Adding or removing kernels in case of kernel-boot
I was intrigued by this article by @linux-aarhus: Convert to systemd-boot.
My question is, will mhwd-kernel or Manjaro Settings Manager be aware of this sort of configuration, or will they only update grub?
Thanks, and good article by the way @dalto!
mhwd-kernel is a wrapper script - and in my experience there’s no issues related to mhwd-kernel.
All credit to @dalto as the original author.
I can confirm (well, on my system at least) that it does not interfere anyway with mhwd-kernel.
Updating grub and/or updating systemd-boot is done by pacman hooks which run after the installation of a kernel. It has nothing to do with mhwd-kernel.
If you use the kernel-install method, it should automatically add boot entries as you add and remove kernels in mhwd-kernel.
If you use the manual method, you will have to manually add them.
