Hello !
Im opening this topic, because im experiencing a lot of problems after the Wyndsdey update.
I was using KDE5 with X11, it was fine.
I was stupid enough to update the system while i was logged in.
Now in experiencing very slow I/O performance in the X11 session.
Now the wayland session is available, i tried it, the UI feels more responsive, but the i/o slowness still persists, maybe not that bad like in the X11 session.
I read that KDE 6 introduced a bug where the bluetooth service constantly polls the devices on the main thread, that is causing the slowdown.
However, im on the latest stable KDE version, and the problem still persists.
I set back the theme to Breeze, and disabled the login greeting screen.
Maybe someone can help me troubleshoot the root cause:
- VERY slow I/O performance, cant even play an mp3 song without lagging and buffering, laoding a CS 1.6 map takes minutes, firefox is dead slow, it takes minutes to load my emails, (chrome is fine for some reason).
- CS 1.6 freezes for seconds during play,
- CS 1.6 black horizontal lines splashing randomly (wayland related).
- Booting and shuttind down takes a minute or two instead of 15s like before the update (the quiet and the splash kernel parameteres somewhow disappeared, now it shows log messages during booting and shutting down)
The boot and shutdown process stops at mounting/unmounting my hard drives for around a minute. - Websites in Chromium flashes randomly (wayland related?)
- High CPU usage on idle
Actions that i already did to mitigate this problem after the update:
- resetting KDE configurations
- added fb_dev and modeset kernel parameters
My system info:
inxi -zv8
Kernel: 6.9.0-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
parameters: BOOT_IMAGE=/boot/vmlinuz-6.9-x86_64
root=UUID=8719b0a7-0023-4e98-89b4-6280ef436536 rw quiet apparmor=1
security=apparmor udev.log_priority=3 nvidia_drm.modeset=1
nvidia_drm.fbdev=1
Desktop: KDE Plasma v: 6.0.4 tk: Qt v: N/A info: frameworks v: 6.1.0
Type: Desktop System: Gigabyte product: N/A v: N/A
serial: <superuser required>
Mobo: Gigabyte model: B150M-D3H-CF serial: <superuser required>
uuid: <superuser required> UEFI-[Legacy]: American Megatrends v: F6
date: 03/14/2016
System RAM: total: 16 GiB available: 15.55 GiB used: 4.67 GiB (30.1%)
Array-1: capacity: 64 GiB slots: 4 modules: 2 EC: None
Device-1: ChannelA-DIMM0 type: no module installed
Device-2: ChannelA-DIMM1 type: DDR4 detail: synchronous size: 8 GiB
speed: 2133 MT/s volts: curr: 1 width (bits): data: 64 total: 64
manufacturer: Kingston part-no: KHX2133C14D4/8G serial: <filter>
Device-3: ChannelB-DIMM0 type: no module installed
Device-4: ChannelB-DIMM1 type: DDR4 detail: synchronous size: 8 GiB
Info: model: Intel Core i5-6500 bits: 64 type: MCP arch: Skylake-S
gen: core 6 level: v3 note: check built: 2015 process: Intel 14nm family: 6
model-id: 0x5E (94) stepping: 3 microcode: 0xF0
Topology: cpus: 1x cores: 4 smt: <unsupported> cache: L1: 256 KiB
desc: d-4x32 KiB; i-4x32 KiB L2: 1024 KiB desc: 4x256 KiB L3: 6 MiB
desc: 1x6 MiB
Speed (MHz): avg: 800 min/max: 800/3600 scaling: driver: intel_pstate
governor: powersave cores: 1: 800 2: 800 3: 800 4: 800 bogomips: 25610
dtherm dts ept ept_ad erms est f16c flexpriority flush_l1d fma fpu
smap smep smx ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2
Type: gather_data_sampling status: Vulnerable: No microcode
disabled
Type: spectre_v2 mitigation: IBRS; IBPB: conditional; STIBP: disabled;
Device-1: NVIDIA GP106 [GeForce GTX 1060 6GB] vendor: Gigabyte
driver: nvidia v: 550.78 alternate: nouveau,nvidia_drm non-free: 545.xx+
status: current (as of 2024-04; EOL~2026-12-xx) arch: Pascal code: GP10x
process: TSMC 16nm built: 2016-2021 pcie: gen: 3 speed: 8 GT/s lanes: 16
ports: active: none off: HDMI-A-1 empty: DP-1,DVI-D-1,DVI-D-2
bus-ID: 01:00.0 chip-ID: 10de:1c03 class-ID: 0300
Display: wayland server: X.org v: 1.21.1.13 with: Xwayland v: 23.2.6
compositor: kwin_wayland driver: X: loaded: nvidia gpu: nvidia display-ID: 0
Monitor-1: HDMI-A-1 res: 1920x1080 size: N/A modes: N/A
API: EGL v: 1.5 hw: drv: nvidia platforms: device: 0 drv: nvidia device: 2
drv: swrast gbm: drv: nvidia surfaceless: drv: nvidia wayland: drv: nvidia
x11: drv: zink inactive: device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 550.78
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce GTX 1060
6GB/PCIe/SSE2 memory: 5.86 GiB display-ID: :1.0
API: Vulkan v: 1.3.279 layers: 8 device: 0 type: discrete-gpu name: NVIDIA
GeForce GTX 1060 6GB driver: nvidia v: 550.78 device-ID: 10de:1c03
surfaces: xcb,xlib,wayland
Device-1: Intel 100 Series/C230 Series Family HD Audio vendor: Gigabyte
driver: snd_hda_intel v: kernel alternate: snd_soc_avs bus-ID: 00:1f.3
chip-ID: 8086:a170 class-ID: 0403
Device-2: NVIDIA GP106 High Definition Audio vendor: Gigabyte
bus-ID: 01:00.1 chip-ID: 10de:10f1 class-ID: 0403
API: ALSA v: k6.9.0-1-MANJARO status: kernel-api with: aoss
Server-1: PipeWire v: 1.0.5 status: active with: 1: pipewire-pulse
status: active 2: pipewire-media-session status: active 3: pipewire-alsa
type: plugin 4: pw-jack type: plugin tools: pactl,pw-cat,pw-cli
Device-1: Intel Ethernet I219-V vendor: Gigabyte driver: e1000e v: kernel
port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15b8 class-ID: 0200
IF: enp0s31f6 state: up speed: 1000 Mbps duplex: full mac: <filter>
IP v4: <filter> type: dynamic scope: global broadcast: <filter>
Local Storage: total: 1.94 TiB used: 951.94 GiB (48.0%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Transcend model: TS128GMTE110S
size: 119.24 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: S0322A3 temp: 42.9 C
scheme: MBR
ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: HD103UJ
size: 931.51 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
tech: N/A serial: <filter> fw-rev: 1113 scheme: MBR
ID-3: /dev/sdb maj-min: 8:16 vendor: Western Digital
model: WD10EZEX-75WN4A1 size: 931.51 GiB block-size: physical: 4096 B
logical: 512 B speed: 1.5 Gb/s tech: N/A serial: <filter> fw-rev: 7113
scheme: MBR
ID-1: / raw-size: 119.24 GiB size: 116.81 GiB (97.96%)
used: 26.23 GiB (22.5%) fs: ext4 dev: /dev/nvme0n1p1 maj-min: 259:1
label: Rendszer uuid: 8719b0a7-0023-4e98-89b4-6280ef436536
ID-2: /home/sapka raw-size: 125 GiB size: 121.98 GiB (97.58%)
used: 65.02 GiB (53.3%) fs: ext4 dev: /dev/sdb1 maj-min: 8:17 label: home
uuid: 64e605c3-43bc-43ad-86d4-eca23b6e0db9
ID-3: /run/media/sapka/Adat raw-size: 806.51 GiB size: 792.78 GiB (98.30%)
used: 564.01 GiB (71.1%) fs: ext4 dev: /dev/sdb2 maj-min: 8:18 label: Adat
uuid: 20bd73f5-b6be-4510-94dc-7cc491ff31ca
ID-4: /run/media/sapka/Nagy raw-size: 833.85 GiB
size: 833.85 GiB (100.00%) used: 296.69 GiB (35.6%) fs: ntfs dev: /dev/sda4
maj-min: 8:4 label: Nagy uuid: AE6E3C176E3BD6B5
ID-1: /dev/sda1 maj-min: 8:1 size: 549 MiB fs: ntfs label: System Reserved
uuid: 14AA2FFDAA2FD9CE
ID-2: /dev/sda2 maj-min: 8:2 size: 96.62 GiB fs: ntfs label: N/A
uuid: 20E634D0E634A844
ID-3: /dev/sda3 maj-min: 8:3 size: 515 MiB fs: ntfs label: N/A
uuid: EE6CE28A6CE24D41
Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
Device-1: 1-3:2 info: A4Tech USB Device type: keyboard,mouse,HID
driver: hid-generic,usbhid interfaces: 3 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s)
lanes: 1 mode: 1.1 power: 100mA chip-ID: 09da:7e81 class-ID: 0300
Device-2: 1-4:3 info: China Resource Semico Keyboard type: keyboard,HID
speed: 1.5 Mb/s (183 KiB/s) lanes: 1 mode: 1.0 power: 98mA
chip-ID: 1a2c:0021 class-ID: 0300
Device-3: 1-11:4 info: Cooler Master MasterFan Pro RGB type: keyboard,HID
lanes: 1 mode: 1.1 power: 100mA chip-ID: 2516:004f class-ID: 0300
Hub-2: 2-0:1 info: super-speed hub ports: 6 rev: 3.0
System Temperatures: cpu: 27.0 C pch: 51.5 C mobo: N/A
Fan Speeds (rpm): N/A
Packages: 1699 pm: pacman pkgs: 1684 libs: 448 tools: pacaur,pamac
pm: flatpak pkgs: 0 pm: snap pkgs: 15
1: https://mirrors.manjaro.org/repo/stable/$repo/$arch
Processes:
CPU top: 5 of 268
1: cpu: 17.3% command: konsole pid: 30247 mem: 116.2 MiB (0.7%)
2: cpu: 9.2% command: chromium pid: 2507 mem: 377.6 MiB (2.3%)
3: cpu: 8.9% command: kwin_wayland pid: 1157 mem: 262.4 MiB (1.6%)
4: cpu: 8.4% command: zsh pid: 30264 mem: 10.3 MiB (0.0%)
5: cpu: 6.5% command: chromium pid: 2089 mem: 236.8 MiB (1.4%)
Memory top: 5 of 268
1: mem: 677.1 MiB (4.2%) command: firefox pid: 1923 cpu: 5.5%
2: mem: 508.3 MiB (3.1%) command: plasmashell pid: 1313 cpu: 1.3%
3: mem: 482.0 MiB (3.0%) command: qbittorrent pid: 1438 cpu: 4.0%
4: mem: 408.7 MiB (2.5%) command: firefox pid: 2176 cpu: 0.8%
5: mem: 384.1 MiB (2.4%) command: chromium pid: 1993 cpu: 6.4%
Processes: 268 Power: uptime: 1h 10m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 6.15 GiB services: org_kde_powerdevil,upowerd
Init: systemd v: 255 default: graphical tool: systemctl
Compilers: clang: 17.0.6 gcc: 13.2.1 Shell: Zsh v: 5.9 default: Bash
v: 5.2.26 running-in: konsole inxi: 3.3.34
atop often reports sdb is busy with red flashing text
systemd-analyze --user blame
50.107s plasma-ksplash-ready.service
43.329s xdg-desktop-portal.service
40.468s plasma-ksplash.service
38.872s plasma-kcminit.service
10.082s appimagelauncherd.service
3.317s plasma-plasmashell.service
2.351s plasma-powerdevil.service
1.667s plasma-kded6.service
906ms xdg-user-dirs-update.service
893ms plasma-xdg-desktop-portal-kde.service
764ms plasma-kactivitymanagerd.service
511ms kde-baloo.service
496ms plasma-kwin_wayland.service
262ms plasma-polkit-agent.service
153ms plasma-ksmserver.service
128ms plasma-baloorunner.service
67ms app-geoclue\x2ddemo\x2dagent@autostart.service
64ms app-kaccess@autostart.service
52ms app-org.kde.discover.notifier@autostart.service
52ms gvfs-daemon.service
51ms app-msm_kde_notifier@autostart.service
45ms app-org.kde.kdeconnect.daemon@autostart.service
45ms app-org.qbittorrent.qBittorrent@autostart.service
42ms app-pamac\x2dtray\x2dplasma@autostart.service
42ms app-at\x2dspi\x2ddbus\x2dbus@autostart.service
41ms plasma-restoresession.service
40ms app-xapp\x2dsn\x2dwatcher@autostart.service
37ms app-pamac\x2dtray@autostart.service
35ms app-pamac\x2dtray\x2dbudgie@autostart.service
32ms app-snap\x2duserd\x2dautostart@autostart.service
30ms plasma-kglobalaccel.service
30ms app-print\x2dapplet@autostart.service
28ms at-spi-dbus-bus.service
23ms dbus.socket
20ms xdg-document-portal.service
13ms dconf.service
11ms plasma-kcminit-phase1.service
9ms xdg-permission-store.service
3ms dbus-broker.service
