Hello Guys, I’m rocking Manjaro Gnome fully updated. This is my first post here!
I am using a Nvidia GeForce 1080 Ti with the latest proprietary drivers connected using Displayport. and Kernel 5.12 btw.
I tried everything I could to control screen brightness, but it has been impossible. At night my screen is just too bright for me to work and I have to boot on windows to do that.
I’ve been following some guides in internet…
But is not working, as there are commands that just don’t work, (maybe it wasn’t written for Manjaro)
Thing is, I just want to be able to increase and reduce my screen brightness somehow, is there anyone who wants to help me with this? I would really appreciate it, and the sole reason for me to use windows will be gone.
I’ve installed Clight and Clight GUI using the Add/Remove software after enabling AUR.
Thing is, it doesn’t work or do anything, when I open the Cling-GUI the increase and reduce brightness options appear with the forbidden icon, and don’t work.
Any idea why isn’t working?
Here the output after clight in Terminal
sudo clight
[sudo] password for x:
Config file /root/.config/clight.conf not found.
Clightd found, version: 5.4.
AC curve: y = -0.024825 + 0.191641x + -0.008928x^2
BL
| ---------->BR
BATT curve: y = -0.010629 + 0.153844x + -0.007284x^2
BL
*---------->BR
Keyboard backlight calibration unsupported.
BUS: Failed to connect to user bus
Could not create org.clight.clight dbus interface: Unknown error 242
Failed to init.
Error loading from cache file.
Not a laptop device. Killing UPower module.
Failed to retrieve AC state; fallback to ON_AC and OPEN lid.
