After suggestion to NOT using grub-customizer
and replace with grub-vanilla
have anyone some link for tutorial or how working , because i can’t find on net!
Thank in advance !
This does not sound right: grub-vanilla
is a replacement for grub
(not grub-customizer
Detailed steps how to install grub-vanilla
can be found in the archived forum:
I saw that and the only info i get is how to install it and no use of grub-vanilla on terminal or as qui .
I prefer use terminal to solve grub problem !
What is grub-vanilla anyway?
Read the first post in that thread…
https://www.youtube.com/watch?v=r7meKJsjqfY
I thing that is a great lesson for understand how configure grub
on system.
And forget about grub-[any]
NOT recommenced for new users
I’m afraid you misunderstood what I told you on a different thread, so I’ll try clarifying in simple terms ─ one never knows who might stumble upon this thread here…
grub-customizer
is a tool for ─ you guessed it ─ customizing the GRUB boot loader. It is available from the Manjaro repository. However, one may only use grub-customizer
when one is using grub-vanilla
, which is the version of GRUB as it ships from its upstream developers.
And grub-vanilla
is also available from the Manjaro repository, but by default, Manjaro uses a heavily customized version of GRUB that is not compatible with grub-customizer
, and the use of grub-customizer
in combination with Manjaro’s already customized version of GRUB will break your system.
So the point was to install grub-vanilla instead grub ?
Why don’t tel so many days ago?
@Aragorn i don’t know how or why but i like your way putting your opinion and if some day candidate for mayor my vote is sure !!
Thank you for your patience.
In what country?
All over the globe !!!
Hello,
Sorry if this is a newbie question, but can someone explain more about the difference between the packages ‘grub’ and ‘grub-vanilla’? By default it seems Manjaro is installing grub-vanilla and not grub, but after issues with grub-vanilla (failing to run grub-probe, see this which is unresolved for me, I switched to grub (uninstalled ‘grub-vanilla’ and installed ‘grub’) and all works fine.
But of course I want to know if this was a good idea!
Thanks for your explanation,
