Accidently Deleted Manjaro Kernel
I have dual booted manjaro with windows 11. I have accidenly deleted manjaro kernal & it does not boot up. It goes to the manjaro grub menu only windows 11 is showing. There is no kernal in /boot.
Anyways to boot it up?
Hi @tester7878, and welcome!
I’d recommend you boot a live environment, enter a chroot environment from there and reinstall the kernel.
How to chroot
  1. Ensure you’ve got a relatively new ISO or at least one with a still supported LTS kernel.
  2. Write/copy/dd the ISO to a USB thumb drive.
  3. When done, boot with the above mentioned USB thumb drive into the live environment.
  4. Once booted, open a terminal and enter the following command to enter the chroot environment:
manjaro-chroot -a
  1. If you have more than one Linux installation, select the correct one to use from the list provided.
When done, you should now be in the chroot environment.
But, be careful, as you’re now in an actual root environment on your computer, so any changes you make will persist after a restart.
For more:
Once there you’d have to install a new kernel. I recommend 6.6 as I use that, it’s LTS, and it works well. To install it, from within the chroot environment, run:
sudo mhwd-kernel --install linux66
if all goes well and there were no errors, exit the chroot environment:
exit
And reboot
Note that the above text is partially pre-prepared as a general introduction for new forum Users. Please take the time to follow links given and learn how to create effective Support requests and encourage quality responses.
Note:
The chroot instructions will not work on a BTRFS filesystem. If you’ve got that, please see the following for chrooting instructions:
Best way is to boot from your installation USB
manjaro-chroot -a
from a Terminal window, then install the Kernel of your choice e.g.
mhwd-kernel -i linux612
@Mirdarthos you beat me to it! :wink:
Either boot a live USB and restore a snaphot, or maybe just chroot from USB and install that way.
I would boot into the Manjaro iso on a usb, then use manjaro-chroot to access your Manjaro installation. Here’s how (assuming you are not using the BTRFS file system):
Once you’ve accessed your system, you can re-install a kernel with:
mhwd-kernel -i linux612.
This should install the latest stable kernel and update GRUB.
No need for sudo with chroot as far as I’m aware, but shouldn’t make any difference in this case.
Fixed it - thank you.
Also, there is no A in “kernel”
This Manjaro Wiki article explains how to reinstall GRUB:
Feel free to ask if anything needs clarification.
A few quick questions:
  • Are Windows and Manjaro on separate disks (preferred) or have you installed both OS to one disk only?
  • Please provide system information:
inxi --admin --verbosity=8 --filter --no-host --width
I tried manjaro-chroot -a
It is detecting the wrong partition.
Manjaro is installed in my nvme drive. It is not getting detected. To detect that i need to update the grub with nvme_core.default_ps_max... .
After adding this param & when i ran sudo update-grub. It gave cannet update latency error.
also i cant mount the manjaro partition since it is not detecting the nvme drive.
And where is Windows installed…
Please answer the question:
I have two drives
Nvme ssd
It has manjaro & windows 11
Hdd
It has Windows 10 and Ubuntu
You have been repeatedly asked for information, both from me and @soundofthunder. Without this any help we provide is at best an educated guess, so please provide more information.
Also, the disk setup you described is, in my humble opinion, as recipe for disaster.
Manjaro & windows is installed in the same drive.
   ~  inxi --admin --verbosity=8 --filter --no-host --width                                          ✔
  Kernel: 6.12.4-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
    clocksource: hpet avail: acpi_pm parameters: BOOT_IMAGE=/boot/vmlinuz-x86_64
    lang=en_US keytable=us tz=UTC misobasedir=manjaro
    misolabel=MANJARO_KDE_2421 quiet systemd.show_status=1 splash driver=free
    nouveau.modeset=1 i915.modeset=1 radeon.modeset=1
  Desktop: KDE Plasma v: 6.2.4 tk: Qt v: N/A info: frameworks v: 6.8.0
  Type: Laptop System: Acer product: Nitro AN515-43 v: V1.12
    serial: <superuser required>
  Mobo: PK model: Octavia_PKS v: V1.12 serial: <superuser required>
    part-nu: 0000000000000000 uuid: <superuser required> UEFI: Insyde v: 1.12
    date: 11/05/2020
  ID-1: BAT1 charge: 25.2 Wh (71.0%) condition: 35.5/57.5 Wh (61.7%)
    volts: 15.1 min: 15.4 model: LGC AP18E8M type: Li-ion serial: <filter>
    status: discharging
  Device-1: hidpp_battery_0 model: Logitech Wireless Mouse B330/M330/M331
    status: discharging
  System RAM: total: 24 GiB available: 21.44 GiB used: 2.61 GiB (12.2%)
    (unregistered) size: 16 GiB speed: spec: 3200 MT/s actual: 2400 MT/s volts:
    note: check curr: 1 min: 1 max: 1 width (bits): data: 64 total: 64
    manufacturer: Crucial part-no: CT16G4SFRA32A.C8FF serial: <filter>
    (unregistered) size: 8 GiB speed: spec: 2667 MT/s actual: 2400 MT/s volts:
    manufacturer: Kingston part-no: ACR26D4S9S8ME-8 serial: <filter>
  Info: model: AMD Ryzen 5 3550H with Radeon Vega Mobile Gfx bits: 64
    type: MT MCP arch: Zen/Zen+ note: check gen: 1 level: v3 note: check
    built: 2019 process: GF 12nm family: 0x17 (23) model-id: 0x18 (24)
    stepping: 1 microcode: 0x8108109
  Topology: cpus: 1x dies: 1 clusters: 1 cores: 4 threads: 8 tpc: 2
    smt: enabled cache: L1: 384 KiB desc: d-4x32 KiB; i-4x64 KiB L2: 2 MiB
    desc: 4x512 KiB L3: 4 MiB desc: 1x4 MiB
  Speed (MHz): avg: 1400 min/max: 1400/2100 boost: enabled scaling:
    driver: acpi-cpufreq governor: schedutil cores: 1: 1400 2: 1400 3: 1400
    4: 1400 5: 1400 6: 1400 7: 1400 8: 1400 bogomips: 33550
    bmi2 bpext clflush clflushopt clzero cmov cmp_legacy constant_tsc cpb
    cpuid cr8_legacy cx16 cx8 de decodeassists extapic extd_apicid f16c
    flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb irperf
    lahf_lm lbrv lm mca mce misalignsse mmx mmxext monitor movbe msr mtrr
    mwaitx nonstop_tsc nopl npt nrip_save nx osvw overflow_recov pae pat
    pausefilter pclmulqdq pdpe1gb perfctr_core perfctr_llc perfctr_nb
    pfthreshold pge pni popcnt pse pse36 rapl rdrand rdseed rdtscp rep_good
    sep sev sev_es sha_ni skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2
    sse4a ssse3 succor svm svm_lock syscall tce topoext tsc tsc_scale
    v_vmsave_vmload vgif vmcb_clean vme vmmcall wdt xgetbv1 xsave xsavec
    xsaveerptr xsaveopt
  Type: retbleed mitigation: untrained return thunk; SMT vulnerable
  Device-1: Advanced Micro Devices [AMD/ATI] Baffin [Radeon RX 460/560D / Pro
    450/455/460/555/555X/560/560X] vendor: Acer Incorporated ALI RX560X 4GB
    driver: amdgpu v: kernel arch: GCN-4 code: Arctic Islands process: GF 14nm
    built: 2016-20 pcie: gen: 1 speed: 2.5 GT/s lanes: 8 link-max: gen: 3
    speed: 8 GT/s bus-ID: 01:00.0 chip-ID: 1002:67ef class-ID: 0380
    temp: 49.0 C
  Device-2: Advanced Micro Devices [AMD/ATI] Picasso/Raven 2 [Radeon Vega
    Series / Radeon Mobile Series] vendor: Acer Incorporated ALI driver: amdgpu
    v: kernel arch: GCN-5 code: Vega process: GF 14nm built: 2017-20 pcie:
    gen: 3 speed: 8 GT/s lanes: 16 ports: active: eDP-1 empty: HDMI-A-1
    bus-ID: 05:00.0 chip-ID: 1002:15d8 class-ID: 0300 temp: 49.0 C
  Device-3: Quanta HD User Facing driver: uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-1:2 chip-ID: 0408:a061
    class-ID: 0e02
  Display: x11 server: X.Org v: 21.1.14 with: Xwayland v: 24.1.4
    compositor: kwin_x11 driver: X: loaded: amdgpu unloaded: modesetting
    alternate: fbdev,vesa dri: radeonsi gpu: amdgpu display-ID: :0 screens: 1
    s-diag: 582mm (22.93")
  Monitor-1: eDP-1 mapped: eDP model: LG Display 0x0563 built: 2018
    res: 1920x1080 hz: 60 dpi: 142 gamma: 1.2 chroma: red: x: 0.592 y: 0.369
    green: x: 0.349 y: 0.557 blue: x: 0.153 y: 0.110 white: x: 0.314 y: 0.329
    size: 344x194mm (13.54x7.64") diag: 395mm (15.5") ratio: 16:9
    modes: 1920x1080, 1680x1050, 1280x1024, 1440x900, 1280x800, 1280x720,
    1024x768, 800x600, 640x480
    device: 1 drv: radeonsi device: 2 drv: swrast gbm: drv: kms_swrast
    surfaceless: drv: radeonsi x11: drv: radeonsi inactive: wayland
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.2.8-arch1.1
    glx-v: 1.4 direct-render: yes renderer: AMD Radeon Vega 8 Graphics (radeonsi
    raven LLVM 18.1.8 DRM 3.59 6.12.4-1-MANJARO) device-ID: 1002:15d8
    memory: 1.95 GiB unified: no
  API: Vulkan v: 1.4.303 layers: N/A device: 0 type: discrete-gpu name: AMD
    Radeon RX Graphics (RADV POLARIS11) driver: N/A device-ID: 1002:67ef
    surfaces: xcb,xlib device: 1 type: integrated-gpu name: AMD Radeon Vega 8
    Graphics (RADV RAVEN) driver: N/A device-ID: 1002:15d8 surfaces: xcb,xlib
  Device-1: Advanced Micro Devices [AMD/ATI] Raven/Raven2/Fenghuang HDMI/DP
    Audio vendor: Acer Incorporated ALI driver: snd_hda_intel v: kernel pcie:
    gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 05:00.1 chip-ID: 1002:15de
    class-ID: 0403
  Device-2: Advanced Micro Devices [AMD] Family 17h/19h/1ah HD Audio
    vendor: Acer Incorporated ALI driver: snd_hda_intel v: kernel pcie: gen: 3
    speed: 8 GT/s lanes: 16 bus-ID: 05:00.6 chip-ID: 1022:15e3 class-ID: 0403
  API: ALSA v: k6.12.4-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.2.7 status: active with: 1: pipewire-pulse
    vendor: Acer Incorporated ALI driver: r8169 v: kernel pcie: gen: 1
    speed: 2.5 GT/s lanes: 1 port: 2000 bus-ID: 03:00.0 chip-ID: 10ec:8168
    class-ID: 0200
  Device-2: Qualcomm Atheros QCA6174 802.11ac Wireless Network Adapter
    vendor: Lite-On driver: ath10k_pci v: kernel pcie: gen: 1 speed: 2.5 GT/s
    lanes: 1 bus-ID: 04:00.0 chip-ID: 168c:003e class-ID: 0280 temp: 48.0 C
  IF: wlp4s0 state: up mac: <filter>
  Device-1: Lite-On driver: btusb v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s
    lanes: 1 mode: 1.1 bus-ID: 3-2:3 chip-ID: 04ca:3016 class-ID: e001
  Local Storage: total: 989.28 GiB used: 0 KiB (0.0%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Toshiba model: MQ04ABF100
    tech: HDD rpm: 5400 serial: <filter> fw-rev: 1J scheme: GPT
  ID-2: /dev/sdb maj-min: 8:16 vendor: HP model: v236w size: 57.77 GiB
    block-size: physical: 512 B logical: 512 B type: USB rev: 2.0 spd: 480 Mb/s
    lanes: 1 mode: 2.0 tech: N/A serial: <filter> fw-rev: PMAP scheme: MBR
  Message: No partition data found.
  ID-1: /dev/sda1 maj-min: 8:1 size: 100 MiB fs: vfat label: N/A
    uuid: DC51-2727
  ID-2: /dev/sda2 maj-min: 8:2 size: 16 MiB fs: <superuser required>
    label: N/A uuid: N/A
  ID-3: /dev/sda3 maj-min: 8:3 size: 709.35 GiB fs: ntfs label: N/A
    uuid: 42F45325F4531A8D
  ID-4: /dev/sda4 maj-min: 8:4 size: 509 MiB fs: ntfs label: N/A
    uuid: 5A8680A78680856B
  ID-5: /dev/sda5 maj-min: 8:5 size: 69.85 GiB fs: ext4 label: N/A
    uuid: e99f6c1d-c450-4c3b-8861-1c3bfd5a0904
  ID-6: /dev/sda6 maj-min: 8:6 size: 135.04 GiB fs: ext4 label: N/A
    uuid: a2baeefe-ce86-45bb-97ea-f1b8fd1325c2
  ID-7: /dev/sda7 maj-min: 8:7 size: 16.66 GiB fs: swap label: N/A
    uuid: 13df60b0-d5e7-466c-a3be-9158037e7c7d
  ID-8: /dev/sdb1 maj-min: 8:17 size: 4.03 GiB fs: iso9660
  ID-9: /dev/sdb2 maj-min: 8:18 size: 4 MiB fs: vfat label: MISO_EFI
    uuid: 97A3-D79B
  Device-1: 1-1:2 info: Quanta HD User Facing type: video driver: uvcvideo
    interfaces: 2 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0
    power: 500mA chip-ID: 0408:a061 class-ID: 0e02
  Device-2: 1-3:3 info: HP v236w type: mass storage driver: usb-storage
    power: 300mA chip-ID: 03f0:7d40 class-ID: 0806 serial: <filter>
  Device-1: 3-1:2 info: Logitech Nano Receiver type: mouse,HID
    driver: logitech-djreceiver,usbhid interfaces: 2 rev: 2.0
    chip-ID: 046d:c52f class-ID: 0300
  Device-2: 3-2:3 info: Lite-On type: bluetooth driver: btusb interfaces: 2
    rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 100mA
  Hub-4: 4-0:1 info: super-speed hub ports: 1 rev: 3.1
  System Temperatures: cpu: 49.2 C mobo: N/A
  Fan Speeds (rpm): N/A
  GPU: device: amdgpu temp: 49.0 C device: amdgpu temp: 49.0 C watts: 6.10
  Packages: pm: pacman pkgs: 1248 libs: 327 tools: pamac pm: flatpak pkgs: 0
    1: https://ftp.caliu.cat/pub/distribucions/manjaro/stable/$repo/$arch
    2: https://mirror.kamtv.ru/manjaro/stable/$repo/$arch
    3: https://mirror.raiolanetworks.com/manjaro/stable/$repo/$arch
    4: https://mirror.yandex.ru/mirrors/manjaro/stable/$repo/$arch
    5: https://mirror.archlinux.tw/Manjaro/stable/$repo/$arch
    6: http://ftp.rz.tu-bs.de/pub/mirror/manjaro.org/repos/stable/$repo/$arch
    7: https://mirror.dkm.cz/manjaro/stable/$repo/$arch
    8: https://ipng.mm.fcix.net/manjaro/stable/$repo/$arch
    9: https://mirror.aarnet.edu.au/pub/manjaro/stable/$repo/$arch
    10: https://mirrors.jlu.edu.cn/manjaro/stable/$repo/$arch
    11: https://mirrors.dotsrc.org/manjaro/stable/$repo/$arch
    12: http://kartolo.sby.datautama.net.id/manjaro/stable/$repo/$arch
    13: https://linorg.usp.br/manjaro/stable/$repo/$arch
    14: https://manjaro.mirror.liquidtelecom.com/stable/$repo/$arch
    15: https://mirrors.xtom.ee/manjaro/stable/$repo/$arch
    16: https://mirror.bardia.tech/manjaro/stable/$repo/$arch
    17: https://manjaro.ipacct.com/manjaro/stable/$repo/$arch
    18: http://ftp.snt.utwente.nl/pub/linux/manjaro/stable/$repo/$arch
    19: https://fastmirror.pp.ua/manjaro/stable/$repo/$arch
    20: https://mirrors.ustc.edu.cn/manjaro/stable/$repo/$arch
    21: https://volico.mm.fcix.net/manjaro/stable/$repo/$arch
    22: https://mirrors.gigenet.com/manjaro/stable/$repo/$arch
    23: https://mirror.seahost.de/manjaro/stable/$repo/$arch
    24: http://ftp.uni-kl.de/pub/linux/manjaro/stable/$repo/$arch
    25: https://mirrors.atlas.net.co/manjaro/stable/$repo/$arch
    26: https://southfront.mm.fcix.net/manjaro/stable/$repo/$arch
    27: https://ftp.gwdg.de/pub/linux/manjaro/stable/$repo/$arch
    28: https://mirror.2degrees.nz/manjaro/stable/$repo/$arch
    29: https://mirror.funami.tech/manjaro/stable/$repo/$arch
    30: https://mirror.ufro.cl/manjaro/stable/$repo/$arch
    31: https://ftpmirror1.infania.net/mirror/manjaro/stable/$repo/$arch
    32: https://ftp.psnc.pl/linux/manjaro/stable/$repo/$arch
    33: https://ftp.cc.uoc.gr/mirrors/linux/manjaro/stable/$repo/$arch
    34: http://ftp.tu-chemnitz.de/pub/linux/manjaro/stable/$repo/$arch
    35: https://irltoolkit.mm.fcix.net/manjaro/stable/$repo/$arch
    36: http://manjaro.mirror.ac.za/stable/$repo/$arch
    37: https://mirror.nyist.edu.cn/manjaro/stable/$repo/$arch
    38: https://mirror.csclub.uwaterloo.ca/manjaro/stable/$repo/$arch
    39: https://ct.mirror.garr.it/mirrors/manjaro/stable/$repo/$arch
    40: https://mirrors2.manjaro.org/stable/$repo/$arch
    41: https://mirror.kku.ac.th/manjaro/stable/$repo/$arch
    42: http://mirror.datacenter.by/pub/mirrors/manjaro/stable/$repo/$arch
    43: https://mirror.netcologne.de/manjaro/stable/$repo/$arch
    44: https://mirror.easyname.at/manjaro/stable/$repo/$arch
    45: https://manjaro.ynh.ovh/stable/$repo/$arch
    46: https://manjaro.repo.cure.edu.uy/stable/$repo/$arch
    47: http://ftp.free.org/mirrors/repo.manjaro.org/repos/stable/$repo/$arch
    48: https://mirror.ufam.edu.br/manjaro/stable/$repo/$arch
    49: https://mirror.nju.edu.cn/manjaro/stable/$repo/$arch
    50: http://mirror.fcix.net/manjaro/stable/$repo/$arch
    51: http://mirror.xeonbd.com/manjaro/stable/$repo/$arch
    52: https://mirrors.ocf.berkeley.edu/manjaro/stable/$repo/$arch
    53: https://nnenix.mm.fcix.net/manjaro/stable/$repo/$arch
    54: http://manjaro.mirrors.uk2.net/stable/$repo/$arch
    55: https://mirrors.netix.net/manjaro/stable/$repo/$arch
    56: https://mirror.23m.com/manjaro/stable/$repo/$arch
    57: https://ohioix.mm.fcix.net/manjaro/stable/$repo/$arch
    58: https://edgeuno-bog2.mm.fcix.net/manjaro/stable/$repo/$arch
    59: https://cofractal-ewr.mm.fcix.net/manjaro/stable/$repo/$arch
    60: https://mirrors.xtom.de/manjaro/stable/$repo/$arch
    61: https://mirrors.tuna.tsinghua.edu.cn/manjaro/stable/$repo/$arch
    62: https://mirror.alwyzon.net/manjaro/stable/$repo/$arch
    63: https://mirrors.manjaro.org/repo/stable/$repo/$arch
    64: https://manjarolinux-mirror.cloud.mu/stable/$repo/$arch
    65: https://forksystems.mm.fcix.net/manjaro/stable/$repo/$arch
    66: http://mirror.terrahost.no/linux/manjaro/stable/$repo/$arch
    67: http://free.nchc.org.tw/manjaro/stable/$repo/$arch
    68: https://mirror.ibakerserver.pt/manjaro/stable/$repo/$arch
    69: https://codingflyboy.mm.fcix.net/manjaro/stable/$repo/$arch
    70: https://ftp.nluug.nl/pub/os/Linux/distr/manjaro/stable/$repo/$arch
    71: https://mirror.init7.net/manjaro/stable/$repo/$arch
    72: https://fosszone.csd.auth.gr/manjaro/stable/$repo/$arch
    73: https://bd.mirror.vanehost.com/Manjaro/stable/$repo/$arch
    74: https://mirror.it4i.cz/manjaro/stable/$repo/$arch
    75: https://mirrors.up.pt/pub/manjaro/stable/$repo/$arch
    76: https://gsl-syd.mm.fcix.net/manjaro/stable/$repo/$arch
    77: https://mirror.xenyth.net/manjaro/stable/$repo/$arch
    78: https://mirrors.xtom.jp/manjaro/stable/$repo/$arch
    79: http://ftp.riken.jp/Linux/manjaro/stable/$repo/$arch
    80: http://manjaro.grena.ge/stable/$repo/$arch
    81: https://mirror.freedif.org/Manjaro/stable/$repo/$arch
    82: https://muug.ca/mirror/manjaro/stable/$repo/$arch
    83: http://mirror.is.co.za/mirrors/manjaro.org/stable/$repo/$arch
    84: https://mirrors.cicku.me/manjaro/stable/$repo/$arch
    85: https://ask4.mm.fcix.net/manjaro/stable/$repo/$arch
    86: https://ridgewireless.mm.fcix.net/manjaro/stable/$repo/$arch
    87: https://mirrors.sjtug.sjtu.edu.cn/manjaro/stable/$repo/$arch
    88: https://ftp.linux.org.tr/manjaro/stable/$repo/$arch
    89: https://mirror1.sox.rs/manjaro/stable/$repo/$arch
    90: https://mirror.futureweb.be/manjaro/stable/$repo/$arch
    91: https://mirror.phoepsilonix.love/manjaro/stable/$repo/$arch
    92: https://mirrors.sonic.net/manjaro/stable/$repo/$arch
    93: http://ftp.tsukuba.wide.ad.jp/Linux/manjaro/stable/$repo/$arch
    94: https://manjaro.mirror.garr.it/manjaro/stable/$repo/$arch
    95: https://coresite.mm.fcix.net/manjaro/stable/$repo/$arch
    96: https://nocix.mm.fcix.net/manjaro/stable/$repo/$arch
    97: https://manjaro.kurdy.org/stable/$repo/$arch
    98: https://mirror.dc.uz/manjaro/stable/$repo/$arch
    99: https://repo.iut.ac.ir/repo/manjaro/stable/$repo/$arch
    100: https://mirrors.pku.edu.cn/manjaro/stable/$repo/$arch
    101: https://ftp.halifax.rwth-aachen.de/manjaro/stable/$repo/$arch
    102: https://opencolo.mm.fcix.net/manjaro/stable/$repo/$arch
    103: https://ziply.mm.fcix.net/manjaro/stable/$repo/$arch
    104: https://mirror.zetup.net/manjaro/stable/$repo/$arch
    105: http://ossmirror.mycloud.services/os/linux/manjaro/stable/$repo/$arch
    106: https://mirrors.ucr.ac.cr/manjaro/stable/$repo/$arch
    107: https://ftp.lysator.liu.se/pub/manjaro/stable/$repo/$arch
    108: https://mirrors.piconets.webwerks.in/manjaro-mirror/stable/$repo/$arch
    109: https://manjaro.mirror.wearetriple.com/stable/$repo/$arch
    110: http://ftp.dei.uc.pt/pub/linux/manjaro/stable/$repo/$arch
    111: https://quantum-mirror.hu/mirrors/pub/manjaro/stable/$repo/$arch
    112: https://mirror.leitecastro.com/manjaro/stable/$repo/$arch
    113: https://mirror.math.princeton.edu/pub/manjaro/stable/$repo/$arch
    114: https://mirrors.nic.cz/manjaro/stable/$repo/$arch
    115: https://mirror.alpix.eu/manjaro/stable/$repo/$arch
    116: https://mirror.bouwhuis.network/manjaro/stable/$repo/$arch
    117: https://www.mirrorservice.org/sites/repo.manjaro.org/repos/stable/$repo/$arch
    118: https://mirrors.ft.uam.es/manjaro/stable/$repo/$arch
    119: https://manjaro.mirrors.lavatech.top/stable/$repo/$arch
    120: https://mnvoip.mm.fcix.net/manjaro/stable/$repo/$arch
    121: http://ftp.belnet.be/mirrors/manjaro/repos/stable/$repo/$arch
    122: https://mirror.koddos.net/manjaro/stable/$repo/$arch
    123: https://mirrors.aliyun.com/manjaro/stable/$repo/$arch
    124: https://repos.silknet.com/manjaro/stable/$repo/$arch
    125: https://manjaro.c3sl.ufpr.br/stable/$repo/$arch
    126: https://mirror.albony.xyz/manjaro/stable/$repo/$arch
    127: https://mirror.telepoint.bg/manjaro/stable/$repo/$arch
    128: https://mirror.truenetwork.ru/manjaro/stable/$repo/$arch
    129: https://repo.ialab.dsu.edu/manjaro/stable/$repo/$arch
    130: https://mirror.vinehost.net/manjaro/stable/$repo/$arch
    131: https://ba.mirror.garr.it/mirrors/manjaro/stable/$repo/$arch
    132: https://uvermont.mm.fcix.net/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 306
  1: cpu: 300% command: ps pid: 3047 mem: 3.54 MiB (0.0%)
  2: cpu: 54.0% command: firefox pid: 2189 mem: 468.5 MiB (2.1%)
  3: cpu: 19.4% command: firefox pid: 2527 mem: 263.2 MiB (1.1%)
  4: cpu: 11.2% command: kwin_x11 pid: 1347 mem: 244.3 MiB (1.1%)
  5: cpu: 11.2% command: plasmashell pid: 1394 mem: 388.6 MiB (1.7%)
  Memory top: 5 of 306
  1: mem: 468.5 MiB (2.1%) command: firefox pid: 2189 cpu: 54.0%
  2: mem: 388.6 MiB (1.7%) command: plasmashell pid: 1394 cpu: 11.2%
  3: mem: 263.2 MiB (1.1%) command: firefox pid: 2527 cpu: 19.4%
  4: mem: 244.3 MiB (1.1%) command: kwin_x11 pid: 1347 cpu: 11.2%
  5: mem: 157.2 MiB (0.7%) command: Xorg pid: 1181 cpu: 10.1%
  Processes: 306 Power: uptime: 2m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 8.53 GiB services: org_kde_powerdevil,
    power-profiles-daemon, upowerd Init: systemd v: 256 default: graphical
    tool: systemctl
  Compilers: N/A Shell: Zsh v: 5.9 running-in: konsole inxi: 3.3.36
At least that eliminates the possibility of BTRFS, but I expect this means the disk is NTFS, correct?
Also, you might want to reconsider this. I can’t say for certain, but I think it’d be wide to do so.
Anyhoo, boot into a live environment and please provide the output of:
manjaro-chroot
…from there, please.
The disk is ntfs
    ~  manjaro-chroot         ✔
==> ERROR: Can't create chroot on non-directory
    ~  lsblk -f         255 ✘
NAME        FSTYPE   FSVER            LABEL            UUID                                 FSAVAIL FSUSE% MOUNTPOINTS
loop0       squashfs 4.0        0   100% /run/miso/sfs/livefs
loop1       squashfs 4.0        0   100% /run/miso/sfs/mhwdfs
loop2       squashfs 4.0        0   100% /run/miso/sfs/desktopfs
loop3       squashfs 4.0        0   100% /run/miso/sfs/rootfs
sda
├─sda1      vfat     FAT32                             DC51-2727
├─sda2
├─sda3      ntfs                                       42F45325F4531A8D
├─sda4      ntfs                                       5A8680A78680856B
├─sda5      ext4     1.0                               e99f6c1d-c450-4c3b-8861-1c3bfd5a0904
├─sda6      ext4     1.0                               a2baeefe-ce86-45bb-97ea-f1b8fd1325c2
└─sda7      swap     1                                 13df60b0-d5e7-466c-a3be-9158037e7c7d
sdb         iso9660  Joliet Extension MANJARO_KDE_2421 2024-12-16-11-21-39-00                     0   100% /run/miso/bootmnt
├─sdb1      iso9660  Joliet Extension MANJARO_KDE_2421 2024-12-16-11-21-39-00
└─sdb2      vfat     FAT12            MISO_EFI         97A3-D79B
nvme0n1
├─nvme0n1p1
├─nvme0n1p2
├─nvme0n1p3
├─nvme0n1p4
├─nvme0n1p5
└─nvme0n1p6
    ~  manjaro-chroot -a         ✔
grub-probe: error: cannot find a GRUB drive for /dev/sdb1.  Check your device.map.
==> Mounting (Ubuntu) [/dev/sda5]
 --> mount: [/mnt]
 --> mount: [/mnt/boot/efi]
 --> mount: [/mnt/home]
root@manjaro:/#
Try:
manjaro-chroot -a
And if successful, please provide the output of:
uname -r
 --> mount: [/mnt]
root@manjaro:/#
root@manjaro:/# uname -r
6.12.4-1-MANJARO
root@manjaro:/#
No file system has been detected on /dev/nvme0n1!
I guess you have not properly shutdown Windoof. Then partitions might be blocked as Win is only hibernating. You need to switch-off Fast startup in Win. Also make sure no Fast Boot in enabled in your firmware.
