Hi, I’m trying to setup swap for hibernation and followed the instructions in the manjaro wiki for swap, including selecting a good size for hibernation, to add a swap partition. The hibernate button shows up, and so does swap space under htop, but pressing the hibernate results in the computer shutting down and not restoring anything on boot. Additionally, I have yet to see a single Kb of swap be used.
I believe the hibernate symptoms sound like the case where my system does not have swap as described by this archived forum post (i.e, attempting to hibernate causes shutdown of computer, accepted solution was adding swap to his system) which makes me think that the system not using the swap and hibernate not functioning is due to the same issue of the swap not functioning.
I’ve checked my swapiness value, and it seems to be at the default of 60.
swapon -v
NAME TYPE SIZE USED PRIO
/dev/nvme0n1p2 partition 20G 0B -2
inxi --admin --verbosity=7 --filter --no-host --width INT ✘
Kernel: 5.15.2-2-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=5cd0efe7-0bc3-40fe-9334-0cb2d5228078 rw quiet apparmor=1
Desktop: KDE Plasma 5.23.3 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Convertible System: LENOVO product: 81C4 v: Lenovo YOGA C930-13IKB
serial: <superuser required> Chassis: type: 31 v: Lenovo YOGA C930-13IKB
Mobo: LENOVO model: LNVNB161216 v: SDK0J40709 WIN
serial: <superuser required> UEFI: LENOVO v: 8GCN37WW date: 11/23/2020
ID-1: BAT1 charge: 42.6 Wh (94.7%) condition: 45.0/60.0 Wh (75.0%)
volts: 8.5 min: 7.7 model: Simplo BASE-BAT type: Li-poly serial: <filter>
status: Unknown
RAM: total: 15.37 GiB used: 3.56 GiB (23.2%)
Info: Quad Core model: Intel Core i7-8550U bits: 64 type: MT MCP
arch: Kaby Lake note: check family: 6 model-id: 8E (142) stepping: A (10)
microcode: EA cache: L1: 256 KiB L2: 1024 KiB L3: 8 MiB bogomips: 32012
Speed: 800 MHz min/max: 400/4000 MHz Core speeds (MHz): 1: 800 2: 799 3: 800
4: 800 5: 800 6: 800 7: 800 8: 800
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon art
avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc cpuid
hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid invpcid_single lahf_lm lm
mca mce md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae pat
rdrand rdseed rdtscp rep_good sdbg sep sgx smap smep ss ssbd sse sse2 sse4_1
xsaves xtopology xtpr
Type: l1tf
Device-1: Intel UHD Graphics 620 vendor: Lenovo driver: i915 v: kernel
bus-ID: 00:02.0 chip-ID: 8086:5917 class-ID: 0300
Device-2: AMD Ellesmere [Radeon RX 470/480/570/570X/580/580X/590]
vendor: XFX Pine driver: amdgpu v: kernel bus-ID: 3a:00.0 chip-ID: 1002:67df
class-ID: 0300
Device-3: Acer Integrated Camera type: USB driver: uvcvideo bus-ID: 1-1:2
chip-ID: 5986:2115 class-ID: 0e02
Device-4: Logitech Webcam C270 type: USB driver: snd-usb-audio,uvcvideo
bus-ID: 1-6.1.2:7 chip-ID: 046d:0825 class-ID: 0102 serial: <filter>
Display: x11 server: X.Org 1.21.1.1 compositor: kwin_x11 driver:
loaded: amdgpu,intel unloaded: modesetting display-ID: :0 screens: 1
Screen-1: 0 s-res: 3840x1080 s-dpi: 96 s-size: 1015x285mm (40.0x11.2")
s-diag: 1054mm (41.5")
Monitor-1: HDMI-A-0 res: 1920x1080 hz: 60 dpi: 82
size: 598x336mm (23.5x13.2") diag: 686mm (27")
Monitor-2: eDP1 res: 1920x1080 hz: 60 dpi: 157 size: 310x170mm (12.2x6.7")
diag: 354mm (13.9")
OpenGL: renderer: AMD Radeon RX 580 Series (POLARIS10 DRM 3.42.0
5.15.2-2-MANJARO LLVM 13.0.0)
v: 4.6 Mesa 21.2.5 direct render: Yes
Device-1: Intel Sunrise Point-LP HD Audio vendor: Lenovo driver: snd_soc_skl
v: kernel alternate: snd_hda_intel bus-ID: 00:1f.3 chip-ID: 8086:9d71
class-ID: 0401
Device-2: AMD Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590]
vendor: XFX Pine driver: snd_hda_intel v: kernel bus-ID: 3a:00.1
chip-ID: 1002:aaf0 class-ID: 0403
Device-3: Logitech Webcam C270 type: USB driver: snd-usb-audio,uvcvideo
Sound Server-1: ALSA v: k5.15.2-2-MANJARO running: yes
Sound Server-3: JACK v: 1.9.19 running: no
Sound Server-4: PulseAudio v: 15.0 running: yes
Sound Server-5: PipeWire v: 0.3.40 running: yes
Device-1: Intel Wireless-AC 9260 driver: iwlwifi v: kernel bus-ID: 6b:00.0
chip-ID: 8086:2526 class-ID: 0280
IF: wlp107s0 state: up mac: <filter>
Device-2: Realtek RTL8153 Gigabit Ethernet Adapter type: USB driver: r8152
bus-ID: 4-1.2:4 chip-ID: 0bda:8153 class-ID: 0000 serial: <filter>
IF: enp55s0u1u2 state: down mac: <filter>
Device-1: Intel Wireless-AC 9260 Bluetooth Adapter type: USB driver: btusb
v: 0.8 bus-ID: 1-8:5 chip-ID: 8087:0025 class-ID: e001
Report: rfkill ID: hci0 rfk-id: 3 state: down bt-service: enabled,running
Local Storage: total: 462.05 GiB used: 92.81 GiB (20.1%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: MZVLB256HAHQ-000L2
size: 238.47 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 type: SSD serial: <filter> rev: 0L1QEXD7 temp: 29.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 type: USB vendor: Kingston model: SA400S37240
size: 223.57 GiB block-size: physical: 512 B logical: 512 B type: N/A
serial: <filter> rev: SBFK scheme: GPT
ID-1: / raw-size: 218.21 GiB size: 214.54 GiB (98.32%)
used: 42.79 GiB (19.9%) fs: ext4 dev: /dev/nvme0n1p5 maj-min: 259:3
label: N/A uuid: 5cd0efe7-0bc3-40fe-9334-0cb2d5228078
ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.46%)
used: 3.5 MiB (1.4%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
label: SYSTEM_DRV uuid: BAA4-116D
ID-3: /run/timeshift/backup raw-size: 73.57 GiB size: 71.86 GiB (97.68%)
used: 50.02 GiB (69.6%) fs: ext4 dev: /dev/sda2 maj-min: 8:2
label: Snapshots uuid: 059799cb-c77b-4839-ab9a-519198ad7016
ID-1: swap-1 type: partition size: 20.01 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A
uuid: 95511b64-13f4-4494-a420-eb3e5b78d85a
ID-1: /dev/sda1 maj-min: 8:1 size: 150 GiB fs: ext4 label: Dock
uuid: 683a1c84-bcc8-4996-a49b-03162f5dcb72
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 12 rev: 2.0
Device-1: 1-1:2 info: Acer Integrated Camera type: Video driver: uvcvideo
interfaces: 2 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 5986:2115
class-ID: 0e02
Device-2: 1-5:3 info: Synaptics type: <vendor specific> driver: N/A
interfaces: 1 rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 06cb:0081
class-ID: ff00 serial: <filter>
Hub-2: 1-6:4 info: VIA Labs VL813 Hub ports: 4 rev: 2.1 speed: 480 Mb/s
chip-ID: 2109:2813 class-ID: 0900
Hub-3: 1-6.1:6 info: Realtek RTS5411 Hub ports: 4 rev: 2.1 speed: 480 Mb/s
chip-ID: 0bda:5411 class-ID: 0900
Device-1: 1-6.1.2:7 info: Logitech Webcam C270 type: Video,Audio
power: 500mA chip-ID: 046d:0825 class-ID: 0102 serial: <filter>
Hub-4: 1-6.1.3:8 info: Terminus Hub ports: 4 rev: 2.0 speed: 480 Mb/s
power: 100mA chip-ID: 1a40:0101 class-ID: 0900
Device-1: 1-6.1.3.1:9 info: Microdia USB DEVICE type: Keyboard,Mouse
power: 100mA chip-ID: 0c45:8520 class-ID: 0301
Device-2: 1-6.1.3.3:10 info: SINOWEALTH Game Mouse type: Mouse,Keyboard
driver: hid-generic,usbhid interfaces: 2 rev: 1.1 speed: 12 Mb/s
power: 480mA chip-ID: 258a:1007 class-ID: 0301
Device-3: 1-8:5 info: Intel Wireless-AC 9260 Bluetooth Adapter
type: Bluetooth driver: btusb interfaces: 2 rev: 2.0 speed: 12 Mb/s
power: 100mA chip-ID: 8087:0025 class-ID: e001
Hub-5: 2-0:1 info: Super-speed hub ports: 6 rev: 3.0 speed: 5 Gb/s
Hub-6: 3-0:1 info: Hi-speed hub with single TT ports: 2 rev: 2.0
Hub-7: 4-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
Hub-8: 4-1:2 info: VIA Labs VL813 Hub ports: 4 rev: 3.0 speed: 5 Gb/s
chip-ID: 2109:0813 class-ID: 0900
Hub-9: 4-1.1:3 info: Realtek Hub ports: 4 rev: 3.0 speed: 5 Gb/s
chip-ID: 0bda:0411 class-ID: 0900
Device-1: 4-1.2:4 info: Realtek RTL8153 Gigabit Ethernet Adapter
type: Network driver: r8152 interfaces: 1 rev: 3.0 speed: 5 Gb/s
power: 256mA chip-ID: 0bda:8153 class-ID: 0000 serial: <filter>
Device-2: 4-1.3:5 info: VIA Labs VL817 SATA Adaptor type: Mass Storage
driver: uas interfaces: 1 rev: 3.1 speed: 5 Gb/s power: 8mA
chip-ID: 2109:0715 class-ID: 0806 serial: <filter>
System Temperatures: cpu: 29.8 C pch: 41.0 C mobo: 27.8 C gpu: amdgpu
temp: 52.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 810
Processes: 335 Uptime: 59m wakeups: 9 Init: systemd v: 249 tool: systemctl
Compilers: gcc: 11.1.0 clang: 13.0.0 Packages: pacman: 1424 lib: 360
flatpak: 0 Shell: Zsh v: 5.8 default: Bash v: 5.1.8 running-in: yakuake
inxi: 3.3.09
Any help would be much appreciated!
Apologies if this isn’t the right category, I wasn’t sure if this could be considered kernel, or something else.
