https://manjaro.org/get-manjaro/, which download section perhaps used more frequently and exactly this section lacks .pkgs description file showing which packages are provided.
PS: Is https://download.manjaro.org/ still avaliable? It says 404 not found so I wonder why @philm use this URL instead of the https://manjaro.org/get-manjaro/ on the forum. It seems that all the mirror sites pointing to https://download.manjaro.org/ fail too
Well, that is the only way we can do it on the CDN and also there should be no 301 as otherwise the downloads higher in the tree won’t work anymore. Before it was only “new_url” which land to the 404 page.
