Abnormal flashes on the screen when switching frames
When using the system, artifacts are visible, which greatly interfere with work.
information:
  Kernel: 6.6.10-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
    clocksource: tsc available: acpi_pm
    root=UUID=457d67b4-cc7a-462e-ad86-48417d24b278 rw quiet splash apparmor=1
  Desktop: GNOME v: 45.3 tk: GTK v: 3.24.39 wm: gnome-shell dm: GDM
    v: 45.0.1 Distro: Manjaro Linux base: Arch Linux
  Type: Laptop System: LENOVO product: 81Y4 v: IdeaPad Gaming 3 15IMH05
    serial: <superuser required> Chassis: type: 10 v: IdeaPad Gaming 3 15IMH05
  Mobo: LENOVO model: LNVNB161216 v: NO DPK serial: <superuser required>
    UEFI: LENOVO v: EGCN34WW date: 05/18/2021
  ID-1: BAT0 charge: 39.2 Wh (100.0%) condition: 39.2/45.0 Wh (87.0%)
    volts: 12.8 min: 11.4 model: SMP L19M3PF7 type: Li-poly serial: <filter>
    status: full cycles: 73
  Info: model: Intel Core i5-10300H bits: 64 type: MT MCP arch: Comet Lake
    gen: core 10 level: v3 note: check built: 2020 process: Intel 14nm family: 6
    model-id: 0xA5 (165) stepping: 2 microcode: 0xF8
    L3: 8 MiB desc: 1x8 MiB
  Speed (MHz): avg: 2169 high: 4497 min/max: 800/4500 scaling:
    driver: intel_pstate governor: powersave cores: 1: 800 2: 800 3: 800 4: 4497
    5: 4482 6: 800 7: 800 8: 4376 bogomips: 40009
  Type: retbleed mitigation: Enhanced IBRS
  Type: spectre_v2 mitigation: Enhanced / Automatic IBRS, IBPB:
    conditional, RSB filling, PBRSB-eIBRS: SW sequence
  Device-1: Intel CometLake-H GT2 [UHD Graphics] vendor: Lenovo driver: i915
    v: kernel arch: Gen-9.5 process: Intel 14nm built: 2016-20 ports:
    active: eDP-1 empty: none bus-ID: 00:02.0 chip-ID: 8086:9bc4
    class-ID: 0300
  Device-2: NVIDIA TU117M [GeForce GTX 1650 Mobile / Max-Q] vendor: Lenovo
    driver: nvidia v: 545.29.06 alternate: nouveau,nvidia_drm non-free: 545.xx+
    status: current (as of 2023-11; EOL~2026-12-xx) arch: Turing code: TUxxx
    process: TSMC 12nm FF built: 2018-2022 pcie: gen: 1 speed: 2.5 GT/s
    lanes: 16 link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.0
    chip-ID: 10de:1f99 class-ID: 0300
  Device-3: Syntek Integrated Camera driver: uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-6:5 chip-ID: 174f:244c
  Display: x11 server: X.org v: 1.21.1.10 with: Xwayland v: 23.2.3
    compositor: gnome-shell driver: X: loaded: modesetting,nvidia
    alternate: fbdev,nouveau,nv,vesa dri: iris gpu: i915 display-ID: :1
    note: <missing: xdpyinfo/xrandr>
  Monitor-1: eDP-1 model: AU Optronics 0x21ed built: 2016 res: 1920x1080
    dpi: 142 gamma: 1.2 size: 344x193mm (13.54x7.6") diag: 394mm (15.5")
    ratio: 16:9 modes: 1920x1080
    drv: nvidia device: 1 drv: iris device: 3 drv: swrast gbm: drv: kms_swrast
    surfaceless: drv: nvidia x11: drv: iris inactive: wayland,device-2
  API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: intel mesa v: 23.3.3-manjaro1.1
    glx-v: 1.4 direct-render: yes renderer: Mesa Intel UHD Graphics (CML GT2)
    device-ID: 8086:9bc4 memory: 15.13 GiB unified: yes
  Device-1: Intel Comet Lake PCH cAVS vendor: Lenovo driver: snd_hda_intel
    chip-ID: 8086:06c8 class-ID: 0403
  Device-2: NVIDIA driver: snd_hda_intel v: kernel pcie: gen: 1
    speed: 2.5 GT/s lanes: 16 link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.1
    chip-ID: 10de:10fa class-ID: 0403
  Device-3: JMTek LLC. USB PnP Audio Device(EEPROM)
    driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 1.1 speed: 12 Mb/s
    lanes: 1 mode: 1.1 bus-ID: 1-2.1:4 chip-ID: 0c76:161f class-ID: 0300
  API: ALSA v: k6.6.10-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.0.0 status: active with: 1: pipewire-pulse
  Device-1: Intel Comet Lake PCH CNVi WiFi driver: iwlwifi v: kernel
    bus-ID: 00:14.3 chip-ID: 8086:06f0 class-ID: 0280
  IF: wlp0s20f3 state: down mac: <filter>
    vendor: Lenovo driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
    port: 3000 bus-ID: 0b:00.0 chip-ID: 10ec:8168 class-ID: 0200
  IF: enp11s0 state: up speed: 100 Mbps duplex: full mac: <filter>
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:7 chip-ID: 8087:0026
    class-ID: e001
  Local Storage: total: 119.24 GiB used: 17.12 GiB (14.4%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Patriot model: Flare size: 119.24 GiB
    block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s tech: SSD
    serial: <filter> fw-rev: 00.8 scheme: GPT
  ID-1: / raw-size: 118.95 GiB size: 116.52 GiB (97.96%)
    used: 17.12 GiB (14.7%) fs: ext4 dev: /dev/sda2 maj-min: 8:2
    used: 296 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1
  System Temperatures: cpu: 59.0 C pch: 55.0 C mobo: N/A
  Fan Speeds (rpm): N/A
  Processes: 299 Uptime: 4m wakeups: 0 Memory: total: 16 GiB
  available: 15.49 GiB used: 3.37 GiB (21.7%) Init: systemd v: 255
  Packages: pm: pacman pkgs: 1211 libs: 339 tools: gnome-software,pamac
  pm: flatpak pkgs: 0 Shell: Zsh v: 5.9 running-in: gnome-terminal
  inxi: 3.3.31
Video with anomalie:
https://drive.google.com/drive/folders/1bfOwPWp4xyCs2rnqwZ17IpelktHbfh-5?usp=sharing
Hello @JudgeOptimizer :wink:
In the video it looks like your system is overloaded and at the end it starts working normally.
So since the question is very general: Don’t expect 100% video playback, when you system is working hard in the background.
Are there any steps to reproduce your specific problem?
A swap file/partition would be a good idea if you run out of RAM.
The system works without freezing, the video was recorded in slow motion mode so that artifacts can be seen in more detail, they are present throughout the system, maybe this is due to the fact that I am using a 170 Hz monitor? On the 60 Hz laptop screen to which the separate monitor is connected, such artifacts are not observed. I know for sure that the built-in graphics of the processor is used on the laptop screen, and the graphics of the video card are used on a separate monitor, so maybe there is a problem with setting it up?
Sure, that is possible. You probably see the “flashes” because the refresh rate is too low for the monitor.
Sorry, but there is no external monitor mentioned in your system infos above. Only the laptop screen.
