I’ve seen you multiple times on here, so I know you’re not new. Please refrain from posting screenshots.
Providing terminal output
When posting terminal output, copy the output and paste it here, wrapped in three (3) backticks, before AND after the pasted text. Like this:
pasted text
Sed
sollicitudin dolor
eget nisl elit id
condimentum
arcu erat varius
cursus sem quis eros.
Instead of like this:
Sed sollicitudin dolor eget nisl elit id condimentum arcu erat varius cursus sem quis eros.
Thereby increasing legibility thus making it easier for those trying to provide assistance.
I do not have a .zprofile
file on my computer, so I think that file is wrong.
Rather put the function in ~/.zshrc
nano ~/.zshrc
Add it to the bottom:
if [ "$XDG_SESSION_TYPE" == "wayland" ]; then
export MOZ_ENABLE_WAYLAND=1
fi
Save, Ctrl+O → Y, and Exit, Ctrl+X → Y
then you need to load the file, by source
ing it, so in your terminal, run:
source ~/.zshrc
Or that’s how I’d have done it!
Hope this helps!
Edit:
Else, you can put it in a separate script, and this where I believe the shebang comes in, and source in the .zshrc
file.
Classic XY problem.
