Came from Windows 2 days ago. Using KDE. and its stable as rock but have a few questions.
1-I am using ssd (os installed here) +HDD and my swap file 8 gb… can i move this swap file to USB flash drive ? and should i use zram
2-As i said system has HDD which was formatted ntfs, i can see my files and explore the disk. How can i delete all files and format it to ext4
Ryzen 3 1200@ 3.5 ghz + 8 GB DDR 4 + RX 560
Not 100% certain manjaro is going the same way but arch is dropping systemd swap file and replacing it with zram.
https://lists.archlinux.org/pipermail/arch-dev-public/2021-May/030429.html
So personally I’d be looking at zram
More precisely this
and supports custom locations …
You install it with:
sudo pacman -S zram-generator
Open KDE Partition Manager and proceed to reformat your HDD … Make sure you do have your files elsewhere in case you need them.
Once converted, take ownership of the partition.
It says some error happened. When i try to format to ext4… should i do this ownership thing before format?
You can’t take ownership on NTFS file system from Linux … make a new partition table (GUID/GPT or MBR), apply, create a partition, apply …
