Hi. I was trying to add a 1440x1080@75Hz resolution to my system (for CSGO) and I have tried about every guide and followed about every piece of advice on any forum I could find. The thing is: sudo xrandr --addmode (long string of stuff)
returns the BadMatch BadMatch (invalid parameter attributes)
error. Okay, but if I do xrandr -q
this is the output:
Screen 0: minimum 8 x 8, current 1920 x 1080, maximum 32767 x 32767
DP-0 disconnected (normal left inverted right x axis y axis)
DP-1 disconnected (normal left inverted right x axis y axis)
DP-2 disconnected (normal left inverted right x axis y axis)
DP-3 disconnected (normal left inverted right x axis y axis)
HDMI-0 connected primary 1920x1080+0+0 (normal left inverted right x axis y axis) 531mm x 299mm
1920x1080 60.00*+ 59.94 50.00
1680x1050 59.95
1600x900 60.00
1440x900 59.89
1280x1024 75.02 60.02
1280x800 59.81
1280x720 60.00 59.94 50.00
1152x864 75.00
1024x768 75.03 70.07 60.00
800x600 75.00 72.19 60.32 56.25
720x576 50.00
720x480 59.94
640x480 75.00 72.81 59.94
DP-4 disconnected (normal left inverted right x axis y axis)
DP-5 disconnected (normal left inverted right x axis y axis)
1440x1080_75.00 (0x351) 165.250MHz -HSync +VSync
h: width 1440 start 1544 end 1696 total 1952 skew 0 clock 84.66KHz
v: height 1080 start 1083 end 1087 total 1130 clock 74.92Hz
Notice that my primary display is HDMI-0
and my desired mode is added to DP-5
. How do I fix that?
I have a GTX 1660 SUPER with one HDMI and ONLY 3 DisplayPorts. My motherboard (ASRock B450 Pro4) has a DP and a HDMI, but I do not have integrated graphics.
Here’s a Pastebin of my whole terminal. To summarize it, I tried adding and removing that mode multiple times and at some point it hit me to just do xrandr -q
and saw the mess that was there.
edit: my mobo has a VGA as well as a USB type C. Again, I don’t have an integrated GPU.
