Adjust sharpness / contrast?
In videos colors are nor a clear as they seem they should be, like when I adjust contrast for a pic in GIMP it does what I want the moniiter contrast doesn’t seem to work that good. People keep saying gama is the same basicly, Other posts here say adjust gamma, but not sure what the ganna shoulk=d be, vuds. only are the prob.
I know that you have not got it easy, have some problems …
But:
When you read what you just wrote -
which is what all the others have to decipher -
do you not notice the many typos?
It is often really hard to grasp what you even mean.
I have no advice regarding your problem.
All the Best!
Yes, i agree :smile:
Have you checked System SettingsDisplay & Monitor → check what RGB Range is set to (Full? Automatic?). See if this makes any difference.
Sorry for so much mistyping, gamma at default is best? Also, I can’t find RGB range.
first: check the settings of your display/monitor. usually different colour/display are avaiable.
second: post the output of the mandatory
what gpu ? intel, amd, nvidia ?
if it’s nvidia you’ll have to use their config-application to adjust brightness and gamma
  Host: nick-b550i Kernel: 6.6.30-2-MANJARO arch: x86_64 bits: 64
    compiler: gcc v: 13.2.1 clocksource: tsc avail: hpet,acpi_pm
    root=UUID=0647dad9-3687-4eba-8d09-acc5ce30021d rw quiet splash
    udev.log_priority=3
  Desktop: KDE Plasma v: 6.0.4 tk: Qt v: N/A info: frameworks v: 6.1.0
  Type: Desktop Mobo: Gigabyte model: B550I AORUS PRO AX v: x.x
    serial: <superuser required> uuid: <superuser required> UEFI: American
    Megatrends LLC. v: FE date: 03/22/2024
  System RAM: total: 16 GiB available: 15.54 GiB used: 4.04 GiB (26.0%)
  Device-1: Channel-A DIMM 0 type: no module installed
    (unregistered) size: 8 GiB speed: 3200 MT/s volts: note: check curr: 1
    min: 1 max: 1 width (bits): data: 64 total: 64 manufacturer: TeamGroup
    part-no: UD4-3200 serial: 01044D69
  Device-3: Channel-B DIMM 0 type: no module installed
    part-no: UD4-3200 serial: 0104F093
  Info: model: AMD Ryzen 7 5800X bits: 64 type: MT MCP arch: Zen 3+ gen: 4
    model-id: 0x21 (33) stepping: 2 microcode: 0xA20120E
  Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
    L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB
    L3: 32 MiB desc: 1x32 MiB
  Speed (MHz): avg: 2534 high: 4014 min/max: 2200/4850 boost: enabled
    scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 2200 2: 3593
    3: 2937 4: 2200 5: 2873 6: 2200 7: 2200 8: 2200 9: 2200 10: 2200 11: 2200
    12: 2200 13: 2936 14: 2200 15: 2200 16: 4014 bogomips: 121416
    xsaves
    affected
  Device-1: NVIDIA GA104 [GeForce RTX 3060 Ti Lite Hash Rate]
    vendor: eVga.com. driver: nvidia v: 550.78 alternate: nouveau,nvidia_drm
    non-free: 550.xx+ status: current (as of 2024-04; EOL~2026-12-xx)
    arch: Ampere code: GAxxx process: TSMC n7 (7nm) built: 2020-2023 pcie:
    gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 05:00.0 chip-ID: 10de:2489
    class-ID: 0300
  Display: x11 server: X.Org v: 21.1.13 with: Xwayland v: 23.2.6
    compositor: kwin_x11 driver: X: loaded: nvidia gpu: nvidia display-ID: :0
    screens: 1
  Screen-1: 0 s-res: 1920x1080 s-dpi: 140 s-size: 348x196mm (13.70x7.72")
    s-diag: 399mm (15.72") monitors: <missing: xrandr>
  Monitor-1: Unknown-1 size-res: N/A modes: 1024x768
  API: EGL v: 1.5 hw: drv: nvidia platforms: device: 0 drv: nvidia device: 2
    drv: swrast gbm: drv: kms_swrast surfaceless: drv: nvidia x11: drv: nvidia
    inactive: wayland,device-1
  API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 550.78
    glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 3060 Ti/PCIe/SSE2
    memory: 7.81 GiB
  API: Vulkan v: 1.3.279 layers: 1 device: 0 type: discrete-gpu name: NVIDIA
    GeForce RTX 3060 Ti driver: nvidia v: 550.78 device-ID: 10de:2489
    surfaces: xcb,xlib
  Device-1: NVIDIA GA104 High Definition Audio vendor: eVga.com.
    bus-ID: 05:00.1 chip-ID: 10de:228b class-ID: 0403
  Device-2: AMD Starship/Matisse HD Audio vendor: Gigabyte
    bus-ID: 07:00.4 chip-ID: 1022:1487 class-ID: 0403
  Device-3: Realtek LG Monitor HP MIC driver: hid-generic,usbhid type: USB
    rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-2.4:6
    chip-ID: 0bda:4027 class-ID: 0300 serial: 200901010001
  API: ALSA v: k6.6.30-2-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.0.5 status: active with: 1: pipewire-pulse
  Device-1: Realtek RTL8125 2.5GbE vendor: Gigabyte driver: r8169 v: kernel
    pcie: gen: 2 speed: 5 GT/s lanes: 1 port: e000 bus-ID: 03:00.0
  IF: eno1 state: up speed: 1000 Mbps duplex: full mac: 74:56:3c:cb:2a:51
  IP v4: 192.168.0.133/24 type: dynamic noprefixroute scope: global
    broadcast: 192.168.0.255
  IP v6: fe80::60f0:c5f6:9cc2:f380/64 type: noprefixroute scope: link
  Device-2: Realtek RTL8852CE PCIe 802.11ax Wireless Network
    driver: rtw89_8852ce v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1
    port: d000 bus-ID: 04:00.0 chip-ID: 10ec:c852 class-ID: 0280
  IF: wlp4s0 state: down mac: ca:ad:a4:e8:7d:0c
  WAN IP: 160.223.178.38
  Device-1: Realtek Bluetooth Radio driver: btusb v: 0.8 type: USB rev: 1.0
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-8:3 chip-ID: 0bda:0852
    class-ID: e001 serial: 00e04c000001
  Local Storage: total: 1.82 TiB used: 54.64 GiB (2.9%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Crucial model: CT1000MX500SSD1
    tech: SSD serial: 2304E6A2F5CC fw-rev: 045 scheme: GPT
  ID-2: /dev/sdb maj-min: 8:16 vendor: Smart Modular Tech.
    model: SHGS31-1000GS-2 size: 931.51 GiB block-size: physical: 4096 B
    logical: 512 B speed: 6.0 Gb/s tech: SSD serial: SJ96N712011007H5S
    fw-rev: 0Q00 scheme: GPT
  Optical-1: /dev/sr0 vendor: HL-DT-ST model: DVDRAM GUD0N rev: 1.00
    dev-links: cdrom
  ID-1: / raw-size: 767.48 GiB size: 754.36 GiB (98.29%)
    used: 54.64 GiB (7.2%) fs: ext4 dev: /dev/sda4 maj-min: 8:4 label: N/A
    uuid: 0647dad9-3687-4eba-8d09-acc5ce30021d
    used: 296 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: N/A
    uuid: 6DB0-0A0F
  ID-1: swap-1 type: partition size: 17.15 GiB used: 0 KiB (0.0%)
    priority: -2 dev: /dev/sda3 maj-min: 8:3 label: swap
    uuid: 432e1292-b63d-42c2-8b0f-55fed2854879
  ID-1: /dev/sda2 maj-min: 8:2 size: 146.59 GiB fs: exfat label: Download
    uuid: 76FB-F724
  ID-2: /dev/sdb1 maj-min: 8:17 size: 118.02 GiB fs: ntfs label: N/A
    uuid: FEDE7716DE76C705
  ID-3: /dev/sdb2 maj-min: 8:18 size: 100 MiB fs: vfat label: NO NAME
    uuid: B362-0880
  ID-4: /dev/sdb3 maj-min: 8:19 size: 538 MiB fs: ntfs label: N/A
    uuid: 407C57BC7C57AC02
  ID-5: /dev/sdb4 maj-min: 8:20 size: 812.87 GiB fs: ntfs label: Data
    uuid: 1CE33ADD03B8E5A9
  Device-1: 1-7:2 info: Integrated Express RGB LED Controller type: HID
    lanes: 1 mode: 1.1 power: 100mA chip-ID: 048d:5702 class-ID: 0300
  Device-2: 1-8:3 info: Realtek Bluetooth Radio type: bluetooth
    driver: btusb interfaces: 2 rev: 1.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1
    mode: 1.1 power: 500mA chip-ID: 0bda:0852 class-ID: e001
  Device-1: 3-1:2 info: Microsoft Classic IntelliMouse type: mouse,HID
    lanes: 1 mode: 1.1 power: 200mA chip-ID: 045e:0823 class-ID: 0300
  Hub-4: 3-2:3 info: Realtek RTS5411 Hub ports: 4 rev: 2.1
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 0bda:5411
  Device-1: 3-2.3:5 info: LG USA Monitor Controls
    type: HID,abstract (modem),CDC-data driver: cdc_acm,hid-generic,usbhid
    interfaces: 4 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1
    chip-ID: 043e:9a8a class-ID: 0a00 serial: A5110200Z589
  Device-2: 3-2.4:6 info: Realtek LG Monitor HP MIC type: HID
  Device-3: 3-3:4 info: China Resource Semico USB Keyboard
    type: keyboard,mouse driver: hid-generic,usbhid interfaces: 2 rev: 1.1
    speed: 1.5 Mb/s (183 KiB/s) lanes: 1 mode: 1.0 power: 500mA
    chip-ID: 1a2c:4b61 class-ID: 0301
  Hub-5: 4-0:1 info: super-speed hub ports: 4 rev: 3.1
  Hub-6: 4-2:2 info: Realtek Hub ports: 2 rev: 3.2
    speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 0bda:0411
  System Temperatures: cpu: 61.4 C mobo: 47.0 C gpu: nvidia temp: 46 C
  Fan Speeds (rpm): N/A gpu: nvidia fan: 43%
  Processes: 299 Power: uptime: 50m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 6.21 GiB services: org_kde_powerdevil,
    tool: systemctl
  Packages: pm: pacman pkgs: 1286 libs: 366 tools: pamac pm: flatpak pkgs: 0
    Compilers: clang: 17.0.6 gcc: 13.2.1 Shell: Zsh v: 5.9 default: Bash
    v: 5.2.26 running-in: konsole inxi: 3.3.34
I have Nvidia, I found something that says RGB range is in Display Config but also mentions wayland, in X it isn’t there, I didn’t see it anyway.
Moderator edit: In the future, please use proper formatting: [HowTo] Post command output and file content as formatted text
udev.log_priority=3
serial: uuid: UEFI: American
xsaves
affected
vendor: [eVga.com](http://eVga.com). driver: nvidia v: 550.78 alternate: nouveau,nvidia_drm
class-ID: 0300
Display: x11 server: [X.Org](http://X.Org) v: 21.1.13 with: Xwayland v: 23.2.6
screens: 1
memory: 7.81 GiB
surfaces: xcb,xlib
Device-1: NVIDIA GA104 High Definition Audio vendor: [eVga.com](http://eVga.com).
dev-links: cdrom
uuid: 6DB0-0A0F
uuid: 76FB-F724
uuid: B362-0880
tool: systemctl
Sorry about the loong post, I couldnt remember the command to shorten. I was just going to delete it & attach it as a file, but I saw your post before I did that. I should turn on FXAA right?
I just took your text and formatted it … correctly.
to help you out, to make it readable
there is a symbol in the top row of the forum edit window, where you input your text
mark the text
click the symbol
done
I do not know what FXAA is or what you mean by it.
I wonder if you would not be better served by using another Linux distro
Mint, for example.
I (reluctantly) did the switch myself.
Just so I could easily help my father - who has got the very same.
No heavy maintenance needed.
I have a screenshot, it is under anti-ailiding (sp).
… only with your information available to others:
try to find your screenshot -
you can’t
you have likely been given a link
share that
It is just a shot of Nvidia X server config. Just showing the FXAA option under anti-aliasins.
no one needs to see that :man_shrugging:
But I still don’t know what FXAA even means or why you would have brought it up.
This is going astray fast, it seems.
Report the issue
what should be vs. what you have now got.
and then videos vs still pictures
Hopefully this will help, gere is a link to another post from me on another forum. https://linustechtips.com/topic/1571074-kde-plasma-6-settings-for-best-picture/#comment-16416510
What are the best settings for my GPU to get the clearest sharpest image?
Moderator edit: Merged topics and made an edit for context
I can visualize (in my mind’s eye) your description.
But I have never actually seen it.
And no one else seems to have seen it either. No one complained about it.
If we can’t actually see the effect (with and without) - by way of a screenshot, perhaps - there can be only perpetual speculation about the reason.
IMO.
Oh - you just changed the whole description and the title.
Rendering my response invalid.
Not only but what ever screenshot provided will be tainted my video settings. Also on if I’ve cleaned my glasses lately.
it won’t be the graphics card. more likely the monitor
That might be it - the resolution it is capable of vs. what it is set to run at.
Or the glasses … :man_shrugging:
