ACPI BIOS Error (bug): AE_AML_PACKAGE_LIMIT, Index (0x000000008)
Hi.
I have an ACER Aspire A114-31 with Manjaro.
When I plug the charger in the screen goes black and it freezes completely. Only a restart helps an only when I start it without the charger in.
I updated the BIOS. Error stays.
The following error occurs:
**Apr 21 16:16:33 miriam-manjaro kernel: ACPI BIOS Error (bug): AE_AML_PACKAGE_LIMIT, Index** (0x000000008) is beyond end of object (length 0x8) (20220331/exoparg2-393)
Apr 21 16:16:33 miriam-manjaro kernel: ACPI Error: Aborting method \_SB.PEPD._DSM due to previous error (AE_AML_PACKAGE_LIMIT) (20220331/psparse-529)
Apr 21 16:16:35 miriam-manjaro bluetoothd[430]: src/plugin.c:plugin_init() Failed to init vcp plugin
Apr 21 16:16:35 miriam-manjaro bluetoothd[430]: src/plugin.c:plugin_init() Failed to init mcp plugin
Apr 21 16:16:35 miriam-manjaro bluetoothd[430]: src/plugin.c:plugin_init() Failed to init bap plugin
Apr 21 16:16:36 miriam-manjaro kernel: EDAC pnd2: Failed to register device with error -22.
Apr 21 16:17:29 miriam-manjaro gdm-password][1018]: gkr-pam: unable to locate daemon control file
Apr 21 16:17:30 miriam-manjaro systemd[1038]: Failed to start Application launched by gnome-session-binary.
Neofetch:
β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ  β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ   miriamw@miriam-manjaro
β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ  β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ   ----------------------
β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ  β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ   OS: Manjaro Linux x86_64
β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ  β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ   Host: Aspire A114-31 V1.29
β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ            β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ   Kernel: 6.1.23-1-MANJARO
β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ  β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ  β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ   Uptime: 15 mins
β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ  β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ  β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ   Packages: 1213 (pacman), 8 (flatpak)
β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ  β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ  β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ   Shell: zsh 5.9
β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ  β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ  β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ   Resolution: 1366x768
β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ  β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ  β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ   Terminal: /dev/pts/1
β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ  β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ  β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ   CPU: Intel Pentium N4200 (4) @ 2.500GHz
β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ  β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ  β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ   GPU: Intel Apollo Lake [HD Graphics 505]
β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ  β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ  β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ   Memory: 1148MiB / 3760MiB
inxi --admin --verbosity=7 --filter --width output:
  Kernel: 6.1.23-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
    root=UUID=b69f9612-c1d4-4c6f-844f-47284d046bd0 rw quiet splash apparmor=1
  Console: pty pts/1 DM: GDM v: 43.0 Distro: Manjaro Linux base: Arch Linux
  Type: Laptop System: Acer product: Aspire A114-31 v: V1.29
  Mobo: APL model: Bulbasaur_AP_S v: V1.29 serial: <superuser required>
    UEFI: Insyde v: 1.29 date: 10/29/2018
  ID-1: BAT1 charge: 30.3 Wh (93.2%) condition: 32.5/37.0 Wh (87.8%) volts: 8.4
    min: 7.7 model: PANASONIC AP16M5J type: Li-ion serial: <filter>
    status: discharging
  RAM: total: 3.67 GiB used: 1.36 GiB (37.1%)
  Info: model: Intel Pentium N4200 bits: 64 type: MCP arch: Goldmont level: v2
    built: 2016 process: Intel 14nm family: 6 model-id: 0x5C (92) stepping: 9
    microcode: 0x48
  Topology: cpus: 1x cores: 4 smt: <unsupported> cache: L1: 224 KiB
    desc: d-4x24 KiB; i-4x32 KiB L2: 2 MiB desc: 2x1024 KiB
  Speed (MHz): avg: 1311 high: 2500 min/max: 800/2500 scaling:
    driver: intel_cpufreq governor: schedutil cores: 1: 2500 2: 1146 3: 800
    4: 800 bogomips: 8756
  Flags: 3dnowprefetch acpi aes aperfmperf apic arat arch_capabilities
    arch_perfmon art bts cat_l2 clflush clflushopt cmov constant_tsc cpuid
    cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts ept ept_ad erms est
    flexpriority fpu fsgsbase fxsr ht ibpb ibrs ida intel_pt lahf_lm lm mca
    mce md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae pat
    pbe pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pts rdrand
    rdseed rdt_a rdtscp rep_good sdbg sep sha_ni smap smep ss sse sse2 sse4_1
    tsc_deadline_timer tsc_known_freq tsc_reliable vme vmx vnmi vpid x2apic
  Type: spec_store_bypass status: Not affected
    STIBP: disabled, RSB filling, PBRSB-eIBRS: Not affected
  Device-1: Intel Apollo Lake [HD Graphics 505] vendor: Acer Incorporated ALI
    driver: i915 v: kernel arch: Gen-9 process: Intel 14n built: 2015-16 ports:
    active: none off: eDP-1 empty: HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:5a84
    class-ID: 0300
  Device-2: Realtek VGA WebCam type: USB driver: uvcvideo bus-ID: 1-7:3
    chip-ID: 0bda:564a class-ID: 0e02 serial: <filter>
  Display: server: X.org v: 1.21.1.8 with: Xwayland v: 23.1.1
    compositor: gnome-shell driver: gpu: i915 note: X driver n/a - try sudo/root
    tty: 213x48
  Monitor-1: eDP-1 model: ChiMei InnoLux 0x14c3 built: 2015 res: 1366x768
    dpi: 112 gamma: 1.2 size: 309x173mm (12.17x6.81") diag: 354mm (13.9")
    ratio: 16:9 modes: 1366x768
  API: OpenGL Message: GL data unavailable in console. Try -G --display
  Device-1: Intel Celeron N3350/Pentium N4200/Atom E3900 Series Audio Cluster
    vendor: Acer Incorporated ALI driver: snd_hda_intel v: kernel
    alternate: snd_soc_skl, snd_soc_avs, snd_sof_pci_intel_apl bus-ID: 00:0e.0
    chip-ID: 8086:5a98 class-ID: 0403
  API: ALSA v: k6.1.23-1-MANJARO status: kernel-api with: aoss
    type: oss-emulator tools: alsamixer,amixer
  Server-2: PipeWire v: 0.3.68 status: off tools: pw-cli
  Server-3: PulseAudio v: 16.1 status: active tools: pacat,pactl
    vendor: Acer Incorporated ALI driver: r8169 v: kernel pcie: gen: 1
    speed: 2.5 GT/s lanes: 1 port: 1000 bus-ID: 02:00.1 chip-ID: 10ec:8168
    class-ID: 0200
  IF: enp2s0f1 state: down mac: <filter>
  Device-2: Qualcomm Atheros QCA9377 802.11ac Wireless Network Adapter
    vendor: Lite-On driver: ath10k_pci v: kernel pcie: gen: 1 speed: 2.5 GT/s
    lanes: 1 bus-ID: 03:00.0 chip-ID: 168c:0042 class-ID: 0280
  Device-1: Lite-On Qualcomm Atheros QCA9377 Bluetooth type: USB driver: btusb
    v: 0.8 bus-ID: 1-5:2 chip-ID: 04ca:3015 class-ID: e001
  Report: rfkill ID: hci0 rfk-id: 4 state: up address: see --recommends
  Local Storage: total: 58.24 GiB used: 12.93 GiB (22.2%)
  ID-1: /dev/mmcblk0 maj-min: 179:0 vendor: SK Hynix model: HCG4a2
    size: 58.24 GiB block-size: physical: 512 B logical: 512 B type: SSD
    serial: <filter> rev: 0x8 scheme: GPT
  ID-1: / raw-size: 57.95 GiB size: 56.74 GiB (97.91%) used: 12.93 GiB (22.8%)
    fs: ext4 dev: /dev/mmcblk0p2 maj-min: 179:2 label: N/A
    uuid: b69f9612-c1d4-4c6f-844f-47284d046bd0
    used: 312 KiB (0.1%) fs: vfat dev: /dev/mmcblk0p1 maj-min: 179:1 label: N/A
    uuid: 9E67-F475
  ID-1: /dev/mmcblk0boot0 maj-min: 179:8 size: 4 MiB fs: <superuser required>
    label: N/A uuid: N/A
  ID-2: /dev/mmcblk0boot1 maj-min: 179:16 size: 4 MiB
    fs: <superuser required> label: N/A uuid: N/A
  Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 8 rev: 2.0
  Device-1: 1-5:2 info: Lite-On Qualcomm Atheros QCA9377 Bluetooth
    type: Bluetooth driver: btusb interfaces: 2 rev: 2.0 speed: 12 Mb/s
    power: 100mA chip-ID: 04ca:3015 class-ID: e001
  Device-2: 1-7:3 info: Realtek VGA WebCam type: Video driver: uvcvideo
    interfaces: 2 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 0bda:564a
  Hub-2: 2-0:1 info: Super-speed hub ports: 7 rev: 3.0 speed: 5 Gb/s
  System Temperatures: cpu: 32.0 C mobo: N/A
  Processes: 209 Uptime: 12m wakeups: 2 Init: systemd v: 252 default: graphical
  tool: systemctl Compilers: gcc: 12.2.1 clang: 15.0.7 Packages: 1221
  pm: pacman pkgs: 1213 libs: 319 tools: gnome-software,pamac,yay pm: flatpak
  pkgs: 8 Shell: Zsh v: 5.9 running-in: pty pts/1 (SSH) inxi: 3.3.26
Thank you in advance.
Hello,
Might not be much, but you could try to add acpi=off in the GRUB_CMDLINE_LINUX_DEFAULT line inside the /etc/default/grub file … but then even ACPI events that work will be disabled …
Or maybe you can try instead to add acpi_enforce_resources=no (but not both at the same time) and once you modified the grub file, from terminal you run:
sudo update-grub
Restart your system and see if things changed for better.
A slightly smaller hammer would be
acpi_enforce_resources=lax
I already tried acpi=off, then the PC wont even start.
I tried the β€œsmaller hammer” from @cscs acpi_enforce_resources=lax but it doesn’t change anything.
Looks like ACPI-errors are mostly harmless, but the driver for your charger is missing or buggy?
https://bbs.archlinux.org/viewtopic.php?id=280549
Firmware for this charger needed?
I don’t think so, its the standard charger from the manufacturer. But how would I find out which firmware to install? the gnome-firmware doesn’t help at all. Haha.
There are many firmwarefiles in the AUR!!
Maybe the name of the devices matches the name of the AUR-packet.
This time using AUR is not bad but sometimes or most times the one and only possibility…
Another explanation would be:
USB port overload (initial current is to high) ==> safety shutdown…
<==> but then: booting with charger put in would work…
tl;dr
OLD firmware does not care about standards ACPI code and newer Linux Kernel just scream about it in logs.
Fairly solution is just upgrade BIOS/UEFI Firmware from Acer, BUT Acer does not care. You have recent version so nothing you can do with this.
noacpi or acpi=off are for debug, not for normal usage.
Intel Apollo Lake released in 2016. So, it is normal see weird ACPI codes errors in latest Linux Kernel.
Flag like acpi_enforce_resources is useful for sensors detect. Nothing more now.
@walrussi please just ignore this mess in DMESG.
