Continuing this thread https:// bbs.archlinux .org /viewtopic.php?pid=1999422#p1999422 here
Question: I want to add SSSD LDAP user’s entry in Linux when they first time login because I want every user to be sudoer.
Setup: using SSSD with LDAP, putting my SSSD and PAM config below if it helps.
/etc/sssd/sssd.conf
[sssd]
config_file_version = 2
services = nss, pam, sudo
domains = MYDOMAIN
[domain/MYDOMAIN]
#cache_credentials = true
debug_level = 5
enumerate = false
id_provider = ldap
auth_provider = ldap
chpass_provider = ldap
access_provider = ldap
ldap_uri = ldaps://xxxxx
ldap_search_base = xxxxxx
ldap_default_bind_dn = xxxx
ldap_group_search_base = cn=groups,xxxxxx
ldap_default_authtok_type = password
ldap_default_authtok = xxxxx
sudo_provider = none
ldap_schema = rfc2307
ldap_tls_reqcert = allow
ldap_access_order = filter
ldap_access_filter = memberOf=cn=member,cn=groups,xxxxxx
ldap_referrals = false
/etc/pam.d/system.auth
#%PAM-1.0
auth sufficient pam_sss.so forward_pass
auth required pam_faillock.so preauth
# Optionally use requisite above if you do not want to prompt for the password
# on locked accounts.
auth [success=2 default=ignore] pam_unix.so try_first_pass nullok
-auth [success=1 default=ignore] pam_systemd_home.so
auth [default=die] pam_faillock.so authfail
auth optional pam_permit.so
auth required pam_env.so
auth required pam_faillock.so authsucc
# If you drop the above call to pam_faillock.so the lock will be done also
# on non-consecutive authentication failures.
account [default=bad success=ok user_unknown=ignore authinfo_unavail=ignore] pam_sss.so
-account [success=1 default=ignore] pam_systemd_home.so
account required pam_unix.so
account optional pam_permit.so
account required pam_time.so
password sufficient pam_sss.so use_authtok
-password [success=1 default=ignore] pam_systemd_home.so
password required pam_unix.so try_first_pass nullok shadow sha512
password optional pam_permit.so
session required pam_mkhomedir.so skel=/etc/skel/ umask=0077
session required pam_limits.so
session required pam_unix.so
session optional pam_sss.so
session optional pam_permit.so
/etc/pam.d/su
#%PAM-1.0
auth sufficient pam_rootok.so
# Uncomment the following line to implicitly trust users in the "wheel" group.
#auth sufficient pam_wheel.so trust use_uid
# Uncomment the following line to require a user to be in the "wheel" group.
#auth required pam_wheel.so use_uid
auth required pam_unix.soaccount
NOTE: Added
pam_sssconfig earlier in/etc/pam.d/sudo, which was causing 2 time sudo password prompt and as per arch thread it’s unnecessary to configuresudobecause it will inherit and usessystem-authso removed it. Just putting it for heads up.
#%PAM-1.0
auth sufficient pam_fprintd.so
auth sufficient pam_unix.so try_first_pass likeauth nullok
auth required pam_deny.so
auth include system-auth
account include system-auth
session include system-auth
