i am terribly sorry but i have to open another topic. after using the OS for about a week i can now no longer open the “about this system” section in the settings, it just crashes the window. this behavior is persistent through a restart.
idk how to print this to a file so you can see the whole thing, sorry. i hope this doesn’t mean i have to reinstall the whole OS…
this is my system according to an earlier post of mine (might no longer be 100% accurate, idk since i can’t access the “about”):
KDE Plasma Version: 6.3.6
KDE Frameworks Version: 6.17.0
Qt Version: 6.9.1
Kernel Version: 6.12.44-3-MANJARO (64-bit)
Graphics Platform: X11
Does the problem also occur on a Plasma Wayland session?
You can change your Plasma session from X11 to Wayland by selecting the session type at the login screen (Wayland is now KDE’s default for Plasma).
If you have set up autologin to skip the password screen, you can change to a Wayland session by opening System Settings → Colors & Themes → Login Screen (SDDM) → Behavior.
If switching from X11 to Wayland doesn’t resolve the issue, then troubleshooting the issue will require more detailed information about your system. Please ensure you read through the pre-prepared instructions below:
As a new or infrequent forum user, you are encouraged to take some time to familiarise yourself with Forum requirements; in particular, the many ways to use the forum to your benefit:
The Update Announcements contain a Known Issues and Solutions section and should generally be checked before posting a request for support.
This is the most useful system information, as I’m certain has already been shown to you in something similar to (below). Plus, don’t forget to place that output in a pre-formatted text box – see link below, also.
Waiting for others to blindly ask questions can be counter-productive – typically, nobody has a at their disposal – Instead, please help others to make informed suggestions, based on information you provide.
System Information
While information from *-fetch type apps might be fine for someone wishing to buy your computer, for Support purposes it’s better to ask your system directly;
the default for me was x11 on installation (i wouldn’t know how to change it) i did change it to wayland now and the issue persists.
wayland was very buggy for me, i had horizontal lines on the screen after moving a window, thunderbird was missing the minimize and maximize buttons and spectacle was totally bugging out. so i changed it right back to x11.
