On my raspberry PI400 adb is not working due to a lack of link to libprotobuf.so.30
adb: error while loading shared libraries: libprotobuf.so.30: cannot open shared object file: No such file or directory
And really:
ldd /usr/bin/adb 127 ✘
linux-vdso.so.1 (0x0000ffff97206000)
libprotobuf.so.30 => not found
libpthread.so.0 => /usr/lib/libpthread.so.0 (0x0000ffff96e90000)
libbrotlidec.so.1 => /usr/lib/libbrotlidec.so.1 (0x0000ffff96e70000)
libbrotlienc.so.1 => /usr/lib/libbrotlienc.so.1 (0x0000ffff96dc0000)
liblz4.so.1 => /usr/lib/liblz4.so.1 (0x0000ffff96d90000)
libusb-1.0.so.0 => /usr/lib/libusb-1.0.so.0 (0x0000ffff96d60000)
libz.so.1 => /usr/lib/libz.so.1 (0x0000ffff96d30000)
libzstd.so.1 => /usr/lib/libzstd.so.1 (0x0000ffff96c70000)
libstdc++.so.6 => /usr/lib/libstdc++.so.6 (0x0000ffff96a20000)
libgcc_s.so.1 => /usr/lib/libgcc_s.so.1 (0x0000ffff969f0000)
libc.so.6 => /usr/lib/libc.so.6 (0x0000ffff96840000)
/lib/ld-linux-aarch64.so.1 => /usr/lib/ld-linux-aarch64.so.1 (0x0000ffff971cd000)
libbrotlicommon.so.1 => /usr/lib/libbrotlicommon.so.1 (0x0000ffff96800000)
libm.so.6 => /usr/lib/libm.so.6 (0x0000ffff96750000)
libudev.so.1 => /usr/lib/libudev.so.1 (0x0000ffff966f0000)
libatomic.so.1 => /usr/lib/libatomic.so.1 (0x0000ffff966d0000)
I have libprotobuf installed
protobuf [Installati] 3.20.1-2 extra
Protocol Buffers - Google's data interchange format
Do we need to recompile the package android-tools ?
Strit
June 12, 2022, 3:06pm
2
Yes. But we inherit android-tools from Arch Linux ARM. They just haven’t rebuilt/updated it yet.
And the bug is also on the correspondent forum Arch Linux ARM • View topic - [android-tools] is outdated but without any response.
Hello,
I was the OP in the archlinuxarm post. I haven’t gotten a response in weeks.
I tried finding the PKGBUILD for android-tools for the arm version but couldn’t find it.
I tried using the PKGBUILD from x86_64 and it failed to build on my Pi.
So I’m stuck there too. Hopefully they fix the issue soon.
I can confirm your report.
I modified the PKGBUILD file in the line arch=(aarch64) , gave the command makepkg --clean–syncdeps but the compilation fails with this message
-- Build files have been written to: /home/leandro/lavoro/android-tools/trunk/src/android-tools-31.0.3p1/build
==> Entro nell'ambiente fakeroot...
==> Avvio di package() in corso...
ninja: Entering directory `build'
[9/226] Building C object vendor/boringssl/crypto/CMakeFiles/crypto.dir/bytestring/cbs.c.o
FAILED: vendor/boringssl/crypto/CMakeFiles/crypto.dir/bytestring/cbs.c.o
/usr/bin/cc -DBORINGSSL_HAVE_LIBUNWIND -DBORINGSSL_IMPLEMENTATION -I/home/leandro/lavoro/android-tools/trunk/src/android-tools-31.0.3p1/vendor/boringssl/third_party/googletest/include -I/home/leandro/lavoro/android-tools/trunk/src/android-tools-31.0.3p1/vendor/boringssl/crypto/../include -march=armv8-a -O2 -pipe -fstack-protector-strong -fno-plt -fexceptions -Wp,-D_FORTIFY_SOURCE=2 -Wformat -Werror=format-security -fstack-clash-protection -Werror -Wformat=2 -Wsign-compare -Wmissing-field-initializers -Wwrite-strings -Wvla -ggdb -Wall -fvisibility=hidden -fno-common -Wno-free-nonheap-object -Wimplicit-fallthrough -Wmissing-prototypes -Wold-style-definition -Wstrict-prototypes -Wshadow -std=c11 -D_XOPEN_SOURCE=700 -O3 -DNDEBUG -MD -MT vendor/boringssl/crypto/CMakeFiles/crypto.dir/bytestring/cbs.c.o -MF vendor/boringssl/crypto/CMakeFiles/crypto.dir/bytestring/cbs.c.o.d -o vendor/boringssl/crypto/CMakeFiles/crypto.dir/bytestring/cbs.c.o -c /home/leandro/lavoro/android-tools/trunk/src/android-tools-31.0.3p1/vendor/boringssl/crypto/bytestring/cbs.c
/home/leandro/lavoro/android-tools/trunk/src/android-tools-31.0.3p1/vendor/boringssl/crypto/bytestring/cbs.c: In function ‘CBS_get_asn1_int64’:
/home/leandro/lavoro/android-tools/trunk/src/android-tools-31.0.3p1/vendor/boringssl/crypto/bytestring/cbs.c:483:16: error: writing 1 byte into a region of size 0 [-Werror=stringop-overflow=]
483 | u.bytes[i] = data[len - i - 1];
/home/leandro/lavoro/android-tools/trunk/src/android-tools-31.0.3p1/vendor/boringssl/crypto/bytestring/cbs.c:480:5: note: at offset 8 into destination object ‘u’ of size 8
480 | } u;
cc1: all warnings being treated as errors
[12/226] Building CXX object vendor/CMakeFiles/libadb.dir/adb/pairing_connection/pairing_connection.cpp.o
/home/leandro/lavoro/android-tools/trunk/src/android-tools-31.0.3p1/vendor/adb/pairing_connection/pairing_connection.cpp: In static member function ‘static PairingAuthPtr PairingConnectionCtx::CreatePairingAuthPtr(PairingConnectionCtx::Role, const Data&)’:
/home/leandro/lavoro/android-tools/trunk/src/android-tools-31.0.3p1/vendor/adb/pairing_connection/pairing_connection.cpp:448:1: warning: control reaches end of non-void function [-Wreturn-type]
448 | }
[13/226] Building CXX object vendor/CMakeFiles/libadb.dir/adb/client/auth.cpp.o
/home/leandro/lavoro/android-tools/trunk/src/android-tools-31.0.3p1/vendor/adb/client/auth.cpp: In function ‘bool load_keys(const string&, bool)’:
/home/leandro/lavoro/android-tools/trunk/src/android-tools-31.0.3p1/vendor/adb/client/auth.cpp:178:49: warning: ignoring attributes on template argument ‘int (*)(DIR*)’ [-Wignored-attributes]
178 | std::unique_ptr<DIR, decltype(&closedir)> dir(opendir(path.c_str()), closedir);
[14/226] Building CXX object vendor/CMakeFiles/adb.dir/adb/transport.cpp.o
ninja: build stopped: subcommand failed.
==> ERRORE: Si è verificato un errore in package().
L'operazione sta per essere interrotta...
zbe
June 13, 2022, 12:16pm
6
As I temporary measure you could either downgrade protobuf (edit: if nothing else depends on it ofc (as mentioned by @Strit )) or use LD_PRELOAD=/path/to/libprotobuf.so.30 adb
ArchlinuxARM archived package where you can get libprotobuf.so.30 and the rest from: http://tardis.tiny-vps.com/aarm/packages/p/protobuf/protobuf-3.19.4-1-aarch64.pkg.tar.xz
Strit
June 13, 2022, 1:18pm
7
Be aware that downgrading a ibraries like protobuf, will likely result in lots of other stuff not working.
just a hint: you also need `libprotobuf.so.30.0.4 in same directory as it is the actual file, the other one is just a symlink.
zbe
June 23, 2022, 10:55am
9
I know, hence I said:
Agreed, could wrote it a bit clearer.
