I have built and pushed new version upgrades of kodi-rpi and code packages to the unstable branch when the mirrors sync.
Be advised that the new kodi-rpi packages are built using several libs in the unstable branch so their newer versions may not exist yet in the testing or stable branch. You may have to switch and do a total upgrade on the unstable branch before kodi-rpi will work.
x2goserver used to be part of ARM Testing, however it is no longer in the repos and when I try to build it, it fails. Is there any way to get it re-added to the ARM distro?
Building x2goserver...
Running as unit: run-u256.service
Press ^] three times within 1s to disconnect TTY.
==> ERROR: x2goserver is not available for the 'aarch64' architecture.
Finished with result: exit-code
Main processes terminated with: code=exited/status=12
Service runtime: 3.167s
CPU time consumed: 3.768s
All I did was change the arch=(‘X86_64’) to arch=(‘aarch64’).
diff --git a/PKGBUILD b/PKGBUILD
index eb6e464..af02acb 100644
--- a/PKGBUILD
+++ b/PKGBUILD
@@ -9,7 +9,7 @@ pkgname=x2goserver
pkgver=4.1.0.3
pkgrel=10
pkgdesc="Open source graphical Remote Desktop and terminal server based on NX technology"
-arch=('x86_64')
+arch=('aarch64')
url="https://www.x2go.org/"
license=('GPL2')
# https://code.x2go.org/gitweb?p=x2goserver.git;a=blob;f=x2goserver.spec
So, the error occurs from removing the ‘x86_64’ from the arch line. Leave it and add the ‘aarch64’ to the line and x2goserver will build and install fine.
When trying to use any lua conky config file I get a nil value error. When I search the internet, many say this is due to conky not being compiled with lua.
conky -v
conky 1.12.2_pre compiled 2022-04-24 for Linux aarch64
Compiled in features:
System config file: /etc/conky/conky.conf
Package library path: /usr/lib/conky
General:
* math
* hddtemp
* portmon
* IPv6
* Curl
* RSS
* Weather (METAR)
* wireless
* support for IBM/Lenovo notebooks
* builtin default configuration
* old configuration syntax
* Imlib2
* OSS mixer support
* apcupsd
* iostats
* ncurses
* Internationalization support
* PulseAudio
X11:
* Xdamage extension
* Xinerama extension (virtual display)
* Xshape extension (click through)
* XDBE (double buffer extension)
* Xft
* ARGB visual
* Own window
* HSV Gradient
Music detection:
* CMUS
* MPD
* MOC
Default values:
* Netdevice: eno1
* Local configfile: $HOME/.conkyrc
* Localedir: /usr/share/locale
* Maximum netdevices: 256
* Maximum text size: 16384
* Size text buffer: 256
@tartanpion kodi-rpi-git v20 was upgraded today so I built and pushed new packages to the unstable branch when the mirrors sync. It still seem to do good here.
