Yesterday I saw some news that I should update systemd, and I’ve been unable to update overall (see here), so I just went ahead and updated systemd and not a full system upgrade. Then I reboot my computer, and it tells me this:
/usr/lib/systemd/systemd-udevd: /usr/lib/libblkid.so.1: version BLKID_2_37' not found (required by /usr/lib/systemd/systemd-udevd) udevadm: /usr/lib/libblkid.so.1: version BLKID_2_37’ not found (required by udevadm)
udevadm: /usr/lib/libblkid.so.1: version BLKID_2_37' not found (required by udevadm) udevadm: /usr/lib/libblkid.so.1: version BLKID_2_37’ not found (required by udevadm)
[FAILED] Failed to start Rule-based Manager for Device Events and Files.
[ TIME ] Timed out waiting for device /dev/disk/by-uuid/01f91f93-5098-4a82-905a-fd21f3a1b3d4
[DEPEND] Dependency failed for /dev/disk/by-uuid/01f91f93-5098-4a82-905a-fd21f3a1b3d4
[DEPEND] Dependency failed for Swap
[ TIME ] Timed out waiting for device /dev/disk/by-uuid-D311-A3E6
[DEPEND] Dependency failed for /boot/efi
[DEPEND] Dependency failed for Local File Systems
[DEPEND] Dependency failed for File System Check on /dev/disk/by-uuid/D311-A3E6
What am I supposed to do?
Additionally, I tried to connect to the internet with the iwctl tool, but when I enter
iw dev
It returns nothing. So I’m not sure how to set up wifi using the tool.
edit: added the [ TIME ] and [DEPEND] stuff
