So, I was wondering, what are the mechanisms one would use to include Flatpaks as part of an ISO?
I have been able to create packages using AppImages and including them on my ISO build, but the time has come that I may want to add my first Flatpak as part of my ISO.
None, from a technical perspective. However, you might wish to see what @philm has to suggest. As I understand it, he was considering flatpak by default for Manjaro, at one time.
I’ll refrain from adding my personal opinions on that.
BUILDISO doesn’t have the feature yet. It has the feature for adding snaps, though. On our upcoming immutable version of Manjaro we have a process to add flatpak packages by default to a disk image.
It would seem to me, that this is a limiting factor for Flatpaks, it will be difficult for Distro’s to include packages in their ISO’s, especially if the package is only available as a Flatpak.
I think AppImage, when installed as a regular Arch Package, seems to have an advantage here.
Only a think, you can try to use penguins-eggs for your user case.
This tool is like the systemback ubuntu app, simple all is in your installation is used for create a redistributable iso.
Disclaimer: i don’t know if you do your customization into a git repository because with penguins-eggs is not possible since is a copy 1:1 of your system ( whitout your personal data of course )
Could you not offer a separate ISO with a default flatpak (or appimage) selection – an offline repo of sorts – some distributions still employ this concept, albeit not with containerised apps.
One of the advantages might be that this offline repo ISO would likely not need rebuilding as often as the OS.
Well, I currently have a separate repo for my little spin of Cinnamon.
Adding an AppImage to an ISO is as simple as building a .pkg.tar.zst package with the appimage inside instead of a binary. It installs as a normal package, it runs as a normal package, has menu item etc. To the user, it is completely transparent, there is no difference between a regular package and an AppImage.
This allows AppImages to be included in the ISO because the package name is the only difference.
Cinelerra is a good example. It is an AppImage that is included in my ISO as cin-appimage. Works perfectly even in live mode.
Fair enough; AppImage may be larger than the binary counterpart, but at least they are more manageable. As a user, I avoid Flatpak in favour of AppImage.
I just thought that (depending on quantity of apps concerned) the separate ISO might have been a valid alternative.
I agree with you, even though I am rather package format agnostic, I tend to lean towards AppImages especially when it comes to larger, more complex packages.
Remember, the binary packages don’t usually have all of the dependencies included, so when you account for totality of what the package requires, it’s really not that bad, especially when you consider that the trade off is simplicity.
