Accidentally deleted xfce.desktop
Hello, new person on the forum here. I hope you can help me.
I accidentally deleted xfce.desktop file in the /usr/share/xsessions folder. Now, I cannot log off my computer.
Can you provide me the contents of the file, so I can restore it like before?
Thank you for your time reading this!
You can re-install xfce4-session to get the default file back.
sudo pacman -S xfce4-session
[Desktop Entry]
Version=1.0
Name=Xfce Session
Name[am]=Xfce ክፍለ ጊዜ
Name[ar]=جلسة إكسفس
Name[ast]=Xfce Session
Name[be]=Сеанс Xfce
Name[be@tarask]=Сэанс Xfce
Name[bg]=Xfce сесия
Name[ca]=Sessió Xfce
Name[cs]=Relace prostředí Xfce
Name[da]=Xfce-session
Name[de]=Xfce-Sitzung
Name[el]=Συνεδρία Xfce
Name[en_AU]=Xfce Session
Name[en_CA]=Xfce Session
Name[en_GB]=Xfce Session
Name[eo]=Xfce-seanco
Name[es]=Sesión de Xfce
Name[et]=Xfce sessioon
Name[eu]=Xfce saioa
Name[fi]=Xfce-istunto
Name[fr]=Session Xfce
Name[gl]=Sesión de Xfce
Name[he]=סשן Xfce
Name[hi]=एक्सएफसीई सत्र
Name[hr]=Xfce sesija
Name[hu]=Xfce munkamenet
Name[hy_AM]=Xfce նիստ
Name[hye]=Xfce նիստ
Name[id]=Sesi Xfce
Name[ie]=Session Xfce
Name[is]=Xfce seta
Name[it]=Sessione di Xfce
Name[ja]=Xfce セッション
Name[kk]=Xfce сессиясы
Name[ko]=Xfce 세션
Name[lt]=Xfce seansas
Name[ms]=Sesi Xfce
Name[nb]=Xfce-økt
Name[nl]=Xfce-sessie
Name[nn]=Xfce-økt
Name[oc]=Sesilha Xfce
Name[pl]=Sesja Xfce
Name[pt]=Sessão Xfce
Name[pt_BR]=Sessão do Xfce
Name[ro]=Sesiune Xfce
Name[ru]=Сеанс Xfce
Name[sk]=Sedenie Xfce
Name[sl]=Xfce seja
Name[sq]=Sesion Xfce
Name[sr]=Седница Иксфце-а
Name[sv]=Xfce-session
Name[te]=Xfce సెషన్
Name[th]=วาระ Xfce
Name[tr]=Xfce Oturumu
Name[ug]=Xfce ئەڭگىمەسى
Name[uk]=Сеанс Xfce
Name[vi]=Phiên chạy Xfce
Name[zh_CN]=Xfce 会话
Name[zh_HK]=Xfce 工作階段
Name[zh_TW]=Xfce 工作階段
Comment=Use this session to run Xfce as your desktop environment
Comment[ar]=إستعمل هذه الجلسة لتشغيل إكسفس كسطح مكتب
Comment[ast]=Usa esta sesión pa executar Xfce como'l to entornu d'escritoriu
Comment[be]=Выкарыстайце гэты сеанс для запуску працоўнага асяроддзя Xfce
Comment[be@tarask]=Выкарыстайце гэты сэанс для запуску асяродьдзя Xfce
Comment[bg]=Използвайте тази сесия за да стартирате Xfce като Ваша графична среда
Comment[ca]=Utilitzeu aquesta sessió per a l'execució de Xfce com al vostre entorn d'escriptori
Comment[cs]=Použít tuto relaci ke spuštění Xfce jako vašeho pracovního prostředí
Comment[da]=Brug denne session til at køre Xfce som dit skrivebordsmiljø
Comment[de]=Diese Sitzung auswählen, um Xfce als Ihre Arbeitsumgebung zu starten
Comment[el]=Χρήση αυτής της συνεδρίας για εκτέλεση του Xfce ως περιβάλλον εργασίας
Comment[en_AU]=Use this session to run Xfce as your desktop environment
Comment[en_CA]=Use this session to run Xfce as your desktop environment
Comment[en_GB]=Use this session to run Xfce as your desktop environment
Comment[es]=Use esta sesión para ejecutar Xfce como su entorno de escritorio
Comment[et]=Kasuta seda sessiooni Xfce käivitamiseks oma töölauakeskkonnana
Comment[eu]=Erabili saio hau Xfce mahaigain ingurune gisa exekutatzeko.
Comment[fi]=Valitse tämä istunto käyttääksesi Xfce-työpöytäympäristöä
Comment[fr]=Utilisez cette session pour exécuter Xfce comme environnement de bureau
Comment[gl]=Empregar esta sesión para executar Xfce como contorno de escritorio
Comment[he]=השתמש בסשן זה כדי להפעיל את Xfce בתור סביבת שולחן עבודה שלך
Comment[hi]=इस सत्र द्वारा एक्सएफसीई डेस्कटॉप वातावरण उपयोग करें
Comment[hr]=Koristite ovu sesiju da bi pokrenuli Xfce kao vaše radno okruženje
Comment[hu]=Használja ezt a munkamenetet az Xfce futtatásához asztali környezetként
Comment[hy_AM]=Գործածէք այս նիստը, գործարկելու համար Xfce աշխատասեղանի միջավայրը
Comment[hye]=Գործածէք այս նիստը, գործարկելու համար Xfce աշխատասեղանի միջավայրը
Comment[id]=Gunakan sesi ini untuk menjalankan Xfce sebagai lingkungan desktop anda
Comment[ie]=Usa ti-ci session por lansar Xfce quam vor ambientie
Comment[is]=Notaðu þessa setu til að keyra Xfce sem skjáborðsumhverfi
Comment[it]=Avvia Xfce come ambiente grafico per questa sessione
Comment[ja]=Xfce をデスクトップ環境として起動するためにこのセッションを使用します
Comment[kk]=Бұл сессияны негізгі жұмыс үстел ортасы ретінде Xfce-ні қолдану үшін қолданыңыз
Comment[ko]=데스크톱 환경으로서 Xfce를 실행하려면 이 세션을 사용합니다
Comment[lt]=Naudoti šį seansą, kad Xfce būtų naudojama kaip jūsų darbalaukio aplinka
Comment[ms]=Gunakan sesi ini untuk jalankan Xfce sebagai persekitaran desktop anda
Comment[nb]=Kjør Xfce som skrivebordsmiljø denne økta.
Comment[nl]=Gebruik deze sessie om Xfce te draaien als uw werkomgeving
Comment[nn]=Bruk denne økta for å køyra Xfce som skrivebordsmiljø
Comment[oc]=Utilizatz aquesta sesilha per executar Xfce coma environament de burèu
Comment[pl]=Uruchamia sesję środowiska graficznego Xfce
Comment[pt]=Utilizar esta sessão para executar o Xfce como ambiente de trabalho
Comment[pt_BR]=Usar esta sessão para executar o Xfce como seu ambiente de trabalho
Comment[ro]=Utilizați această sesiune pentru a inițializa mediul desktop Xfce
Comment[ru]=Использовать этот сеанс, чтобы сделать Xfce вашим окружением
Comment[sk]=Použite toto sedenie pre spustenie Xfce ako vášho pracovného prostredia
Comment[sl]=Zaženi sejo Xfce namiznega okolja
Comment[sq]=Përdoreni këtë sesion që të xhironi Xfce-në si mjedisin tuaj desktop
Comment[sr]=Користите ову седницу за покретање ИксФЦЕ-а као радног окружења
Comment[sv]=Använd denna session för att köra Xfce som din skrivbordsmiljö
Comment[th]=ใช้วาระนี้เพื่อเรียกใช้ Xfce เป็นเดสก์ท็อปของคุณ
Comment[tr]=Xfce'yi masaüstü ortamınız olarak kullanmak için bu oturumu kullanın
Comment[ug]=مەزكۇر ئەڭگىمەدە ئۈستەلئۈستى ئۈچۈن Xfce ئىشلىتىلىدۇ
Comment[uk]=Використайте цей сеанс для запуску Xfce як Вашого типого середовища.
Comment[vi]=Sử dụng phiên chạy này để dùng Xfce như môi trường làm việc của bạn
Comment[zh_CN]=使用此会话将 Xfce 作为您的桌面环境运行
Comment[zh_HK]=使用這個工作階段來執行 Xfce 作為桌面環境
Comment[zh_TW]=使用這個工作階段來執行 Xfce 作為您的桌面環境
Exec=startxfce4
Icon=
Type=Application
DesktopNames=XFCE
Thanks a lot
