Add/Remove Software: Remote peer disconnected
Hello,
I just installed Manjaro Linux KDE Plasma 24.0.8 on my desktop.
The app “Install / Remove Software” cannot be started : comment given : “Remote peer disconnected” !
What to do to solve this problem ?
Thanks in advance for your reply.
Best regards.
I dont really know about this error … but …
What happens if you launch it from the terminal?
pamac-manager
Furthermore we could make sure you are fully synced/updated;
sudo pacman-mirrors --continent && sudo pacman -Syu
That sounds strange - the only thing that comes to mind is the mirrorlist.
To remedy that - see the comment by @cscs
Unless you know what you are doing - I recommend you do not enable AUR in the Add/Remove Software app.
For AUR in general see → [Need-To-Know] About Manjaro and AUR
@lukvdl I’ve edited your topic title to be more clear and concise.
Notice in your menu the application is called Add/Remove Software (aka Pamac). :wink:
