Hello,
I’m trying to add a variable in my PATH. I used this command :
export PATH=$PATH:/home/USERNAME/.local/share/gem/ruby/3.0.0/bin
This work but if I open a new terminal, the variable doesn’t work again. How it’s possible to add a variable globally on the system ?
Thanks
pobrn
29 April 2021 09:37
2
Since it references your user’s home directory, it’s probably not a good idea to add it globally to the PATH
. You could put it in the .bashrc
/.zshrc
file, though.
Thank you, I’ve added my command in these files and it’s work perfectly !
system
Closed
15 May 2021 06:34
6
