find -type f -name <filename>
Where <filename>
is the name of the file previously specified.
Or find the file by:
sudo updated
locate <filename>
Where <filename>
The results should contain the full path to the file, from which you should be able to find out where it’s been saved.
Hope this helps!
Thank you.
