my macbook pro model deactivates the integrated intel gpu on every system except osx. right now i’m using the nvidia graphics.
there is an efi program that activates the internal graphics.
in short I think there is an efi file chainloaded so that the laptop thinks it starts osx.
you have to copy the file to the efi folder and edit the 40_custom grub file.
although it is advertised in the arch wiki it won’t work on my system. I had it working on ubuntu before.
I think there is a problem with the 40_custom changes.
if I follow the official instructions from the link above I have to add the following to 40_custom
search --no-floppy --set=root --label EFI
chainloader (${root})/EFI/custom/apple_set_os.efi
boot
after update-grub and reboot nothing changes. the integrated graphics card is not visible with lspci | grep VGA
there is another site, that explains the same efi program but with another 40_custom entry.
there the addition to 40_custom looks like
search --no-floppy --set=root --file /EFI/custom/apple_set_os.efi
chainloader /EFI/custom/apple_set_os.efi
boot
If I use these changes and reboot. Manjaro hangs on boot and I had to chroot and cancel the changes.
Does anyone know how to chainload this file to make it work?
I wish I could post the links to the sites, but somehow I am not allowed.
Thank you for your help!
6x12
15 August 2022 11:56
2
hello. thank you for your answer. yes I copied the file as described in the instructions.
6x12
15 August 2022 12:06
4
Well, first can you give the output of
inxi -Fz
to check if yours is indeed a mbp 11,3 - ’ MacBook Pro Mid 2014’ isn’t enough info, there’s more than one model.
6x12:
inxi -Fz
it is an mbp 11,3
Kernel: 5.15.60-1-MANJARO arch: x86_64 bits: 64 Desktop: GNOME v: 42.4
Distro: Manjaro Linux
Type: Laptop System: Apple product: MacBookPro11,3 v: 1.0
serial: <superuser required>
Mobo: Apple model: Mac-2BD1B31983FE1663 v: MacBookPro11,3
serial: <superuser required> UEFI: Apple v: 433.120.6.0.0 date: 03/16/2022
ID-1: BAT0 charge: 97.0 Wh (100.0%) condition: 97.0/97.2 Wh (99.8%)
Info: quad core model: Intel Core i7-4870HQ bits: 64 type: MT MCP cache:
L2: 1024 KiB
Speed (MHz): avg: 1075 min/max: 800/3700 cores: 1: 1091 2: 1098 3: 1018
4: 1098 5: 1006 6: 1098 7: 1098 8: 1097
Device-1: NVIDIA GK107M [GeForce GT 750M Mac Edition] driver: nvidia
v: 390.154
Display: x11 server: X.org v: 1.21.1.4 with: Xwayland v: 22.1.3 driver:
X: loaded: nvidia gpu: nvidia resolution: 2880x1800~60Hz
OpenGL: renderer: GeForce GT 750M/PCIe/SSE2 v: 4.6.0 NVIDIA 390.154
Device-1: Intel 8 Series/C220 Series High Definition Audio
driver: snd_hda_intel
Device-2: NVIDIA GK107 HDMI Audio driver: snd_hda_intel
Device-3: Broadcom 720p FaceTime HD Camera driver: N/A
Sound Server-1: ALSA v: k5.15.60-1-MANJARO running: yes
Sound Server-3: PipeWire v: 0.3.56 running: yes
Device-1: Broadcom BCM4360 802.11ac Wireless Network Adapter driver: wl
IF-ID-1: nordlynx state: unknown speed: N/A duplex: N/A mac: N/A
Device-1: Apple Bluetooth Host Controller type: USB driver: btusb
Local Storage: total: 465.92 GiB used: 34.19 GiB (7.3%)
ID-1: /dev/sda vendor: Apple model: SSD SM0512F size: 465.92 GiB
ID-1: / size: 448.53 GiB used: 34.19 GiB (7.6%) fs: btrfs dev: /dev/sda2
ID-2: /boot/efi size: 299.4 MiB used: 620 KiB (0.2%) fs: vfat
dev: /dev/sda1
ID-3: /home size: 448.53 GiB used: 34.19 GiB (7.6%) fs: btrfs
dev: /dev/sda2
ID-4: /var/log size: 448.53 GiB used: 34.19 GiB (7.6%) fs: btrfs
dev: /dev/sda2
ID-1: swap-1 type: partition size: 17.09 GiB used: 0 KiB (0.0%)
dev: /dev/sda3
System Temperatures: cpu: 67.0 C mobo: N/A gpu: nvidia temp: 64 C
Processes: 292 Uptime: 1h 3m Memory: 15.54 GiB used: 3.06 GiB (19.7%)
Shell: Zsh inxi: 3.3.20
6x12
15 August 2022 12:34
6
Under ‘issues’ Search line in /etc/grub.d/40_custom is not generic · Issue #23 · 0xbb/apple_set_os.efi · GitHub
“Search line in /etc/grub.d/40_custom is not generic”
So first run:
# grep "set=root" `find /boot -name "grub.cfg"` | tail -1
then use output:
search --no-floppy --fs-uuid --set=root 00000000-0000-0000-0000-000000000000
to edit 40_custom:
boot
Update grub…
I get this output
search --fs-uuid --no-floppy --set=root --hint-bios=hd0,gpt2 --hint-efi=hd0,gpt2 --hint-baremetal=ahci0,gpt2 faa55db0-ec60-49ef-8ff4-57fdf794625a
I also read that comment in issues and added the shown number behind root.
so just use this?
search --no-floppy --fs-uuid --set=root faa55db0-ec60-49ef-8ff4-57fdf794625a
boot
I think I already tried it. but I will try again.
6x12
15 August 2022 12:53
8
I’d put the full output in.
I’ll use this then
boot
lspci | grep VGA still only show the NVIDIA graphics.
6x12
15 August 2022 14:04
11
Hmm. Short of checking the process again, I’m running out of ideas, sorry.
Checking the MacBookPro11,x - ArchWiki you’ll need the intel driver, a gpu switch and since 'gpu-switch will not completely power down the dedicated card, you will have to create a custom grub menuentry and compile a program that will power off the dedicated card."
Which sounds almost more hassle then it’s worth. I also wouldn’t be so sure that the integrated intel iris card (which will stress the cpu more) will be able to run
fruitsaladus:
Desktop: GNOME
properly.
It already worked in Debian setup. It had some advantages on that system. battery life, heat etc.
I got it to work with this grub.d/40_custom
boot
Credits to
https://github.com/0xbb/apple_set_os.efi
https://gist.github.com/stefanocoding/c6dbf4489f330021bd9335d655c9fbbf
the combination of their grub.d/40_custom files worked.
ty for your help also.
6x12
15 August 2022 16:32
13
Glad you found a solution.
Try auto-cpufreq, been following this thread: Aggressive powersaving? and for me it brought temps down significantly on 2 older laps, one a nvidia mbp.
