I have an Alienware m17 laptop with an NVIDIA RTX 3070 GPU in it. When I plug in my AORUS FV43U monitor in it, though, both screens blank. It works if the OS boots with the monitor plugged in, but will then fail again if I wake it up from sleep.
If I go into the virtual console (which shows up properly on both monitors) and attempt to adjust the xrandr settings (i.e. xrandr --display :0 --output DP-4 --auto), I get the following error:
xrandr: Configure crtc 0 failed
X Error of failed request: BadMatch (invalid parameter attributes)
Major opcode of failed request: 140 (RANDR)
Minor opcode of failed request: 7 (RRSetScreenSize)
Serial number of failed request: 47
Current serial number in output stream: 48
My research has turned up little in regards to a BadMatch relating to RRSetScreenSize. Does anyone here know anything about it?
My display setup: [Plain Text code - 345 lines - codepad]. I do not have a xorg.conf file.
