I am using a Dell XPS 9310 (intel i915 driver) with KDE Plasma and when adjusting the brightness to lowest level, the screen turns off (I guess?) and doesn’t come back on when brightness values are increased. I have to shut the laptop and then open it again causing it to go into sleep and then resume, at which the screen will turn back on.
I am running linux513 5.13.rc5.d0606.g614124b-1, but had the issue on linux512 5.12.9-1 as well.
I think it might have been fixed in rc4, but the system was crashing very frequently and I went back to 5.12 until rc5 came through.
I’m on linux-firmware 20210518.r1928.f846292-1.
Can anyone guide me in the right direction please?
Here is the journalctl logs of the event where the power settings tries to dim/shut off (?) the screen causing it to blackout and not return.
Jun 16 18:06:21 manjarocomp dbus-daemon[422]: [system] Activating service name='org.kde.powerdevil.backlighthelper' requested by ':1.31' (uid=1000 pid=3622 comm="/usr/lib/org_kde_powerdevil ") (using servicehelper)
Jun 16 18:06:21 manjarocomp dbus-daemon[422]: [system] Successfully activated service 'org.kde.powerdevil.backlighthelper'
Jun 16 18:06:21 manjarocomp kscreen_backend_launcher[3762]: kscreen.xcb.helper: RRNotify_OutputProperty (ignored)
Jun 16 18:06:21 manjarocomp kscreen_backend_launcher[3762]: kscreen.xcb.helper: Output: 68
Jun 16 18:06:21 manjarocomp kscreen_backend_launcher[3762]: kscreen.xcb.helper: Property: Backlight
Jun 16 18:06:21 manjarocomp kscreen_backend_launcher[3762]: kscreen.xcb.helper: State (newValue, Deleted): 0
Jun 16 18:06:21 manjarocomp kscreen_backend_launcher[3762]: kscreen.xcb.helper: Property: BACKLIGHT
Jun 16 18:06:24 manjarocomp kscreen_backend_launcher[3762]: kscreen.xcb.helper: RRNotify_OutputProperty (ignored)
Jun 16 18:06:24 manjarocomp kscreen_backend_launcher[3762]: kscreen.xcb.helper: Output: 68
Jun 16 18:06:24 manjarocomp kscreen_backend_launcher[3762]: kscreen.xcb.helper: Property: Backlight
Jun 16 18:06:24 manjarocomp kscreen_backend_launcher[3762]: kscreen.xcb.helper: State (newValue, Deleted): 0
Jun 16 18:06:24 manjarocomp kscreen_backend_launcher[3762]: kscreen.xcb.helper: Property: BACKLIGHT
Here are the PCI devices:
0000:00:00.0 Host bridge [0600]: Intel Corporation 11th Gen Core Processor Host Bridge/DRAM Registers [8086:9a14] (rev 01)
Subsystem: Dell Device [1028:0991]
0000:00:02.0 VGA compatible controller [0300]: Intel Corporation Iris Xe Graphics [8086:9a49] (rev 01)
DeviceName: Onboard - Video
Kernel driver in use: i915
Kernel modules: i915
0000:00:04.0 Signal processing controller [1180]: Intel Corporation Device [8086:9a03] (rev 01)
Kernel driver in use: proc_thermal
Kernel modules: processor_thermal_device
0000:00:06.0 System peripheral [0880]: Intel Corporation Device [8086:09ab]
0000:00:07.0 PCI bridge [0604]: Intel Corporation Tiger Lake-LP Thunderbolt 4 PCI Express Root Port #0 [8086:9a23] (rev 01)
Kernel driver in use: pcieport
0000:00:07.2 PCI bridge [0604]: Intel Corporation Tiger Lake-LP Thunderbolt 4 PCI Express Root Port #2 [8086:9a27] (rev 01)
0000:00:0a.0 Signal processing controller [1180]: Intel Corporation Device [8086:9a0d] (rev 01)
Kernel driver in use: intel-pmt
Kernel modules: intel_pmt
0000:00:0d.0 USB controller [0c03]: Intel Corporation Tiger Lake-LP Thunderbolt 4 USB Controller [8086:9a13] (rev 01)
Kernel driver in use: xhci_hcd
Kernel modules: xhci_pci
0000:00:0d.2 USB controller [0c03]: Intel Corporation Tiger Lake-LP Thunderbolt 4 NHI #0 [8086:9a1b] (rev 01)
Subsystem: Device [2222:1111]
Kernel driver in use: thunderbolt
Kernel modules: thunderbolt
0000:00:0d.3 USB controller [0c03]: Intel Corporation Tiger Lake-LP Thunderbolt 4 NHI #1 [8086:9a1d] (rev 01)
0000:00:0e.0 RAID bus controller [0104]: Intel Corporation Volume Management Device NVMe RAID Controller [8086:9a0b]
Kernel driver in use: vmd
Kernel modules: vmd
0000:00:12.0 Serial controller [0700]: Intel Corporation Tiger Lake-LP Integrated Sensor Hub [8086:a0fc] (rev 20)
Kernel driver in use: intel_ish_ipc
Kernel modules: intel_ish_ipc
0000:00:14.0 USB controller [0c03]: Intel Corporation Tiger Lake-LP USB 3.2 Gen 2x1 xHCI Host Controller [8086:a0ed] (rev 20)
0000:00:14.2 RAM memory [0500]: Intel Corporation Tiger Lake-LP Shared SRAM [8086:a0ef] (rev 20)
0000:00:15.0 Serial bus controller [0c80]: Intel Corporation Tiger Lake-LP Serial IO I2C Controller #0 [8086:a0e8] (rev 20)
Kernel driver in use: intel-lpss
Kernel modules: intel_lpss_pci
0000:00:15.1 Serial bus controller [0c80]: Intel Corporation Tiger Lake-LP Serial IO I2C Controller #1 [8086:a0e9] (rev 20)
0000:00:16.0 Communication controller [0780]: Intel Corporation Tiger Lake-LP Management Engine Interface [8086:a0e0] (rev 20)
Kernel driver in use: mei_me
Kernel modules: mei_me
0000:00:19.0 Serial bus controller [0c80]: Intel Corporation Tiger Lake-LP Serial IO I2C Controller #4 [8086:a0c5] (rev 20)
0000:00:19.1 Serial bus controller [0c80]: Intel Corporation Tiger Lake-LP Serial IO I2C Controller #5 [8086:a0c6] (rev 20)
0000:00:1c.0 PCI bridge [0604]: Intel Corporation Device [8086:a0b8] (rev 20)
0000:00:1d.0 PCI bridge [0604]: Intel Corporation Device [8086:a0b3] (rev 20)
0000:00:1e.0 Communication controller [0780]: Intel Corporation Tiger Lake-LP Serial IO UART Controller #0 [8086:a0a8] (rev 20)
0000:00:1f.0 ISA bridge [0601]: Intel Corporation Tiger Lake-LP LPC Controller [8086:a082] (rev 20)
0000:00:1f.3 Multimedia audio controller [0401]: Intel Corporation Tiger Lake-LP Smart Sound Technology Audio Controller [8086:a0c8] (rev 20)
Kernel driver in use: sof-audio-pci-intel-tgl
Kernel modules: snd_hda_intel, snd_sof_pci_intel_tgl
0000:00:1f.4 SMBus [0c05]: Intel Corporation Tiger Lake-LP SMBus Controller [8086:a0a3] (rev 20)
Kernel driver in use: i801_smbus
Kernel modules: i2c_i801
0000:00:1f.5 Serial bus controller [0c80]: Intel Corporation Tiger Lake-LP SPI Controller [8086:a0a4] (rev 20)
0000:71:00.0 Network controller [0280]: Qualcomm Device [17cb:1101] (rev 01)
Subsystem: Rivet Networks Device [1a56:a501]
Kernel driver in use: ath11k_pci
Kernel modules: ath11k_pci
0000:72:00.0 Unassigned class [ff00]: Realtek Semiconductor Co., Ltd. RTS5260 PCI Express Card Reader [10ec:5260] (rev 01)
Kernel driver in use: rtsx_pci
Kernel modules: rtsx_pci
10000:e0:06.0 PCI bridge [0604]: Intel Corporation 11th Gen Core Processor PCIe Controller [8086:9a09] (rev 01)
10000:e1:00.0 Non-Volatile memory controller [0108]: Toshiba Corporation XG6 NVMe SSD Controller [1179:011a]
Subsystem: Toshiba Corporation Device [1179:0001]
Kernel driver in use: nvme
