A stop job is running for bridge eno1?
Hello,
When I restart my system, I get the following message: “A stop job is running for bridge eno1,” and it lasts for 51 seconds.
I didn’t get this message a few months ago. I don’t understand what’s wrong!
I use netctl to configure a bridge because I have a few qemu/kvm VMs in place.
Hi @Titanet,
Let’s see if we can see what might be wrong. Please providew the output of:
journalctl --grep=eno1 --priority=warning --boot=-1 --no-pager
Probably nothing is wrong, if it is occasional and not every time.
$ journalctl --grep=eno1 --priority=warning --boot=-1 --no-pager
-- No entries --
It happens every time I restart !
That means nothing’s wrong, just as @Teo said. Why it happens I have absolutely no idea. If someone does know, I’d be happy to hear as well.
Edit:
Please provide the following, first:
inxi -zv8 --color=0
$ inxi -zv8 --color=0
  Kernel: 6.12.68-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
    root=UUID=32c4f166-a26b-470e-b3e7-9e0350e4e118 rw reboot=bios
    lsm=landlock,lockdown,yama,integrity,apparmor,bpf audit=1 verbose
    video=DP-0 udev.log_priority=3 amd_iommu=on iommu=pt
    vfio-pci.ids=1002:73df,1022:1457
  Desktop: Cinnamon v: 6.6.6 tk: GTK v: 3.24.51 wm: Muffin v: 6.6.3 tools:
    avail: cinnamon-screensaver vt: 7 dm: LightDM v: 1.32.0 Distro: Manjaro
    base: Arch Linux
  Type: Desktop System: Micro-Star product: MS-7A32 v: 1.0
    serial: <superuser required>
  Mobo: Micro-Star model: X370 GAMING PRO CARBON (MS-7A32) v: 1.0
    serial: <superuser required> uuid: <superuser required>
    Firmware: UEFI-[Legacy] vendor: American Megatrends v: 1.NX
    date: 07/07/2020
  System RAM: total: 32 GiB available: 31.29 GiB used: 7.19 GiB (23.0%)
  Device-1: Channel-A DIMM 0 type: no module installed
    (unregistered) size: 16 GiB speed: 2133 MT/s volts: note: check curr: 1
    min: 1 max: 1 width (bits): data: 64 total: 64 manufacturer: Corsair
    part-no: CMK32GX4M2E3200C16 serial: N/A
  Device-3: Channel-B DIMM 0 type: no module installed
  Info: model: AMD Ryzen 7 1700 bits: 64 type: MT MCP arch: Zen level: v3
    note: check built: 2017-19 process: GF 14nm family: 0x17 (23) model-id: 1
    stepping: 1 microcode: 0x8001138
    smt: enabled cache: L1: 768 KiB desc: d-8x32 KiB; i-8x64 KiB L2: 4 MiB
    desc: 8x512 KiB L3: 16 MiB desc: 2x8 MiB
  Speed (MHz): avg: 1534 min/max: 1550/3000 boost: enabled scaling:
    driver: acpi-cpufreq governor: schedutil cores: 1: 1534 2: 1534 3: 1534
    4: 1534 5: 1534 6: 1534 7: 1534 8: 1534 9: 1534 10: 1534 11: 1534 12: 1534
    13: 1534 14: 1534 15: 1534 16: 1534 bogomips: 96021
    bmi2 bpext clflush clflushopt clzero cmov cmp_legacy constant_tsc cpb
    cpuid cr8_legacy cx16 cx8 de decodeassists extapic extd_apicid f16c
    flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb lahf_lm lbrv
    lm mca mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx
    nonstop_tsc nopl npt nrip_save nx osvw overflow_recov pae pat pausefilter
    pclmulqdq pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pni
    popcnt pse pse36 rapl rdrand rdseed rdtscp rep_good sep sev sha_ni skinit
    smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 succor svm
    svm_lock syscall tce topoext tsc tsc_scale v_vmsave_vmload vgif
    vmcb_clean vme vmmcall wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt
  Type: retbleed mitigation: untrained return thunk; SMT vulnerable
  Device-1: Advanced Micro Devices [AMD/ATI] Navi 22 [Radeon RX 6700/6700
    XT/6750 XT / 6800M/6850M XT] vendor: Gigabyte driver: amdgpu v: kernel
    arch: RDNA-2 code: Navi-2x process: TSMC n7 (7nm) built: 2020-22 pcie:
    gen: 4 speed: 16 GT/s lanes: 16 ports: active: DP-2 empty: DP-1,
    HDMI-A-1, HDMI-A-2, Writeback-1 bus-ID: 29:00.0 chip-ID: 1002:73df
    class-ID: 0300
  Display: x11 server: X.Org v: 21.1.21 with: Xwayland v: 24.1.9 driver: X:
    loaded: amdgpu unloaded: modesetting,radeon alternate: fbdev,vesa
    dri: radeonsi gpu: amdgpu display-ID: :0 screens: 1
  Screen-1: 0 s-res: 3440x1440 s-dpi: 96 s-size: 910x381mm (35.83x15.00")
    s-diag: 987mm (38.84")
  Monitor-1: DP-2 mapped: DisplayPort-1 model: Idek Iiyama PL3467WQ
    serial: <filter> built: 2023 res: N/A dpi: 110 gamma: 1.2 chroma: red:
    x: 0.675 y: 0.310 green: x: 0.278 y: 0.651 blue: x: 0.153 y: 0.071 white:
    x: 0.314 y: 0.329 size: 797x334mm (31.38x13.15") diag: 864mm (34")
    modes: 3440x1440, 3840x2160, 1920x1200, 1920x1080, 1600x1200, 1680x1050,
    1280x1024, 1440x900, 1280x960, 1280x800, 1152x864, 1280x720, 1024x768,
    800x600, 720x576, 720x480, 640x480, 720x400
  EDID-Warnings: 1: parse_edid: unhandled CEA mode 97 2: parse_edid:
    unhandled CEA mode 96 3: parse_edid: unknown tag 112
    device: 1 drv: swrast gbm: drv: kms_swrast surfaceless: drv: radeonsi x11:
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 25.3.4-arch1.1
    glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 6700 XT (radeonsi
    navi22 LLVM 21.1.6 DRM 3.61 6.12.68-1-MANJARO) device-ID: 1002:73df
    memory: 11.72 GiB unified: no
  API: Vulkan v: 1.4.335 layers: 8 device: 0 type: discrete-gpu name: AMD
    Radeon RX 6700 XT (RADV NAVI22) driver: mesa radv v: 25.3.4-arch1.1
    device-ID: 1002:73df surfaces: N/A
  Info: Tools: api: eglinfo, glxinfo, vulkaninfo gpu: radeontop
    wl: wayland-info x11: xdriinfo, xdpyinfo, xprop, xrandr
  Device-1: Advanced Micro Devices [AMD/ATI] Navi 21/23 HDMI/DP Audio
    bus-ID: 29:00.1 chip-ID: 1002:ab28 class-ID: 0403
  Device-2: Advanced Micro Devices [AMD] Family 17h HD Audio
    vendor: Micro-Star MSI driver: snd_hda_intel v: kernel pcie: gen: 3
    speed: 8 GT/s lanes: 16 bus-ID: 2b:00.3 chip-ID: 1022:1457 class-ID: 0403
  API: ALSA v: k6.12.68-1-MANJARO status: kernel-api with: aoss
  Server-1: PipeWire v: 1.4.10 status: active with: 1: pipewire-pulse
    4: pw-jack type: plugin tools: pactl,pw-cat,pw-cli,wpctl
  Device-1: Intel I211 Gigabit Network vendor: Micro-Star MSI driver: igb
    v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 21:00.0
  IF-ID-1: br0 state: up speed: 1000 Mbps duplex: unknown mac: <filter>
  IP v6: <filter> type: dynamic mngtmpaddr proto kernel_ra scope: global
  IP v6: <filter> virtual: proto kernel_ll scope: link
  IF-ID-2: virbr0 state: down mac: <filter>
  IF-ID-3: virbr1 state: down mac: <filter>
  IF-ID-4: virbr2 state: down mac: <filter>
  Info: services: NetworkManager,ntpd
  Local Storage: total: 8.84 TiB used: 4.35 TiB (49.2%)
  ID-1: /dev/nvme0n1 maj-min: 259:1 vendor: Corsair model: Force MP500
    size: 223.57 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
    lanes: 4 tech: SSD serial: <filter> fw-rev: E7FM02.1 temp: 60.9 C
    scheme: GPT
  ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Corsair model: Force MP510
    size: 447.13 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
    lanes: 4 tech: SSD serial: <filter> fw-rev: ECFM12.2 temp: 41.9 C
    scheme: GPT
  ID-3: /dev/sda maj-min: 8:0 vendor: Seagate model: ST3000VN007-2E4166
    size: 2.73 TiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
    tech: HDD rpm: 5900 serial: <filter> fw-rev: SC60 temp: 36.0 C scheme: GPT
  ID-4: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST4000VN006-3CW104
    size: 3.64 TiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
    tech: HDD rpm: 5400 serial: <filter> fw-rev: SC60 temp: 42.0 C scheme: GPT
  ID-5: /dev/sdc maj-min: 8:32 vendor: Western Digital
    model: WD20EARS-00MVWB0 size: 1.82 TiB block-size: physical: 512 B
    logical: 512 B speed: 3.0 Gb/s tech: N/A serial: <filter> fw-rev: AB51
  ID-1: / raw-size: 69.07 GiB size: 67.81 GiB (98.18%) used: 55.27 GiB (81.5%)
    fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:3 label: Manjaro
    uuid: 32c4f166-a26b-470e-b3e7-9e0350e4e118
  ID-2: /home raw-size: 447.13 GiB size: 439.04 GiB (98.19%)
    used: 246.55 GiB (56.2%) fs: ext4 dev: /dev/nvme1n1p1 maj-min: 259:5
    label: SSD-Home uuid: 6e51c93e-1fef-4628-a1e8-39b5c54e3490
  ID-3: /run/media/Games raw-size: 1.57 TiB size: 1.55 TiB (98.36%)
    used: 657.16 GiB (41.5%) fs: ext4 dev: /dev/sdc2 maj-min: 8:34 label: Games
    uuid: b3024220-3acc-4064-aa97-e595bfa6a90a
  ID-4: /run/media/IronWolf raw-size: 2.41 TiB size: 2.37 TiB (98.39%)
    used: 576.55 GiB (23.8%) fs: ext4 dev: /dev/sdb3 maj-min: 8:19
    label: IronWolf uuid: e9575f83-0b44-43b9-94eb-9fae63333f25
  ID-5: /run/media/Old-homes raw-size: 253.91 GiB size: 248.86 GiB (98.01%)
    used: 183.75 GiB (73.8%) fs: ext4 dev: /dev/sdc1 maj-min: 8:33
    label: Old-Homes uuid: bfaf3e62-a063-4399-85e7-507ad78f35c0
  ID-6: /run/media/Steam raw-size: 1.04 TiB size: 1.02 TiB (98.33%)
    used: 857.62 GiB (81.8%) fs: ext4 dev: /dev/sdb2 maj-min: 8:18 label: Steam
    uuid: 941f438a-d744-478a-a97d-75589f425780
  ID-7: /run/media/Video raw-size: 2.73 TiB size: 2.69 TiB (98.42%)
    used: 1.72 TiB (64.0%) fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: Video
    uuid: 67a8491e-b8a9-4825-94b1-e584152100dd
  ID-8: /run/media/VirtMach raw-size: 195.31 GiB size: 191.19 GiB (97.89%)
    used: 113.37 GiB (59.3%) fs: ext4 dev: /dev/sdb1 maj-min: 8:17
    label: VirtMach uuid: 28d91870-7ac1-438e-9120-060e0fe4166c
  Kernel: swappiness: 10 (default 60) cache-pressure: 50 (default 100)
    zswap: no
  ID-1: swap-1 type: zram size: 7.82 GiB used: 0 KiB (0.0%) priority: 100
    comp: zstd avail: lzo-rle,lzo,lz4,lz4hc,deflate,842 max-streams: 16
    dev: /dev/zram0
  ID-1: /dev/nvme0n1p1 maj-min: 259:2 size: 2 MiB fs: <superuser required>
    label: N/A uuid: N/A
  ID-2: /dev/nvme0n1p3 maj-min: 259:4 size: 48.83 GiB fs: ext4 label: Mint
    uuid: c7a30c3f-5298-4e5a-a13a-6b48b77d767e
  Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 14 rev: 2.0
  Hub-2: 2-0:1 info: super-speed hub ports: 8 rev: 3.1
  Hub-5: 5-0:1 info: hi-speed hub with single TT ports: 4 rev: 2.0
  Hub-6: 5-2:2 info: Realtek RTS5411 Hub ports: 5 rev: 2.1
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 0bda:5411
  Device-1: 5-2.1:4 info: Microsoft Xbox360 Controller
    type: <vendor specific> driver: xpad interfaces: 4 rev: 2.0
    chip-ID: 045e:028e class-ID: ff00 serial: <filter>
  Device-2: 5-2.2:5 info: Microsoft Xbox360 Controller
    type: <vendor specific> driver: xpad interfaces: 1 rev: 2.0
  Device-3: 5-2.3:6 info: CHERRY Wireless Device type: keyboard,mouse
    lanes: 1 mode: 1.1 power: 100mA chip-ID: 046a:c092 class-ID: 0301
  Device-4: 5-2.5:7 info: Realtek USB2.0 HID type: HID
    chip-ID: 0bda:1100 class-ID: 0300
  Device-5: 5-3:3 info: SHARKOON GmbH [Mediatrack Edge Mini Keyboard]
    type: keyboard,mouse driver: hid-generic,usbhid interfaces: 2 rev: 1.1
    chip-ID: 1ea7:0066 class-ID: 0301
  Hub-7: 6-0:1 info: super-speed hub ports: 4 rev: 3.0
  Hub-8: 6-2:2 info: Realtek Hub ports: 4 rev: 3.2
    speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 0bda:0411
  System Temperatures: cpu: 39.0 C mobo: 42.0 C gpu: amdgpu temp: 57.0 C
    mem: 54.0 C
  Fan Speeds (rpm): fan-1: 0 fan-2: 2272 fan-3: 553 fan-4: 0 fan-5: 0
    fan-6: 0 gpu: amdgpu fan: 0
  Power: 12v: N/A 5v: N/A 3.3v: 3.28 vbat: 3.26 gpu: amdgpu watts: 15.00
  Packages: 2133 pm: pacman pkgs: 2067 libs: 488 tools: pamac,yay pm: flatpak
    pkgs: 66
    1: https://manjaro.kurdy.org/stable/$repo/$arch
    2: https://mirrors.eric.ovh/manjaro/stable/$repo/$arch
    3: https://mirror.netcologne.de/manjaro/stable/$repo/$arch
    4: https://manjaro.ynh.ovh/stable/$repo/$arch
    5: https://manjaro.mirror.wearetriple.com/stable/$repo/$arch
    6: https://ftp.tu-chemnitz.de/pub/linux/manjaro/stable/$repo/$arch
    7: https://ftp.gwdg.de/pub/linux/manjaro/stable/$repo/$arch
    8: https://mirror.bakertelekom.fr/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 442
  1: cpu: 35.2% command: cinnamon-subprocess-wrapper pid: 19903
    mem: 28.8 MiB (0.0%)
  2: cpu: 20.3% command: firefox pid: 3457 mem: 643.5 MiB (2.0%)
  3: cpu: 16.5% command: cinnamon pid: 3355 mem: 259.7 MiB (0.8%)
  4: cpu: 9.5% command: radeontop pid: 19905 mem: 4.75 MiB (0.0%)
  5: cpu: 7.9% command: Xorg pid: 1235 mem: 222.5 MiB (0.6%)
  Memory top: 5 of 442
  1: mem: 643.5 MiB (2.0%) command: firefox pid: 3457 cpu: 20.3%
  2: mem: 346.5 MiB (1.0%) command: firefox pid: 5117 cpu: 0.9%
  3: mem: 327.2 MiB (1.0%) command: firefox pid: 5733 cpu: 3.2%
  4: mem: 305.9 MiB (0.9%) command: Telegram pid: 3466 cpu: 0.3%
  5: mem: 259.7 MiB (0.8%) command: cinnamon pid: 3355 cpu: 16.5%
  Processes: 442 Power: uptime: 17m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 12.49 GiB services: csd-power,upowerd
    Init: systemd v: 258 default: graphical tool: systemctl
  Compilers: clang: 21.1.6 gcc: 15.2.1 Shell: Bash v: 5.3.9
    running-in: gnome-terminal inxi: 3.3.40
As you can see from your output - eno1 is not a bridge but a network interface
But your system also has a bridge configured br0 and several virbr*.
If the bridge is in use by a service, the system is designed to signal the service to shutdown - and it will wait for the service for some time - usually 90s or something around that.
Yes, my bridge is br0 but the message tell eno1 and i have no VMs running when i reboot my system.
