hi guys, I have had to make a new account using the same email and username that i did in November so just over 2 months ago.now i didn’t break any rules i even posted on a thread about a lib32 issue .only to find out about 2 months later that either you guys removed my account or there is an issue with your forums.am i going to have to make another account using the same email and same username in 2 months again?
Please see:
thanks for the fast reply and thanks for the information too.ah the joys of computers
However, if you disagree with my choice, please feel free to take any other answer as the solution to your question or even remove the solution altogether: You are in control! (If you disagree with my choice, just send me a personal message and explain why I shouldn’t have done this or
or
if you agree)
P.S. In the future, please don’t forget to come back and click the 3 dots below the answer to mark a solution like this below the answer that helped you most:
